I’ve been trying to transition from Plasma to i3, getting over some hiccups along the way, and now I’m stuck with the issue of my sound being broken. When logging into i3, the main sound sink disappears and is replaced with a dummy sink. Switching back to Plasma doesn’t even fix the issue, and I have to restart the machine and log directly into Plasma to get sound again.
I’ve quite a bit of reading on ALSA and Pulseaudio, and while I think I understand the systems a little better, I’m still unsure how to diagnose my problem deeper.
Output of some relevant commands in Plasma:
> aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC289 Analog [ALC289 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
> pacmd list-sinks
1 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause: (none)
priority: 9039
volume: front-left: 48397 / 74% / -7.90 dB, front-right: 48397 / 74% / -7.90 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 38.19 ms
max request: 7 KiB
max rewind: 7 KiB
monitor source: 0
sample spec: s16le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 1
configured latency: 40.00 ms; range is 0.50 .. 2000.00 ms
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC289 Analog"
alsa.id = "ALC289 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x603dbb0000 irq 184"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "34c8"
device.product.name = "Ice Lake-LP Smart Sound Technology Audio Controller"
device.string = "front:0"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 8
Tile Size: 65472
User Name: brooksvb
Host Name: manjystone
Server Name: pulseaudio
Server Version: 15.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Default Source: alsa_input.pci-0000_00_1f.3.analog-stereo
Cookie: d386:8a2b
Output of commands in i3:
> aplay -l
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
> pacmd list-sinks
* index: 0
driver: <module-null-sink.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 64880 / 99% / -0.26 dB
balance -0.01
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 344 KiB
max rewind: 344 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
module: 15
properties:
device.description = "Dummy Output"
device.class = "abstract"
device.icon_name = "audio-card"
> pactl info
Is Local: yes
Client Index: 7
Tile Size: 65472
User Name: brooksvb
Default Sink: auto_null
Default Source: auto_null.monitor
Cookie: 467c:7daa
Running pulseaudio -k; pulseaudio -vvvvvv
I encounter the following error:
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
So it seems that ALSA still sees the sound card fine, but for some reason Pulseaudio fails to load them.
Any advice is appreciated.
