sxhkd - numeric keypad - assigning shortcuts?
Any one know how to assign a hotkey to the numbers on the numeric keypad?
I have tried:
super + KP_1
      bopp
Nothing. Strangley:
super + KP_Add
 	bopp
super + KP_Subtract
 	bopm
Works perfectly. Bopp(m) are just my scripts to toggle the opacity in Alacritty.
What does the xev say? Is numlock on?
xev reports KP_n and yes num lock is on.
KeyRelease event, serial 28, synthetic NO, window 0xbc00001,
    root 0x16a, subw 0x0, time 24176554, (122,267), root:(958,754),
    state 0x10, keycode 87 (keysym 0xffb1, KP_1), same_screen YES,
    XLookupString gives 1 bytes: (31) "1"
    XFilterEvent returns: False
Numlock is turned on with numlockx on.
:edit:
showkey returns 0x4f 0x3f
With numlock off - KP_End also works.
Seems like sxhkd ignores NumLock on status.
In my keyboard;
super + KP_Endsuper + KP_1
super + KP_Downsuper + KP_2
super + KP_Nextsuper + KP_3
And the keysyms do not appear to work either, bummer.
