drag to the right to see
fdisk -l
Disk /dev/nvme0n1: 953.87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: PC601A NVMe SK hynix 1TB
Disklabel type: gpt
Disk identifier: BDA4A58F-387A-4CBD-9795-FD63F95896C0
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 206847 204800 100M EFI System
/dev/nvme0n1p2 206848 1462479344 1462272497 697.3G Microsoft basic data
/dev/nvme0n1p3 1999354544 2000405167 1050624 513M Windows recovery environment
/dev/nvme0n1p4 1462479345 1463529471 1050127 512.8M EFI System
/dev/nvme0n1p5 1463529472 1467723775 4194304 2G Linux swap
/dev/nvme0n1p6 1467723776 1598795775 131072000 62.5G Linux filesystem
/dev/nvme0n1p7 1598795776 1999354543 400558768 191G Linux filesystem
Partition table entries are not in disk order.
Disk /dev/loop0: 55.56 MiB, 58261504 bytes, 113792 sectors
Disk /dev/loop1: 113.99 MiB, 119525376 bytes, 233448 sectors
Disk /dev/loop2: 4 KiB, 4096 bytes, 8 sectors
Disk /dev/loop4: 68 KiB, 69632 bytes, 136 sectors
Disk /dev/loop3: 61.96 MiB, 64966656 bytes, 126888 sectors
Disk /dev/loop6: 114.93 MiB, 120508416 bytes, 235368 sectors
Disk /dev/loop8: 55.56 MiB, 58261504 bytes, 113792 sectors
Disk /dev/loop7: 164.76 MiB, 172761088 bytes, 337424 sectors
Disk /dev/loop5: 63.22 MiB, 66293760 bytes, 129480 sectors
Disk /dev/loop9: 346.3 MiB, 363118592 bytes, 709216 sectors
Disk /dev/loop10: 91.69 MiB, 96141312 bytes, 187776 sectors
Disk /dev/loop11: 6.01 MiB, 6303744 bytes, 12312 sectors
Disk /dev/loop13: 322.95 MiB, 338636800 bytes, 661400 sectors
Disk /dev/loop12: 6.02 MiB, 6311936 bytes, 12328 sectors
Disk /dev/loop14: 434.95 MiB, 456073216 bytes, 890768 sectors
Disk /dev/loop15: 436.97 MiB, 458199040 bytes, 894920 sectors
Disk /dev/loop16: 347.09 MiB, 363945984 bytes, 710832 sectors
Disk /dev/loop17: 346.97 MiB, 363827200 bytes, 710600 sectors
Disk /dev/loop18: 465.73 MiB, 488349696 bytes, 953808 sectors
Disk /dev/loop19: 463.16 MiB, 485662720 bytes, 948560 sectors
Disk /dev/sda: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: PSSD T7 Touch
I/O size (minimum/optimal): 512 bytes / 33553920 bytes
Disklabel type: gpt
Disk identifier: 3C50A09C-29B2-4056-8DE7-177E278F38DA
/dev/sda1 2048 4196351 4194304 2G Microsoft basic data
/dev/sda2 4196352 3907025071 3902828720 1.8T Microsoft basic data
It’s the opposite. I am getting many options from peers, and it’s confusing me further
Options help you analyze best course of action plus a better understanding of things.
But at this stage i just want to get it done, and that’s it!
Disk space is not an issue. As i will reduce windows size to increase linux’s.
Not being able to paste links, or paste/upload images is really annoying me.
Anyway i will delete the existing swap partition and create a 32gb one, to see if this much allows hibernation.
Let me know if there’s anything else you could chime as you use manjaro for much longer than i do
