I am running KDE desktop, and have Bose QC35 II bluetooth headphones.
To use the built-in mic for Zoom meetings I need to manually switch the profile to HSP. I do this from sound settings.
The question is whether I can configure pipewire to detect video meetings and switch the profile automatically, or maybe there is an easy script/command that I can run to switch it manually. In that case, I would ideally want something that I can pin to the panel for easy one-click access.
inxi -F
Host: shmuel-manjaro Kernel: 5.15.7-1-MANJARO x86_64
bits: 64 Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A
v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 1203 date: 10/10/2019
Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP
cache: L2: 2 MiB
Speed (MHz): avg: 1100 min/max: 800/4700 cores: 1: 1200
2: 1200 3: 1200 4: 1201 5: 1200 6: 1187 7: 817 8: 800
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630]
driver: i915 v: kernel
Device-2: Microdia USB Live camera type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.org 1.21.1.2 driver:
loaded: modesetting resolution: <missing: xdpyinfo>
Message: Unable to show advanced data. Required tool
glxinfo missing.
Device-1: Intel 200 Series PCH HD Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit
Ethernet
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full
mac: a8:5e:45:e2:87:3c
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode)
type: USB driver: btusb
Report: rfkill ID: hci0 state: up
address: see --recommends
Local Storage: total: 2.26 TiB used: 848.3 GiB (36.7%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G
ID-2: /dev/sdb vendor: Toshiba model: HDWD120
ID-1: / size: 53.42 GiB used: 17.26 GiB (32.3%) fs: btrfs
dev: /dev/sda5
ID-2: /boot/efi size: 299.6 MiB used: 572 KiB (0.2%)
fs: vfat dev: /dev/sda6
ID-3: /home size: 53.42 GiB used: 17.26 GiB (32.3%)
fs: btrfs dev: /dev/sda5
ID-4: /var/log size: 53.42 GiB used: 17.26 GiB (32.3%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 302 Uptime: 36m Memory: 15.49 GiB
used: 7.74 GiB (50.0%) Shell: Bash inxi: 3.3.11
