Suspend wake up - fan & lockup
Hi team
I’m hoping a bit of help to isolate the source of some recent trouble w/ laptop wake-up from suspend. This is a system76 machine.
Host: Galago Pro galp5
Kernel: 6.12.62-1-MANJARO
DE: Plasma 6.5.4
When the machine is not actively used I suspend, but recently, sometimes, when I wake it up, the fan comes on full throttle and the machine is otherwise locked up with black screen.
FYI, this started shortly after the 2025-12-08 - 25.1 Anh-Linh update. Maybe it’s related. Maybe not. Maybe it’s the first signs of hardware failure (?). Can’t tell.
It’s possible I need to fetch some log info but I’m not sure where that lives or how to retrieve it.
When the fan blasts it might be pointing to a thermal issue, but I’ve looked at temps and they seem fine.
Thanks
Reid
Hello, I’m not sure I’ll be able to help, but I think it would be useful in any case to look at the output of journalctl -b -1 and inxi -Fza
Great. I will look at the journal after the next hang, I guess.
Here’s is a clip the journal, captured right after a lockup . I didn’t include all. Just the last minute.
Dec 17 09:36:10 reid-galagopro kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Dec 17 09:36:10 reid-galagopro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Dec 17 09:36:10 reid-galagopro kernel: ACPI: EC: interrupt blocked
Dec 17 09:36:10 reid-galagopro kernel: ACPI: EC: interrupt unblocked
Dec 17 09:36:10 reid-galagopro kernel: mei_me 0000:00:16.0: hbm: dma setup response: failure = 3 REJECTED
Dec 17 09:36:10 reid-galagopro kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
Dec 17 09:36:10 reid-galagopro kernel: OOM killer enabled.
Dec 17 09:36:10 reid-galagopro kernel: Restarting tasks ... done.
Dec 17 09:36:10 reid-galagopro kernel: random: crng reseeded on system resumption
Dec 17 09:36:10 reid-galagopro kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Dec 17 09:36:10 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Dec 17 09:36:10 reid-galagopro wpa_supplicant[851]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all
Dec 17 09:36:10 reid-galagopro wpa_supplicant[851]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
Dec 17 09:36:10 reid-galagopro nmbd[1037]: [2025/12/17 09:36:10.403653,  0] ../../source3/libsmb/nmblib.c:929(send_udp)
Dec 17 09:36:10 reid-galagopro nmbd[1037]:   Packet send failed to 192.168.1.255(138) ERRNO=Network is unreachable
Dec 17 09:36:10 reid-galagopro nmbd[1037]: [2025/12/17 09:36:10.411022,  0] ../../source3/libsmb/nmblib.c:929(send_udp)
Dec 17 09:36:10 reid-galagopro kernel: video LNXVIDEO:00: Restoring backlight state
Dec 17 09:36:10 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
Dec 17 09:36:10 reid-galagopro systemd-sleep[3962]: System returned from sleep operation 'suspend'.
Dec 17 09:36:10 reid-galagopro bluetoothd[703]: Controller resume with wake event 0x0
Dec 17 09:36:10 reid-galagopro kernel: PM: suspend exit
Dec 17 09:36:10 reid-galagopro systemd[1]: session-2.scope: Unit now thawed.
Dec 17 09:36:10 reid-galagopro systemd[1]: user@1000.service: Unit now thawed.
Dec 17 09:36:10 reid-galagopro systemd[1]: user-1000.slice: Unit now thawed.
Dec 17 09:36:10 reid-galagopro systemd[1]: user.slice: Unit now thawed.
Dec 17 09:36:10 reid-galagopro systemd-sleep[3962]: Successfully thawed unit 'user.slice'.
Dec 17 09:36:10 reid-galagopro systemd[1]: systemd-suspend.service: Deactivated successfully.
Dec 17 09:36:10 reid-galagopro systemd[1]: Finished System Suspend.
Dec 17 09:36:10 reid-galagopro systemd[1]: Stopped target Sleep.
Dec 17 09:36:10 reid-galagopro systemd[1]: Reached target Suspend.
Dec 17 09:36:10 reid-galagopro systemd[1]: Stopped target Suspend.
Dec 17 09:36:10 reid-galagopro systemd-logind[707]: Operation 'suspend' finished.
Dec 17 09:36:10 reid-galagopro NetworkManager[700]: <info>  [1765982170.5750] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Dec 17 09:36:10 reid-galagopro ModemManager[766]: <msg> [sleep-monitor-systemd] system is resuming
Dec 17 09:36:10 reid-galagopro NetworkManager[700]: <info>  [1765982170.5752] device (enp36s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Dec 17 09:36:10 reid-galagopro kernel: Generic FE-GE Realtek PHY r8169-0-2400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-2400:00, irq=MAC)
Dec 17 09:36:10 reid-galagopro ModemManager[766]: <wrn> [plugin-manager] task 4: port context already scheduled
Dec 17 09:36:10 reid-galagopro ModemManager[766]: <wrn> [plugin-manager] task 5: port context already scheduled
Dec 17 09:36:10 reid-galagopro wpa_supplicant[851]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
Dec 17 09:36:10 reid-galagopro NetworkManager[700]: <info>  [1765982170.7627] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Dec 17 09:36:10 reid-galagopro kernel: r8169 0000:24:00.0 enp36s0: Link is Down
Dec 17 09:36:10 reid-galagopro NetworkManager[700]: <info>  [1765982170.9916] device (wlp0s20f3): set-hw-addr: set MAC address to D2:10:74:01:CA:78 (scanning)
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.1860] device (30:74:67:22:6E:DE): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <warn>  [1765982171.1862] device (30:74:67:22:6E:DE): error setting IPv4 forwarding to '1': Resource temporarily unavailable
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.1866] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <warn>  [1765982171.1867] device (p2p-dev-wlp0s20f3): error setting IPv4 forwarding to '1': Resource temporarily unavailable
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.1871] manager: NetworkManager state is now CONNECTED_LOCAL
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.1879] device (30:74:67:22:6E:DE): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.2499] device (wlp0s20f3): supplicant interface state: internal-starting -> disconnected
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.2500] device (p2p-dev-wlp0s20f3): state change: unavailable -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.2506] Wi-Fi P2P device controlled by interface wlp0s20f3 created
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.2510] manager: (p2p-dev-wlp0s20f3): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/8)
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.2514] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <warn>  [1765982171.2515] device (p2p-dev-wlp0s20f3): error setting IPv4 forwarding to '1': Resource temporarily unavailable
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.2523] device (wlp0s20f3): state change: unavailable -> disconnected (reason 'supplicant-available', managed-type: 'full')
Dec 17 09:36:11 reid-galagopro NetworkManager[700]: <info>  [1765982171.2530] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
Dec 17 09:36:11 reid-galagopro ModemManager[766]: <wrn> [plugin-manager] task 4,wlp0s20f3: error when checking support with plugin 'Intel': (Intel) Missing port probe for port (net/wlp0s20f3)
Dec 17 09:36:11 reid-galagopro ModemManager[766]: <wrn> [plugin-manager] task 4,wlp0s20f3: error when checking support with plugin 'generic': (generic) Missing port probe for port (net/wlp0s20f3)
Dec 17 09:36:11 reid-galagopro systemd-logind[707]: Lid opened.
Dec 17 09:36:11 reid-galagopro thunderbird[1931]: [Parent 1931, Main Thread] WARNING: Couldn't map window 0x7f5f1d231f80 as subsurface because its parent is not mapped.: 'glib warning', file /usr/src/debug/thunderb>
Dec 17 09:36:11 reid-galagopro org.mozilla.Thunderbird[1931]: Couldn't map window 0x7f5f1d231f80 as subsurface because its parent is not mapped.
Dec 17 09:36:11 reid-galagopro thunderbird[1931]: [Parent 1931, Main Thread] WARNING: Couldn't map window 0x7f5f25d5f2c0 as subsurface because its parent is not mapped.: 'glib warning', file /usr/src/debug/thunderb>
Dec 17 09:36:11 reid-galagopro thunderbird[1931]: [Parent 1931, Main Thread] WARNING: Couldn't map window 0x7f5f1caf5fc0 as subsurface because its parent is not mapped.: 'glib warning', file /usr/src/debug/thunderb>
Dec 17 09:36:11 reid-galagopro thunderbird[1931]: [Parent 1931, Main Thread] WARNING: Couldn't map window 0x7f5f21ef1ae0 as subsurface because its parent is not mapped.: 'glib warning', file /usr/src/debug/thunderb>
Dec 17 09:36:11 reid-galagopro org.mozilla.Thunderbird[1931]: Couldn't map window 0x7f5f25d5f2c0 as subsurface because its parent is not mapped.
Dec 17 09:36:11 reid-galagopro org.mozilla.Thunderbird[1931]: Couldn't map window 0x7f5f1caf5fc0 as subsurface because its parent is not mapped.
Dec 17 09:36:11 reid-galagopro org.mozilla.Thunderbird[1931]: Couldn't map window 0x7f5f21ef1ae0 as subsurface because its parent is not mapped.
Dec 17 09:36:13 reid-galagopro ModemManager[766]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
Dec 17 09:36:13 reid-galagopro ModemManager[766]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.1/0000:24:00.0': not supported by any plugin
Dec 17 09:36:14 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=US
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7058] policy: auto-activating connection 'djgrsv' (ec06356c-4968-438f-a1a5-9e45bddaba83)
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7069] device (wlp0s20f3): Activation: starting connection 'djgrsv' (ec06356c-4968-438f-a1a5-9e45bddaba83)
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7070] device (wlp0s20f3): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7074] manager: NetworkManager state is now CONNECTING
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7615] device (wlp0s20f3): set-hw-addr: reset MAC address to 28:11:A8:75:3F:CD (preserve)
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7648] device (wlp0s20f3): state change: prepare -> config (reason 'none', managed-type: 'full')
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7651] device (wlp0s20f3): Activation: (wifi) access point 'djgrsv' has security, but secrets are required.
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7652] device (wlp0s20f3): state change: config -> need-auth (reason 'none', managed-type: 'full')
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7654] sup-iface[e5a52bb801c78c7c,3,wlp0s20f3]: wps: type pbc start...
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7839] device (wlp0s20f3): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7842] device (wlp0s20f3): state change: prepare -> config (reason 'none', managed-type: 'full')
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7846] device (wlp0s20f3): Activation: (wifi) connection 'djgrsv' has security, and secrets exist.  No new secrets needed.
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7847] Config: added 'ssid' value 'djgrsv'
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7847] Config: added 'scan_ssid' value '1'
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7847] Config: added 'bgscan' value 'simple:30:-65:300'
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7848] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7848] Config: added 'auth_alg' value 'OPEN'
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.7848] Config: added 'psk' value '<hidden>'
Dec 17 09:36:14 reid-galagopro wpa_supplicant[851]: wlp0s20f3: WPS-CANCEL
Dec 17 09:36:14 reid-galagopro wpa_supplicant[851]: wlp0s20f3: SME: Trying to authenticate with 34:98:b5:23:d4:d8 (SSID='djgrsv' freq=2412 MHz)
Dec 17 09:36:14 reid-galagopro kernel: wlp0s20f3: authenticate with 34:98:b5:23:d4:d8 (local address=28:11:a8:75:3f:cd)
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.8191] device (wlp0s20f3): supplicant interface state: disconnected -> authenticating
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.8191] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> authenticating
Dec 17 09:36:14 reid-galagopro kernel: wlp0s20f3: send auth to 34:98:b5:23:d4:d8 (try 1/3)
Dec 17 09:36:14 reid-galagopro kernel: wlp0s20f3: authenticated
Dec 17 09:36:14 reid-galagopro wpa_supplicant[851]: wlp0s20f3: Trying to associate with 34:98:b5:23:d4:d8 (SSID='djgrsv' freq=2412 MHz)
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.8489] device (wlp0s20f3): supplicant interface state: authenticating -> associating
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.8489] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> associating
Dec 17 09:36:14 reid-galagopro kernel: wlp0s20f3: associate with 34:98:b5:23:d4:d8 (try 1/3)
Dec 17 09:36:14 reid-galagopro kernel: wlp0s20f3: RX AssocResp from 34:98:b5:23:d4:d8 (capab=0x1c31 status=0 aid=3)
Dec 17 09:36:14 reid-galagopro wpa_supplicant[851]: wlp0s20f3: Associated with 34:98:b5:23:d4:d8
Dec 17 09:36:14 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Dec 17 09:36:14 reid-galagopro kernel: wlp0s20f3: associated
Dec 17 09:36:14 reid-galagopro kernel: wlp0s20f3: Limiting TX power to 30 (30 - 0) dBm as advertised by 34:98:b5:23:d4:d8
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.9258] device (wlp0s20f3): supplicant interface state: associating -> associated
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.9259] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> associated
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.9596] device (wlp0s20f3): supplicant interface state: associated -> 4way_handshake
Dec 17 09:36:14 reid-galagopro NetworkManager[700]: <info>  [1765982174.9596] device (p2p-dev-wlp0s20f3): supplicant management interface state: associated -> 4way_handshake
Dec 17 09:36:15 reid-galagopro wpa_supplicant[851]: wlp0s20f3: WPA: Key negotiation completed with 34:98:b5:23:d4:d8 [PTK=CCMP GTK=CCMP]
Dec 17 09:36:15 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-CONNECTED - Connection to 34:98:b5:23:d4:d8 completed [id=0 id_str=]
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.0345] device (wlp0s20f3): supplicant interface state: 4way_handshake -> completed
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.0346] device (wlp0s20f3): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "djgrsv"
Dec 17 09:36:15 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-58 noise=9999 txrate=26000
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.0346] device (p2p-dev-wlp0s20f3): supplicant management interface state: 4way_handshake -> completed
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.0350] device (wlp0s20f3): state change: config -> ip-config (reason 'none', managed-type: 'full')
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.0358] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
Dec 17 09:36:15 reid-galagopro avahi-daemon[702]: Joining mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::57ff:1805:7a38:2afb.
Dec 17 09:36:15 reid-galagopro avahi-daemon[702]: New relevant interface wlp0s20f3.IPv6 for mDNS.
Dec 17 09:36:15 reid-galagopro avahi-daemon[702]: Registering new address record for fe80::57ff:1805:7a38:2afb on wlp0s20f3.*.
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.0504] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.1.203, acd pending
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.2482] dhcp4 (wlp0s20f3): state changed new lease, address=192.168.1.203
Dec 17 09:36:15 reid-galagopro avahi-daemon[702]: Joining mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.1.203.
Dec 17 09:36:15 reid-galagopro avahi-daemon[702]: New relevant interface wlp0s20f3.IPv4 for mDNS.
Dec 17 09:36:15 reid-galagopro avahi-daemon[702]: Registering new address record for 192.168.1.203 on wlp0s20f3.IPv4.
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.2519] policy: set 'djgrsv' (wlp0s20f3) as default for IPv4 routing and DNS
Dec 17 09:36:15 reid-galagopro dnsmasq[981]: reading /etc/resolv.conf
Dec 17 09:36:15 reid-galagopro dnsmasq[981]: using nameserver 192.168.1.254#53
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.2734] device (wlp0s20f3): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.2760] device (wlp0s20f3): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.2762] device (wlp0s20f3): state change: secondaries -> activated (reason 'none', managed-type: 'full')
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.2767] manager: NetworkManager state is now CONNECTED_SITE
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.2797] device (wlp0s20f3): Activation: successful, device activated.
Dec 17 09:36:15 reid-galagopro kded6[1312]: Failed to notify "Created too many similar notifications in quick succession"
Dec 17 09:36:15 reid-galagopro NetworkManager[700]: <info>  [1765982175.5641] manager: NetworkManager state is now CONNECTED_GLOBAL
Dec 17 09:36:16 reid-galagopro NetworkManager[700]: <info>  [1765982176.4768] dhcp6 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
Dec 17 09:36:16 reid-galagopro avahi-daemon[702]: Leaving mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::57ff:1805:7a38:2afb.
Dec 17 09:36:16 reid-galagopro avahi-daemon[702]: Joining mDNS multicast group on interface wlp0s20f3.IPv6 with address 2600:1700:57f1:28d0:6088:6de7:8ff:9811.
Dec 17 09:36:16 reid-galagopro NetworkManager[700]: <info>  [1765982176.4785] policy: set 'djgrsv' (wlp0s20f3) as default for IPv6 routing and DNS
Dec 17 09:36:16 reid-galagopro avahi-daemon[702]: Registering new address record for 2600:1700:57f1:28d0:6088:6de7:8ff:9811 on wlp0s20f3.*.
Dec 17 09:36:16 reid-galagopro avahi-daemon[702]: Withdrawing address record for fe80::57ff:1805:7a38:2afb on wlp0s20f3.
Dec 17 09:36:16 reid-galagopro dnsmasq[981]: reading /etc/resolv.conf
Dec 17 09:36:16 reid-galagopro dnsmasq[981]: using nameserver 192.168.1.254#53
Dec 17 09:36:16 reid-galagopro dnsmasq[981]: using nameserver 2600:1700:57f1:28d0::1#53
Dec 17 09:36:16 reid-galagopro NetworkManager[700]: <info>  [1765982176.5005] dhcp6 (wlp0s20f3): state changed new lease, address=2600:1700:57f1:28d0::3b
Dec 17 09:36:16 reid-galagopro avahi-daemon[702]: Registering new address record for 2600:1700:57f1:28d0::3b on wlp0s20f3.*.
Dec 17 09:36:17 reid-galagopro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 17 09:36:19 reid-galagopro systemd[1]: dbus-:1.2-org.kde.powerdevil.wakeupsourcehelper@1.service: Deactivated successfully.
Dec 17 09:36:24 reid-galagopro unix_chkpwd[4012]: password check failed for user (rsv2)
Dec 17 09:36:24 reid-galagopro kscreenlocker_greet[3767]: pam_unix(kde:auth): authentication failure; logname=rsv2 uid=1000 euid=1000 tty= ruser= rhost=  user=rsv2
Dec 17 09:36:34 reid-galagopro kwin_wayland_wrapper[3767]: warning: queue "mesa egl surface queue" 0x55a985fe8920 destroyed while proxies still attached:
Dec 17 09:36:34 reid-galagopro kwin_wayland_wrapper[3767]:   wp_presentation#39 still attached
Dec 17 09:36:34 reid-galagopro kscreenlocker_greet[3767]: Could not create EGL surface (EGL error 0x3000)
Dec 17 09:36:35 reid-galagopro kwin_wayland_wrapper[3767]: warning: queue "mesa egl surface queue" 0x55a985a957f0 destroyed while proxies still attached:
Dec 17 09:36:35 reid-galagopro kwin_wayland_wrapper[3767]:   wp_presentation#39 still attached
Dec 17 09:36:35 reid-galagopro kscreenlocker_greet[3767]: Could not create EGL surface (EGL error 0x3000)
Dec 17 09:36:35 reid-galagopro kscreenlocker_greet[3767]: Failed to write to the pipe: Bad file descriptor.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:256: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:461: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:657: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:911: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:1047: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:1249: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:1451: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:1629: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:1737: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:1978: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:38 reid-galagopro kwin_wayland[1140]: <input>:303:2221: Could not add child element to parent element because the types are incorrect.
Dec 17 09:36:43 reid-galagopro systemd[1060]: Started btop++ - System Monitor.
Dec 17 09:36:43 reid-galagopro systemd[1060]: Started app-org.kde.konsole-4036.scope.
Dec 17 09:36:48 reid-galagopro systemd-logind[707]: Suspend key pressed short.
Dec 17 09:36:48 reid-galagopro systemd[1]: Started dbus-:1.2-org.kde.powerdevil.wakeupsourcehelper@2.service.
Dec 17 09:36:48 reid-galagopro systemd-logind[707]: The system will suspend now!
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.3731] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.3731] device (enp36s0): state change: unavailable -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
Dec 17 09:36:48 reid-galagopro ModemManager[766]: <msg> [sleep-monitor-systemd] system is about to suspend
Dec 17 09:36:48 reid-galagopro ModemManager[766]: <msg> [sleep-monitor-systemd] ready to sleep; dropping inhibitor
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.3821] device (30:74:67:22:6E:DE): state change: disconnected -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.3822] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.3826] manager: NetworkManager state is now DISABLED (ASLEEP)
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.3830] device (wlp0s20f3): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
Dec 17 09:36:48 reid-galagopro systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 17 09:36:48 reid-galagopro kwin_wayland[1140]: Failed to delay sleep: The operation inhibition has been requested for is already running
Dec 17 09:36:48 reid-galagopro systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 17 09:36:48 reid-galagopro kernel: wlp0s20f3: deauthenticating from 34:98:b5:23:d4:d8 by local choice (Reason: 3=DEAUTH_LEAVING)
Dec 17 09:36:48 reid-galagopro wpa_supplicant[851]: nl80211: send_event_marker failed: Source based routing not supported
Dec 17 09:36:48 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=34:98:b5:23:d4:d8 reason=3 locally_generated=1
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.5987] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
Dec 17 09:36:48 reid-galagopro wpa_supplicant[851]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
Dec 17 09:36:48 reid-galagopro avahi-daemon[702]: Withdrawing address record for 2600:1700:57f1:28d0::3b on wlp0s20f3.
Dec 17 09:36:48 reid-galagopro avahi-daemon[702]: Withdrawing address record for 2600:1700:57f1:28d0:6088:6de7:8ff:9811 on wlp0s20f3.
Dec 17 09:36:48 reid-galagopro avahi-daemon[702]: Leaving mDNS multicast group on interface wlp0s20f3.IPv6 with address 2600:1700:57f1:28d0:6088:6de7:8ff:9811.
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.5996] dhcp4 (wlp0s20f3): canceled DHCP transaction
Dec 17 09:36:48 reid-galagopro avahi-daemon[702]: Joining mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::57ff:1805:7a38:2afb.
Dec 17 09:36:48 reid-galagopro NetworkManager[700]: <info>  [1765982208.5996] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 second
thx
Reid
Also here’s the inxi output
rsv2@reid-galagopro:~$ inxi -Fza
  Kernel: 6.12.62-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=6c1f5b80-96fa-4e72-b95e-ee99c44cd85d rw quiet apparmor=1
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.20.0
  Type: Laptop System: System76 product: Galago Pro v: galp5
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: System76 model: Galago Pro v: galp5 serial: <superuser required>
    Firmware: UEFI vendor: coreboot v: 2021-07-20_93c2809 date: 07/20/2021
  ID-1: BAT0 charge: 30.1 Wh (92.2%) condition: 32.7/49.4 Wh (66.2%)
    volts: 15.58 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
    charging: status: discharging control: start: 0% end: 100% cycles: N/A
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
    status: discharging
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xBC
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 685 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 685 2: 685 3: 685 4: 685 5: 685 6: 685 7: 685
    8: 685 bogomips: 44864
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Type: vmscape status: Not affected
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
    HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 5986:9102
    class-ID: 0e02
    alternate: fbdev,vesa dri: iris gpu: i915 d-rect: 3840x1080 display-ID: 0
  Monitor-1: Unknown-1 pos: right res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 96 size: 508x285mm (20x11.22") diag: 582mm (22.93")
    modes: 1920x1080
  Monitor-2: eDP-1 pos: primary,left model: ChiMei InnoLux 0x14f2
    built: 2018 res: mode: 1920x1080 hz: 60 scale: 110% (1.1) to: 1745x982
    dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
    ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 30.46 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 2 device: 0 type: integrated-gpu name: Intel
    Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.3.1-arch1.2
    device-ID: 8086:9a49 surfaces: N/A
  Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.12.62-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.9 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 17.0-93-gbe2efb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 4000 bus-ID: 24:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp36s0 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 465.76 GiB used: 244.58 GiB (52.5%)
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 30.9 C scheme: GPT
  ID-1: / raw-size: 34.18 GiB size: 33.35 GiB (97.56%) used: 19.59 GiB (58.8%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 427.08 GiB size: 419.31 GiB (98.18%)
    used: 224.99 GiB (53.7%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p4 maj-min: 259:4
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0
  Memory: total: 32 GiB note: est. available: 31.19 GiB used: 2.99 GiB (9.6%)
  Processes: 253 Power: uptime: 10m states: freeze,standby,mem,disk
    suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 12.46 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 258
  Packages: 1773 pm: pacman pkgs: 1760 libs: 459 tools: octopi,pamac,yay
    pm: flatpak pkgs: 7 pm: snap pkgs: 6 Compilers: gcc: 15.2.1 Shell: Bash
    v: 5.3.8 running-in: konsole inxi: 3.3.40
This appears to have been fixed by installing the System76 driver software,
I installed the drivers, not the entire OS. Just FYI. :grinning_face:
