System broke after unexpected shutdown during the update install and chroot pacman -Syyuu not helped
Last day morning, I started updating manjaro pamac update
And I lost the power to the system and did not have a power backup or UPS.
Now the system is broke :frowning:
This is what I tried to fix so far:
Booted from the latest Manjaro live:
sudo su -
manjaro-chroot -a
pacman-mirrors -f 2 && pacman -Syyuu
and I got the process completed, but I don’t think it fixed the problem.
I had both running BSPWM and KDE Plasma wayland.
Nothing happens if I type dbus-run-session startplasma-wayland
nothing happened if I type git command. It just goes to the next like.
I tried yay -Syyuu too
also gave me errors
 -> could not open file /var/lib/pacman/local/lib32-gcc-libs-12.2.0-1/desc: No such file or directory
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1]  python2-six-1.16.0-6
:: (0/1) Downloaded PKGBUILD: python2-six
 -> error fetching python2-six:
	 context: fork/exec /usr/bin/git: exec format error
I see ths exec format error thing is everywhere.
I’m trying to give the life to this system because I have a crypto wallet in my brave browser and have some BAT tokens, and I cannot backup and restore it to a new device because I’ve lost passphrases.
I need to keep trying… please help
How should I find which part is broken in my system?
in chroot run this:
touch /var/lib/pacman/local/lib32-gcc-libs-12.2.0-1/desc
then reinstall it:
pacman -S lib32-gcc-libs
then remove the python2-six AUR pacakge if you are not using it
Thank you very much for the response
# pacman -S lib32-gcc-libs
warning: lib32-gcc-libs-12.2.0-1 is up to date -- reinstalling
resolving dependencies...
error: could not open file /var/lib/pacman/local/lib32-gcc-libs-12.2.0-1/files: No such file or directory
warning: could not fully load metadata for package lib32-gcc-libs-12.2.0-1
error: failed to prepare transaction (invalid or corrupted package)
more errors… :frowning:
ok so it worked, now its files instead of desc, so continue:
touch /var/lib/pacman/local/lib32-gcc-libs-12.2.0-1/files
reinstall it:
It worked?
Packages (1) lib32-gcc-libs-12.2.0-1
Total Installed Size:  107.52 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring                     [######################] 100%
(1/1) checking package integrity                   [######################] 100%
(1/1) loading package files                        [######################] 100%
(1/1) checking for file conflicts                  [######################] 100%
error: failed to commit transaction (conflicting files)
lib32-gcc-libs: /usr/lib32/libasan.so exists in filesystem
lib32-gcc-libs: /usr/lib32/libasan.so.8 exists in filesystem
lib32-gcc-libs: /usr/lib32/libasan.so.8.0.0 exists in filesystem
lib32-gcc-libs: /usr/lib32/libatomic.so exists in filesystem
lib32-gcc-libs: /usr/lib32/libatomic.so.1 exists in filesystem
lib32-gcc-libs: /usr/lib32/libatomic.so.1.2.0 exists in filesystem
lib32-gcc-libs: /usr/lib32/libgcc_s.so exists in filesystem
lib32-gcc-libs: /usr/lib32/libgcc_s.so.1 exists in filesystem
lib32-gcc-libs: /usr/lib32/libgdruntime.so exists in filesystem
lib32-gcc-libs: /usr/lib32/libgdruntime.so.3 exists in filesystem
lib32-gcc-libs: /usr/lib32/libgdruntime.so.3.0.0 exists in filesystem
lib32-gcc-libs: /usr/lib32/libgfortran.so exists in filesystem
lib32-gcc-libs: /usr/lib32/libgfortran.so.5 exists in filesystem
lib32-gcc-libs: /usr/lib32/libgfortran.so.5.0.0 exists in filesystem
lib32-gcc-libs: /usr/lib32/libgo.so exists in filesystem
lib32-gcc-libs: /usr/lib32/libgo.so.21 exists in filesystem
lib32-gcc-libs: /usr/lib32/libgo.so.21.0.0 exists in filesystem
I tried removing python-six too: also more errors
# pamac remove python-six
Preparing...
Checking dependencies...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing python-six breaks dependency 'python-six' required by python-anytree
so you need to overwrite it:
pacman -S lib32-gcc-libs --overwrite '*'
hopefully it is only this one package
remove the python-anytree first if you are not using it
# pacman -S lib32-gcc-libs --overwrite '*'
(1/1) checking keys in keyring                         [############################] 100%
(1/1) checking package integrity                       [############################] 100%
(1/1) loading package files                            [############################] 100%
(1/1) checking for file conflicts                      [############################] 100%
(1/1) checking available disk space                    [############################] 100%
(1/1) reinstalling lib32-gcc-libs                      [############################] 100%
ldconfig: File /usr/lib/libhunspell-1.7.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libKF5NotifyConfig.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libkcmkwincommon.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libkfontinst.so.5 is empty, not checked.
ldconfig: File /usr/lib/libnotificationmanager.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libcolorcorrect.so.5 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_cuda.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libprotobuf-lite.so is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectpluginkcm.so.22 is empty, not checked.
ldconfig: File /usr/lib/libKF5Prison.so is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensors.so.1 is empty, not checked.
ldconfig: File /usr/lib/libKF5ThreadWeaver.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libkioarchive.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libjcat.so.1 is empty, not checked.
ldconfig: File /usr/lib/liblab_gamut.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensors.so is empty, not checked.
ldconfig: File /usr/lib/libpathplan.so.4.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5Activities.so.5 is empty, not checked.
ldconfig: File /usr/lib/libprocessui.so is empty, not checked.
ldconfig: File /usr/lib/libKF5PrisonScanner.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libkwinxrenderutils.so is empty, not checked.
ldconfig: File /usr/lib/libKF5UnitConversion.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5KDELibs4Support.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_ompio.so.41 is empty, not checked.
ldconfig: File /usr/lib/libKF5Prison.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensors.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardFormatter.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Runner.so is empty, not checked.
ldconfig: File /usr/lib/libksgrd.so.9 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensorFaces.so is empty, not checked.
ldconfig: File /usr/lib/libflashrom.so.1 is empty, not checked.
ldconfig: File /usr/lib/libKF5Holidays.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libprotobuf.so.3.21.5.0 is empty, not checked.
ldconfig: File /usr/lib/libjcat.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_sm.so.40 is empty, not checked.
ldconfig: File /usr/lib/libprocessui.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKInfoCenterInternal.so is empty, not checked.
ldconfig: File /usr/lib/libcolorcorrect.so is empty, not checked.
ldconfig: File /usr/lib/libmpi_mpifh.so is empty, not checked.
ldconfig: File /usr/lib/libpmix.so.2.6.0 is empty, not checked.
ldconfig: File /usr/lib/libkfontinst.so is empty, not checked.
ldconfig: File /usr/lib/libksignalplotter.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Su.so.5.97.0.old is empty, not checked.
ldconfig: File /usr/lib/libkworkspace5.so is empty, not checked.
ldconfig: File /usr/lib/libaccounts-glib.so.0 is empty, not checked.
ldconfig: File /usr/lib/libprotoc.so.32 is empty, not checked.
ldconfig: File /usr/lib/libMagick++-7.Q16HDRI.so is empty, not checked.
ldconfig: File /usr/lib/libprotobuf-lite.so.3.21.5.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5ActivitiesStats.so is empty, not checked.
ldconfig: File /usr/lib/libfwupdplugin.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib/libcdt.so.5.0.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi.so.40 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_sm.so is empty, not checked.
ldconfig: File /usr/lib/libKScreenLocker.so.5 is empty, not checked.
ldconfig: File /usr/lib/libksgrd.so is empty, not checked.
ldconfig: File /usr/lib/libKF5TextEditor.so.5 is empty, not checked.
ldconfig: File /usr/lib/libheif.so.1 is empty, not checked.
ldconfig: File /usr/lib/liblab_gamut.so is empty, not checked.
ldconfig: File /usr/lib/libksignalplotter.so.9 is empty, not checked.
ldconfig: File /usr/lib/libaccounts-glib.so is empty, not checked.
ldconfig: File /usr/lib/libMagickWand-7.Q16HDRI.so.10 is empty, not checked.
ldconfig: File /usr/lib/libcc1.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PrisonScanner.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5ThreadWeaver.so.5 is empty, not checked.
ldconfig: File /usr/lib/libkwin.so.5 is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectcore.so.22 is empty, not checked.
ldconfig: File /usr/lib/libplasma-geolocation-interface.so is empty, not checked.
ldconfig: File /usr/lib/libKF5PeopleWidgets.so.5 is empty, not checked.
ldconfig: File /usr/lib/libxdot.so.4.0.0 is empty, not checked.
ldconfig: File /usr/lib/libprocesscore.so.9 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSystemStats.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libkioarchive.so.5 is empty, not checked.
ldconfig: File /usr/lib/libprocessui.so.9 is empty, not checked.
ldconfig: File /usr/lib/libmilou.so.5 is empty, not checked.
ldconfig: File /usr/lib/liblsofui.so.9 is empty, not checked.
ldconfig: File /usr/lib/libKF5Runner.so.5 is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectinterfaces.so.22 is empty, not checked.
ldconfig: File /usr/lib/libKF5KExiv2.so is empty, not checked.
ldconfig: File /usr/lib/libxdot.so.4 is empty, not checked.
ldconfig: File /usr/lib/libfwupdplugin.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Screen.so is empty, not checked.
ldconfig: File /usr/lib/libKF5PlasmaQuick.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5People.so is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensorFaces.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Contacts.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_sm.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libgvpr.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_monitoring.so.50.20.0 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardFormatter.so is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so.2.2 is empty, not checked.
ldconfig: File /usr/lib/libcbor.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Plasma.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libheif.so is empty, not checked.
ldconfig: File /usr/lib/libnetpbm.so.11.73 is empty, not checked.
ldconfig: File /usr/lib/libplasmapotdprovidercore.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5UnitConversion.so is empty, not checked.
ldconfig: File /usr/lib/libsystemsettingsview.so.3 is empty, not checked.
ldconfig: File /usr/lib/libkactivitymanagerd_plugin.so is empty, not checked.
ldconfig: File /usr/lib/liblsofui.so is empty, not checked.
ldconfig: File /usr/lib/libKF5PeopleWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libKScreenLocker.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libkwin.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/liblsofui.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libpmix.so is empty, not checked.
ldconfig: File /usr/lib/libKF5People.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libflashrom.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libplasmapotdprovidercore.so.1 is empty, not checked.
ldconfig: File /usr/lib/libmpi.so is empty, not checked.
ldconfig: File /usr/lib/libprotoc.so.3.21.5.0 is empty, not checked.
ldconfig: File /usr/lib/libheif.so.1.13.0 is empty, not checked.
ldconfig: File /usr/lib/libplasma-geolocation-interface.so.5 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_cuda.so is empty, not checked.
ldconfig: File /usr/lib/libqalculate.so is empty, not checked.
ldconfig: File /usr/lib/libmpi_cxx.so.40 is empty, not checked.
ldconfig: File /usr/lib/libKF5People.so.5 is empty, not checked.
ldconfig: File /usr/lib/libxdot.so is empty, not checked.
ldconfig: File /usr/lib/libKF5ThreadWeaver.so is empty, not checked.
ldconfig: File /usr/lib/libadwaita-1.so is empty, not checked.
ldconfig: File /usr/lib/libMagickWand-7.Q16HDRI.so.10.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5Holidays.so.5 is empty, not checked.
ldconfig: File /usr/lib/libsmbios_c.so.2.2.1 is empty, not checked.
ldconfig: File /usr/lib/libprocesscore.so is empty, not checked.
ldconfig: File /usr/lib/libkwinglutils.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Contacts.so is empty, not checked.
ldconfig: File /usr/lib/libKF5NotifyConfig.so.5 is empty, not checked.
ldconfig: File /usr/lib/libweather_ion.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Screen.so.7 is empty, not checked.
ldconfig: File /usr/lib/libkhotkeysprivate.so.5 is empty, not checked.
ldconfig: File /usr/lib/libcbor.so.0.9.0 is empty, not checked.
ldconfig: File /usr/lib/libprotobuf.so.32 is empty, not checked.
ldconfig: File /usr/lib/libmpi_mpifh.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libcgraph.so is empty, not checked.
ldconfig: File /usr/lib/libkcmkwincommon.so.5 is empty, not checked.
ldconfig: File /usr/lib/libopen-pal.so is empty, not checked.
ldconfig: File /usr/lib/libmpi_cxx.so.40.30.1 is empty, not checked.
ldconfig: File /usr/lib/libKF5Activities.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PeopleBackend.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libhunspell-1.7.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Plasma.so is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so is empty, not checked.
ldconfig: File /usr/lib/libkwineffects.so is empty, not checked.
ldconfig: File /usr/lib/libopen-rte.so.40 is empty, not checked.
ldconfig: File /usr/lib/libKF5TextEditor.so is empty, not checked.
ldconfig: File /usr/lib/libgvpr.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Screen.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5PlasmaQuick.so is empty, not checked.
ldconfig: File /usr/lib/libsmbios_c.so is empty, not checked.
ldconfig: File /usr/lib/libKF5ActivitiesStats.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libgvc.so.6 is empty, not checked.
ldconfig: File /usr/lib/libgvpr.so.2 is empty, not checked.
ldconfig: File /usr/lib/libKF5KExiv2.so.5.0.0 is empty, not checked.
ldconfig: File /usr/lib/libMagickCore-7.Q16HDRI.so.10.0.0 is empty, not checked.
ldconfig: File /usr/lib/libldns.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_monitoring.so is empty, not checked.
ldconfig: File /usr/lib/libkaccounts.so.22.08.0 is empty, not checked.
ldconfig: File /usr/lib/libopen-pal.so.40 is empty, not checked.
ldconfig: File /usr/lib/libadwaita-1.so.0 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_monitoring.so.50 is empty, not checked.
ldconfig: File /usr/lib/libjcat.so is empty, not checked.
ldconfig: File /usr/lib/libnotificationmanager.so.1 is empty, not checked.
ldconfig: File /usr/lib/libkworkspace5.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Prison.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libprotoc.so is empty, not checked.
ldconfig: File /usr/lib/libompitrace.so is empty, not checked.
ldconfig: File /usr/lib/libprotobuf-lite.so.32 is empty, not checked.
ldconfig: File /usr/lib/libplasma-geolocation-interface.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libqalculate.so.22.17.1 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so is empty, not checked.
ldconfig: File /usr/lib/libhunspell-1.7.so.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PlasmaQuick.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libkwineffects.so.13 is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so.2 is empty, not checked.
ldconfig: File /usr/lib/libkwinxrenderutils.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5KExiv2.so.15.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PeopleWidgets.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PrisonScanner.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Emoticons.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_mpifh.so.40 is empty, not checked.
ldconfig: File /usr/lib/libcgraph.so.6.0.0 is empty, not checked.
ldconfig: File /usr/lib/libtaskmanager.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Contacts.so.5 is empty, not checked.
ldconfig: File /usr/lib/libtaskmanager.so.6 is empty, not checked.
ldconfig: File /usr/lib/libcc1.so is empty, not checked.
ldconfig: File /usr/lib/libqalculate.so.22 is empty, not checked.
ldconfig: File /usr/lib/libcbor.so.0.9 is empty, not checked.
ldconfig: File /usr/lib/libtaskmanager.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libkhotkeysprivate.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libmca_common_cuda.so.40 is empty, not checked.
ldconfig: File /usr/lib/libflashrom.so is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempif08.so.40 is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectinterfaces.so.22.08.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5KDELibs4Support.so is empty, not checked.
ldconfig: File /usr/lib/libKF5DNSSD.so.5 is empty, not checked.
ldconfig: File /usr/lib/liblab_gamut.so.1 is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so is empty, not checked.
ldconfig: File /usr/lib/libkwinglutils.so is empty, not checked.
ldconfig: File /usr/lib/libsmbios_c.so.2 is empty, not checked.
ldconfig: File /usr/lib/libMagick++-7.Q16HDRI.so.5 is empty, not checked.
ldconfig: File /usr/lib/libMagickCore-7.Q16HDRI.so.10 is empty, not checked.
ldconfig: File /usr/lib/libkfontinstui.so is empty, not checked.
ldconfig: File /usr/lib/libkwinglutils.so.13 is empty, not checked.
ldconfig: File /usr/lib/libnetpbm.so.11 is empty, not checked.
ldconfig: File /usr/lib/libmpi_cxx.so is empty, not checked.
ldconfig: File /usr/lib/libweather_ion.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib/libkworkspace5.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Activities.so is empty, not checked.
ldconfig: File /usr/lib/libpathplan.so.4 is empty, not checked.
ldconfig: File /usr/lib/libopen-rte.so.40.30.2 is empty, not checked.
ldconfig: File /usr/lib/libcolorcorrect.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5TextEditor.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libkaccounts.so.2 is empty, not checked.
ldconfig: File /usr/lib/libMagick++-7.Q16HDRI.so.5.0.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempif08.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5DNSSD.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PeopleBackend.so is empty, not checked.
ldconfig: File /usr/lib/libkfontinst.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Emoticons.so.5 is empty, not checked.
ldconfig: File /usr/lib/libldns.so.3.5.0 is empty, not checked.
ldconfig: File /usr/lib/libcdt.so is empty, not checked.
ldconfig: File /usr/lib/libkwineffects.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKScreenLocker.so is empty, not checked.
ldconfig: File /usr/lib/libnotificationmanager.so is empty, not checked.
ldconfig: File /usr/lib/libfwupdplugin.so.7 is empty, not checked.
ldconfig: File /usr/lib/libnetpbm.so is empty, not checked.
ldconfig: File /usr/lib/libkfontinstui.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so.2.2.0 is empty, not checked.
ldconfig: File /usr/lib/libkrdb.so is empty, not checked.
ldconfig: File /usr/lib/libprocesscore.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5DNSSD.so is empty, not checked.
ldconfig: File /usr/lib/libompitrace.so.40 is empty, not checked.
ldconfig: File /usr/lib/libcc1.so.0 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so.40.30.0 is empty, not checked.
ldconfig: File /usr/lib/libkaccounts.so is empty, not checked.
ldconfig: File /usr/lib/libgvc.so.6.0.0 is empty, not checked.
ldconfig: File /usr/lib/libplasmapotdprovidercore.so is empty, not checked.
ldconfig: File /usr/lib/libldns.so.3 is empty, not checked.
ldconfig: File /usr/lib/libcdt.so.5 is empty, not checked.
ldconfig: File /usr/lib/libkfontinstui.so.5 is empty, not checked.
ldconfig: File /usr/lib/libgvc.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Holidays.so is empty, not checked.
ldconfig: File /usr/lib/libaccounts-glib.so.1.25 is empty, not checked.
ldconfig: File /usr/lib/libkwinxrenderutils.so.13 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempif08.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_ompio.so is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5ActivitiesStats.so.1 is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so.5 is empty, not checked.
ldconfig: File /usr/lib/libprotobuf.so is empty, not checked.
ldconfig: File /usr/lib/libpmix.so.2 is empty, not checked.
ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so.40 is empty, not checked.
ldconfig: File /usr/lib/libksgrd.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libpathplan.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Runner.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5UnitConversion.so.5.97.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PeopleBackend.so.5 is empty, not checked.
ldconfig: File /usr/lib/libopen-pal.so.40.30.2 is empty, not checked.
ldconfig: File /usr/lib/libksignalplotter.so is empty, not checked.
ldconfig: File /usr/lib/libKF5KDELibs4Support.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSensorFaces.so.1 is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectpluginkcm.so.22.08.0 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSystemStats.so is empty, not checked.
ldconfig: File /usr/lib/libMagickCore-7.Q16HDRI.so is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardFormatter.so.1 is empty, not checked.
ldconfig: File /usr/lib/libKF5NotifyConfig.so is empty, not checked.
ldconfig: File /usr/lib/libmpi.so.40.30.4 is empty, not checked.
ldconfig: File /usr/lib/libKF5Plasma.so.5 is empty, not checked.
ldconfig: File /usr/lib/libMagickWand-7.Q16HDRI.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Emoticons.so is empty, not checked.
ldconfig: File /usr/lib/libompitrace.so.40.30.1 is empty, not checked.
ldconfig: File /usr/lib/libKSysGuardSystemStats.so.1 is empty, not checked.
ldconfig: File /usr/lib/libcgraph.so.6 is empty, not checked.
ldconfig: File /usr/lib/libweather_ion.so.7 is empty, not checked.
ldconfig: File /usr/lib/libmilou.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libhunspell.so is empty, not checked.
ldconfig: File /usr/lib/libLayerShellQtInterface.so.5.25.5 is empty, not checked.
ldconfig: File /usr/lib/libopen-rte.so is empty, not checked.
ldconfig: File /usr/lib/libmca_common_ompio.so.41.29.4 is empty, not checked.
ldconfig: File /usr/lib/libkdeconnectcore.so.22.08.0 is empty, not checked.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
Oh boy, look at that… I could see ldconfig … is empty error also everywhere
then again,
# pamac remove python-anytree
Preparing...
- removing python-anytree breaks dependency 'python-anytree' required by gtk-doc
run this first:
pacman -Syyu --overwrite "*"
post any errors from it
# pacman -Syyu --overwrite "*"
 core                  166.2 KiB  17.8 KiB/s 00:09 [######################] 100%
 extra                1955.5 KiB  29.0 KiB/s 01:07 [######################] 100%
 community               7.3 MiB  33.1 KiB/s 03:45 [######################] 100%
 multilib              180.5 KiB  25.1 KiB/s 00:07 [######################] 100%
 there is nothing to do
Huh?
It took a while to complete the process and seems like it’s all done, but the commands are still broken.
if you type #git --version it gives you nothing but goes to the next line, i cannot install AUR packages or work with pycharm or anything, because of this case.
btw I do not have to chroot into the system, some major parts of BSPWM is working. But KDE Plasma on wayland is fully broken.
i dont know what you mean… what commands are empty …
you can reinstall git:
pacman -S git
and see if it gives you errors
do you have nvidia? and yes kde+wayland is buggy, is it broken on xorg too?
Many commands such as git, feh, and most of programs.
it gives you empty output and goes to the next line of terminal. I do not know what is wrong
look…
# pacman -S git
warning: git-2.37.3-1 is up to date -- reinstalling
Packages (1) git-2.37.3-1
Total Installed Size:  34.49 MiB
git: /usr/bin/git exists in filesystem
git: /usr/bin/git-cvsserver exists in filesystem
git: /usr/bin/git-receive-pack exists in filesystem
git: /usr/bin/git-shell exists in filesystem
git: /usr/bin/git-upload-archive exists in filesystem
git: /usr/bin/git-upload-pack exists in filesystem
git: /usr/bin/gitk exists in filesystem
git: /usr/lib/git-core/git exists in filesystem
git: /usr/lib/git-core/git-add exists in filesystem
git: /usr/lib/git-core/git-add--interactive exists in filesystem
git: /usr/lib/git-core/git-am exists in filesystem
git: /usr/lib/git-core/git-annotate exists in filesystem
git: /usr/lib/git-core/git-apply exists in filesystem
git: /usr/lib/git-core/git-archimport exists in filesystem
git: /usr/lib/git-core/git-archive exists in filesystem
git: /usr/lib/git-core/git-bisect exists in filesystem
git: /usr/lib/git-core/git-bisect--helper exists in filesystem
git: /usr/lib/git-core/git-blame exists in filesystem
git: /usr/lib/git-core/git-branch exists in filesystem
git: /usr/lib/git-core/git-bugreport exists in filesystem
git: /usr/lib/git-core/git-bundle exists in filesystem
git: /usr/lib/git-core/git-cat-file exists in filesystem
git: /usr/lib/git-core/git-check-attr exists in filesystem
git: /usr/lib/git-core/git-check-ignore exists in filesystem
git: /usr/lib/git-core/git-check-mailmap exists in filesystem
git: /usr/lib/git-core/git-check-ref-format exists in filesystem
git: /usr/lib/git-core/git-checkout exists in filesystem
git: /usr/lib/git-core/git-checkout--worker exists in filesystem
git: /usr/lib/git-core/git-checkout-index exists in filesystem
git: /usr/lib/git-core/git-cherry exists in filesystem
git: /usr/lib/git-core/git-cherry-pick exists in filesystem
git: /usr/lib/git-core/git-citool exists in filesystem
git: /usr/lib/git-core/git-clean exists in filesystem
git: /usr/lib/git-core/git-clone exists in filesystem
git: /usr/lib/git-core/git-column exists in filesystem
git: /usr/lib/git-core/git-commit exists in filesystem
git: /usr/lib/git-core/git-commit-graph exists in filesystem
git: /usr/lib/git-core/git-commit-tree exists in filesystem
git: /usr/lib/git-core/git-config exists in filesystem
git: /usr/lib/git-core/git-count-objects exists in filesystem
git: /usr/lib/git-core/git-credential exists in filesystem
git: /usr/lib/git-core/git-credential-cache exists in filesystem
git: /usr/lib/git-core/git-credential-cache--daemon exists in filesystem
git: /usr/lib/git-core/git-credential-gnome-keyring exists in filesystem
git: /usr/lib/git-core/git-credential-libsecret exists in filesystem
git: /usr/lib/git-core/git-credential-store exists in filesystem
git: /usr/lib/git-core/git-cvsexportcommit exists in filesystem
git: /usr/lib/git-core/git-cvsimport exists in filesystem
git: /usr/lib/git-core/git-cvsserver exists in filesystem
git: /usr/lib/git-core/git-daemon exists in filesystem
git: /usr/lib/git-core/git-describe exists in filesystem
git: /usr/lib/git-core/git-diff exists in filesystem
git: /usr/lib/git-core/git-diff-files exists in filesystem
git: /usr/lib/git-core/git-diff-index exists in filesystem
git: /usr/lib/git-core/git-diff-tree exists in filesystem
git: /usr/lib/git-core/git-difftool exists in filesystem
git: /usr/lib/git-core/git-difftool--helper exists in filesystem
git: /usr/lib/git-core/git-env--helper exists in filesystem
git: /usr/lib/git-core/git-fast-export exists in filesystem
git: /usr/lib/git-core/git-fast-import exists in filesystem
git: /usr/lib/git-core/git-fetch exists in filesystem
git: /usr/lib/git-core/git-fetch-pack exists in filesystem
git: /usr/lib/git-core/git-filter-branch exists in filesystem
git: /usr/lib/git-core/git-fmt-merge-msg exists in filesystem
git: /usr/lib/git-core/git-for-each-ref exists in filesystem
git: /usr/lib/git-core/git-for-each-repo exists in filesystem
git: /usr/lib/git-core/git-format-patch exists in filesystem
git: /usr/lib/git-core/git-fsck exists in filesystem
git: /usr/lib/git-core/git-fsck-objects exists in filesystem
git: /usr/lib/git-core/git-fsmonitor--daemon exists in filesystem
git: /usr/lib/git-core/git-gc exists in filesystem
git: /usr/lib/git-core/git-get-tar-commit-id exists in filesystem
git: /usr/lib/git-core/git-grep exists in filesystem
git: /usr/lib/git-core/git-gui exists in filesystem
git: /usr/lib/git-core/git-gui--askpass exists in filesystem
git: /usr/lib/git-core/git-hash-object exists in filesystem
git: /usr/lib/git-core/git-help exists in filesystem
git: /usr/lib/git-core/git-hook exists in filesystem
git: /usr/lib/git-core/git-http-backend exists in filesystem
git: /usr/lib/git-core/git-http-fetch exists in filesystem
git: /usr/lib/git-core/git-http-push exists in filesystem
git: /usr/lib/git-core/git-imap-send exists in filesystem
git: /usr/lib/git-core/git-index-pack exists in filesystem
git: /usr/lib/git-core/git-init exists in filesystem
git: /usr/lib/git-core/git-init-db exists in filesystem
git: /usr/lib/git-core/git-instaweb exists in filesystem
git: /usr/lib/git-core/git-interpret-trailers exists in filesystem
git: /usr/lib/git-core/git-log exists in filesystem
git: /usr/lib/git-core/git-ls-files exists in filesystem
git: /usr/lib/git-core/git-ls-remote exists in filesystem
git: /usr/lib/git-core/git-ls-tree exists in filesystem
git: /usr/lib/git-core/git-mailinfo exists in filesystem
git: /usr/lib/git-core/git-mailsplit exists in filesystem
git: /usr/lib/git-core/git-maintenance exists in filesystem
git: /usr/lib/git-core/git-merge exists in filesystem
git: /usr/lib/git-core/git-merge-base exists in filesystem
git: /usr/lib/git-core/git-merge-file exists in filesystem
git: /usr/lib/git-core/git-merge-index exists in filesystem
git: /usr/lib/git-core/git-merge-octopus exists in filesystem
git: /usr/lib/git-core/git-merge-one-file exists in filesystem
git: /usr/lib/git-core/git-merge-ours exists in filesystem
git: /usr/lib/git-core/git-merge-recursive exists in filesystem
git: /usr/lib/git-core/git-merge-resolve exists in filesystem
git: /usr/lib/git-core/git-merge-subtree exists in filesystem
git: /usr/lib/git-core/git-merge-tree exists in filesystem
git: /usr/lib/git-core/git-mergetool exists in filesystem
git: /usr/lib/git-core/git-mergetool--lib exists in filesystem
git: /usr/lib/git-core/git-mktag exists in filesystem
git: /usr/lib/git-core/git-mktree exists in filesystem
git: /usr/lib/git-core/git-multi-pack-index exists in filesystem
git: /usr/lib/git-core/git-mv exists in filesystem
git: /usr/lib/git-core/git-mw exists in filesystem
git: /usr/lib/git-core/git-name-rev exists in filesystem
git: /usr/lib/git-core/git-notes exists in filesystem
git: /usr/lib/git-core/git-p4 exists in filesystem
git: /usr/lib/git-core/git-pack-objects exists in filesystem
git: /usr/lib/git-core/git-pack-redundant exists in filesystem
git: /usr/lib/git-core/git-pack-refs exists in filesystem
git: /usr/lib/git-core/git-patch-id exists in filesystem
git: /usr/lib/git-core/git-prune exists in filesystem
git: /usr/lib/git-core/git-prune-packed exists in filesystem
git: /usr/lib/git-core/git-pull exists in filesystem
git: /usr/lib/git-core/git-push exists in filesystem
git: /usr/lib/git-core/git-quiltimport exists in filesystem
git: /usr/lib/git-core/git-range-diff exists in filesystem
git: /usr/lib/git-core/git-read-tree exists in filesystem
git: /usr/lib/git-core/git-rebase exists in filesystem
git: /usr/lib/git-core/git-receive-pack exists in filesystem
git: /usr/lib/git-core/git-reflog exists in filesystem
git: /usr/lib/git-core/git-remote exists in filesystem
git: /usr/lib/git-core/git-remote-ext exists in filesystem
git: /usr/lib/git-core/git-remote-fd exists in filesystem
git: /usr/lib/git-core/git-remote-ftp exists in filesystem
git: /usr/lib/git-core/git-remote-ftps exists in filesystem
git: /usr/lib/git-core/git-remote-http exists in filesystem
git: /usr/lib/git-core/git-remote-https exists in filesystem
git: /usr/lib/git-core/git-remote-mediawiki exists in filesystem
git: /usr/lib/git-core/git-repack exists in filesystem
git: /usr/lib/git-core/git-replace exists in filesystem
git: /usr/lib/git-core/git-request-pull exists in filesystem
git: /usr/lib/git-core/git-rerere exists in filesystem
git: /usr/lib/git-core/git-reset exists in filesystem
git: /usr/lib/git-core/git-restore exists in filesystem
git: /usr/lib/git-core/git-rev-list exists in filesystem
git: /usr/lib/git-core/git-rev-parse exists in filesystem
git: /usr/lib/git-core/git-revert exists in filesystem
git: /usr/lib/git-core/git-rm exists in filesystem
git: /usr/lib/git-core/git-send-email exists in filesystem
git: /usr/lib/git-core/git-send-pack exists in filesystem
git: /usr/lib/git-core/git-sh-i18n exists in filesystem
git: /usr/lib/git-core/git-sh-i18n--envsubst exists in filesystem
git: /usr/lib/git-core/git-sh-setup exists in filesystem
git: /usr/lib/git-core/git-shell exists in filesystem
git: /usr/lib/git-core/git-shortlog exists in filesystem
git: /usr/lib/git-core/git-show exists in filesystem
git: /usr/lib/git-core/git-show-branch exists in filesystem
git: /usr/lib/git-core/git-show-index exists in filesystem
git: /usr/lib/git-core/git-show-ref exists in filesystem
git: /usr/lib/git-core/git-sparse-checkout exists in filesystem
git: /usr/lib/git-core/git-stage exists in filesystem
git: /usr/lib/git-core/git-stash exists in filesystem
git: /usr/lib/git-core/git-status exists in filesystem
git: /usr/lib/git-core/git-stripspace exists in filesystem
git: /usr/lib/git-core/git-submodule exists in filesystem
git: /usr/lib/git-core/git-submodule--helper exists in filesystem
git: /usr/lib/git-core/git-subtree exists in filesystem
git: /usr/lib/git-core/git-svn exists in filesystem
git: /usr/lib/git-core/git-switch exists in filesystem
git: /usr/lib/git-core/git-symbolic-ref exists in filesystem
git: /usr/lib/git-core/git-tag exists in filesystem
git: /usr/lib/git-core/git-unpack-file exists in filesystem
git: /usr/lib/git-core/git-unpack-objects exists in filesystem
git: /usr/lib/git-core/git-update-index exists in filesystem
git: /usr/lib/git-core/git-update-ref exists in filesystem
git: /usr/lib/git-core/git-update-server-info exists in filesystem
git: /usr/lib/git-core/git-upload-archive exists in filesystem
git: /usr/lib/git-core/git-upload-pack exists in filesystem
git: /usr/lib/git-core/git-var exists in filesystem
git: /usr/lib/git-core/git-verify-commit exists in filesystem
git: /usr/lib/git-core/git-verify-pack exists in filesystem
git: /usr/lib/git-core/git-verify-tag exists in filesystem
git: /usr/lib/git-core/git-web--browse exists in filesystem
git: /usr/lib/git-core/git-whatchanged exists in filesystem
git: /usr/lib/git-core/git-worktree exists in filesystem
git: /usr/lib/git-core/git-write-tree exists in filesystem
git: /usr/lib/git-core/mergetools/araxis exists in filesystem
git: /usr/lib/git-core/mergetools/bc exists in filesystem
git: /usr/lib/git-core/mergetools/codecompare exists in filesystem
git: /usr/lib/git-core/mergetools/deltawalker exists in filesystem
git: /usr/lib/git-core/mergetools/diffmerge exists in filesystem
git: /usr/lib/git-core/mergetools/diffuse exists in filesystem
git: /usr/lib/git-core/mergetools/ecmerge exists in filesystem
git: /usr/lib/git-core/mergetools/emerge exists in filesystem
git: /usr/lib/git-core/mergetools/examdiff exists in filesystem
git: /usr/lib/git-core/mergetools/guiffy exists in filesystem
git: /usr/lib/git-core/mergetools/gvimdiff exists in filesystem
git: /usr/lib/git-core/mergetools/kdiff3 exists in filesystem
git: /usr/lib/git-core/mergetools/kompare exists in filesystem
git: /usr/lib/git-core/mergetools/meld exists in filesystem
git: /usr/lib/git-core/mergetools/nvimdiff exists in filesystem
git: /usr/lib/git-core/mergetools/opendiff exists in filesystem
git: /usr/lib/git-core/mergetools/p4merge exists in filesystem
git: /usr/lib/git-core/mergetools/smerge exists in filesystem
git: /usr/lib/git-core/mergetools/tkdiff exists in filesystem
git: /usr/lib/git-core/mergetools/tortoisemerge exists in filesystem
git: /usr/lib/git-core/mergetools/vimdiff exists in filesystem
git: /usr/lib/git-core/mergetools/winmerge exists in filesystem
git: /usr/lib/git-core/mergetools/xxdiff exists in filesystem
git: /usr/lib/systemd/system/git-daemon.socket exists in filesystem
git: /usr/lib/systemd/system/git-daemon@.service exists in filesystem
git: /usr/lib/sysusers.d/git.conf exists in filesystem
git: /usr/share/bash-completion/completions/git exists in filesystem
git: /usr/share/git-core/templates/description exists in filesystem
git: /usr/share/git-core/templates/hooks/applypatch-msg.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/commit-msg.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/fsmonitor-watchman.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/post-update.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/pre-applypatch.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/pre-commit.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/pre-merge-commit.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/pre-push.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/pre-rebase.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/pre-receive.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/prepare-commit-msg.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/push-to-checkout.sample exists in filesystem
git: /usr/share/git-core/templates/hooks/update.sample exists in filesystem
git: /usr/share/git-core/templates/info/exclude exists in filesystem
git: /usr/share/git-gui/lib/about.tcl exists in filesystem
git: /usr/share/git-gui/lib/blame.tcl exists in filesystem
git: /usr/share/git-gui/lib/branch.tcl exists in filesystem
git: /usr/share/git-gui/lib/branch_checkout.tcl exists in filesystem
git: /usr/share/git-gui/lib/branch_create.tcl exists in filesystem
git: /usr/share/git-gui/lib/branch_delete.tcl exists in filesystem
git: /usr/share/git-gui/lib/branch_rename.tcl exists in filesystem
git: /usr/share/git-gui/lib/browser.tcl exists in filesystem
git: /usr/share/git-gui/lib/checkout_op.tcl exists in filesystem
git: /usr/share/git-gui/lib/choose_font.tcl exists in filesystem
git: /usr/share/git-gui/lib/choose_repository.tcl exists in filesystem
git: /usr/share/git-gui/lib/choose_rev.tcl exists in filesystem
git: /usr/share/git-gui/lib/chord.tcl exists in filesystem
git: /usr/share/git-gui/lib/class.tcl exists in filesystem
git: /usr/share/git-gui/lib/commit.tcl exists in filesystem
git: /usr/share/git-gui/lib/console.tcl exists in filesystem
git: /usr/share/git-gui/lib/database.tcl exists in filesystem
git: /usr/share/git-gui/lib/date.tcl exists in filesystem
git: /usr/share/git-gui/lib/diff.tcl exists in filesystem
git: /usr/share/git-gui/lib/encoding.tcl exists in filesystem
git: /usr/share/git-gui/lib/error.tcl exists in filesystem
git: /usr/share/git-gui/lib/git-gui.ico exists in filesystem
git: /usr/share/git-gui/lib/index.tcl exists in filesystem
git: /usr/share/git-gui/lib/line.tcl exists in filesystem
git: /usr/share/git-gui/lib/logo.tcl exists in filesystem
git: /usr/share/git-gui/lib/merge.tcl exists in filesystem
git: /usr/share/git-gui/lib/mergetool.tcl exists in filesystem
git: /usr/share/git-gui/lib/msgs/bg.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/de.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/el.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/fr.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/hu.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/it.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/ja.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/nb.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/pt_br.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/pt_pt.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/ru.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/sv.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/vi.msg exists in filesystem
git: /usr/share/git-gui/lib/msgs/zh_cn.msg exists in filesystem
git: /usr/share/git-gui/lib/option.tcl exists in filesystem
git: /usr/share/git-gui/lib/remote.tcl exists in filesystem
git: /usr/share/git-gui/lib/remote_add.tcl exists in filesystem
git: /usr/share/git-gui/lib/remote_branch_delete.tcl exists in filesystem
git: /usr/share/git-gui/lib/search.tcl exists in filesystem
git: /usr/share/git-gui/lib/shortcut.tcl exists in filesystem
git: /usr/share/git-gui/lib/spellcheck.tcl exists in filesystem
git: /usr/share/git-gui/lib/sshkey.tcl exists in filesystem
git: /usr/share/git-gui/lib/status_bar.tcl exists in filesystem
git: /usr/share/git-gui/lib/tclIndex exists in filesystem
git: /usr/share/git-gui/lib/themed.tcl exists in filesystem
git: /usr/share/git-gui/lib/tools.tcl exists in filesystem
git: /usr/share/git-gui/lib/tools_dlg.tcl exists in filesystem
git: /usr/share/git-gui/lib/transport.tcl exists in filesystem
git: /usr/share/git-gui/lib/win32.tcl exists in filesystem
git: /usr/share/git-gui/lib/win32_shortcut.js exists in filesystem
git: /usr/share/git/README exists in filesystem
git: /usr/share/git/buildsystems/CMakeLists.txt exists in filesystem
git: /usr/share/git/buildsystems/Generators.pm exists in filesystem
git: /usr/share/git/buildsystems/Generators/QMake.pm exists in filesystem
git: /usr/share/git/buildsystems/Generators/Vcproj.pm exists in filesystem
git: /usr/share/git/buildsystems/Generators/Vcxproj.pm exists in filesystem
git: /usr/share/git/buildsystems/engine.pl exists in filesystem
git: /usr/share/git/buildsystems/generate exists in filesystem
git: /usr/share/git/buildsystems/parse.pl exists in filesystem
git: /usr/share/git/coccinelle/README exists in filesystem
git: /usr/share/git/coccinelle/array.cocci exists in filesystem
git: /usr/share/git/coccinelle/commit.cocci exists in filesystem
git: /usr/share/git/coccinelle/equals-null.cocci exists in filesystem
git: /usr/share/git/coccinelle/flex_alloc.cocci exists in filesystem
git: /usr/share/git/coccinelle/free.cocci exists in filesystem
git: /usr/share/git/coccinelle/hashmap.cocci exists in filesystem
git: /usr/share/git/coccinelle/object_id.cocci exists in filesystem
git: /usr/share/git/coccinelle/preincr.cocci exists in filesystem
git: /usr/share/git/coccinelle/qsort.cocci exists in filesystem
git: /usr/share/git/coccinelle/strbuf.cocci exists in filesystem
git: /usr/share/git/coccinelle/swap.cocci exists in filesystem
git: /usr/share/git/coccinelle/the_repository.pending.cocci exists in filesystem
git: /usr/share/git/coccinelle/xcalloc.cocci exists in filesystem
git: /usr/share/git/coccinelle/xopen.cocci exists in filesystem
git: /usr/share/git/coccinelle/xstrdup_or_null.cocci exists in filesystem
git: /usr/share/git/completion/.gitattributes exists in filesystem
git: /usr/share/git/completion/git-completion.bash exists in filesystem
git: /usr/share/git/completion/git-completion.tcsh exists in filesystem
git: /usr/share/git/completion/git-completion.zsh exists in filesystem
git: /usr/share/git/completion/git-prompt.sh exists in filesystem
git: /usr/share/git/contacts/Makefile exists in filesystem
git: /usr/share/git/contacts/git-contacts exists in filesystem
git: /usr/share/git/contacts/git-contacts.txt exists in filesystem
git: /usr/share/git/coverage-diff.sh exists in filesystem
git: /usr/share/git/credential/gnome-keyring/Makefile exists in filesystem
git: /usr/share/git/credential/gnome-keyring/git-credential-gnome-keyring.c exists in filesystem
git: /usr/share/git/credential/libsecret/Makefile exists in filesystem
git: /usr/share/git/credential/libsecret/git-credential-libsecret.c exists in filesystem
git: /usr/share/git/credential/netrc/Makefile exists in filesystem
git: /usr/share/git/credential/netrc/git-credential-netrc.perl exists in filesystem
git: /usr/share/git/credential/netrc/t-git-credential-netrc.sh exists in filesystem
git: /usr/share/git/credential/netrc/test.command-option-gpg exists in filesystem
git: /usr/share/git/credential/netrc/test.git-config-gpg exists in filesystem
git: /usr/share/git/credential/netrc/test.netrc exists in filesystem
git: /usr/share/git/credential/netrc/test.netrc.gpg exists in filesystem
git: /usr/share/git/credential/netrc/test.pl exists in filesystem
git: /usr/share/git/credential/osxkeychain/Makefile exists in filesystem
git: /usr/share/git/credential/osxkeychain/git-credential-osxkeychain.c exists in filesystem
git: /usr/share/git/credential/wincred/Makefile exists in filesystem
git: /usr/share/git/credential/wincred/git-credential-wincred.c exists in filesystem
git: /usr/share/git/diff-highlight/DiffHighlight.pm exists in filesystem
git: /usr/share/git/diff-highlight/Makefile exists in filesystem
git: /usr/share/git/diff-highlight/README exists in filesystem
git: /usr/share/git/diff-highlight/diff-highlight exists in filesystem
git: /usr/share/git/diff-highlight/diff-highlight.perl exists in filesystem
git: /usr/share/git/diff-highlight/shebang.perl exists in filesystem
git: /usr/share/git/diff-highlight/t/Makefile exists in filesystem
git: /usr/share/git/diff-highlight/t/t9400-diff-highlight.sh exists in filesystem
git: /usr/share/git/emacs/README exists in filesystem
git: /usr/share/git/emacs/git-blame.el exists in filesystem
git: /usr/share/git/emacs/git.el exists in filesystem
git: /usr/share/git/examples/README exists in filesystem
git: /usr/share/git/fast-import/git-import.perl exists in filesystem
git: /usr/share/git/fast-import/git-import.sh exists in filesystem
git: /usr/share/git/fast-import/git-p4.README exists in filesystem
git: /usr/share/git/fast-import/import-directories.perl exists in filesystem
git: /usr/share/git/fast-import/import-tars.perl exists in filesystem
git: /usr/share/git/fast-import/import-zips.py exists in filesystem
git: /usr/share/git/git-jump/README exists in filesystem
git: /usr/share/git/git-jump/git-jump exists in filesystem
git: /usr/share/git/git-prompt.sh exists in filesystem
git: /usr/share/git/git-resurrect.sh exists in filesystem
git: /usr/share/git/git-shell-commands/README exists in filesystem
git: /usr/share/git/git-shell-commands/help exists in filesystem
git: /usr/share/git/git-shell-commands/list exists in filesystem
git: /usr/share/git/hg-to-git/hg-to-git.py exists in filesystem
git: /usr/share/git/hg-to-git/hg-to-git.txt exists in filesystem
git: /usr/share/git/hooks/multimail/README.Git exists in filesystem
git: /usr/share/git/hooks/post-receive-email exists in filesystem
git: /usr/share/git/hooks/pre-auto-gc-battery exists in filesystem
git: /usr/share/git/hooks/setgitperms.perl exists in filesystem
git: /usr/share/git/hooks/update-paranoid exists in filesystem
git: /usr/share/git/long-running-filter/example.pl exists in filesystem
git: /usr/share/git/mw-to-git/.perlcriticrc exists in filesystem
git: /usr/share/git/mw-to-git/Git/Mediawiki.pm exists in filesystem
git: /usr/share/git/mw-to-git/Makefile exists in filesystem
git: /usr/share/git/mw-to-git/bin-wrapper/git exists in filesystem
git: /usr/share/git/mw-to-git/git-mw exists in filesystem
git: /usr/share/git/mw-to-git/git-mw.perl exists in filesystem
git: /usr/share/git/mw-to-git/git-remote-mediawiki exists in filesystem
git: /usr/share/git/mw-to-git/git-remote-mediawiki.perl exists in filesystem
git: /usr/share/git/mw-to-git/git-remote-mediawiki.txt exists in filesystem
git: /usr/share/git/mw-to-git/t/Makefile exists in filesystem
git: /usr/share/git/mw-to-git/t/README exists in filesystem
git: /usr/share/git/mw-to-git/t/install-wiki.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/push-pull-tests.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/t9360-mw-to-git-clone.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/t9361-mw-to-git-push-pull.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/t9362-mw-to-git-utf8.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/t9363-mw-to-git-export-import.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/t9364-pull-by-rev.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/t9365-continuing-queries.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/test-gitmw-lib.sh exists in filesystem
git: /usr/share/git/mw-to-git/t/test-gitmw.pl exists in filesystem
git: /usr/share/git/mw-to-git/t/test.config exists in filesystem
git: /usr/share/git/persistent-https/LICENSE exists in filesystem
git: /usr/share/git/persistent-https/Makefile exists in filesystem
git: /usr/share/git/persistent-https/README exists in filesystem
git: /usr/share/git/persistent-https/client.go exists in filesystem
git: /usr/share/git/persistent-https/main.go exists in filesystem
git: /usr/share/git/persistent-https/proxy.go exists in filesystem
git: /usr/share/git/persistent-https/socket.go exists in filesystem
git: /usr/share/git/remote-helpers/README exists in filesystem
git: /usr/share/git/remote-helpers/git-remote-bzr exists in filesystem
git: /usr/share/git/remote-helpers/git-remote-hg exists in filesystem
git: /usr/share/git/remotes2config.sh exists in filesystem
git: /usr/share/git/rerere-train.sh exists in filesystem
git: /usr/share/git/scalar/Makefile exists in filesystem
git: /usr/share/git/scalar/README.md exists in filesystem
git: /usr/share/git/scalar/scalar.c exists in filesystem
git: /usr/share/git/scalar/scalar.txt exists in filesystem
git: /usr/share/git/scalar/t/Makefile exists in filesystem
git: /usr/share/git/scalar/t/t9099-scalar.sh exists in filesystem
git: /usr/share/git/stats/git-common-hash exists in filesystem
git: /usr/share/git/stats/mailmap.pl exists in filesystem
git: /usr/share/git/stats/packinfo.pl exists in filesystem
git: /usr/share/git/subtree/COPYING exists in filesystem
git: /usr/share/git/subtree/INSTALL exists in filesystem
git: /usr/share/git/subtree/Makefile exists in filesystem
git: /usr/share/git/subtree/README exists in filesystem
git: /usr/share/git/subtree/git-subtree exists in filesystem
git: /usr/share/git/subtree/git-subtree.1 exists in filesystem
git: /usr/share/git/subtree/git-subtree.sh exists in filesystem
git: /usr/share/git/subtree/git-subtree.txt exists in filesystem
git: /usr/share/git/subtree/git-subtree.xml exists in filesystem
git: /usr/share/git/subtree/t/Makefile exists in filesystem
git: /usr/share/git/subtree/t/t7900-subtree.sh exists in filesystem
git: /usr/share/git/subtree/todo exists in filesystem
git: /usr/share/git/thunderbird-patch-inline/README exists in filesystem
git: /usr/share/git/thunderbird-patch-inline/appp.sh exists in filesystem
git: /usr/share/git/update-unicode/README exists in filesystem
git: /usr/share/git/update-unicode/update_unicode.sh exists in filesystem
git: /usr/share/git/vscode/.gitattributes exists in filesystem
git: /usr/share/git/vscode/README.md exists in filesystem
git: /usr/share/git/vscode/init.sh exists in filesystem
git: /usr/share/git/workdir/.gitattributes exists in filesystem
git: /usr/share/git/workdir/git-new-workdir exists in filesystem
git: /usr/share/gitk/lib/msgs/bg.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/ca.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/de.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/es.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/fr.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/hu.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/it.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/ja.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/pt_br.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/pt_pt.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/ru.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/sv.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/vi.msg exists in filesystem
git: /usr/share/gitk/lib/msgs/zh_cn.msg exists in filesystem
git: /usr/share/gitweb/gitweb.cgi exists in filesystem
git: /usr/share/gitweb/static/git-favicon.png exists in filesystem
git: /usr/share/gitweb/static/git-logo.png exists in filesystem
git: /usr/share/gitweb/static/gitweb.css exists in filesystem
git: /usr/share/gitweb/static/gitweb.js exists in filesystem
git: /usr/share/locale/bg/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/ca/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/de/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/el/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/es/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/fr/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/id/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/is/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/it/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/ko/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/pl/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/pt_PT/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/ru/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/sv/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/tr/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/vi/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/zh_CN/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/locale/zh_TW/LC_MESSAGES/git.mo exists in filesystem
git: /usr/share/man/man1/git-add.1.gz exists in filesystem
git: /usr/share/man/man1/git-am.1.gz exists in filesystem
git: /usr/share/man/man1/git-annotate.1.gz exists in filesystem
git: /usr/share/man/man1/git-apply.1.gz exists in filesystem
git: /usr/share/man/man1/git-archimport.1.gz exists in filesystem
git: /usr/share/man/man1/git-archive.1.gz exists in filesystem
git: /usr/share/man/man1/git-bisect.1.gz exists in filesystem
git: /usr/share/man/man1/git-blame.1.gz exists in filesystem
git: /usr/share/man/man1/git-branch.1.gz exists in filesystem
git: /usr/share/man/man1/git-bugreport.1.gz exists in filesystem
git: /usr/share/man/man1/git-bundle.1.gz exists in filesystem
git: /usr/share/man/man1/git-cat-file.1.gz exists in filesystem
git: /usr/share/man/man1/git-check-attr.1.gz exists in filesystem
git: /usr/share/man/man1/git-check-ignore.1.gz exists in filesystem
git: /usr/share/man/man1/git-check-mailmap.1.gz exists in filesystem
git: /usr/share/man/man1/git-check-ref-format.1.gz exists in filesystem
git: /usr/share/man/man1/git-checkout-index.1.gz exists in filesystem
git: /usr/share/man/man1/git-checkout.1.gz exists in filesystem
git: /usr/share/man/man1/git-cherry-pick.1.gz exists in filesystem
git: /usr/share/man/man1/git-cherry.1.gz exists in filesystem
git: /usr/share/man/man1/git-citool.1.gz exists in filesystem
git: /usr/share/man/man1/git-clean.1.gz exists in filesystem
git: /usr/share/man/man1/git-clone.1.gz exists in filesystem
git: /usr/share/man/man1/git-column.1.gz exists in filesystem
git: /usr/share/man/man1/git-commit-graph.1.gz exists in filesystem
git: /usr/share/man/man1/git-commit-tree.1.gz exists in filesystem
git: /usr/share/man/man1/git-commit.1.gz exists in filesystem
git: /usr/share/man/man1/git-config.1.gz exists in filesystem
git: /usr/share/man/man1/git-count-objects.1.gz exists in filesystem
git: /usr/share/man/man1/git-credential-cache--daemon.1.gz exists in filesystem
git: /usr/share/man/man1/git-credential-cache.1.gz exists in filesystem
git: /usr/share/man/man1/git-credential-store.1.gz exists in filesystem
git: /usr/share/man/man1/git-credential.1.gz exists in filesystem
git: /usr/share/man/man1/git-cvsexportcommit.1.gz exists in filesystem
git: /usr/share/man/man1/git-cvsimport.1.gz exists in filesystem
git: /usr/share/man/man1/git-cvsserver.1.gz exists in filesystem
git: /usr/share/man/man1/git-daemon.1.gz exists in filesystem
git: /usr/share/man/man1/git-describe.1.gz exists in filesystem
git: /usr/share/man/man1/git-diff-files.1.gz exists in filesystem
git: /usr/share/man/man1/git-diff-index.1.gz exists in filesystem
git: /usr/share/man/man1/git-diff-tree.1.gz exists in filesystem
git: /usr/share/man/man1/git-diff.1.gz exists in filesystem
git: /usr/share/man/man1/git-difftool.1.gz exists in filesystem
git: /usr/share/man/man1/git-fast-export.1.gz exists in filesystem
git: /usr/share/man/man1/git-fast-import.1.gz exists in filesystem
git: /usr/share/man/man1/git-fetch-pack.1.gz exists in filesystem
git: /usr/share/man/man1/git-fetch.1.gz exists in filesystem
git: /usr/share/man/man1/git-filter-branch.1.gz exists in filesystem
git: /usr/share/man/man1/git-fmt-merge-msg.1.gz exists in filesystem
git: /usr/share/man/man1/git-for-each-ref.1.gz exists in filesystem
git: /usr/share/man/man1/git-for-each-repo.1.gz exists in filesystem
git: /usr/share/man/man1/git-format-patch.1.gz exists in filesystem
git: /usr/share/man/man1/git-fsck-objects.1.gz exists in filesystem
git: /usr/share/man/man1/git-fsck.1.gz exists in filesystem
git: /usr/share/man/man1/git-fsmonitor--daemon.1.gz exists in filesystem
git: /usr/share/man/man1/git-gc.1.gz exists in filesystem
git: /usr/share/man/man1/git-get-tar-commit-id.1.gz exists in filesystem
git: /usr/share/man/man1/git-grep.1.gz exists in filesystem
git: /usr/share/man/man1/git-gui.1.gz exists in filesystem
git: /usr/share/man/man1/git-hash-object.1.gz exists in filesystem
git: /usr/share/man/man1/git-help.1.gz exists in filesystem
git: /usr/share/man/man1/git-hook.1.gz exists in filesystem
git: /usr/share/man/man1/git-http-backend.1.gz exists in filesystem
git: /usr/share/man/man1/git-http-fetch.1.gz exists in filesystem
git: /usr/share/man/man1/git-http-push.1.gz exists in filesystem
git: /usr/share/man/man1/git-imap-send.1.gz exists in filesystem
git: /usr/share/man/man1/git-index-pack.1.gz exists in filesystem
git: /usr/share/man/man1/git-init-db.1.gz exists in filesystem
git: /usr/share/man/man1/git-init.1.gz exists in filesystem
git: /usr/share/man/man1/git-instaweb.1.gz exists in filesystem
git: /usr/share/man/man1/git-interpret-trailers.1.gz exists in filesystem
git: /usr/share/man/man1/git-log.1.gz exists in filesystem
git: /usr/share/man/man1/git-ls-files.1.gz exists in filesystem
git: /usr/share/man/man1/git-ls-remote.1.gz exists in filesystem
git: /usr/share/man/man1/git-ls-tree.1.gz exists in filesystem
git: /usr/share/man/man1/git-mailinfo.1.gz exists in filesystem
git: /usr/share/man/man1/git-mailsplit.1.gz exists in filesystem
git: /usr/share/man/man1/git-maintenance.1.gz exists in filesystem
git: /usr/share/man/man1/git-merge-base.1.gz exists in filesystem
git: /usr/share/man/man1/git-merge-file.1.gz exists in filesystem
git: /usr/share/man/man1/git-merge-index.1.gz exists in filesystem
git: /usr/share/man/man1/git-merge-one-file.1.gz exists in filesystem
git: /usr/share/man/man1/git-merge-tree.1.gz exists in filesystem
git: /usr/share/man/man1/git-merge.1.gz exists in filesystem
git: /usr/share/man/man1/git-mergetool--lib.1.gz exists in filesystem
git: /usr/share/man/man1/git-mergetool.1.gz exists in filesystem
git: /usr/share/man/man1/git-mktag.1.gz exists in filesystem
git: /usr/share/man/man1/git-mktree.1.gz exists in filesystem
git: /usr/share/man/man1/git-multi-pack-index.1.gz exists in filesystem
git: /usr/share/man/man1/git-mv.1.gz exists in filesystem
git: /usr/share/man/man1/git-name-rev.1.gz exists in filesystem
git: /usr/share/man/man1/git-notes.1.gz exists in filesystem
git: /usr/share/man/man1/git-p4.1.gz exists in filesystem
git: /usr/share/man/man1/git-pack-objects.1.gz exists in filesystem
git: /usr/share/man/man1/git-pack-redundant.1.gz exists in filesystem
git: /usr/share/man/man1/git-pack-refs.1.gz exists in filesystem
git: /usr/share/man/man1/git-patch-id.1.gz exists in filesystem
git: /usr/share/man/man1/git-prune-packed.1.gz exists in filesystem
git: /usr/share/man/man1/git-prune.1.gz exists in filesystem
git: /usr/share/man/man1/git-pull.1.gz exists in filesystem
git: /usr/share/man/man1/git-push.1.gz exists in filesystem
git: /usr/share/man/man1/git-quiltimport.1.gz exists in filesystem
git: /usr/share/man/man1/git-range-diff.1.gz exists in filesystem
git: /usr/share/man/man1/git-read-tree.1.gz exists in filesystem
git: /usr/share/man/man1/git-rebase.1.gz exists in filesystem
git: /usr/share/man/man1/git-receive-pack.1.gz exists in filesystem
git: /usr/share/man/man1/git-reflog.1.gz exists in filesystem
git: /usr/share/man/man1/git-remote-ext.1.gz exists in filesystem
git: /usr/share/man/man1/git-remote-fd.1.gz exists in filesystem
git: /usr/share/man/man1/git-remote.1.gz exists in filesystem
git: /usr/share/man/man1/git-repack.1.gz exists in filesystem
git: /usr/share/man/man1/git-replace.1.gz exists in filesystem
git: /usr/share/man/man1/git-request-pull.1.gz exists in filesystem
git: /usr/share/man/man1/git-rerere.1.gz exists in filesystem
git: /usr/share/man/man1/git-reset.1.gz exists in filesystem
git: /usr/share/man/man1/git-restore.1.gz exists in filesystem
git: /usr/share/man/man1/git-rev-list.1.gz exists in filesystem
git: /usr/share/man/man1/git-rev-parse.1.gz exists in filesystem
git: /usr/share/man/man1/git-revert.1.gz exists in filesystem
git: /usr/share/man/man1/git-rm.1.gz exists in filesystem
git: /usr/share/man/man1/git-send-email.1.gz exists in filesystem
git: /usr/share/man/man1/git-send-pack.1.gz exists in filesystem
git: /usr/share/man/man1/git-sh-i18n--envsubst.1.gz exists in filesystem
git: /usr/share/man/man1/git-sh-i18n.1.gz exists in filesystem
git: /usr/share/man/man1/git-sh-setup.1.gz exists in filesystem
git: /usr/share/man/man1/git-shell.1.gz exists in filesystem
git: /usr/share/man/man1/git-shortlog.1.gz exists in filesystem
git: /usr/share/man/man1/git-show-branch.1.gz exists in filesystem
git: /usr/share/man/man1/git-show-index.1.gz exists in filesystem
git: /usr/share/man/man1/git-show-ref.1.gz exists in filesystem
git: /usr/share/man/man1/git-show.1.gz exists in filesystem
git: /usr/share/man/man1/git-sparse-checkout.1.gz exists in filesystem
git: /usr/share/man/man1/git-stage.1.gz exists in filesystem
git: /usr/share/man/man1/git-stash.1.gz exists in filesystem
git: /usr/share/man/man1/git-status.1.gz exists in filesystem
git: /usr/share/man/man1/git-stripspace.1.gz exists in filesystem
git: /usr/share/man/man1/git-submodule.1.gz exists in filesystem
git: /usr/share/man/man1/git-subtree.1.gz exists in filesystem
git: /usr/share/man/man1/git-svn.1.gz exists in filesystem
git: /usr/share/man/man1/git-switch.1.gz exists in filesystem
git: /usr/share/man/man1/git-symbolic-ref.1.gz exists in filesystem
git: /usr/share/man/man1/git-tag.1.gz exists in filesystem
git: /usr/share/man/man1/git-unpack-file.1.gz exists in filesystem
git: /usr/share/man/man1/git-unpack-objects.1.gz exists in filesystem
git: /usr/share/man/man1/git-update-index.1.gz exists in filesystem
git: /usr/share/man/man1/git-update-ref.1.gz exists in filesystem
git: /usr/share/man/man1/git-update-server-info.1.gz exists in filesystem
git: /usr/share/man/man1/git-upload-archive.1.gz exists in filesystem
git: /usr/share/man/man1/git-upload-pack.1.gz exists in filesystem
git: /usr/share/man/man1/git-var.1.gz exists in filesystem
git: /usr/share/man/man1/git-verify-commit.1.gz exists in filesystem
git: /usr/share/man/man1/git-verify-pack.1.gz exists in filesystem
git: /usr/share/man/man1/git-verify-tag.1.gz exists in filesystem
git: /usr/share/man/man1/git-version.1.gz exists in filesystem
git: /usr/share/man/man1/git-web--browse.1.gz exists in filesystem
git: /usr/share/man/man1/git-whatchanged.1.gz exists in filesystem
git: /usr/share/man/man1/git-worktree.1.gz exists in filesystem
git: /usr/share/man/man1/git-write-tree.1.gz exists in filesystem
git: /usr/share/man/man1/git.1.gz exists in filesystem
git: /usr/share/man/man1/gitk.1.gz exists in filesystem
git: /usr/share/man/man1/gitweb.1.gz exists in filesystem
git: /usr/share/man/man3/Git.3pm.gz exists in filesystem
git: /usr/share/man/man5/gitattributes.5.gz exists in filesystem
git: /usr/share/man/man5/githooks.5.gz exists in filesystem
git: /usr/share/man/man5/gitignore.5.gz exists in filesystem
git: /usr/share/man/man5/gitmailmap.5.gz exists in filesystem
git: /usr/share/man/man5/gitmodules.5.gz exists in filesystem
git: /usr/share/man/man5/gitrepository-layout.5.gz exists in filesystem
git: /usr/share/man/man5/gitweb.conf.5.gz exists in filesystem
git: /usr/share/man/man7/gitcli.7.gz exists in filesystem
git: /usr/share/man/man7/gitcore-tutorial.7.gz exists in filesystem
git: /usr/share/man/man7/gitcredentials.7.gz exists in filesystem
git: /usr/share/man/man7/gitcvs-migration.7.gz exists in filesystem
git: /usr/share/man/man7/gitdiffcore.7.gz exists in filesystem
git: /usr/share/man/man7/giteveryday.7.gz exists in filesystem
git: /usr/share/man/man7/gitfaq.7.gz exists in filesystem
git: /usr/share/man/man7/gitglossary.7.gz exists in filesystem
git: /usr/share/man/man7/gitnamespaces.7.gz exists in filesystem
git: /usr/share/man/man7/gitremote-helpers.7.gz exists in filesystem
git: /usr/share/man/man7/gitrevisions.7.gz exists in filesystem
git: /usr/share/man/man7/gitsubmodules.7.gz exists in filesystem
git: /usr/share/man/man7/gittutorial-2.7.gz exists in filesystem
git: /usr/share/man/man7/gittutorial.7.gz exists in filesystem
git: /usr/share/man/man7/gitworkflows.7.gz exists in filesystem
git: /usr/share/perl5/vendor_perl/Git.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/I18N.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/IndexInfo.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/LoadCPAN.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/LoadCPAN/Error.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/LoadCPAN/Mail/Address.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/Mediawiki.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/Packet.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Editor.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Fetcher.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/GlobSpec.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Log.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Memoize/YAML.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Migration.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Prompt.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Ra.pm exists in filesystem
git: /usr/share/perl5/vendor_perl/Git/SVN/Utils.pm exists in filesystem
Web browsers, Rofi, and some python programs are working.
many others are broken. something is really wrong, just look what happened when I try to re-install git. See?
well your whole installation is messed up… since pacman -Syyu overwrite didnt work, we need to try something else … for this you need to be chrooted, so chroot first and then run this:
pacman -Qqn | pacman --overwrite=* -S -
this will reinstall everything and should fix your system …
Okay it’s gonna take a while i guess…
total ( 3 / 1053) 1%
yes it will reinstall all packages - practically your whole system… and hopefully fix it
oh boy this is very unfortunate.
# pacman -Qqn | pacman --overwrite=* -S -
warning: a52dec-0.7.4-11 is up to date -- reinstalling
warning: aalib-1.4rc5-14 is up to date -- reinstalling
warning: abseil-cpp-20220623.1-1 is up to date -- reinstalling
warning: dependency cycle detected:
warning: ruby-rake will be installed before its ruby dependency
warning: ruby-rexml will be installed before its ruby dependency
warning: ruby-test-unit will be installed before its ruby dependency
warning: xdg-desktop-portal-wlr will be installed before its xdg-desktop-portal dependency
Packages (1804) pulseaudio-16.1-1 [removal]  a52dec-0.7.4-11  aalib-1.4rc5-14
                abseil-cpp-20220623.1-1  accounts-qml-module-0.7-4
                accountsservice-22.08.8-2  acl-2.3.1-2  acpi-1.7-3  acpid-2.0.33-1
                adobe-source-code-pro-fonts-2.038ro+1.058it+1.018var-1
                adwaita-icon-theme-42.0+r1+gc144c3d75-1  aha-0.5.1-2  aircrack-ng-1.7-1
                alacritty-0.10.1-2  alsa-card-profiles-1:0.3.57-1  alsa-firmware-1.2.4-2
                yarn-1.22.19-1  yasm-1.3.0-5  yay-11.3.0-1  yelp-42.1-2
                yelp-tools-42.0-1  yelp-xsl-42.0-1  youtube-dl-2021.12.17-1
                yubico-c-1.13-6  yubico-c-client-2.15-5  yubikey-manager-4.0.9-1
                yubikey-personalization-1.20.0-3  yubikey-personalization-gui-3.1.25-2
                zbar-0.23.1-9  zeitgeist-1.0.4-1  zenity-3.43.0-1  zeromq-4.3.4-2
                zimg-3.0.4-1  zip-3.0-10  zita-alsa-pcmi-0.5.1-1  zita-convolver-4.0.3-2
                zita-resampler-1.8.0-1  zlib-1:1.2.12-2  zsh-5.9-1
                zsh-completions-0.34.0-2  zstd-1.5.2-7  zvbi-0.2.35-4  zxing-cpp-1.4.0-1
Total Download Size:     264.22 MiB
Total Installed Size:  12515.47 MiB
Net Upgrade Size:       1482.87 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 qt5-webengine-5.15.10-2-x86_64 is up to date
 docker-1:20.10.17-1-x86_64 is up to date
 noto-fonts-20220607-1-any is up to date
 vibrancy-icons-teal-...    24.1 MiB  36.2 KiB/s 11:21 [############################] 100%
 gimp-2.10.32-1-x86_64 is up to date
 ghostscript-9.56.1-1-x86_64 is up to date
 perl-5.36.0-1-x86_64 is up to date
 grub-2.06.r261.g2f4430cc0-1-x86_64 is up to date
 boost-1.79.0-1-x86_64 is up to date
 python2-2.7.18-5-x86_64    13.6 MiB  34.6 KiB/s 06:42 [############################] 100%
 calf-0.90.3-5-x86_64       13.0 MiB  35.5 KiB/s 06:16 [############################] 100%
 qt6-base-6.3.1-1-x86_64 is up to date
 qt5-webkit-5.212.0alpha4-15-x86_64 is up to date
 presage-0.9.1-1-x86_64     12.2 MiB  33.1 KiB/s 06:17 [############################] 100%
 qt6-declarative-6.3.1-1-x86_64 is up to date
 icu-71.1-1-x86_64 is up to date
 js78-78.15.0-4-x86_64 is up to date
 lib32-icu-71.1-1-x86_64 is up to date
 ffmpeg4.4-4.4.2-3-x86_64 is up to date
 subversion-1.14.1-6-x86_64 is up to date
 gtk3-1:3.24.34-1-x86_64 is up to date
 matcha-gtk-theme-20220607-1-any is up to date
 guile-2.2.7-2-x86_64.pkg.tar.zst failed to download
 Total (  23/1053)         264.2 MiB   138 KiB/s 32:38 [############################] 100%
error: failed retrieving file 'guile-2.2.7-2-x86_64.pkg.tar.zst' from manjaro.moson.eu : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'guile-2.2.7-2-x86_64.pkg.tar.zst' from mirror.moson.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'guile-2.2.7-2-x86_64.pkg.tar.zst' from mirror.alpix.eu : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'guile-2.2.7-2-x86_64.pkg.tar.zst' from ftp.gwdg.de : Resolving timed out after 10000 milliseconds
warning: failed to retrieve some files
error: failed to commit transaction (download library error)
Again, Errors! Errors!
Full log: Command failure # pacman -Qqn | pacman --overwrite=* -S - - Pastebin.com
god damn haha … this is not really something bad, we just forget to refresh mirrors before, so that this doesnt happen …
pacman-mirrors --fasttrack 5 && pacman -Syyu
Welp, This time it downloads faster!
Total (117/1031) 61%
hmm This is not good.
I see that ldconfig file..... is empty. not checked errors have appeared again. And also many other warnings missing firmware for module XXXX
Look at the full log here: [https://]gist.github[.]com/BlurryFlurry/4d9e469b92edeed37fda4b4c6a2864b3#file-gistfile1-txt-L3228-L3506
warning: accounts-qml-module-0.7-4 is up to date -- reinstalling
warning: accountsservice-22.08.8-2 is up to date -- reinstalling
warning: acl-2.3.1-2 is up to date -- reinstalling
warning: acpi-1.7-3 is up to date -- reinstalling
warning: acpid-2.0.33-1 is up to date -- reinstalling
Packages (1804) pulseaudio-16.1-1 [removal]  a52dec-0.7.4-11  aalib-1.4rc5-14  abseil-cpp-20220623.1-1  accounts-qml-module-0.7-4  accountsservice-22.08.8-2  acl-2.3.1-2  acpi-1.7-3
                acpid-2.0.33-1  adobe-source-code-pro-fonts-2.038ro+1.058it+1.018var-1  adwaita-icon-theme-42.0+r1+gc144c3d75-1  aha-0.5.1-2  aircrack-ng-1.7-1  alacritty-0.10.1-2
4-1  zenity-3.43.0-1  zeromq-4.3.4-2  zimg-3.0.4-1  zip-3.0-10  zita-alsa-pcmi-0.5.1-1
                zita-convolver-4.0.3-2  zita-resampler-1.8.0-1  zlib-1:1.2.12-2  zsh-5.9-1  zsh-completions-0.34.0-2  zstd-1.5.2-7  zvbi-0.2.35-4  zxing-cpp-1.4.0-1
Total Download Size:     201.17 MiB
 guile-2.2.7-2-x86_64        6.1 MiB   578 KiB/s 00:11 [####################################################################] 100%
 python-babel-2.10.3-1-any is up to date
 mathjax2-2.7.9-1-any        6.0 MiB  1583 KiB/s 00:04 [####################################################################] 100%
 gtk2-2.24.33-2-x86_64        5.9 MiB  1562 KiB/s 00:04 [####################################################################] 100%
 man-pages-5.13-1-any        5.9 MiB  1957 KiB/s 00:03 [####################################################################] 100%
 manjaro-documentation-en-20181009-1-any                                                5.6 MiB  1990 KiB/s 00:03 [####################################################################] 100%
 nmap-7.92-1-x86_64        5.4 MiB  2035 KiB/s 00:03 [####################################################################] 100%
 cups-1:2.4.2-3-x86_64 is up to date
 libpurple-2.14.10-1-x86_64 is up to date
 qt5-declarative-5.15.5+kde+r19-1-x86_64 is up to date
 doxygen-1.9.3-1-x86_64        4.5 MiB  1979 KiB/s 00:02 [####################################################################] 100%
 adwaita-icon-theme-42.0+r1+gc144c3d75-1-any is up to date
 python-pyqt5-5.15.7-1-x86_64 is up to date
 gavl-1.4.0-6-x86_64 is up to date
 gdb-12.1-1-x86_64 is up to date
 ttf-droid-20121017-10-any                                                              4.0 MiB  2.01 MiB/s 00:02 [####################################################################] 100%
 imath-3.1.5-2-x86_64 is up to date
 sddm-0.19.0-8-x86_64        3.4 MiB  2.10 MiB/s 00:02 [####################################################################] 100%
 alsa-firmware-1.2.4-2-any                                                              3.3 MiB  2.15 MiB/s 00:02 [####################################################################] 100%
 mesa-demos-8.5.0-2-x86_64 is up to date
 manjaro-wallpapers-17.0-1.3-1-any                                                      3.1 MiB  1942 KiB/s 00:02 [####################################################################] 100%
 lib32-gtk3-3.24.34-1-x86_64 is up to date
 dbus-python-1.2.18-3-x86_64                                                            2.8 MiB  1906 KiB/s 00:01 ...
 mugshot-0.4.3-3-any        2.3 MiB  1028 KiB/s 00:02 [####################################################################] 100%
 youtube-dl-2021.12.17-1-any                                                            2.3 MiB  1198 KiB/s 00:02 [####################################################################] 100%
 tigervnc-1.12.0-3-x86_64 is up to date
 zsh-5.9-1-x86_64 is up to date
 gendesk-1.0.9-3-x86_64 is up to date
 groff-1.22.4-7-x86_64 is up to date
 gst-plugins-bad-libs-1.20.3-1-x86_64 is up to date
 gst-plugins-base-libs-1.20.3-1-x86_64 is up to date
 boost-libs-1.79.0-1-x86_64 is up to date
 ripgrep-13.0.0-2-x86_64                                                             1316.7 KiB   668 KiB/s 00:02 [####################################################################] 100%
 v4l-utils-1.22.1-1-x86_64                                                           1304.7 KiB   673 KiB/s 00:02 [####################################################################] 100%
 hexchat-2.16.1-2-x86_64 is up to date
 krb5-1.19.3-3-x86_64 is up to date
 lynx-2.8.9-5-x86_64        1268.7 KiB   681 KiB/s 00:02 ..
..                        [####################################################################] 100%
( 261/1803) reinstalling sed        [####################################################################] 100%
( 262/1803) reinstalling fakeroot        [####################################################################] 100%
usr/bin/ldconfig: File /usr/lib/libhunspell-1.7.so.0.0.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5NotifyConfig.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkcmkwincommon.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkfontinst.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libnotificationmanager.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcolorcorrect.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_cuda.so.40.30.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkdeconnectpluginkcm.so.22 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Prison.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSensors.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5ThreadWeaver.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkioarchive.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libjcat.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/liblab_gamut.so.1.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSensors.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libpathplan.so.4.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Activities.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libprocessui.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PrisonScanner.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwinxrenderutils.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5UnitConversion.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5KDELibs4Support.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_ompio.so.41 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Prison.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSensors.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardFormatter.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Runner.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libksgrd.so.9 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSensorFaces.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libflashrom.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Holidays.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libjcat.so.1.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_sm.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libprocessui.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKInfoCenterInternal.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcolorcorrect.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_mpifh.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libpmix.so.2.6.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkfontinst.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libksignalplotter.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Su.so.5.97.0.old is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkworkspace5.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagick++-7.Q16HDRI.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5ActivitiesStats.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libfwupdplugin.so.7.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcdt.so.5.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_sm.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKScreenLocker.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libksgrd.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5TextEditor.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libheif.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/liblab_gamut.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libksignalplotter.so.9 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagickWand-7.Q16HDRI.so.10 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcc1.so.0.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PrisonScanner.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5ThreadWeaver.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwin.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkdeconnectcore.so.22 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libplasma-geolocation-interface.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PeopleWidgets.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libxdot.so.4.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libprocesscore.so.9 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSystemStats.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkioarchive.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libprocessui.so.9 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmilou.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/liblsofui.so.9 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Runner.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkdeconnectinterfaces.so.22 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5KExiv2.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libxdot.so.4 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libfwupdplugin.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Screen.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PlasmaQuick.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5People.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSensorFaces.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Contacts.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_sm.so.40.30.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libgvpr.so.2.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libfwupd.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_monitoring.so.50.20.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardFormatter.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libGLEW.so.2.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcbor.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Plasma.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libheif.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libnetpbm.so.11.73 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libplasmapotdprovidercore.so.1.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5UnitConversion.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libsystemsettingsview.so.3 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkactivitymanagerd_plugin.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/liblsofui.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PeopleWidgets.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKScreenLocker.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwin.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/liblsofui.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libpmix.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5People.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libflashrom.so.1.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libplasmapotdprovidercore.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libheif.so.1.13.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libplasma-geolocation-interface.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_cuda.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libqalculate.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_cxx.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5People.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libxdot.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5ThreadWeaver.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libadwaita-1.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagickWand-7.Q16HDRI.so.10.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Holidays.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libsmbios_c.so.2.2.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libprocesscore.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwinglutils.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Contacts.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5NotifyConfig.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libweather_ion.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Screen.so.7 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkhotkeysprivate.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcbor.so.0.9.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_mpifh.so.40.30.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcgraph.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkcmkwincommon.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libopen-pal.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_cxx.so.40.30.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Activities.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PeopleBackend.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libhunspell-1.7.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Plasma.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libLayerShellQtInterface.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwineffects.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libopen-rte.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5TextEditor.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libgvpr.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Screen.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PlasmaQuick.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libsmbios_c.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5ActivitiesStats.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libgvc.so.6 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libgvpr.so.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5KExiv2.so.5.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagickCore-7.Q16HDRI.so.10.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libldns.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_monitoring.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkaccounts.so.22.08.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libopen-pal.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libadwaita-1.so.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_monitoring.so.50 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libjcat.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libnotificationmanager.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkworkspace5.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Prison.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libompitrace.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libplasma-geolocation-interface.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libqalculate.so.22.17.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libhunspell-1.7.so.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PlasmaQuick.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwineffects.so.13 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libfwupd.so.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwinxrenderutils.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5KExiv2.so.15.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PeopleWidgets.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PrisonScanner.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Emoticons.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_mpifh.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcgraph.so.6.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libtaskmanager.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Contacts.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libtaskmanager.so.6 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcc1.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libqalculate.so.22 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcbor.so.0.9 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libtaskmanager.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkhotkeysprivate.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_cuda.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libflashrom.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_usempif08.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkdeconnectinterfaces.so.22.08.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5KDELibs4Support.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5DNSSD.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/liblab_gamut.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libGLEW.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwinglutils.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libsmbios_c.so.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagick++-7.Q16HDRI.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagickCore-7.Q16HDRI.so.10 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkfontinstui.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwinglutils.so.13 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libnetpbm.so.11 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_cxx.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libweather_ion.so.7.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkworkspace5.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Activities.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libpathplan.so.4 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libopen-rte.so.40.30.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcolorcorrect.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5TextEditor.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkaccounts.so.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagick++-7.Q16HDRI.so.5.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_usempif08.so.40.30.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5DNSSD.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PeopleBackend.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkfontinst.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Emoticons.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libldns.so.3.5.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcdt.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwineffects.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKScreenLocker.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libnotificationmanager.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libfwupdplugin.so.7 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libnetpbm.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkfontinstui.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libGLEW.so.2.2.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkrdb.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libprocesscore.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5DNSSD.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libompitrace.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcc1.so.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so.40.30.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkaccounts.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libgvc.so.6.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libplasmapotdprovidercore.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libldns.so.3 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcdt.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkfontinstui.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libgvc.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Holidays.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkwinxrenderutils.so.13 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_usempif08.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_ompio.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libfwupd.so.2.0.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5ActivitiesStats.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libLayerShellQtInterface.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libpmix.so.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi_usempi_ignore_tkr.so.40 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libksgrd.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libpathplan.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Runner.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5UnitConversion.so.5.97.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5PeopleBackend.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libopen-pal.so.40.30.2 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libksignalplotter.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5KDELibs4Support.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSensorFaces.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkdeconnectpluginkcm.so.22.08.0 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSystemStats.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagickCore-7.Q16HDRI.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardFormatter.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5NotifyConfig.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmpi.so.40.30.4 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Plasma.so.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libMagickWand-7.Q16HDRI.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKF5Emoticons.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libompitrace.so.40.30.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libKSysGuardSystemStats.so.1 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libcgraph.so.6 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libweather_ion.so.7 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmilou.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libhunspell.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libLayerShellQtInterface.so.5.25.5 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libopen-rte.so is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libmca_common_ompio.so.41.29.4 is empty, not checked.
usr/bin/ldconfig: File /usr/lib/libkdeconnectcore.so.22.08.0 is empty, not checked.
( 263/1803) reinstalling db        [####################################################################] 100%
( 264/1803) reinstalling perl        ..
(1790/1803) reinstalling yay        [####################################################################] 100%
(1791/1803) reinstalling yelp        [####################################################################] 100%
(1792/1803) reinstalling youtube-dl        [####################################################################] 100%
(1793/1803) reinstalling yubico-c        [####################################################################] 100%
(1794/1803) reinstalling yubico-c-client        [####################################################################] 100%
(1795/1803) reinstalling yubikey-personalization        [####################################################################] 100%
(1796/1803) reinstalling yubikey-manager        [####################################################################] 100%
(1797/1803) reinstalling yubikey-personalization-gui                                                              [####################################################################] 100%
(1798/1803) reinstalling zeitgeist        [####################################################################] 100%
(1799/1803) reinstalling zenity        [####################################################################] 100%
(1800/1803) reinstalling zita-alsa-pcmi        [####################################################################] 100%
(1801/1803) reinstalling zita-resampler        [####################################################################] 100%
(1802/1803) reinstalling zsh        [####################################################################] 100%
(1803/1803) reinstalling zsh-completions        [####################################################################] 100%
( 1/42) Creating system user accounts...
( 2/42) Registering binary formats...
( 3/42) Updating journal message catalog...
( 4/42) Reloading system manager configuration...
( 5/42) Updating udev hardware database...
( 6/42) Applying kernel sysctl settings...
( 7/42) Creating temporary files...
( 8/42) Reloading device manager configuration...
( 9/42) Arming ConditionNeedsUpdate...
(10/42) Updating the MIME type database...
(11/42) Rebuilding certificate stores...
(12/42) Updating module dependencies...
(13/42) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.141-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [resume]
  -> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qed
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux511.preset: 'default'
  -> -k /boot/vmlinuz-5.11-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.11-x86_64.img
==> Starting build: 5.11.22-2-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.11-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux511.preset: 'fallback'
  -> -k /boot/vmlinuz-5.11-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.11-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.11-x86_64-fallback.img
(14/42) Refreshing PackageKit...
(15/42) Qt5 Upgrade Warning
[WARNING] qt5-base was updated, qt5 applications will break until qt5-styleplugins is rebuilt.
(16/42) Updating the appstream cache...
✔ Metadata cache was updated successfully.
(17/42) Updating Grub-Bootmenu
Found background: /usr/share/grub/background.png
Found linux image: /boot/vmlinuz-5.11-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.11-x86_64.img
Found initrd fallback image: /boot/initramfs-5.11-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found Windows Boot Manager on /dev/sdc1@/EFI/Microsoft/Boot/bootmgfw.efi
done
(18/42) Reloading system bus configuration...
(19/42) Warn about old perl modules
(20/42) Copy Firefox Distribution Settings
(21/42) Updating fontconfig cache...
(22/42) Updating 32-bit fontconfig cache...
(23/42) Probing GDK-Pixbuf loader modules...
(24/42) Probing 32-bit GDK-Pixbuf loader modules...
(25/42) Updating GIO module cache...
(26/42) Updating 32-bit GIO module cache...
(27/42) Compiling GSettings XML schema files...
(28/42) Probing GTK2 input method modules...
(29/42) Probing GTK3 input method modules...
(30/42) Probing 32-bit GTK3 input method modules...
(31/42) Updating icon theme caches...
gtk-update-icon-cache: The generated cache was invalid.
(32/42) Updating GTK4 module cache...
(33/42) Reloading GVFS config...
(34/42) Creating background picture sym-links for XFCE...
'/usr/share/backgrounds/xfce/breath.png' -> '/usr/share/backgrounds/breath.png'
'/usr/share/backgrounds/xfce/illyria-default.jpg' -> '/usr/share/backgrounds/illyria-default.jpg'
'/usr/share/backgrounds/xfce/illyria-default-lockscreen.jpg' -> '/usr/share/backgrounds/illyria-default-lockscreen.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_01.jpg' -> '/usr/share/backgrounds/manjarowall17_01.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_02.jpg' -> '/usr/share/backgrounds/manjarowall17_02.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_03.jpg' -> '/usr/share/backgrounds/manjarowall17_03.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_04.jpg' -> '/usr/share/backgrounds/manjarowall17_04.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_05.jpg' -> '/usr/share/backgrounds/manjarowall17_05.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_06.jpg' -> '/usr/share/backgrounds/manjarowall17_06.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_07.jpg' -> '/usr/share/backgrounds/manjarowall17_07.jpg'
'/usr/share/backgrounds/xfce/manjarowall17_08.jpg' -> '/usr/share/backgrounds/manjarowall17_08.jpg'
(35/42) Changing NetworkManager Connectivity-Ping to manjaro.org
(36/42) Configuring pacman-mirrors ...
::INFO => Mirror status: https://repo.manjaro.org/status.json
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
(37/42) Updating the info directory file...
(38/42) Copy Thunderbird Distribution Settings
(39/42) Updating the desktop file MIME type cache...
(40/42) Updating the vlc plugin cache...
(41/42) Enabling proprietary media playback in Vivaldi…
Proprietary media codecs (104.0.5112.101) was already present
(42/42) Updating X fontdir indices...
