I have managed to install the new kernel however after a few reboots the system is still using the old one, and there is no option to remove the old one either (doing so I thought might “trigger” the system to use the new one, but that is moot as I cannot uninstall the old one anyway).
why do you have installed ‘rt’ kernels? do you need them for specific purpose?
if you install newer kernel, you should automatically boot with it… if not, you can tap esc during boot, and the grub menu should appear, and in there in advanced options you select the kernel you want, but dont select the fallback one … or you can do this: sudo nano /etc/default/grub
and edit this line: GRUB_TIMEOUT_STYLE=hidden
to look like this: GRUB_TIMEOUT_STYLE=menu
then press ctrl+x to save the file
run this command: sudo update-grub
reboot and the grub menu will appear automatically
I see you are testing kernels. Its a good idea to have two installed in case of a bad upgrade or bugs. Imho a LTS kernel works best as a backup, say 5.15.
Recent kernels should not need RT anymore, only threadirqs kernel command line required. Of course your actual needs might be tougher that you actually need a RT kernel, just trying to give a suggestion. Ardour and Guitarix run responsively with ~2ms latency on my system.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=“Manjaro”
GRUB_CMDLINE_LINUX_DEFAULT=“quiet apparmor=1 security=apparmor udev.log_priority=3”
GRUB_CMDLINE_LINUX="cpufreq.default_governor=performance threadirqs"Generating grub configuration file …
GRUB_DISABLE_OS_PROBER=false
Found linux image: /boot/vmlinuz-5.19-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.19-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.19-rt-x86_64-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
Adding boot menu entry for UEFI Firmware Settings …
it looks like /etc/default/grub has got mixed up some output messages from the terminal.
Could you have pressed the middle mouse button and pasted output from the terminal in there?
Do you have a backup for that file before editing?
here is mine:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=6
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="resume=UUID=1234 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=1600x900
GRUB_GFXPAYLOAD_LINUX=1600x900
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro-smfont/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
Generating grub configuration file … and the lines after GRUB_DISABLE_OS_PROBER=false don’t like like they belong in a grub config file.
Yeah they did seem a bit incongruous but it was all a default Manjaro Install…this is the first time I’ve even looked at the grub, let alone edited it!!
EDIT: Nope that doesn’t work either…Unless it is not the ESC key to press?? If it is, then none of the solutions offered enable me to choose the Kernel.
