Hello all.
I was just switching from hybrid to Nvidia driver. I noticed that the log-out process took longer time than usual (maybe 30 - 60 sec), which is usually instant.
I managed to log in, but the start screen after got stuck at half the way through loading. I managed to TTY into another session and start startx
Now flipping back to TTY1 results in going into my default DE, but the launcher is missing, and the SUPER key does not initiate launcher or do anything. I think I am able to start terminal there (didn’t check).
I am however able to use TTY2, but the scaling is weird (like it is 150% instead of 100%), and that is the lowest the scaling will go.
I am also noticing heavy usage of:
/usr/bin/kscreenlocker_greet --graceTime 5000 -- ksldfd 23
this process is using 100% of one core.
I am not able to use SUPER+TAB (I have reconfigured the command from Alt+TAB) to cycle through open programs.
NOTE: This might be a ONE-OFF, meaning rebooting will solve everything, but if there is any bug or something that needs to be addressed, I am happy to provide all the info needed.
Here are few outputs from terminal which I think could be relevant. I am sure you will correct me if I chose wrong.
inxi -Fazy
olividir@HP ~> inxi -Fazy
Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.9-x86_64
root=UUID=e653bc99-80b5-4a10-a82e-0db5407c2306 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8478 v: 70.57 serial: <filter> UEFI: Insyde v: F.22
date: 04/21/2020
ID-1: BAT1 charge: 26.5 Wh condition: 25.4/52.8 Wh (48%) volts: 12.8/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Unknown
Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 8192 KiB
bogomips: 36812
Speed: 3671 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 3684 2: 3673
3: 3642 4: 3690 5: 3666 6: 3632 7: 3669 8: 3625
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus ID: 1-5:5 chip ID: 05c8:03bc
Display: server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia display ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.7x14.4")
s-diag: 748mm (29.4")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.9.8-2-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 4000 bus ID: 02:00.0 chip ID: 10ec:b822
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
chip ID: 10ec:8168
Local Storage: total: 1.60 TiB used: 467.69 GiB (28.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000H1
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: CXB73H1Q scheme: GPT
ID-2: /dev/sda type: USB vendor: Western Digital model: WD My Passport 0740
size: 465.73 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1007 scheme: GPT
ID-3: /dev/sdb type: USB vendor: Toshiba model: External USB 3.0
size: 931.51 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 5438 scheme: MBR
ID-1: / raw size: 237.97 GiB size: 237.97 GiB (100.00%)
used: 53.24 GiB (22.4%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /home raw size: 237.97 GiB size: 237.97 GiB (100.00%)
System Temperatures: cpu: 59.0 C mobo: 29.8 C gpu: nvidia temp: 57 C
Processes: 310 Uptime: 4h 27m Memory: 15.53 GiB used: 2.68 GiB (17.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
pacman: 1378 lib: 385 flatpak: 0 Shell: fish v: 3.1.2 running in: konsole
inxi: 3.1.08
dmesg -l emerg,alert,crit,err,warn
[ 0.107528] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.107528] #5 #6 #7
[ 0.113351] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.169934] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.169938] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.169940] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20200717/dswload2-326)
[ 0.169942] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200717/psobject-220)
[ 0.256223] ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200717/psparse-529)
[ 0.256229] ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200717/uteval-68)
[ 0.257259] ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200717/psparse-529)
[ 0.257264] ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20200717/uteval-68)
[ 1.129861] pcieport 0000:00:1b.3: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1.129862] pcieport 0000:00:1b.3: device [8086:a343] error status/mask=00001000/00002000
[ 1.129864] pcieport 0000:00:1b.3: [12] Timeout
[ 1.135125] pcieport 0000:00:1b.3: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1.135127] pcieport 0000:00:1b.3: device [8086:a343] error status/mask=00001000/00002000
[ 1.135128] pcieport 0000:00:1b.3: [12] Timeout
[ 1.139486] pcieport 0000:00:1b.3: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1.139487] pcieport 0000:00:1b.3: device [8086:a343] error status/mask=00001000/00002000
[ 1.139488] pcieport 0000:00:1b.3: [12] Timeout
[ 1.151272] usb: port power management may be unreliable
[ 2.347835] vboxdrv: loading out-of-tree module taints kernel.
[ 2.373864] VBoxNetAdp: Successfully started.
[ 2.375896] VBoxNetFlt: Successfully started.
[ 2.679423] lis3lv02d: unknown sensor type 0x0
[ 2.679427] hp_accel: probe of HPQ6007:00 failed with error -22
[ 2.688714] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.688718] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.688719] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.688720] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.688946] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 2.689068] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 2.689087] wmi_bus wmi_bus-PNP0C14:04: WQBJ data block query control method not found
[ 2.774898] sd 6:0:0:0: [sda] No Caching mode page found
[ 2.774900] sd 6:0:0:0: [sda] Assuming drive cache: write through
[ 2.824402] r8169 0000:05:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 3.116921] FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 3.607379] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 3.900735] nvidia: module license 'NVIDIA' taints kernel.
[ 3.900736] Disabling lock debugging due to kernel taint
[ 3.990940] scsi 6:0:0:1: Wrong diagnostic page; asked for 1 got 8
[ 3.990942] scsi 6:0:0:1: Failed to get diagnostic page 0x1
[ 3.990943] scsi 6:0:0:1: Failed to bind enclosure -19
[ 4.060440] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.45.01 Thu Nov 5 23:03:56 UTC 2020
[ 5.398118] kauditd_printk_skb: 27 callbacks suppressed
[ 5.407073] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200717/nsarguments-59)
[ 10.515654] kauditd_printk_skb: 9 callbacks suppressed
[14869.904271] kauditd_printk_skb: 47 callbacks suppressed
cat /var/log/Xorg.0.log
[ 14863.367] (--) Log file renamed from "/var/log/Xorg.pid-35024.log" to "/var/log/Xorg.0.log"
[ 14863.367]
X.Org X Server 1.20.9
[ 14863.367] Build Operating System: Linux Manjaro Linux
[ 14863.367] Current Operating System: Linux HP 5.9.8-2-MANJARO #1 SMP PREEMPT Wed Nov 18 06:38:03 UTC 2020 x86_64
[ 14863.367] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.9-x86_64 root=UUID=e653bc99-80b5-4a10-a82e-0db5407c2306 rw rootflags=subvol=@ quiet udev.log_priority=3
[ 14863.367] Build Date: 17 November 2020 03:15:53PM
[ 14863.367]
[ 14863.367] Current version of pixman: 0.40.0
[ 14863.367] Before reporting problems, check http://wiki.x.org
[ 14863.367] Markers: (--) probed, (**) from config file, (==) default setting,
[ 14863.367] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Nov 22 13:36:16 2020
[ 14863.367] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 14863.367] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 14863.367] (==) ServerLayout "layout"
[ 14863.368] (**) |-->Screen "nvidia" (0)
[ 14863.368] (**) | |-->Monitor "<default monitor>"
[ 14863.368] (**) | |-->Device "nvidia"
[ 14863.368] (**) | |-->GPUDevice "intel"
[ 14863.368] (==) No monitor specified for screen "nvidia".
[ 14863.368] (==) Automatically adding devices
[ 14863.368] (==) Automatically enabling devices
[ 14863.368] (==) Automatically adding GPU devices
[ 14863.368] (==) Automatically binding GPU devices
[ 14863.368] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 14863.368] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 14863.368] Entry deleted from font path.
[ 14863.368] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 14863.368] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 14863.368] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 14863.368] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 14863.368] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 14863.368] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 14863.368] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 14863.368] (==) FontPath set to:
[ 14863.368] (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 14863.368] (II) The server relies on udev to provide the list of input devices.
[ 14863.368] (II) Module ABI versions:
[ 14863.368] X.Org ANSI C Emulation: 0.4
[ 14863.368] X.Org Video Driver: 24.1
[ 14863.368] X.Org XInput driver : 24.1
[ 14863.368] X.Org Server Extension : 10.0
[ 14863.368] (++) using VT number 1
[ 14863.368] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 14863.369] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 14863.369] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 14863.396] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 14863.396] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 14863.403] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 14863.403] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg/modules,/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 14863.404] (--) PCI:*(0@0:2:0) 8086:3e9b:103c:8478 rev 0, Mem @ 0xb2000000/16777216, 0x80000000/536870912, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
[ 14863.404] (--) PCI: (1@0:0:0) 10de:1c8d:103c:8478 rev 161, Mem @ 0xb3000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 14863.404] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 14863.404] (II) LoadModule: "glx"
[ 14863.404] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 14863.405] (II) Module glx: vendor="X.Org Foundation"
[ 14863.405] compiled for 1.20.9, module version = 1.0.0
[ 14863.405] ABI class: X.Org Server Extension, version 10.0
[ 14863.405] (II) LoadModule: "nvidia"
[ 14863.405] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 14863.405] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 14863.405] compiled for 1.6.99.901, module version = 1.0.0
[ 14863.405] Module class: X.Org Video Driver
[ 14863.405] (II) LoadModule: "modesetting"
[ 14863.405] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 14863.405] (II) Module modesetting: vendor="X.Org Foundation"
[ 14863.405] compiled for 1.20.9, module version = 1.20.9
[ 14863.405] ABI class: X.Org Video Driver, version 24.1
[ 14863.405] (II) NVIDIA dlloader X Driver 455.45.01 Thu Nov 5 23:01:05 UTC 2020
[ 14863.406] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 14863.406] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 14863.406] (II) Loading sub module "fb"
[ 14863.406] (II) LoadModule: "fb"
[ 14863.406] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 14863.406] (II) Module fb: vendor="X.Org Foundation"
[ 14863.406] compiled for 1.20.9, module version = 1.0.0
[ 14863.406] ABI class: X.Org ANSI C Emulation, version 0.4
[ 14863.406] (II) Loading sub module "wfb"
[ 14863.406] (II) LoadModule: "wfb"
[ 14863.406] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 14863.406] (II) Module wfb: vendor="X.Org Foundation"
[ 14863.406] (II) Loading sub module "ramdac"
[ 14863.406] (II) LoadModule: "ramdac"
[ 14863.406] (II) Module "ramdac" already built-in
[ 14863.419] (II) modeset(G0): using drv /dev/dri/card0
[ 14863.419] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 14863.419] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 14863.419] (==) NVIDIA(0): RGB weight 888
[ 14863.419] (==) NVIDIA(0): Default visual is TrueColor
[ 14863.419] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 14863.419] (**) Option "AllowNVIDIAGpuScreens"
[ 14863.419] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 14863.419] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 14863.419] (**) NVIDIA(0): Option "Coolbits" "28"
[ 14863.419] (**) NVIDIA(0): Enabling 2D acceleration
[ 14863.419] (II) Loading sub module "glxserver_nvidia"
[ 14863.419] (II) LoadModule: "glxserver_nvidia"
[ 14863.419] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 14863.424] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 14863.424] compiled for 1.6.99.901, module version = 1.0.0
[ 14863.424] Module class: X.Org Server Extension
[ 14863.424] (II) NVIDIA GLX Module 455.45.01 Thu Nov 5 22:58:18 UTC 2020
[ 14863.424] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 14863.425] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 14863.425] (--) NVIDIA(0): DFP-0
[ 14863.426] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 1050 (GP107-A) at PCI:1:0:0 (GPU-0)
[ 14863.426] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 14863.426] (--) NVIDIA(0): VideoBIOS: 86.07.68.00.13
[ 14863.426] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 14863.426] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 14863.426] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 14863.426] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 14863.426] (==) NVIDIA(0):
[ 14863.426] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 14863.426] (==) NVIDIA(0): will be used as the requested mode.
[ 14863.426] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 14863.426] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 14863.426] (II) NVIDIA(0): Validated MetaModes:
[ 14863.426] (II) NVIDIA(0): "NULL"
[ 14863.426] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 14863.426] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 14863.426] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 14863.426] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 14863.426] (==) modeset(G0): RGB weight 888
[ 14863.426] (==) modeset(G0): Default visual is TrueColor
[ 14863.426] (II) Loading sub module "glamoregl"
[ 14863.426] (II) LoadModule: "glamoregl"
[ 14863.426] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 14863.429] (II) Module glamoregl: vendor="X.Org Foundation"
[ 14863.429] compiled for 1.20.9, module version = 1.0.1
[ 14863.429] ABI class: X.Org ANSI C Emulation, version 0.4
[ 14863.489] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
[ 14863.489] (II) modeset(G0): glamor initialized
[ 14863.490] (II) modeset(G0): Output eDP-1-1 has no monitor section
[ 14863.490] (II) modeset(G0): Output DP-1-1 has no monitor section
[ 14863.496] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 14863.497] (II) modeset(G0): EDID for output eDP-1-1
[ 14863.497] (II) modeset(G0): Manufacturer: AUO Model: 23ed Serial#: 0
[ 14863.497] (II) modeset(G0): Year: 2016 Week: 0
[ 14863.497] (II) modeset(G0): EDID Version: 1.4
[ 14863.497] (II) modeset(G0): Digital Display Input
[ 14863.497] (II) modeset(G0): 6 bits per channel
[ 14863.497] (II) modeset(G0): Digital interface is DisplayPort
[ 14863.497] (II) modeset(G0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 14863.497] (II) modeset(G0): Gamma: 2.20
[ 14863.497] (II) modeset(G0): No DPMS capabilities specified
[ 14863.497] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:2:2
[ 14863.497] (II) modeset(G0): First detailed timing is preferred mode
[ 14863.497] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[ 14863.497] (II) modeset(G0): Display is continuous-frequency
[ 14863.497] (II) modeset(G0): redX: 0.575 redY: 0.346 greenX: 0.347 greenY: 0.572
[ 14863.497] (II) modeset(G0): blueX: 0.158 blueY: 0.117 whiteX: 0.313 whiteY: 0.329
[ 14863.497] (II) modeset(G0): Manufacturer's mask: 0
[ 14863.497] (II) modeset(G0): Supported detailed timing:
[ 14863.497] (II) modeset(G0): clock: 141.0 MHz Image Size: 344 x 193 mm
[ 14863.497] (II) modeset(G0): h_active: 1920 h_sync: 2028 h_sync_end 2076 h_blank_end 2086 h_border: 0
[ 14863.497] (II) modeset(G0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1126 v_border: 0
[ 14863.497] (II) modeset(G0): clock: 94.0 MHz Image Size: 344 x 193 mm
[ 14863.497] (II) modeset(G0): Unknown vendor-specific block 2
[ 14863.497] (II) modeset(G0): EDID (in hex):
[ 14863.497] (II) modeset(G0): 00ffffffffffff0006afed2300000000
[ 14863.497] (II) modeset(G0): 001a010495221378116e859358589228
[ 14863.497] (II) modeset(G0): 1e505400000001010101010101010101
[ 14863.497] (II) modeset(G0): 010101010101143780a670382e406c30
[ 14863.497] (II) modeset(G0): aa0058c110000018b82480a670382e40
[ 14863.497] (II) modeset(G0): 6c30aa0058c110000018000000000000
[ 14863.497] (II) modeset(G0): 00000000000000000000000000000002
[ 14863.497] (II) modeset(G0): 001048ff0f3c6e0f16286e2020200033
[ 14863.497] (II) modeset(G0): Printing probed modes for output eDP-1-1
[ 14863.497] (II) modeset(G0): Modeline "1920x1080"x60.0 141.00 1920 2028 2076 2086 1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[ 14863.497] (II) modeset(G0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1920x1080"x40.0 94.00 1920 2028 2076 2086 1080 1090 1100 1126 -hsync -vsync (45.1 kHz e)
[ 14863.497] (II) modeset(G0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 14863.497] (II) modeset(G0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 14863.498] (II) modeset(G0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 14863.498] (II) modeset(G0): EDID for output DP-1-1
[ 14863.504] (II) modeset(G0): EDID for output HDMI-1-1
[ 14863.504] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 14863.504] (==) modeset(G0): DPI set to (96, 96)
[ 14863.504] (II) Loading sub module "fb"
[ 14863.504] (II) LoadModule: "fb"
[ 14863.504] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 14863.504] (II) Module fb: vendor="X.Org Foundation"
[ 14863.504] compiled for 1.20.9, module version = 1.0.0
[ 14863.504] ABI class: X.Org ANSI C Emulation, version 0.4
[ 14863.504] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 14863.504] (II) NVIDIA: access.
[ 14863.511] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 14863.511] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 14863.511] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 14863.511] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 14863.511] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 14863.511] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 14863.511] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 14863.511] (II) NVIDIA(0): Config Options in the README.
[ 14863.532] (II) NVIDIA(0): Setting mode "NULL"
[ 14863.550] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 14863.559] (==) NVIDIA(0): Backing store enabled
[ 14863.559] (==) NVIDIA(0): Silken mouse disabled
[ 14863.559] (==) NVIDIA(0): DPMS enabled
[ 14863.559] (II) Loading sub module "dri2"
[ 14863.559] (II) LoadModule: "dri2"
[ 14863.559] (II) Module "dri2" already built-in
[ 14863.559] (II) NVIDIA(0): [DRI2] Setup complete
[ 14863.559] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 14863.564] (==) modeset(G0): Backing store enabled
[ 14863.564] (==) modeset(G0): Silken mouse disabled
[ 14863.635] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 14863.635] (==) modeset(G0): DPMS enabled
[ 14863.635] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 14863.635] (II) modeset(G0): [DRI2] Setup complete
[ 14863.635] (II) modeset(G0): [DRI2] DRI driver: iris
[ 14863.635] (II) modeset(G0): [DRI2] VDPAU driver: va_gl
[ 14863.635] (II) Initializing extension Generic Event Extension
[ 14863.636] (II) Initializing extension SHAPE
[ 14863.636] (II) Initializing extension MIT-SHM
[ 14863.636] (II) Initializing extension XInputExtension
[ 14863.636] (II) Initializing extension XTEST
[ 14863.636] (II) Initializing extension BIG-REQUESTS
[ 14863.636] (II) Initializing extension SYNC
[ 14863.636] (II) Initializing extension XKEYBOARD
[ 14863.636] (II) Initializing extension XC-MISC
[ 14863.636] (II) Initializing extension SECURITY
[ 14863.636] (II) Initializing extension XFIXES
[ 14863.636] (II) Initializing extension RENDER
[ 14863.636] (II) Initializing extension RANDR
[ 14863.636] (II) Initializing extension COMPOSITE
[ 14863.637] (II) Initializing extension DAMAGE
[ 14863.637] (II) Initializing extension MIT-SCREEN-SAVER
[ 14863.637] (II) Initializing extension DOUBLE-BUFFER
[ 14863.637] (II) Initializing extension RECORD
[ 14863.637] (II) Initializing extension DPMS
[ 14863.637] (II) Initializing extension Present
[ 14863.637] (II) Initializing extension DRI3
[ 14863.637] (II) Initializing extension X-Resource
[ 14863.637] (II) Initializing extension XVideo
[ 14863.637] (II) Initializing extension XVideo-MotionCompensation
[ 14863.637] (II) Initializing extension GLX
[ 14863.637] (II) Indirect GLX disabled.
[ 14863.637] (II) GLX: Another vendor is already registered for screen 0
[ 14863.637] (II) Initializing extension XFree86-VidModeExtension
[ 14863.637] (II) Initializing extension XFree86-DGA
[ 14863.637] (II) Initializing extension XFree86-DRI
[ 14863.637] (II) Initializing extension DRI2
[ 14863.638] (II) Initializing extension NV-GLX
[ 14863.638] (II) Initializing extension NV-CONTROL
[ 14864.167] (II) modeset(G0): Damage tracking initialized
[ 14864.193] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 14864.193] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14864.193] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 14864.193] (**) Power Button: Applying InputClass "system-keyboard"
[ 14864.193] (II) LoadModule: "libinput"
[ 14864.193] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 14864.194] (II) Module libinput: vendor="X.Org Foundation"
[ 14864.194] compiled for 1.20.8, module version = 0.30.0
[ 14864.194] Module class: X.Org XInput Driver
[ 14864.194] ABI class: X.Org XInput driver, version 24.1
[ 14864.194] (II) Using input driver 'libinput' for 'Power Button'
[ 14864.194] (**) Power Button: always reports core events
[ 14864.194] (**) Option "Device" "/dev/input/event2"
[ 14864.194] (**) Option "_source" "server/udev"
[ 14864.195] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 14864.195] (II) event2 - Power Button: device is a keyboard
[ 14864.195] (II) event2 - Power Button: device removed
[ 14864.220] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 14864.220] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 14864.220] (**) Option "xkb_layout" "is"
[ 14864.233] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 14864.233] (II) event2 - Power Button: device is a keyboard
[ 14864.233] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 14864.233] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 14864.233] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 14864.233] (**) Video Bus: Applying InputClass "system-keyboard"
[ 14864.233] (II) Using input driver 'libinput' for 'Video Bus'
[ 14864.233] (**) Video Bus: always reports core events
[ 14864.233] (**) Option "Device" "/dev/input/event8"
[ 14864.233] (**) Option "_source" "server/udev"
[ 14864.234] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 14864.234] (II) event8 - Video Bus: device is a keyboard
[ 14864.234] (II) event8 - Video Bus: device removed
[ 14864.280] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input10/event8"
[ 14864.280] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 14864.280] (**) Option "xkb_layout" "is"
[ 14864.281] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 14864.281] (II) event8 - Video Bus: device is a keyboard
[ 14864.281] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[ 14864.281] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 14864.281] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 14864.281] (**) Video Bus: Applying InputClass "system-keyboard"
[ 14864.281] (II) Using input driver 'libinput' for 'Video Bus'
[ 14864.281] (**) Video Bus: always reports core events
[ 14864.281] (**) Option "Device" "/dev/input/event7"
[ 14864.281] (**) Option "_source" "server/udev"
[ 14864.282] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 14864.282] (II) event7 - Video Bus: device is a keyboard
[ 14864.282] (II) event7 - Video Bus: device removed
[ 14864.347] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input9/event7"
[ 14864.347] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 14864.347] (**) Option "xkb_layout" "is"
[ 14864.348] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 14864.348] (II) event7 - Video Bus: device is a keyboard
[ 14864.348] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 14864.348] (II) No input driver specified, ignoring this device.
[ 14864.348] (II) This device may have been added with another device file.
[ 14864.348] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 14864.348] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14864.348] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 14864.348] (**) Power Button: Applying InputClass "system-keyboard"
[ 14864.348] (II) Using input driver 'libinput' for 'Power Button'
[ 14864.348] (**) Power Button: always reports core events
[ 14864.348] (**) Option "Device" "/dev/input/event1"
[ 14864.348] (**) Option "_source" "server/udev"
[ 14864.349] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 14864.349] (II) event1 - Power Button: device is a keyboard
[ 14864.349] (II) event1 - Power Button: device removed
[ 14864.373] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 14864.373] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 14864.373] (**) Option "xkb_layout" "is"
[ 14864.374] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 14864.374] (II) event1 - Power Button: device is a keyboard
[ 14864.375] (II) config/udev: Adding input device MOSART Semi. USB Device (/dev/input/event17)
[ 14864.375] (**) MOSART Semi. USB Device: Applying InputClass "evdev pointer catchall"
[ 14864.375] (**) MOSART Semi. USB Device: Applying InputClass "libinput pointer catchall"
[ 14864.375] (II) Using input driver 'libinput' for 'MOSART Semi. USB Device'
[ 14864.375] (**) MOSART Semi. USB Device: always reports core events
[ 14864.375] (**) Option "Device" "/dev/input/event17"
[ 14864.375] (**) Option "_source" "server/udev"
[ 14864.431] (II) event17 - MOSART Semi. USB Device: is tagged by udev as: Mouse
[ 14864.431] (II) event17 - MOSART Semi. USB Device: device is a pointer
[ 14864.431] (II) event17 - MOSART Semi. USB Device: device removed
[ 14864.493] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:062A:410C.0001/input/input18/event17"
[ 14864.493] (II) XINPUT: Adding extended input device "MOSART Semi. USB Device" (type: MOUSE, id 10)
[ 14864.493] (**) Option "AccelerationScheme" "none"
[ 14864.493] (**) MOSART Semi. USB Device: (accel) selected scheme none/0
[ 14864.493] (**) MOSART Semi. USB Device: (accel) acceleration factor: 2.000
[ 14864.493] (**) MOSART Semi. USB Device: (accel) acceleration threshold: 4
[ 14864.551] (II) event17 - MOSART Semi. USB Device: is tagged by udev as: Mouse
[ 14864.551] (II) event17 - MOSART Semi. USB Device: device is a pointer
[ 14864.551] (II) config/udev: Adding input device MOSART Semi. USB Device (/dev/input/mouse1)
[ 14864.551] (II) No input driver specified, ignoring this device.
[ 14864.551] (II) This device may have been added with another device file.
[ 14864.552] (II) config/udev: Adding input device HP Wide Vision HD Camera: HP Wi (/dev/input/event18)
[ 14864.552] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "evdev keyboard catchall"
[ 14864.552] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "libinput keyboard catchall"
[ 14864.552] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "system-keyboard"
[ 14864.552] (II) Using input driver 'libinput' for 'HP Wide Vision HD Camera: HP Wi'
[ 14864.552] (**) HP Wide Vision HD Camera: HP Wi: always reports core events
[ 14864.552] (**) Option "Device" "/dev/input/event18"
[ 14864.552] (**) Option "_source" "server/udev"
[ 14864.553] (II) event18 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 14864.553] (II) event18 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 14864.553] (II) event18 - HP Wide Vision HD Camera: HP Wi: device removed
[ 14864.627] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input19/event18"
[ 14864.627] (II) XINPUT: Adding extended input device "HP Wide Vision HD Camera: HP Wi" (type: KEYBOARD, id 11)
[ 14864.627] (**) Option "xkb_layout" "is"
[ 14864.628] (II) event18 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 14864.628] (II) event18 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 14864.628] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event9)
[ 14864.628] (II) No input driver specified, ignoring this device.
[ 14864.628] (II) This device may have been added with another device file.
[ 14864.628] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event10)
[ 14864.628] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event11)
[ 14864.629] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event12)
[ 14864.629] (II) No input driver specified, ignoring this device.
[ 14864.629] (II) This device may have been added with another device file.
[ 14864.629] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event13)
[ 14864.629] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event14)
[ 14864.629] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event15)
[ 14864.630] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 14864.630] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 14864.630] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 14864.630] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 14864.630] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 14864.630] (**) AT Translated Set 2 keyboard: always reports core events
[ 14864.630] (**) Option "Device" "/dev/input/event3"
[ 14864.630] (**) Option "_source" "server/udev"
[ 14864.630] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 14864.631] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 14864.631] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 14864.667] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 14864.667] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 14864.667] (**) Option "xkb_layout" "is"
[ 14864.667] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 14864.668] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 14864.668] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event6)
[ 14864.668] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 14864.668] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 14864.668] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[ 14864.668] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 14864.668] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 14864.668] (**) Option "Device" "/dev/input/event6"
[ 14864.668] (**) Option "_source" "server/udev"
[ 14864.669] (II) event6 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 14864.670] (II) event6 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 14864.670] (II) event6 - ETPS/2 Elantech Touchpad: device removed
[ 14864.733] (**) Option "Tapping" "on"
[ 14864.733] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event6"
[ 14864.733] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 13)
[ 14864.734] (**) Option "AccelerationScheme" "none"
[ 14864.734] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 14864.734] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 14864.734] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 14864.735] (II) event6 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 14864.736] (II) event6 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 14864.736] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 14864.736] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[ 14864.736] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 14864.736] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 14864.736] (**) Option "Device" "/dev/input/mouse0"
[ 14864.736] (**) Option "_source" "server/udev"
[ 14864.787] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 14864.787] (EE) libinput: ETPS/2 Elantech Touchpad: Failed to create a device for /dev/input/mouse0
[ 14864.787] (EE) PreInit returned 2 for "ETPS/2 Elantech Touchpad"
[ 14864.787] (II) UnloadModule: "libinput"
[ 14864.787] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 14864.787] (II) No input driver specified, ignoring this device.
[ 14864.787] (II) This device may have been added with another device file.
[ 14864.787] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event4)
[ 14864.787] (**) HP Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[ 14864.787] (**) HP Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[ 14864.787] (**) HP Wireless hotkeys: Applying InputClass "system-keyboard"
[ 14864.787] (II) Using input driver 'libinput' for 'HP Wireless hotkeys'
[ 14864.787] (**) HP Wireless hotkeys: always reports core events
[ 14864.787] (**) Option "Device" "/dev/input/event4"
[ 14864.787] (**) Option "_source" "server/udev"
[ 14864.788] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 14864.788] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 14864.788] (II) event4 - HP Wireless hotkeys: device removed
[ 14864.853] (**) Option "config_info" "udev:/sys/devices/virtual/input/input5/event4"
[ 14864.853] (II) XINPUT: Adding extended input device "HP Wireless hotkeys" (type: KEYBOARD, id 14)
[ 14864.853] (**) Option "xkb_layout" "is"
[ 14864.854] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 14864.854] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 14864.854] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event16)
[ 14864.854] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 14864.854] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 14864.854] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[ 14864.854] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 14864.854] (**) HP WMI hotkeys: always reports core events
[ 14864.854] (**) Option "Device" "/dev/input/event16"
[ 14864.854] (**) Option "_source" "server/udev"
[ 14864.855] (II) event16 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 14864.855] (II) event16 - HP WMI hotkeys: device is a keyboard
[ 14864.855] (II) event16 - HP WMI hotkeys: device removed
[ 14864.907] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event16"
[ 14864.907] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 15)
[ 14864.907] (**) Option "xkb_layout" "is"
[ 14864.907] (II) event16 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 14864.907] (II) event16 - HP WMI hotkeys: device is a keyboard
[ 14864.954] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 14864.954] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 14864.954] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 14870.574] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 14870.574] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 14870.574] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 14955.916] (II) event2 - Power Button: device removed
[ 14955.945] (II) event8 - Video Bus: device removed
[ 14955.984] (II) event7 - Video Bus: device removed
[ 14956.028] (II) event1 - Power Button: device removed
[ 14956.048] (II) event17 - MOSART Semi. USB Device: device removed
[ 14956.097] (II) event18 - HP Wide Vision HD Camera: HP Wi: device removed
[ 14956.148] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 14956.174] (II) event6 - ETPS/2 Elantech Touchpad: device removed
[ 14956.228] (II) event4 - HP Wireless hotkeys: device removed
[ 14956.281] (II) event16 - HP WMI hotkeys: device removed
[ 14977.059] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 14977.059] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 14977.059] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 14977.068] (II) NVIDIA(0): Setting mode "NULL"
[ 14977.071] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 14977.071] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 14977.071] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 14977.071] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 14977.071] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 14977.071] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 14977.071] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 14977.071] (II) NVIDIA(0): Config Options in the README.
[ 14977.155] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 14977.156] (II) event2 - Power Button: device is a keyboard
[ 14977.157] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 14977.157] (II) event8 - Video Bus: device is a keyboard
[ 14977.158] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 14977.158] (II) event7 - Video Bus: device is a keyboard
[ 14977.159] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 14977.159] (II) event1 - Power Button: device is a keyboard
[ 14977.160] (II) event17 - MOSART Semi. USB Device: is tagged by udev as: Mouse
[ 14977.160] (II) event17 - MOSART Semi. USB Device: device is a pointer
[ 14977.161] (II) event18 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 14977.161] (II) event18 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 14977.162] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 14977.162] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 14977.164] (II) event6 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 14977.165] (II) event6 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 14977.165] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 14977.165] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 14977.166] (II) event16 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 14977.166] (II) event16 - HP WMI hotkeys: device is a keyboard
[ 14982.729] (II) event2 - Power Button: device removed
[ 14982.761] (II) event8 - Video Bus: device removed
[ 14982.774] (II) event7 - Video Bus: device removed
[ 14982.801] (II) event1 - Power Button: device removed
[ 14982.827] (II) event17 - MOSART Semi. USB Device: device removed
[ 14982.868] (II) event18 - HP Wide Vision HD Camera: HP Wi: device removed
[ 14982.895] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 14982.921] (II) event6 - ETPS/2 Elantech Touchpad: device removed
[ 14982.948] (II) event4 - HP Wireless hotkeys: device removed
[ 14982.988] (II) event16 - HP WMI hotkeys: device removed
[ 14985.775] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 14985.775] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 14985.775] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 14985.784] (II) NVIDIA(0): Setting mode "NULL"
[ 14985.787] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 14985.787] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 14985.787] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 14985.787] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 14985.787] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 14985.787] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 14985.787] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 14985.787] (II) NVIDIA(0): Config Options in the README.
[ 14985.868] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 14985.868] (II) event2 - Power Button: device is a keyboard
[ 14985.869] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 14985.869] (II) event8 - Video Bus: device is a keyboard
[ 14985.870] (II) event7 - Video Bus: is tagged by udev as: Keyboard
[ 14985.870] (II) event7 - Video Bus: device is a keyboard
[ 14985.871] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 14985.871] (II) event1 - Power Button: device is a keyboard
[ 14985.872] (II) event17 - MOSART Semi. USB Device: is tagged by udev as: Mouse
[ 14985.872] (II) event17 - MOSART Semi. USB Device: device is a pointer
[ 14985.873] (II) event18 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 14985.874] (II) event18 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 14985.874] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 14985.875] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 14985.876] (II) event6 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 14985.877] (II) event6 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 14985.878] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 14985.878] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 14985.879] (II) event16 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 14985.879] (II) event16 - HP WMI hotkeys: device is a keyboard
[ 15022.452] (II) event2 - Power Button: device removed
[ 15022.494] (II) event8 - Video Bus: device removed
[ 15022.520] (II) event7 - Video Bus: device removed
[ 15022.560] (II) event1 - Power Button: device removed
[ 15022.587] (II) event17 - MOSART Semi. USB Device: device removed
[ 15022.613] (II) event18 - HP Wide Vision HD Camera: HP Wi: device removed
[ 15022.640] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 15022.667] (II) event6 - ETPS/2 Elantech Touchpad: device removed
[ 15022.694] (II) event4 - HP Wireless hotkeys: device removed
[ 15022.720] (II) event16 - HP WMI hotkeys: device removed
