Hello all,
Due to heavy the nature of my work I need to run very heavy GPU ML computations on my desktop which makes my whole screen lag.
For this reason I have thought of maybe using the IGPU on my intel cpu for everyday needs while having the gpu only for the heavy cuda applications.
So my question is how can i switch from using the gpu to the igpu? I have tried installing video-linux
but it didnt do anything (yes i have plugged the hdmi cable to the igpu), and i dont know how to proceed from here.
Thanks!
pobrn
30 April 2021 19:54
2
video-hybrid-intel-nvidia-prime is what you want. After that, I recommend installing optimus-manager
because that way you’ll be able to switch back and forth between the nvidia and the intel GPUs with relative ease should you want that. Please also post the output of mhwd -li
and inxi -Gazy
Thanks for the suggestion, but I dont think I want optimus since i will never use the “graphics displaying” capabilities of my GPU, just it’s computational power.
From my understand prime lets you run some applications, say steam, through the GPU while others more “light” with the iGPU.
[delta@x ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
[delta@x ~]$ inxi -Gazy
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1b81 class-ID: 0300
Device-2: Microsoft LifeCam VX-2000 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-3:2 chip-ID: 045e:0761 class-ID: 0102
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
pobrn
30 April 2021 20:20
4
There doesn’t seem to be another video card. Are you sure there’s one? Or is it disabled?
The other video card only gets enabled when a display is plugged into it, which I cant do since by doing that it results into black screen. Missing drivers or something.
If I plug the hdmi cable to the iGPU then it will show up, but I can only have a tty.
pobrn
30 April 2021 22:46
6
Well, that is interesting… and strange. Can you determine why it results in a black screen? Anything in the journal?
What is its PCI address? If you have that, you should be able to replace the current Xorg video settings with the following:
Section "ServerLayout"
Identifier "layout"
Screen 0 "integrated"
EndSection
Section "Device"
Identifier "integrated"
Driver "modesetting"
BusID "PCI:<PCI ADDRESS HERE>"
EndSection
Section "Screen"
Device "integrated"
EndSection
(e.g. /etc/X11/xorg.conf.d/10-integrated.conf
My guess is the black screen is caused by driver mismatch since last time I tried this I had 2 drivers installed, on the nvidia and the intel one. I guess the nvidia display is disabled if the iGPU gets enabled?
Below are some outputs of when the iGPU is enabled.
> PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0300:10de:1b81)
Display controller nVidia Corporation GP104 [GeForce GTX 1070]
> INSTALLED:
ATTACHED: PCI
VERSION: 2020.11.30
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302
VENDORIDS: 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2020.11.30
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 6
FREEDRIVER: false
DEPENDS: video-modesetting
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2020.11.30
INFO: Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2020.11.30
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2020.11.30
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:5912)
Display controller Intel Corporation HD Graphics 630
> AVAILABLE:
ATTACHED: PCI
VERSION: 2020.11.30
PRIORITY: 6
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2020.11.30
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0300
Device-2: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
Device-3: Microsoft LifeCam VX-2000 type: USB driver: snd-usb-audio,uvcvideo
Display: server: X.org 1.20.11 driver: loaded: nvidia tty: 240x67
Message: Advanced graphics data unavailable in console. Try -G --display
