hello! I installed synfigstudio from pamac, but the program doesn’t work properly. Then I tried downloading it from the website the appimage format, but it couldn’t work. when trying to run via terminal:
/tmp/.mount_sU1FGE/usr/bin/synfigstudio: /tmp/.mount_sU1FGE/usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.30’ not found (required by /usr/lib/libjack.so.0)
