I am very new to linux but decided to make the switch and am going through with the steep learning curve. I am currently on a 5800x and 3080 with 32 gb of ram at 3800 cl16. I am using the testing branch with kernel 5.11.6. Is it recommend to enable svm on my system via bios?
If you’re going to be using virtual machines, then the answer is “yes”. Modern virtualization software like Xen, Qemu/KVM, VMware and VirtualBox all makes use of the hardware’s built-in virtualization assisence.
