Hello, today I reinstalled my Gnome and while I was setting it up i saw that with libreoffice-still package comes GNUjump, do someone know why this is connected to LibreOffice product at all?
Thank you for your attention!
I dont see it in the depends …
pactree -r gnujump
will show us what, if anything, relies on gnujump
Am I allowed to upload pictures in here or to post link from imgur?
Why not just post the text output ?
Because it is not gnujump package, in the package manager, Installed section while i was scrolling to see something i randomly saw GNUjump app installed who says that it comes from libreoffice-still package
pactree -r gnujump ✔ 12s
error: package 'gnujump' not found
I’m not sure I understand …
That’s what I’m talking about.
I’m not sure whats going on there.
The text doesnt match of course. libreoffice-still and gnujump are different.
gnujump
is also at version 1.0.8-6, and is ~2.14mb …
so something is up with that listing.
Please make sure you are fully synced, updated, etc.
PS.
Oh. and maybe check if you have “Software Mode” enabled.
I did the following commands:
sudo pacman-mirrors --fasttrack
sudo pacman -Syyu
After that i rebooted and installed libreoffice-still →
sudo pacman -S libreoffice-still
Nothing strange I think.
Well thats all pacman.
Does pamac
still display incorrectly?
Its also entirely fine to prefer pacman. I do.
I dont use pamac, for AUR packages i use yay
And for software mode when i click it it shows the same stuff. Two times each Libre App + GNUjump.
pamac is the photo you shared.
I suppose some cache got corrupted somewhere.
pamac --force-refresh
might help.
okay, the GUI then, didn’t understand you properly, sorry!
This is what it gives me as response
pamac --force-refresh ✔
Available actions:
pamac --version
pamac --help, -h [action]
pamac search [options] <package(s)>
pamac list [options] <package(s)>
pamac info [options] <package(s)>
pamac install [options] <package(s)>
pamac reinstall [options] <package(s)>
pamac remove [options] [package(s)]
pamac checkupdates [options]
pamac update,upgrade [options]
pamac clone [options] <package(s)>
pamac build [options] [package(s)]
pamac clean [options]
Try:
pamac checkupdates --force-refresh
That’s all:
pamac checkupdates --force-refresh ✔
Safely check for updates without modifiying the databases
(Exit code is 100 if updates are available)
options:
--builddir <dir> : build directory (use with --devel), if no directory is given the one specified in
pamac.conf file is used
--aur, -a : also check updates in AUR
--no-aur : do not check updates in AUR
--quiet, -q : only print one line per update
--devel : also check development packages updates (use with --aur)
--no-devel : do not check development packages updates
My bad. The correct command:
pamac update --force-refresh
(Just tested it.)
Okay, so this is the output:
pamac update --force-refresh ✔
Preparing...
Authenticating as: user (user)
Password:
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
Refreshing AUR...
Nothing to do.
And still GNUjump is still there
