O yea thats a really good point , it was late.
inxi
❱inxi -zv8
Kernel: 6.13.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.13-x86_64
root=UUID=992bfc64-a9b6-4084-a727-cb2c64726fc2 rw rootflags=subvol=@
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop System: Micro (HK) Tech product: Venus Series v: N/A
serial: <superuser required>
Mobo: Shenzhen Meigao Equipment model: AHWSA serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: AHWSA.1.22
date: 03/12/2024
System RAM: total: 32 GiB available: 31.07 GiB used: 12.25 GiB (39.4%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Crucial Technology part-no: CT16G56C46S5.C8D
serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
serial: <filter>
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4124
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 591 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 591 2: 591 3: 591 4: 591
5: 591 6: 591 7: 591 8: 591 9: 591 10: 591 11: 591 12: 591 13: 591 14: 591
15: 591 16: 591 17: 591 18: 591 19: 591 20: 591 bogomips: 119807
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:a7a0 class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: HDMI serial: <filter>
built: 2022 res: mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 163 gamma: 1.2
chroma: red: x: 0.671 y: 0.314 green: x: 0.278 y: 0.639 blue: x: 0.133
y: 0.067 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024,
1440x900, 1280x720, 1024x768, 800x600, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 15.17 GiB unified: yes
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Raptor Lake-P/U/H cAVS driver: snd_hda_intel v: kernel
alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51ca class-ID: 0403
Device-2: Jieli UACDemoV1.0
driver: hid-generic,snd-usb-audio,usb-storage,usbhid type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3 chip-ID: 4c4a:4155
class-ID: 0300 serial: <filter>
API: ALSA v: k6.13.7-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I226-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 56:00.0 chip-ID: 8086:125c
class-ID: 0200
IF: enp86s0 state: down mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 58:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp88s0 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:5 chip-ID: 0e8d:c616
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 1.84 TiB used: 345.34 GiB (18.3%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Kingston model: OM8PGP41024Q-A0
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 18.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 30.9 C
scheme: GPT
ID-1: / raw-size: 747.31 GiB size: 747.31 GiB (100.00%)
used: 345.33 GiB (46.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:9
label: N/A uuid: 992bfc64-a9b6-4084-a727-cb2c64726fc2
used: 8.5 MiB (2.8%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:10 label: N/A
uuid: F6F9-F0D0
ID-3: /home raw-size: 747.31 GiB size: 747.31 GiB (100.00%)
ID-4: /var/cache raw-size: 747.31 GiB size: 747.31 GiB (100.00%)
ID-5: /var/log raw-size: 747.31 GiB size: 747.31 GiB (100.00%)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:11 label: N/A
uuid: 9cf42b0a-d6e9-4cb2-9c17-e8e1c0c786d7
ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 100 MiB fs: vfat label: SYSTEM
uuid: FE0B-B236
ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 197.34 GiB fs: ntfs
label: Windows uuid: B8420EAF420E7304
ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 1023 MiB fs: ntfs
label: Recovery uuid: 1A660F3F660F1B61
ID-5: /dev/nvme1n1p1 maj-min: 259:1 size: 239.67 GiB fs: ext4
label: Secondary uuid: 0275aa50-2ab2-485b-8927-9ce4bd401ede
ID-6: /dev/nvme1n1p2 maj-min: 259:2 size: 442.38 GiB fs: btrfs
label: btrfs-backup uuid: c8e5829d-6ca5-4da6-b018-ccc507ff2c3a
ID-7: /dev/nvme1n1p3 maj-min: 259:3 size: 249.46 GiB fs: ext4
label: Tersary uuid: 55b2d8b1-ca51-436b-a715-6ccac553c200
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-2:2 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Hub-5: 3-2.3:4 info: Terminus Hub ports: 4 rev: 2.0
Device-1: 3-2.3.1:6 info: Hailuck PTP TouchPad type: mouse,HID
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 202mA
chip-ID: 258a:0010 class-ID: 0301 serial: <filter>
Device-2: 3-2.3.3:7 info: SINO WEALTH USB KEYBOARD type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 258a:0135 class-ID: 0300
Device-3: 3-5:3 info: Jieli UACDemoV1.0 type: mass storage,audio,HID
driver: hid-generic,snd-usb-audio,usb-storage,usbhid interfaces: 5 rev: 1.1
chip-ID: 4c4a:4155 class-ID: 0300 serial: <filter>
Device-4: 3-10:5 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:c616 class-ID: e001 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 30.8 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1654 libs: 403 tools: pamac,yay
1: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
2: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
3: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
4: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
Processes:
CPU top: 5 of 389
1: cpu: 1.6% command: waterfox-g pid: 3443 mem: 603.6 MiB (1.8%)
2: cpu: 0.9% command: waterfox pid: 3754 mem: 444.1 MiB (1.3%)
3: cpu: 0.9% command: plasmashell pid: 27774 mem: 430.7 MiB (1.3%)
4: cpu: 0.7% command: waterfox pid: 4058 mem: 326.4 MiB (1.0%)
5: cpu: 0.7% command: ksystemstats pid: 27796 mem: 32.5 MiB (0.1%)
Memory top: 5 of 389
1: mem: 603.6 MiB (1.8%) command: waterfox-g pid: 3443 cpu: 1.6%
2: mem: 454.4 MiB (1.4%) command: thunderbird pid: 1882 cpu: 0.1%
3: mem: 444.1 MiB (1.3%) command: waterfox pid: 3754 cpu: 0.9%
4: mem: 430.7 MiB (1.3%) command: plasmashell pid: 27774 cpu: 0.9%
5: mem: 326.4 MiB (1.0%) command: waterfox pid: 4058 cpu: 0.7%
Processes: 389 Power: uptime: 9h 18m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: fish v: 4.0.1 default: Bash
v: 5.2.37 running-in: yakuake inxi: 3.3.37
there is plenty of space
❱df -h
Filesystem Size Used Avail Use% Mounted on
dev 16G 0 16G 0% /dev
run 16G 2.1M 16G 1% /run
efivarfs 192K 128K 60K 69% /sys/firmware/efi/efivars
/dev/nvme0n1p5 748G 346G 402G 47% /
tmpfs 16G 6.1M 16G 1% /dev/shm
tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service
tmpfs 16G 6.6G 9.0G 43% /tmp
/dev/nvme0n1p5 748G 346G 402G 47% /var/cache
/dev/nvme0n1p5 748G 346G 402G 47% /home
/dev/nvme0n1p5 748G 346G 402G 47% /var/log
tmpfs 3.2G 116K 3.2G 1% /run/user/1000
/dev/nvme0n1p6 300M 8.5M 291M 3% /boot/efi
o gosh, i suppose i shall just have to try again but very slowly.
