Switched to Unsupported Branch, Now System Seems Stuck On It
Hi All,
Learning experience here so please pardon my flubs. I was hoping to get my hands on Kodi 21 (long story short, another system of mine auto updated, not on Manjaro, now I have two different SQL backends that’s not ideal). Anyways, used these instructions Switching Branches - Manjaro to switch branch. After switching, I found out that I can’t just upgrade Kodi (lots of depencies), decided at this point to switch back to the Stable branch. Unfortunately, it appears like I still have a cache or something of the other branch because I have 552 updates and they don’t appear to be the Stable branch updates.
When I switched back to stable I did this:
sudo pacman-mirrors --api --set-branch stable
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syu
Is there something else I have to do to make sure I’m running stable only? I haven’t actually done any upgrades, I just see the long list. Thanks!
Please go back and read the text in the post you linked to till the end.
… “Questions”
Thank you. You’d think 20 years of Linux would teach me to reach until the end . . .
I still have over 500 updates…maybe there was just a roll into stable (crossing fingers).
There was. Yesterday, I think. It depends on when you switched to unstable whether there are now also a lot of updates when going back to stable.
sudo pacman -Syuu
will downgrade to the now newest versions which might not have been there when you went from stable up to unstable.
