those is empty, not checked should be fixed with this … unless pacman is somehow affected … also noticed you are running eol kernel, so post output from:
mhwd-kernel -li
System broke after unexpected shutdown during the update install and chroot pacman -Syyuu not helped
# mhwd-kernel -li
Currently running: 5.11.22-2-MANJARO (linux511)
* linux510
* linux511
btw I’m able to log-in to kde-plasma wayland now!
By this command
dbus-run-session startplasma-wayland
I’m able to load kde-plasma wayland!
and also now the git -v
shows the output, the version.
seems like most of things are fixed now!
511 is EOL?
were you using the login command before?
remove the 511, its eol:
sudo mhwd-kernel -r linux511
yes most are but all of it should be fixed…
try running this:
sudo pacman -Syyf
Nah, it’s good for another 1000 years.
ok then, I’ll install 5.19
# pacman -Syyf
error: invalid option '-f'
I use BSPWM as my default WM, and it was working fine, except for wallpapers etc (because feh program did not work),
and but sometimes I have to use KDE-plasma wayland because I was testing android on linux, (Waydroid) and it requires Wayland session
I will just kick the bucket in the next 30 years but be that as it may, I still got to get this system up and running for the next 30 years.
Long lives 511 then
a lot of those messages are related to plasma, so reinstall it:
pacman - S plasma kio-extras kwin glibc --overwrite "*"
# pacman - S plasma kio-extras kwin glibc --overwrite "*"
error: invalid option '--overwrite
the --overwrite
part has to come to the front?
also # pacman -Syyf
command did not work
No, there is something else wrong with that command. You should always take a look at what you are copy pasting.
(same for -Syyf)
wrong command, this is the correct one:
pacman -S plasma kio-extras kwin glibc --overwrite "*"
ok this time it’s working.
I’m gonna go ahead and hit enter for this:
# pacman -S plasma kio-extras kwin glibc --overwrite "*"
:: There are 46 members in group plasma:
:: Repository extra
1) bluedevil 2) breeze 3) breeze-gtk 4) discover 5) drkonqi 6) kactivitymanagerd
7) kde-cli-tools 8) kde-gtk-config 9) kdecoration 10) kdeplasma-addons 11) kgamma5
12) khotkeys 13) kinfocenter 14) kmenuedit 15) kscreen 16) kscreenlocker
17) ksshaskpass 18) ksystemstats 19) kwallet-pam 20) kwayland-integration 21) kwin
22) kwrited 23) layer-shell-qt 24) libkscreen 25) libksysguard 26) milou
27) oxygen 28) oxygen-sounds 29) plasma-browser-integration 30) plasma-desktop
31) plasma-disks 32) plasma-firewall 33) plasma-integration 34) plasma-nm
35) plasma-pa 36) plasma-sdk 37) plasma-systemmonitor 38) plasma-thunderbolt
39) plasma-vault 40) plasma-workspace 41) plasma-workspace-wallpapers
42) polkit-kde-agent 43) powerdevil 44) sddm-kcm 45) systemsettings
46) xdg-desktop-portal-kde
Enter a selection (default=all):
yes do it, then we do the same with the remaining empty, not checked
errors
Well, got two of 'em here
:: Repository extra
warning: bluedevil-1:5.25.5-1 is up to date -- reinstalling
warning: breeze-5.25.5-1 is up to date -- reinstalling
warning: breeze-gtk-5.25.5-1 is up to date -- reinstalling
warning: discover-5.25.5-1 is up to date -- reinstalling
warning: drkonqi-5.25.5-1 is up to date -- reinstalling
warning: kactivitymanagerd-5.25.5-1 is up to date -- reinstalling
warning: kde-cli-tools-5.25.5-1 is up to date -- reinstalling
warning: kde-gtk-config-5.25.5-1 is up to date -- reinstalling
warning: kdecoration-5.25.5-1 is up to date -- reinstalling
warning: kdeplasma-addons-5.25.5-1 is up to date -- reinstalling
warning: kgamma5-5.25.5-1 is up to date -- reinstalling
warning: khotkeys-5.25.5-1 is up to date -- reinstalling
warning: kinfocenter-5.25.5-1 is up to date -- reinstalling
warning: kmenuedit-5.25.5-1 is up to date -- reinstalling
warning: kscreen-5.25.5-1 is up to date -- reinstalling
warning: kscreenlocker-5.25.5-1 is up to date -- reinstalling
warning: ksshaskpass-5.25.5-1 is up to date -- reinstalling
warning: ksystemstats-5.25.5-1 is up to date -- reinstalling
warning: kwallet-pam-5.25.5-1 is up to date -- reinstalling
warning: kwayland-integration-5.25.5-1 is up to date -- reinstalling
warning: kwin-5.25.5-1 is up to date -- reinstalling
warning: kwrited-5.25.5-1 is up to date -- reinstalling
warning: layer-shell-qt-5.25.5-1 is up to date -- reinstalling
warning: libkscreen-5.25.5-1 is up to date -- reinstalling
warning: libksysguard-5.25.5-1 is up to date -- reinstalling
warning: milou-5.25.5-1 is up to date -- reinstalling
warning: oxygen-5.25.5-1 is up to date -- reinstalling
warning: oxygen-sounds-5.25.5-1 is up to date -- reinstalling
warning: plasma-browser-integration-5.25.5-1 is up to date -- reinstalling
warning: plasma-desktop-5.25.5-1 is up to date -- reinstalling
warning: plasma-disks-5.25.5-1 is up to date -- reinstalling
warning: plasma-firewall-5.25.5-1 is up to date -- reinstalling
warning: plasma-integration-5.25.5-1 is up to date -- reinstalling
warning: plasma-nm-5.25.5-1 is up to date -- reinstalling
warning: plasma-pa-5.25.5-1 is up to date -- reinstalling
warning: plasma-sdk-5.25.5-1 is up to date -- reinstalling
warning: plasma-systemmonitor-5.25.5-1 is up to date -- reinstalling
warning: plasma-thunderbolt-5.25.5-1 is up to date -- reinstalling
warning: plasma-vault-5.25.5-1 is up to date -- reinstalling
warning: plasma-workspace-5.25.5-1 is up to date -- reinstalling
warning: plasma-workspace-wallpapers-5.25.5-1 is up to date -- reinstalling
warning: polkit-kde-agent-5.25.5-1 is up to date -- reinstalling
warning: powerdevil-5.25.5-1 is up to date -- reinstalling
warning: sddm-kcm-5.25.5-1 is up to date -- reinstalling
warning: systemsettings-5.25.5-1 is up to date -- reinstalling
warning: xdg-desktop-portal-kde-5.25.5-1 is up to date -- reinstalling
warning: kio-extras-22.08.0-1 is up to date -- reinstalling
warning: glibc-2.36-3 is up to date -- reinstalling
resolving dependencies...
Packages (48) bluedevil-1:5.25.5-1 breeze-5.25.5-1 breeze-gtk-5.25.5-1 discover-5.25.5-1 drkonqi-5.25.5-1 glibc-2.36-3 kactivitymanagerd-5.25.5-1 kde-cli-tools-5.25.5-1
kde-gtk-config-5.25.5-1 kdecoration-5.25.5-1 kdeplasma-addons-5.25.5-1 kgamma5-5.25.5-1 khotkeys-5.25.5-1 kinfocenter-5.25.5-1 kio-extras-22.08.0-1 kmenuedit-5.25.5-1
kscreen-5.25.5-1 kscreenlocker-5.25.5-1 ksshaskpass-5.25.5-1 ksystemstats-5.25.5-1 kwallet-pam-5.25.5-1 kwayland-integration-5.25.5-1 kwin-5.25.5-1 kwrited-5.25.5-1
layer-shell-qt-5.25.5-1 libkscreen-5.25.5-1 libksysguard-5.25.5-1 milou-5.25.5-1 oxygen-5.25.5-1 oxygen-sounds-5.25.5-1 plasma-browser-integration-5.25.5-1
plasma-desktop-5.25.5-1 plasma-disks-5.25.5-1 plasma-firewall-5.25.5-1 plasma-integration-5.25.5-1 plasma-nm-5.25.5-1 plasma-pa-5.25.5-1 plasma-sdk-5.25.5-1
plasma-systemmonitor-5.25.5-1 plasma-thunderbolt-5.25.5-1 plasma-vault-5.25.5-1 plasma-workspace-5.25.5-1 plasma-workspace-wallpapers-5.25.5-1 polkit-kde-agent-5.25.5-1
powerdevil-5.25.5-1 sddm-kcm-5.25.5-1 systemsettings-5.25.5-1 xdg-desktop-portal-kde-5.25.5-1
Total Installed Size: 338.64 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(48/48) checking keys in keyring [####################################################################] 100%
(48/48) checking package integrity [####################################################################] 100%
(48/48) loading package files [####################################################################] 100%
(48/48) checking for file conflicts [####################################################################] 100%
(48/48) checking available disk space [####################################################################] 100%
( 1/48) reinstalling glibc [####################################################################] 100%
Generating locales...
en_US.UTF-8... done
si_LK.UTF-8... done
Generation complete.
ldconfig: File /usr/lib/libKF5Su.so.5.97.0.old is empty, not checked.
( 2/48) reinstalling bluedevil [####################################################################] 100%
( 3/48) reinstalling kdecoration [####################################################################] 100%
( 4/48) reinstalling breeze [####################################################################] 100%
( 5/48) reinstalling breeze-gtk [####################################################################] 100%
( 6/48) reinstalling discover [####################################################################] 100%
( 7/48) reinstalling drkonqi [####################################################################] 100%
( 8/48) reinstalling kactivitymanagerd [####################################################################] 100%
( 9/48) reinstalling kde-cli-tools [####################################################################] 100%
(10/48) reinstalling kde-gtk-config [####################################################################] 100%
(11/48) reinstalling libksysguard [####################################################################] 100%
(12/48) reinstalling ksystemstats [####################################################################] 100%
(13/48) reinstalling milou [####################################################################] 100%
(14/48) reinstalling layer-shell-qt [####################################################################] 100%
(15/48) reinstalling kscreenlocker [####################################################################] 100%
(16/48) reinstalling kwin [####################################################################] 100%
(17/48) reinstalling plasma-integration [####################################################################] 100%
(18/48) reinstalling libkscreen [####################################################################] 100%
(19/48) reinstalling kio-extras [####################################################################] 100%
(20/48) reinstalling oxygen-sounds [####################################################################] 100%
(21/48) reinstalling plasma-workspace [####################################################################] 100%
(22/48) reinstalling kdeplasma-addons [####################################################################] 100%
(23/48) reinstalling systemsettings [####################################################################] 100%
(24/48) reinstalling kgamma5 [####################################################################] 100%
(25/48) reinstalling khotkeys [####################################################################] 100%
(26/48) reinstalling kinfocenter [####################################################################] 100%
(27/48) reinstalling kmenuedit [####################################################################] 100%
(28/48) reinstalling kscreen [####################################################################] 100%
(29/48) reinstalling ksshaskpass [####################################################################] 100%
(30/48) reinstalling kwallet-pam [####################################################################] 100%
(31/48) reinstalling kwayland-integration [####################################################################] 100%
(32/48) reinstalling kwrited [####################################################################] 100%
(33/48) reinstalling oxygen [####################################################################] 100%
(34/48) reinstalling plasma-browser-integration [####################################################################] 100%
(35/48) reinstalling polkit-kde-agent [####################################################################] 100%
(36/48) reinstalling plasma-desktop [####################################################################] 100%
(37/48) reinstalling plasma-disks [####################################################################] 100%
(38/48) reinstalling plasma-firewall [####################################################################] 100%
(39/48) reinstalling plasma-nm [####################################################################] 100%
(40/48) reinstalling plasma-pa [####################################################################] 100%
(41/48) reinstalling plasma-sdk [####################################################################] 100%
(42/48) reinstalling plasma-systemmonitor [####################################################################] 100%
(43/48) reinstalling plasma-thunderbolt [####################################################################] 100%
(44/48) reinstalling plasma-vault [####################################################################] 100%
(45/48) reinstalling plasma-workspace-wallpapers [####################################################################] 100%
(46/48) reinstalling powerdevil [####################################################################] 100%
(47/48) reinstalling sddm-kcm [####################################################################] 100%
(48/48) reinstalling xdg-desktop-portal-kde [####################################################################] 100%
(1/9) Reloading system manager configuration...
(2/9) Creating temporary files...
(3/9) Arming ConditionNeedsUpdate...
(4/9) Updating the MIME type database...
(5/9) Refreshing PackageKit...
(6/9) Reloading system bus configuration...
(7/9) Updating icon theme caches...
(8/9) Updating the info directory file...
(9/9) Updating the desktop file MIME type cache...
here
and here
they belong to kdesu, so reinstall it too:
pacman -S kdesu --overwrite "*"
# pacman -S kdesu --overwrite "*"
warning: kdesu-5.97.0-1 is up to date -- reinstalling
Packages (1) kdesu-5.97.0-1
Total Installed Size: 0.52 MiB
(1/1) checking keys in keyring [###############################] 100%
(1/1) checking package integrity [###############################] 100%
(1/1) loading package files [###############################] 100%
(1/1) checking for file conflicts [###############################] 100%
(1/1) checking available disk space [###############################] 100%
(1/1) reinstalling kdesu [###############################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
it gives the same error
it says there that is old, so check:
pacman -Qo /usr/lib/libKF5Su.so.5.97.0.old
it should return that it doesnt belong to anything
that’s correct!
# pacman -Qo /usr/lib/libKF5Su.so.5.97.0.old
error: No package owns /usr/lib/libKF5Su.so.5.97.0.old
btw I installed the new Kernel,
# mhwd-kernel -li
Currently running: 5.19.7-1-MANJARO (linux519)
* linux510
* linux511
* linux519
