Hi, just wanted to let you know that after flashing Tow-Boot to SPI I’ve got working suspend. Steps are described in updog’s response here on Reddit: https://www.reddit.com/r/PINE64official/comments/n9fp6a/any_improvements_regarding_standby_on_pinebook/
The instructions worked for the first release. I haven’t checked out the new one yet since it requires a SD card
Fabby
2
Thank you for sharing!
However, could you do me a favour and:
- edit your question by pressing the 3 dots and the pencil icon
- make it into a real question
- cut and paste the solution into a reply to your own question
- click the 3 dots below your own answer to mark a solution like this:
so that the next person that has the exact same problem you just had will benefit from your post as your question will now be in the “solved” status.
