Hi everyone,
I was experiencing extremely frequent irrecoverable system freezes on my freshly installed Manjaro Gnome system. One day I was just checking the details of all my partitions and found that my swap status was “Not Active”. So I checked the fstab file and sure enough, there wasn’t an entry for the swap partition. I added the swap partition to the fstab file and the freezes haven’t occurred since. BTW, my swap partition is on a different disk compared to my other partitions so that might have something to do with this but I can confirm that I correctly chose, labelled and formatted the swap partition during setup.
$ sudo inxi -Fxxxz
System: Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Console: pty pts/0 wm: gnome-shell DM: GDM 41.0
Machine: Type: Convertible System: HP product: HP Pavilion x360 Convertible 14m-dw1xxx v: N/A serial: <filter> Chassis:
type: 31 serial: <filter>
Mobo: HP model: 87F4 v: 39.32 serial: <filter> UEFI: AMI v: F.36 date: 08/30/2021
Battery: ID-1: BAT0 charge: 35.8 Wh (100.0%) condition: 35.8/35.8 Wh (100.0%) volts: 12.8 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Unknown cycles: 354
Device-1: hid-0018:04F3:2B55.0002-battery model: ELAN2513:00 04F3:2B55 serial: N/A charge: N/A status: N/A
CPU: Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP arch: Tiger Lake rev: 1 cache:
L1: 320 KiB L2: 5 MiB L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38720
Speed: 1070 MHz min/max: 400/4200 MHz volts: 0.7 V ext-clock: 100 MHz Core speeds (MHz): 1: 1170 2: 1070 3: 1167
4: 1127 5: 1105 6: 1068 7: 1257 8: 1253
Graphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard driver: i915 v: kernel
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 3-6:3 chip-ID: 04f2:b6bb
Display: server: X.org 1.21.1.1 compositor: gnome-shell driver: loaded: modesetting alternate: fbdev,vesa
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5 chip-ID: 8087:0026 class-ID: e001
RAID: Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0
chip-ID: 8086:9a0b rev: class-ID: 0104
Drives: Local Storage: total: 504.19 GiB used: 222.18 GiB (44.1%)
ID-1: /dev/nvme0n1 vendor: Intel model: HBRPEKNX0202AH size: 476.94 GiB speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: HPS2 temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Intel model: HBRPEKNX0202AHO size: 27.25 GiB speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: HPS3 temp: 54.9 C scheme: GPT
Partition: ID-1: / size: 475.93 GiB used: 221.8 GiB (46.6%) fs: btrfs dev: /dev/dm-0
mapped: luks-b52f8539-8a9e-4a29-b840-4b91bad920c6
ID-2: /boot/efi size: 1022 MiB used: 712 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2
ID-3: /home size: 475.93 GiB used: 221.8 GiB (46.6%) fs: btrfs dev: /dev/dm-0
ID-4: /var/log size: 475.93 GiB used: 221.8 GiB (46.6%) fs: btrfs dev: /dev/dm-0
Swap: ID-1: swap-1 type: partition size: 27.25 GiB used: 384.8 MiB (1.4%) priority: -2 dev: /dev/nvme1n1p1
Sensors: System Temperatures: cpu: 55.0 C mobo: 0.0 C
Info: Processes: 341 Uptime: 44m wakeups: 2923 Memory: 7.41 GiB used: 3.62 GiB (48.9%) Init: systemd v: 249 Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1606 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.12
running-in: gnome-terminal inxi: 3.3.09
Thanks
