Symbolic links flashing red despite existing
I've created a symbolic link
ln -s /home/{user2}/Music /home/{user1}/Music
The target exists and {user1} has rwx permissions to the directory via membership of 'users'
ls -al /home/household |grep Music
drwxrwxr-x+ 270 {user2} users     12288 Jul 17 17:18 Music
But the link created does not appear in dolphin and flashes red in ls
What's going wrong?
Example:
ln -s /data/steve/Downloads ~/Downloads
link /where/the/directory-is to /where/you/want/the/link
so
ln -s /home/user1/music /home/user2/music
Assuming the music folder is under user1's home.
Sorry, I can't see any difference between that and the code I quoted as having done. What am I missing?
(the music folder is in user2's home, so it's the other way round)
That wasn't clear. And I can't read :smiley:
I take it the {} braces are you hiding your user name?
Might require sudo....? ? ?
Apologies, my bad.
Yes, If I revealed my true name, I'd have to kill you.
Thanks, just tried it with sudo but to no avail, still flashing.
user1 might not be able to read /home/user2.
Login as user1 and check via cd /home/user2 and/or cd /home/user2/Music.
Yes, that's right. I'm hoping it's not the case that one user needs read rights to the whole of another user's home just in order to make a link? Basically, I want user1 to have access to the 'Music' folder of user2. I don't want user2 to have access to any of user1's files in return. Is that possible?
To access a directory one must have rx-access to any path component.
One option would be to move the Music-directory to a new location outside /home and create symlinks in every user-home.
I think you need to rethink your folder layout.
My instinct tells me it is a permission issue with the parent /home/$USER folder.
You can solve this - avoiding making the $USER folder readable by all - by creating an extra folder structure for the shared files e.g. /data/shared.
Then move the shared music folder to the shared folder.
$ sudo mkdir /data/shared
$ sudo chmod ugo+rw /data/shared
$ mv /home/$user2/Music /data/shared
You may need to adjust the moved Music folder's and the files permission
sudo chmod ugo+rw /data/shared/Music -R
login into the user2 account
$ rm Music
$ ln -s /data/shared/Music /home/$user2
then login into the user1 account and repeat
$ rm Music
$ ln -s /data/shared/Music /home/$user1
This is not a problem, I can try that...
...but I don't understand the reason
I've done sudo chown -R {user2} users on the whole '{user2}/Music' directory so anyone in 'users' should have full access, shouldn't they?
Yep, it looks like that's what I've got to do. Thanks for such exhaustive instructions. I still don't really understand why though, but I guess that will have to wait.
So the structure is:
/home
└── user1 (Steve for me)
└── user2 (user2 for me)
sudo mkdir /home/user2
sudo chgrp -R users /home/user2
sudo cp -r dotfiles /home/user2 # a small folder in my home.
ln -s /home/user2/dotfiles ~/ttemp
Then list the directory:
ls ttemp/
'#.aliasesrc#'         azirevpn-wg.sh   emacs.d                 plasma-xcape.sh   scripts    xbindkey
 aliasesrc-emergency   bash             Most_Files_are_Hidden   README.md         tmux       Xmodmap
 autokey               config.org       plasmacfg               reinstall         tmux-old   zshrc-emergency
All seems to work here.
The only difference seems to be that you're putting the whole /home/user2 directory into 'users' group whereas I'm only putting a sub-directory of /home/user2 into 'users'. /home/user2 remains owned by user2:user2.
The process I've carried out on my OP has literally been cut and pasted from my console, so you can see what I've done.
I can't fathom why that would be a problem, but when I get back in this evening, I'm going to try the solution above, and if it works then at least I'll know where the problem stems from, even if I don't understand why.
Yes - because when you make a folder using sudo you are creating with permissions 755 which is
user  rwx
group r_x
other r_x
When a user is created the home folder is with permissions 700 which is
user  rwx
group ___
other ___
That is why it is working just by creating a folder like you did.
To my limited knowledge to access a path it requires at least the execute bit to be able to cd to that folder.
OK. But I use the method you stated anyway, I have a /data/ shared directory.
...but I changed the ownership of the /home/user2/Music folder to {user2}:users and checked it with ls (as you can see above). The folder I'm trying to link to is
doesn't that mean that anyone in 'users' has full rwx permissions to it?
As I understand it Yes - but if you have no execute rights on the parent user2 folder you cannot cd into it.
You need to be able to cd into /home/user2 before you can cd into Music folder.
So ls -la /home/user2 will probably reveal permissions 700 which will prevent everybody but the user to cd into the folder.
I don't understand the permissions schema completely and I just checked my setup and I get a little confused
~ >>> ls -la /home
total 12
drwxr-xr-x  3 root root 4096 Jul  2 10:52 .
drwxr-xr-x 18 root root 4096 Jul 13 08:45 ..
drwxr-xr-x 33 fh   fh   4096 Jul 19 15:15 fh
Which seems to allow anyone to cd into the home folder of fh. Permissions is 755 which I must have set somehow. It could be a side effect of autologin - but that is just speculation as I don't remember how I created the initial user.
I just tested creating a user and it is as I expected - new user is created with permissions 700 which explicitly blocks anyone but the test user to enter the /home/test folder
~ >>> sudo useradd -m -U test
[sudo] password for fh:
~ >>> ls -la /home
total 16
drwxr-xr-x  4 root root 4096 Jul 19 16:04 .
drwx------  6 test test 4096 Jul 19 16:04 test
No it does not. It also depends on rx-permissions for users-group-members on all ancestor-directories.
So an alternative is to give everyone rx permission on /home/user2? I could do that as I only set up user2 as a kind of central storage user (I used a user rather than just a directory structure because I also wanted a 'default' desktop environment, so doing so seemed to kill two birds with one stone).
I'm away from the computer now but I'll try it when I get back.
It actually only requires the executable bit as illustrated below
A solution to your present setup is the following as illustrated with a terminal output.
Note that I am only setting the executable bit on the test user folder and inside the test user's homefolder I am setting ugo+rwx on a folder.
~ >>> ls -la /home
total 16
~ >>> sudo chmod go+x /home/test
~ >>> ls -la /home
total 16
drwx--x--x  6 test test 4096 Jul 19 16:04 test
~ >>> sudo mkdir /home/test/blindfold
~ >>> sudo chown test:test /home/test/blindfold
~ >>> sudo chmod ugo+rw /home/test/blindfold
~ >>> ls -la /home/test
ls: cannot open directory '/home/test': Permission denied
~ >>> cd /home/test/blindfold
/home/test/blindfold >>>
/home/test/blindfold >>> touch blindfold.txt
/home/test/blindfold >>> nano blindfold.txt
/home/test/blindfold >>> cd
~ >>> ls -la /home/test/blindfold
total 12
drwxrwxrwx 2 test test 4096 Jul 19 16:21 .
drwx--x--x 7 test test 4096 Jul 19 16:18 ..
-rw-r--r-- 1 fh   fh     12 Jul 19 16:22 blindfold.txt
~ >>> cat /home/test/blindfold/blindfold.txt
blindfolded
To summarize:
You only need to set the execute bit on the user2 folder to be able to access the user2/Music folder and also - as you did - set the go permissions on the Music folder - otherwise it won't work.
You access it blindfolded as you cannot see what else is available in the user2 folder.
Nice, I did not know that. Would suffice for symlinking etc.
