Hey Guys,
So i want to swap from XFCE to KDE Plasma. For that i have a empty disk where i want to install KDE Plasma.
My Questions are now:
- Can i just copy/paste my home directory onto the new installation?
- How do i export all my installed packages so i can reinstall those onto Plasma
- optional only those packages(+the requirements) which were used in the last 6 month/this year, is this even possible?
- How do i implement a dual boot on two different drives? I want to use the old system disk for windows 10
ben81
#2
You could just install Plasma and remove all xfce packages without reinstalling Manjaro.
oguere
#3
Yep, just run
sudo pacman -S plasma-desktop
sudo pacman -Rcs xfcedesktop ### if you wanna get rid of xfce
and you’re done
badruk
#4
Wasn’t migrating DEs discouraged?
AFAIK, yes it was.
But being discouraged doesn’t mean it can’t be done.
system
closed
#6
