huh.
Maybe its starting too fast? I guess we could get picky about the Wants and After lines … but you could also maybe put a sleep in there to pause for a few seconds:
Cheers. Glad it works. Obviously, you can fiddle with the timer there and use something other than 6 seconds… find the sweet spot where it works but you arent waiting around for it.
Also … if it ever somehow does start too soon you can still run it again
systemctl start syna3602-driver-workaround
Of course since we know it works … you could fine-tune the service as well … maybe better After lines or similar, or config it to retry X times, etc.
Aw thanks
Yes … on second though … maybe try implementing the Conflicts,After,WantedBy params from phils here:
Yes I’ll try shorter wait times. Now if only the physical buttons on the touchpad would work as well, that would make it fully functional.
I used to get it working out of the box on kernel 5.3. I have a hunch it is some kind of timing issue as well, as even on other kernels it sometimes work (like 1 in 100 boots).
Hey Gustavo, I have a VAIO FE14 with the SYNA3602 touchpad too, and I found a way to make the touchpad works fine, except for the click of the left button. I am looking for this funcionality. I don’t know if you still with the laptop but I am contacting anyway.
EDIT: I managed a way to do it but the touchpad is double-clicking when pressed on the touch area. Maybe you understand how to fix this problem.
Hi guys yesterday I bought a VAIO Fe14 and it came with that touch I copied the system and they have a touchpad fix I’m going to share to see if it works sorry for my English
