Swap not detected, fstab?
Hi all
I installed Manjaro 21.1.4 yesterday on a three partition HD:
  • 500 Mo to swap
  • 60 Go for /
  • 160 Go for /home
I surely badly have made the partition process choice during the installation because the swap is not detected, but physically is on the HD, prepared with GParted before
I tried a #swapon as root but nothing happens of course because there is no swap in my /etc/fstab
[bozzoh@bozzoh ~]$ cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=aacdfc19-57f9-45e8-ad02-8f5c1076126f /              ext4    defaults,noatime 0 1
UUID=27f6a858-cd1b-450a-a0aa-182dbaed9944 /home          ext4    defaults,noatime 0 2
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
How can i edit fstab to mount the swap?
The swap partition should be detected automatically on a GPT partition table. Otherwise, you do need to declare it in fstab.
https://wiki.archlinux.org/title/Swap#Swap_partition
What filesystem did you use?
lsblk -f
Thank you very much maycne.sonahoz! :smiley:
Read your link and applied the tuto, i’ve rebooted to be sure and it works!
[bozzoh@bozzoh ~]$ lsblk -f
NAME   FSTYPE FSVER LABEL       UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 swap   1                 fdeece8c-aa44-4c0e-8f96-3390947185c9                [SWAP]
├─sda2 ext4   1.0               aacdfc19-57f9-45e8-ad02-8f5c1076126f   40,4G    25% /
└─sda3 ext4   1.0               27f6a858-cd1b-450a-a0aa-182dbaed9944    119G    21% /home
sdb
└─sdb1 ntfs         My Passport 2C660348660311EE
sr0
sr1
[bozzoh@bozzoh ~]$
Thank you :+1:
