Hello! I have two sessions plasma 6.xx and lxqt on my pc but when I close plasma and log on lxqt all my sync data are lost, I use only one user and this only happen in chromium base browsers, (google chrome and m edge) firefox and zen works just fine, I have to start all over syncs and re-conf my sites, I installed profile-sync-daemon but it doesn’t work ethier, I’ll appreciate any advice, I’m not an experience user, thanks!
profile-sync-daemon
is for keeping your profile on tmpfs/RAM (not disk).
Are the chromium profiles in use the same?
You can open up chrome://version
in the browser and scroll down to Profile Path where you will see the path to the current user directory. Does it match?
The sync data is probably stored in kwallet, which is not opened when lxqt starts.
psd can be configured - and probably should be
see also the
Note:
here
you can specify browsers instead of auto-detecting them - and also configure the time interval in between syncs
I have tried to use it in the past - but with a spinning HDD this is no fun - the profile can be quite large and therefore quite some time passes until it is synced/available
it’s not stored in any wallet …
profiles are store in .conf, on both sessions are the same for chrone and edge.
I’ll check, I give it a blank password in order to aboid it, thanks.
I did it in BROWSER sec on psd.conf.
You were right, it was kwallet I turnned to “false” and now I will re-sync both browsers, what a mess I wonder if its possible to change the default path other than .config like .mozilla in home directory, thank you
