Suspend not restoring state
When I put my system to suspend and then start the system again, sometimes the previous state isn't restored. What's the issue?
$ inxi -Fx
System:    Host: sh3ll Kernel: 5.3.8-3-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: Xfce 4.14.1
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Inspiron 7560 v: N/A serial: <root required>
           Mobo: Dell model: 036R0F v: A00 serial: <root required> UEFI [Legacy]: Dell v: 1.8.0
           date: 10/04/2018
Battery:   ID-1: BAT0 charge: 11.2 Wh condition: 31.5/42.0 Wh (75%) model: SMP DELL 3CRH35B
           status: Discharging
CPU:       Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Kaby Lake rev: 9
           L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
           Speed: 900 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia v: 430.40 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.5 driver: modesetting,nvidia resolution: 1920x1080~60Hz
           OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 430.40 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3
           Sound Server: ALSA v: k5.3.8-3-MANJARO
Network:   Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0
           IF: wlp2s0 state: up mac: 3c:f8:62:f4:b2:6c
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
           v: kernel port: d000 bus ID: 03:00.0
           IF: enp3s0 state: down mac: d4:81:d7:ae:cc:41
Drives:    Local Storage: total: 931.51 GiB used: 67.60 GiB (7.3%)
           ID-1: /dev/sda vendor: Western Digital model: WD10SPCX-75KHST0 size: 931.51 GiB
Partition: ID-1: / size: 97.93 GiB used: 67.60 GiB (69.0%) fs: ext4 dev: /dev/sda5
Sensors:   System Temperatures: cpu: 50.0 C mobo: 46.0 C sodimm: 39.0 C gpu: nvidia temp: 48 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 183 Uptime: 2h 32m Memory: 7.60 GiB used: 1.40 GiB (18.4%) Init: systemd Compilers:
           gcc: 9.2.0 Shell: bash v: 5.0.11 inxi: 3.0.36
Are you talking about suspend-to-ram or suspend-to-disk (aka hibernate)?
Suspend to RAM.
When suspended to RAM the machine still needs energy, albeit very little compared to letting it run.
If the battery is depleted while your machine is suspended it will loose it's state and startup like any other cold boot.
The battery isn't depleted, it still doesn't restore the session sometimes.
Does it do a cold boot? Please describe exactly what the machine does after "waking from suspend".
Do you see any hints in logs: journalctl -xb?
I'll post the output of journalctl next time when the session isn't restored after suspending-to-RAM. By the way, whenever the session isn't restored, Lightdm greeter asks me to login twice.
To be specific, when I start my system after suspending, Lightdm will ask me to login. After entering the password, the screen goes blank and once again lightdm greeter asks me for password to login. And when this happens, the session isn't restored.
Which, unexpectedly, happened in Windows too. Not the session not restoring part, but after cold boot it would ask me my password twice sometimes, just as described above.
Weird.
You could try switching display manager to sddm.
This sounds like (but not sure) an incomplete attempt to logout or suspend (no matter the reason, auto or manual) and then "wake-up from suspend" or just logout-login...
Only journal might give some light to this IMHO.
Ahhh!! XFCE has a habit of conflicts with session lockers and screensaver lock.
Check what is used for session lock and your power saving settings.
Maybe some clues exist in ~/.xsession-errors
Few lines from the $ journalctl -xb while suspending.
Nov 18 20:00:01 sh3ll CROND[2138]: (root) CMD (timeshift --check --scripted)
Nov 18 20:00:02 sh3ll CROND[2137]: (root) CMDOUT ((process:2138): GLib-GIO-CRITICAL **: 20:00:02.560: g_file_get_path: assertion 'G_IS_FILE (file)' failed)
Nov 18 20:00:02 sh3ll CROND[2137]: (root) CMDOUT ()
Nov 18 20:00:02 sh3ll CROND[2137]: (root) CMDOUT (** (process:2138): CRITICAL **: 20:00:02.561: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed)
Nov 18 20:00:02 sh3ll CROND[2137]: (root) CMDOUT (** (process:2138): CRITICAL **: 20:00:02.561: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed)
Nov 18 20:00:02 sh3ll CROND[2137]: (root) CMDOUT (Monthly snapshot are enabled)
Nov 18 20:00:02 sh3ll CROND[2137]: (root) CMDOUT (Last monthly snapshot is 13 days old)
Nov 18 20:00:02 sh3ll CROND[2137]: (root) CMDOUT (------------------------------------------------------------------------------)
Nov 18 20:00:02 sh3ll crontab[2170]: (root) LIST (root)
Nov 18 20:00:02 sh3ll crontab[2171]: (root) LIST (root)
Nov 18 20:01:01 sh3ll CROND[2177]: (root) CMD (run-parts /etc/cron.hourly)
Nov 18 20:01:25 sh3ll kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Nov 18 20:01:31 sh3ll systemd-logind[637]: Lid closed.
Nov 18 20:01:33 sh3ll systemd-logind[637]: Suspending...
Nov 18 20:01:33 sh3ll NetworkManager[636]: <info>  [1574087493.9637] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Nov 18 20:01:33 sh3ll NetworkManager[636]: <info>  [1574087493.9638] device (enp3s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 18 20:01:33 sh3ll NetworkManager[636]: <info>  [1574087493.9881] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 18 20:01:33 sh3ll NetworkManager[636]: <info>  [1574087493.9884] manager: NetworkManager state is now ASLEEP
Nov 18 20:01:33 sh3ll systemd[1]: Starting TLP suspend/resume...
-- Subject: A start job for unit tlp-sleep.service has begun execution
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/technical-issues-and-assistance
-- A start job for unit tlp-sleep.service has begun execution.
-- The job identifier is 1631.
Nov 18 20:01:34 sh3ll systemd[1]: Started TLP suspend/resume.
-- Subject: A start job for unit tlp-sleep.service has finished successfully
-- A start job for unit tlp-sleep.service has finished successfully.
Nov 18 20:01:34 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:01:34 sh3ll systemd[1]: Reached target Sleep.
-- Subject: A start job for unit sleep.target has finished successfully
-- A start job for unit sleep.target has finished successfully.
-- The job identifier is 1630.
Nov 18 20:01:34 sh3ll kernel: audit: type=1130 audit(1574087494.133:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:01:34 sh3ll systemd[1]: Starting Suspend...
-- Subject: A start job for unit systemd-suspend.service has begun execution
-- A start job for unit systemd-suspend.service has begun execution.
-- The job identifier is 1627.
Nov 18 20:01:34 sh3ll systemd-sleep[2428]: Suspending system...
-- Subject: System sleep state suspend entered
-- The system has now entered the suspend sleep state.
Nov 18 20:01:34 sh3ll kernel: PM: suspend entry (deep)
Nov 18 20:01:34 sh3ll kernel: broken atomic modeset userspace detected, disabling atomic
Nov 18 20:01:34 sh3ll audit[2313]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=2313 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Nov 18 20:01:34 sh3ll kernel: audit: type=1701 audit(1574087494.166:98): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=2313 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Nov 18 20:01:34 sh3ll systemd[1]: Started Process Core Dump (PID 2432/UID 0).
-- Subject: A start job for unit systemd-coredump@2-2432-0.service has finished successfully
-- A start job for unit systemd-coredump@2-2432-0.service has finished successfully.
-- The job identifier is 1682.
Nov 18 20:01:34 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-2432-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:01:34 sh3ll kernel: audit: type=1130 audit(1574087494.173:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-2432-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
This time even the lightdm greeter didn't start. I had to use tty to start startx and then the previous session was lost.
Idk why the journal's timing is not in order as well. 20:16 till 20:19, then 20:18 and then 20:17!
Few lines from $ journalctl -xb after starting laptop:
Nov 18 20:16:56 sh3ll kernel: Filesystems sync: 0.425 seconds
Nov 18 20:16:56 sh3ll kernel: Freezing user space processes ... (elapsed 0.008 seconds) done.
Nov 18 20:16:56 sh3ll kernel: OOM killer disabled.
Nov 18 20:16:56 sh3ll kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Nov 18 20:16:56 sh3ll kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Nov 18 20:16:56 sh3ll kernel: wlp2s0: deauthenticating from 70:ea:1a:04:cd:d4 by local choice (Reason: 3=DEAUTH_LEAVING)
Nov 18 20:16:56 sh3ll kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Nov 18 20:16:56 sh3ll kernel: sd 0:0:0:0: [sda] Stopping disk
Nov 18 20:16:56 sh3ll kernel: ACPI: EC: interrupt blocked
Nov 18 20:16:56 sh3ll kernel: ACPI: Preparing to enter system sleep state S3
Nov 18 20:16:56 sh3ll kernel: ACPI: EC: event blocked
Nov 18 20:16:56 sh3ll kernel: ACPI: EC: EC stopped
Nov 18 20:16:56 sh3ll kernel: PM: Saving platform NVS memory
Nov 18 20:16:56 sh3ll kernel: Disabling non-boot CPUs ...
Nov 18 20:16:56 sh3ll kernel: smpboot: CPU 1 is now offline
Nov 18 20:16:56 sh3ll kernel: smpboot: CPU 2 is now offline
Nov 18 20:16:56 sh3ll kernel: smpboot: CPU 3 is now offline
Nov 18 20:16:56 sh3ll kernel: ACPI: Low-level resume complete
Nov 18 20:16:56 sh3ll kernel: ACPI: EC: EC started
Nov 18 20:16:56 sh3ll kernel: PM: Restoring platform NVS memory
Nov 18 20:16:56 sh3ll kernel: Enabling non-boot CPUs ...
Nov 18 20:16:56 sh3ll kernel: x86: Booting SMP configuration:
Nov 18 20:16:56 sh3ll kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Nov 18 20:16:56 sh3ll kernel: microcode: sig=0x806e9, pf=0x80, revision=0x8e
Nov 18 20:16:56 sh3ll kernel: CPU1 is up
Nov 18 20:16:56 sh3ll kernel: smpboot: Booting Node 0 Processor 2 APIC 0x1
Nov 18 20:16:56 sh3ll kernel: microcode: sig=0x806e9, pf=0x80, revision=0xca
Nov 18 20:16:56 sh3ll kernel: CPU2 is up
Nov 18 20:16:56 sh3ll kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Nov 18 20:16:56 sh3ll kernel: CPU3 is up
Nov 18 20:16:56 sh3ll kernel: ACPI: Waking up from system sleep state S3
Nov 18 20:16:56 sh3ll kernel: ACPI: EC: interrupt unblocked
Nov 18 20:16:56 sh3ll kernel: nvidia 0000:01:00.0: Enabling HDA controller
Nov 18 20:16:56 sh3ll kernel: ACPI: EC: event unblocked
Nov 18 20:16:56 sh3ll kernel: sd 0:0:0:0: [sda] Starting disk
Nov 18 20:16:56 sh3ll kernel: iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
Nov 18 20:16:56 sh3ll kernel: iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
Nov 18 20:16:56 sh3ll kernel: usb 1-6: reset high-speed USB device number 2 using xhci_hcd
Nov 18 20:16:56 sh3ll kernel: ata3: SATA link down (SStatus 4 SControl 300)
Nov 18 20:16:56 sh3ll kernel: usb 1-8: reset full-speed USB device number 3 using xhci_hcd
Nov 18 20:16:56 sh3ll kernel: acpi LNXPOWER:13: Turning OFF
Nov 18 20:16:56 sh3ll kernel: acpi LNXPOWER:12: Turning OFF
Nov 18 20:16:56 sh3ll kernel: acpi LNXPOWER:11: Turning OFF
Nov 18 20:16:56 sh3ll kernel: acpi LNXPOWER:10: Turning OFF
Nov 18 20:16:56 sh3ll kernel: acpi LNXPOWER:0f: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:0e: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:0d: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:0c: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:0b: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:0a: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:09: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:08: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:07: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:06: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:04: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:03: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:02: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:01: Turning OFF
Nov 18 20:16:59 sh3ll kernel: acpi LNXPOWER:00: Turning OFF
Nov 18 20:16:59 sh3ll kernel: OOM killer enabled.
Nov 18 20:16:59 sh3ll kernel: Restarting tasks ...
Nov 18 20:16:59 sh3ll kernel: audit: type=1130 audit(1574088416.753:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll kernel: done.
Nov 18 20:16:59 sh3ll kernel: PM: suspend exit
Nov 18 20:16:59 sh3ll kernel: broken atomic modeset userspace detected, disabling atomic
Nov 18 20:16:59 sh3ll kernel: audit: type=1130 audit(1574088416.806:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll kernel: audit: type=1131 audit(1574088416.806:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll kernel: Generic Realtek PHY r8169-300:00: attached PHY driver [Generic Realtek PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
Nov 18 20:16:59 sh3ll kernel: audit: type=1130 audit(1574088416.836:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Nov 18 20:16:59 sh3ll kernel: iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
Nov 18 20:16:59 sh3ll kernel: iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
Nov 18 20:16:59 sh3ll kernel: mei_hdcp mei::b638ab7e-94e2-4ea2-a552-d1c54b627f04:01: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Nov 18 20:16:59 sh3ll kernel: Bluetooth: hci0: read Intel version: 370810011003110e00
Nov 18 20:16:59 sh3ll kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
Nov 18 20:16:59 sh3ll kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Nov 18 20:16:59 sh3ll kernel: Bluetooth: hci0: Intel firmware patch completed and activated
Nov 18 20:16:59 sh3ll kernel: audit: type=1130 audit(1574088418.963:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll kernel: audit: type=1006 audit(1574088418.966:105): pid=2580 uid=0 subj==unconfined old-auid=4294967295 auid=970 tty=(none) old-ses=4294967295 ses=6 res=1
Nov 18 20:16:59 sh3ll kernel: audit: type=1130 audit(1574088419.019:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 18 20:16:59 sh3ll kernel: ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
Nov 18 20:16:59 sh3ll kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Nov 18 20:16:59 sh3ll kernel: ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
Nov 18 20:16:59 sh3ll kernel: ata1.00: configured for UDMA/133
Nov 18 20:16:56 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:56 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:56 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:56 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:58 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:56 sh3ll bluetoothd[638]: Endpoint unregistered: sender=:1.70 path=/MediaEndpoint/A2DPSink/sbc
Nov 18 20:16:56 sh3ll systemd[1]: Starting Load/Save RF Kill Switch Status...
-- Subject: A start job for unit systemd-rfkill.service has begun execution
-- A start job for unit systemd-rfkill.service has begun execution.
-- The job identifier is 1691.
Nov 18 20:16:59 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=70:ea:1a:04:cd:d4 reason=3 locally_generated=1
Nov 18 20:16:59 sh3ll wpa_supplicant[724]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/1
Nov 18 20:16:59 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Nov 18 20:16:59 sh3ll wpa_supplicant[724]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Nov 18 20:16:59 sh3ll wpa_supplicant[724]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Nov 18 20:16:56 sh3ll bluetoothd[638]: Endpoint unregistered: sender=:1.70 path=/MediaEndpoint/A2DPSource/sbc
Nov 18 20:16:56 sh3ll systemd-logind[637]: Lid opened.
Nov 18 20:16:56 sh3ll avahi-daemon[639]: Withdrawing address record for 10.103.181.184 on wlp2s0.
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.7482] bluez5: NAP: removed interface 3C:F8:62:F4:B2:70
Nov 18 20:16:56 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 10.103.181.184.
Nov 18 20:16:56 sh3ll systemd[1]: Started Load/Save RF Kill Switch Status.
-- Subject: A start job for unit systemd-rfkill.service has finished successfully
-- A start job for unit systemd-rfkill.service has finished successfully.
Nov 18 20:16:56 sh3ll avahi-daemon[639]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Nov 18 20:16:56 sh3ll NetworkManager[636]: <warn>  [1574088416.7569] sup-iface[0x55ced37c5210,wlp2s0]: connection disconnected (reason -3)
Nov 18 20:16:56 sh3ll avahi-daemon[639]: Withdrawing address record for fe80::b198:3f20:315a:42a8 on wlp2s0.
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.7570] device (wlp2s0): supplicant interface state: completed -> disconnected
Nov 18 20:16:56 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::b198:3f20:315a:42a8.
Nov 18 20:16:56 sh3ll systemd[1]: Stopped target Bluetooth.
-- Subject: A stop job for unit bluetooth.target has finished
-- A stop job for unit bluetooth.target has finished.
-- The job identifier is 1699 and the job result is done.
Nov 18 20:16:56 sh3ll avahi-daemon[639]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
Nov 18 20:16:56 sh3ll systemd-sleep[2428]: System resumed.
-- Subject: System sleep state suspend left
-- The system has now left the suspend sleep state.
Nov 18 20:16:56 sh3ll dbus-daemon[635]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.8' (uid=0 pid=636 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Nov 18 20:16:56 sh3ll systemd[1]: systemd-suspend.service: Succeeded.
-- Subject: Unit succeeded
-- The unit systemd-suspend.service has successfully entered the 'dead' state.
Nov 18 20:16:56 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 18 20:16:56 sh3ll systemd[1]: Started Suspend.
-- Subject: A start job for unit systemd-suspend.service has finished successfully
-- A start job for unit systemd-suspend.service has finished successfully.
Nov 18 20:16:58 sh3ll lightdm[2576]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Nov 18 20:16:56 sh3ll systemd[1]: Stopped target Sleep.
-- Subject: A stop job for unit sleep.target has finished
-- A stop job for unit sleep.target has finished.
-- The job identifier is 1700 and the job result is done.
Nov 18 20:16:58 sh3ll systemd[2580]: pam_unix(systemd-user:session): session opened for user lightdm by (uid=0)
Nov 18 20:16:56 sh3ll systemd[1]: Reached target Suspend.
-- Subject: A start job for unit suspend.target has finished successfully
-- A start job for unit suspend.target has finished successfully.
-- The job identifier is 1626.
Nov 18 20:16:59 sh3ll ModemManager[727]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.4/0000:02:00.0': not supported by any plugin
Nov 18 20:16:56 sh3ll systemd-logind[637]: Operation 'sleep' finished.
Nov 18 20:16:59 sh3ll ModemManager[727]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.5/0000:03:00.0': not supported by any plugin
Nov 18 20:16:56 sh3ll systemd[1]: Stopping TLP suspend/resume...
-- Subject: A stop job for unit tlp-sleep.service has begun execution
-- A stop job for unit tlp-sleep.service has begun execution.
-- The job identifier is 1704.
Nov 18 20:16:56 sh3ll systemd[1]: Stopped target Suspend.
-- Subject: A stop job for unit suspend.target has finished
-- A stop job for unit suspend.target has finished.
-- The job identifier is 1703 and the job result is done.
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.8104] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.8108] device (wlp2s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.8110] dhcp4 (wlp2s0): canceled DHCP transaction
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.8111] dhcp4 (wlp2s0): state changed bound -> done
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.8148] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.8171] manager: NetworkManager state is now DISCONNECTED
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.8233] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 18 20:16:56 sh3ll systemd[1]: Starting Network Manager Script Dispatcher Service...
-- Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
-- A start job for unit NetworkManager-dispatcher.service has begun execution.
-- The job identifier is 1705.
Nov 18 20:16:56 sh3ll systemd[1]: Started Network Manager Script Dispatcher Service.
-- Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
-- A start job for unit NetworkManager-dispatcher.service has finished successfully.
Nov 18 20:16:56 sh3ll NetworkManager[636]: <info>  [1574088416.9443] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 18 20:16:57 sh3ll NetworkManager[636]: <info>  [1574088417.1073] device (wlp2s0): set-hw-addr: set MAC address to 1E:39:2C:21:08:E5 (scanning)
Nov 18 20:16:57 sh3ll systemd[1]: Reached target Bluetooth.
-- Subject: A start job for unit bluetooth.target has finished successfully
-- A start job for unit bluetooth.target has finished successfully.
-- The job identifier is 1759.
Nov 18 20:16:57 sh3ll NetworkManager[636]: <info>  [1574088417.2218] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 18 20:16:58 sh3ll systemd[1]: Created slice User Slice of UID 970.
-- Subject: A start job for unit user-970.slice has finished successfully
-- A start job for unit user-970.slice has finished successfully.
-- The job identifier is 1868.
Nov 18 20:16:58 sh3ll systemd[1]: Starting User Runtime Directory /run/user/970...
-- Subject: A start job for unit user-runtime-dir@970.service has begun execution
-- A start job for unit user-runtime-dir@970.service has begun execution.
-- The job identifier is 1815.
Nov 18 20:16:58 sh3ll systemd-logind[637]: New session c4 of user lightdm.
-- Subject: A new session c4 has been created for user lightdm
-- Documentation: https://www.freedesktop.org/wiki/Software/systemd/multiseat
-- A new session with the ID c4 has been created for the user lightdm.
-- The leading process of the session is 2576.
Nov 18 20:16:58 sh3ll systemd[1]: Started User Runtime Directory /run/user/970.
-- Subject: A start job for unit user-runtime-dir@970.service has finished successfully
-- A start job for unit user-runtime-dir@970.service has finished successfully.
Nov 18 20:16:58 sh3ll systemd[1]: Starting User Manager for UID 970...
-- Subject: A start job for unit user@970.service has begun execution
-- A start job for unit user@970.service has begun execution.
-- The job identifier is 1814.
Nov 18 20:16:59 sh3ll systemd[2580]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
-- Subject: A start job for unit UNIT has finished successfully
-- A start job for unit UNIT has finished successfully.
-- The job identifier is 10.
Nov 18 20:17:00 sh3ll kernel: audit: type=1131 audit(1574088419.966:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:16:59 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:00 sh3ll bluetoothd[638]: Endpoint registered: sender=:1.70 path=/MediaEndpoint/A2DPSink/sbc
Nov 18 20:17:00 sh3ll bluetoothd[638]: Endpoint registered: sender=:1.70 path=/MediaEndpoint/A2DPSource/sbc
Nov 18 20:17:00 sh3ll NetworkManager[636]: <info>  [1574088420.1872] bluez5: NAP: added interface 3C:F8:62:F4:B2:70
Nov 18 20:17:00 sh3ll systemd-coredump[2433]: Process 2313 (Xorg) of user 0 dumped core.
                                              Stack trace of thread 2313:
                                              #0  0x00007fd444a50f25 raise (libc.so.6)
                                              #1  0x00007fd444a3a897 abort (libc.so.6)
                                              #2  0x000055b0746a1c8a OsAbort (Xorg)
                                              #3  0x000055b0746a54c1 FatalError (Xorg)
                                              #4  0x000055b0746a8cf2 n/a (Xorg)
                                              #5  0x00007fd444a50fb0 __restore_rt (libc.so.6)
                                              #6  0x00007fd444a50f25 raise (libc.so.6)
                                              #7  0x00007fd444a3a897 abort (libc.so.6)
                                              #8  0x00007fd444a3a767 __assert_fail_base.cold (libc.so.6)
                                              #9  0x00007fd444a49526 __assert_fail (libc.so.6)
                                              #10 0x000055b074751a79 dixRegisterPrivateKey (Xorg)
                                              #11 0x00007fd43f4106e9 glamor_init (libglamoregl.so)
                                              #12 0x00007fd43f7988cd n/a (modesetting_drv.so)
                                              #13 0x000055b074771fce AddGPUScreen (Xorg)
                                              #14 0x000055b074674d22 n/a (Xorg)
                                              #15 0x000055b0746565a6 n/a (Xorg)
                                              #16 0x000055b07464952a n/a (Xorg)
                                              #17 0x000055b07464a28b config_init (Xorg)
                                              #18 0x000055b07468f189 InitInput (Xorg)
                                              #19 0x000055b0746377fa n/a (Xorg)
                                              #20 0x00007fd444a3c153 __libc_start_main (libc.so.6)
                                              #21 0x000055b0746383ae _start (Xorg)
                                              Stack trace of thread 2429:
                                              #0  0x00007fd4444b3c45 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                              #1  0x00007fd43ead15ac n/a (i965_dri.so)
                                              #2  0x00007fd43ead11a8 n/a (i965_dri.so)
                                              #3  0x00007fd4444ad4cf start_thread (libpthread.so.0)
                                              #4  0x00007fd444b142d3 __clone (libc.so.6)
-- Subject: Process 2313 (Xorg) dumped core
-- Documentation: man:core(5)
-- Process 2313 (Xorg) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
Nov 18 20:17:00 sh3ll systemd[1]: systemd-coredump@2-2432-0.service: Succeeded.
-- The unit systemd-coredump@2-2432-0.service has successfully entered the 'dead' state.
Nov 18 20:17:03 sh3ll kernel: audit: type=1131 audit(1574088420.243:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-2432-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:03 sh3ll kernel: audit: type=1131 audit(1574088422.649:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:00 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-2432-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:02 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:00 sh3ll dbus-daemon[2682]: [session uid=970 pid=2682] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=970 pid=2673 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Nov 18 20:17:00 sh3ll NetworkManager[636]: <info>  [1574088420.2465] sup-iface[0x55ced37c5300,wlp2s0]: supports 5 scan SSIDs
Nov 18 20:17:00 sh3ll dbus-daemon[2682]: [session uid=970 pid=2682] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.2' (uid=970 pid=2683 comm="/usr/lib/at-spi-bus-launcher " label="unconfined")
Nov 18 20:17:00 sh3ll NetworkManager[636]: <info>  [1574088420.2471] device (wlp2s0): supplicant interface state: starting -> ready
Nov 18 20:17:00 sh3ll dbus-daemon[2682]: [session uid=970 pid=2682] Successfully activated service 'org.gtk.vfs.Daemon'
Nov 18 20:17:00 sh3ll NetworkManager[636]: <info>  [1574088420.2472] device (p2p-dev-wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 18 20:17:00 sh3ll dbus-daemon[2682]: [session uid=970 pid=2682] Successfully activated service 'org.a11y.Bus'
Nov 18 20:17:03 sh3ll at-spi-bus-launcher[2683]: dbus-daemon[2700]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=970 pid=2673 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Nov 18 20:17:03 sh3ll at-spi-bus-launcher[2683]: dbus-daemon[2700]: Successfully activated service 'org.a11y.atspi.Registry'
Nov 18 20:17:00 sh3ll NetworkManager[636]: <info>  [1574088420.2475] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 18 20:17:00 sh3ll polkitd[632]: /usr/share/polkit-1/rules.d/lightdm.rules:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Nov 18 20:17:03 sh3ll at-spi-bus-launcher[2683]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Nov 18 20:17:04 sh3ll lightdm[2710]: pam_unix(lightdm:auth): authentication failure; logname= uid=0 euid=0 tty=:1 ruser= rhost=  user=mehul
Nov 18 20:17:04 sh3ll lightdm[2710]: gkr-pam: unable to locate daemon control file
Nov 18 20:17:04 sh3ll wpa_supplicant[724]: wlp2s0: SME: Trying to authenticate with 70:ea:1a:04:cd:d4 (SSID='Amity-WiFi' freq=2437 MHz)
Nov 18 20:17:04 sh3ll kernel: wlp2s0: authenticate with 70:ea:1a:04:cd:d4
Nov 18 20:17:04 sh3ll kernel: wlp2s0: send auth to 70:ea:1a:04:cd:d4 (try 1/3)
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8209] device (wlp2s0): supplicant interface state: scanning -> authenticating
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8210] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
Nov 18 20:17:04 sh3ll wpa_supplicant[724]: wlp2s0: Trying to associate with 70:ea:1a:04:cd:d4 (SSID='Amity-WiFi' freq=2437 MHz)
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8316] device (wlp2s0): supplicant interface state: authenticating -> associating
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8316] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Nov 18 20:17:04 sh3ll kernel: wlp2s0: authenticated
Nov 18 20:17:04 sh3ll kernel: wlp2s0: associate with 70:ea:1a:04:cd:d4 (try 1/3)
Nov 18 20:17:04 sh3ll kernel: wlp2s0: RX AssocResp from 70:ea:1a:04:cd:d4 (capab=0x1421 status=0 aid=97)
Nov 18 20:17:04 sh3ll kernel: wlp2s0: associated
Nov 18 20:17:04 sh3ll wpa_supplicant[724]: wlp2s0: Associated with 70:ea:1a:04:cd:d4
Nov 18 20:17:04 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 70:ea:1a:04:cd:d4 completed [id=0 id_str=]
Nov 18 20:17:04 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 18 20:17:04 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-70 noise=9999 txrate=1000
Nov 18 20:17:04 sh3ll kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8934] device (wlp2s0): supplicant interface state: associating -> completed
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8935] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Amity-WiFi"
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8935] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8949] device (wlp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.8960] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Nov 18 20:17:04 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::b198:3f20:315a:42a8.
Nov 18 20:17:04 sh3ll avahi-daemon[639]: New relevant interface wlp2s0.IPv6 for mDNS.
Nov 18 20:17:04 sh3ll avahi-daemon[639]: Registering new address record for fe80::b198:3f20:315a:42a8 on wlp2s0.*.
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9244] dhcp4 (wlp2s0): state changed unknown -> bound
Nov 18 20:17:04 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 10.103.181.184.
Nov 18 20:17:04 sh3ll avahi-daemon[639]: New relevant interface wlp2s0.IPv4 for mDNS.
Nov 18 20:17:04 sh3ll avahi-daemon[639]: Registering new address record for 10.103.181.184 on wlp2s0.IPv4.
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9284] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9344] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9353] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9366] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9428] manager: NetworkManager state is now CONNECTED_SITE
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9432] policy: set 'Amity-WiFi' (wlp2s0) as default for IPv4 routing and DNS
Nov 18 20:17:04 sh3ll NetworkManager[636]: <info>  [1574088424.9451] device (wlp2s0): Activation: successful, device activated.
Nov 18 20:17:04 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-71 noise=9999 txrate=43300
Nov 18 20:17:05 sh3ll kernel: wlp2s0: Limiting TX power to 22 dBm as advertised by 70:ea:1a:04:cd:d4
Nov 18 20:17:06 sh3ll audit[2710]: USER_LOGIN pid=2710 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="mehul" exe="/usr/bin/lightdm" hostname=sh3ll addr=? terminal=/dev/tty8 res=failed'
Nov 18 20:17:06 sh3ll kernel: audit: type=1112 audit(1574088426.229:110): pid=2710 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=login acct="mehul" exe="/usr/bin/lightdm" hostname=sh3ll addr=? terminal=/dev/tty8 res=failed'
Nov 18 20:17:07 sh3ll systemd[1]: NetworkManager-dispatcher.service: Succeeded.
-- The unit NetworkManager-dispatcher.service has successfully entered the 'dead' state.
Nov 18 20:17:07 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:07 sh3ll kernel: audit: type=1131 audit(1574088427.143:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:07 sh3ll NetworkManager[636]: <info>  [1574088427.5363] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 18 20:17:07 sh3ll dbus-daemon[635]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.8' (uid=0 pid=636 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Nov 18 20:17:07 sh3ll systemd[1]: Starting Network Manager Script Dispatcher Service...
-- The job identifier is 1927.
Nov 18 20:17:07 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 18 20:17:07 sh3ll systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 18 20:17:07 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:07 sh3ll kernel: audit: type=1130 audit(1574088427.546:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:08 sh3ll lightdm[2719]: gkr-pam: unable to locate daemon control file
Nov 18 20:17:09 sh3ll systemd[1]: session-c4.scope: Killing process 2576 (lightdm) with signal SIGTERM.
Nov 18 20:17:09 sh3ll systemd[1]: session-c4.scope: Killing process 2673 (lightdm-gtk-gre) with signal SIGTERM.
Nov 18 20:17:09 sh3ll systemd[1]: Stopping Session c4 of user lightdm.
-- Subject: A stop job for unit session-c4.scope has begun execution
-- A stop job for unit session-c4.scope has begun execution.
-- The job identifier is 1981.
Nov 18 20:17:09 sh3ll lightdm[2576]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Nov 18 20:17:09 sh3ll systemd[1]: session-c4.scope: Succeeded.
-- The unit session-c4.scope has successfully entered the 'dead' state.
Nov 18 20:17:09 sh3ll systemd[1]: Stopped Session c4 of user lightdm.
-- Subject: A stop job for unit session-c4.scope has finished
-- A stop job for unit session-c4.scope has finished.
-- The job identifier is 1981 and the job result is done.
Nov 18 20:17:09 sh3ll systemd-logind[637]: Removed session c4.
-- Subject: Session c4 has been terminated
-- A session with the ID c4 has been terminated.
Nov 18 20:17:18 sh3ll systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Nov 18 20:17:18 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:18 sh3ll kernel: audit: type=1131 audit(1574088438.149:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:19 sh3ll kernel: audit: type=1131 audit(1574088439.273:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:19 sh3ll kernel: audit: type=1131 audit(1574088439.283:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:19 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:19 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:17:19 sh3ll systemd[2581]: pam_unix(systemd-user:session): session closed for user lightdm
Nov 18 20:17:43 sh3ll dbus-daemon[966]: [session uid=1000 pid=966] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.17' (uid=1000 pid=1026 comm="Thunar --daemon " label="unconfined")
Nov 18 20:17:43 sh3ll org.freedesktop.thumbnails.Thumbnailer1[966]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Nov 18 20:17:43 sh3ll org.freedesktop.thumbnails.Thumbnailer1[966]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Nov 18 20:17:43 sh3ll org.freedesktop.thumbnails.Thumbnailer1[966]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Nov 18 20:17:43 sh3ll org.freedesktop.thumbnails.Thumbnailer1[966]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Nov 18 20:17:43 sh3ll dbus-daemon[966]: [session uid=1000 pid=966] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Nov 18 20:17:43 sh3ll tumblerd[3008]: g_date_time_unref: assertion 'datetime != NULL' failed
Nov 18 20:17:49 sh3ll tumblerd[3008]: g_date_time_unref: assertion 'datetime != NULL' failed
Nov 18 20:18:53 sh3ll pkexec[3026]: pam_unix(polkit-1:session): session opened for user root by (uid=1000)
Nov 18 20:18:53 sh3ll pkexec[3026]: mehul: Executing command [USER=root] [TTY=unknown] [CWD=/] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness 2904]
Nov 18 20:18:54 sh3ll pkexec[3032]: pam_unix(polkit-1:session): session opened for user root by (uid=1000)
Nov 18 20:18:54 sh3ll pkexec[3032]: mehul: Executing command [USER=root] [TTY=unknown] [CWD=/] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness 2154]
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.0374] device (wlp2s0): disconnecting for new activation request.
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.0375] device (wlp2s0): state change: activated -> deactivating (reason 'new-activation', sys-iface-state: 'managed')
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.0388] manager: NetworkManager state is now DISCONNECTING
Nov 18 20:19:43 sh3ll audit[636]: USYS_CONFIG pid=636 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=d1248ed1-e02c-4304-82ae-346479f1e3f8 name="AmityWifi" pid=1087 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.0433] audit: op="connection-activate" uuid="d1248ed1-e02c-4304-82ae-346479f1e3f8" name="AmityWifi" pid=1087 uid=1000 result="success"
Nov 18 20:19:43 sh3ll kernel: audit: type=1111 audit(1574088583.039:116): pid=636 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=d1248ed1-e02c-4304-82ae-346479f1e3f8 name="AmityWifi" pid=1087 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Nov 18 20:19:43 sh3ll dbus-daemon[635]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.8' (uid=0 pid=636 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Nov 18 20:19:43 sh3ll systemd[1]: Starting Network Manager Script Dispatcher Service...
-- The job identifier is 1987.
Nov 18 20:19:43 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 18 20:19:43 sh3ll systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 18 20:19:43 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:19:43 sh3ll kernel: audit: type=1130 audit(1574088583.059:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:19:43 sh3ll kernel: wlp2s0: deauthenticating from 70:ea:1a:04:cd:d4 by local choice (Reason: 3=DEAUTH_LEAVING)
Nov 18 20:19:43 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=70:ea:1a:04:cd:d4 reason=3 locally_generated=1
Nov 18 20:19:43 sh3ll wpa_supplicant[724]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/2
Nov 18 20:19:43 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=0 noise=9999 txrate=0
Nov 18 20:19:43 sh3ll NetworkManager[636]: <warn>  [1574088583.1136] sup-iface[0x55ced37c5300,wlp2s0]: connection disconnected (reason -3)
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1145] device (wlp2s0): state change: deactivating -> disconnected (reason 'new-activation', sys-iface-state: 'managed')
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1153] dhcp4 (wlp2s0): canceled DHCP transaction
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1154] dhcp4 (wlp2s0): state changed bound -> done
Nov 18 20:19:43 sh3ll avahi-daemon[639]: Withdrawing address record for fe80::b198:3f20:315a:42a8 on wlp2s0.
Nov 18 20:19:43 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::b198:3f20:315a:42a8.
Nov 18 20:19:43 sh3ll avahi-daemon[639]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
Nov 18 20:19:43 sh3ll avahi-daemon[639]: Withdrawing address record for 10.103.181.184 on wlp2s0.
Nov 18 20:19:43 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 10.103.181.184.
Nov 18 20:19:43 sh3ll avahi-daemon[639]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1221] device (wlp2s0): set-hw-addr: set MAC address to AA:21:50:F7:A1:0E (scanning)
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1321] manager: NetworkManager state is now DISCONNECTED
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1337] device (wlp2s0): Activation: starting connection 'AmityWifi' (d1248ed1-e02c-4304-82ae-346479f1e3f8)
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1362] device (wlp2s0): supplicant interface state: completed -> disconnected
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1362] device (p2p-dev-wlp2s0): supplicant management interface state: completed -> disconnected
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1452] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1512] manager: NetworkManager state is now CONNECTING
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1623] device (wlp2s0): set-hw-addr: reset MAC address to 3C:F8:62:F4:B2:6C (preserve)
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1804] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1813] device (wlp2s0): Activation: (wifi) access point 'AmityWifi' has security, but secrets are required.
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1814] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1953] device (wlp2s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1963] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1968] device (wlp2s0): Activation: (wifi) connection 'AmityWifi' has security, and secrets exist.  No new secrets needed.
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1969] Config: added 'ssid' value 'AmityWifi'
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1969] Config: added 'scan_ssid' value '1'
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1969] Config: added 'bgscan' value 'simple:30:-80:86400'
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1969] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Nov 18 20:19:43 sh3ll NetworkManager[636]: <info>  [1574088583.1970] Config: added 'psk' value '<hidden>'
Nov 18 20:19:45 sh3ll NetworkManager[636]: <info>  [1574088585.2343] device (wlp2s0): supplicant interface state: disconnected -> scanning
Nov 18 20:19:45 sh3ll NetworkManager[636]: <info>  [1574088585.2344] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> scanning
Nov 18 20:19:46 sh3ll wpa_supplicant[724]: wlp2s0: SME: Trying to authenticate with 90:78:b2:e8:63:f9 (SSID='AmityWifi' freq=2412 MHz)
Nov 18 20:19:46 sh3ll kernel: wlp2s0: authenticate with 90:78:b2:e8:63:f9
Nov 18 20:19:46 sh3ll kernel: wlp2s0: send auth to 90:78:b2:e8:63:f9 (try 1/3)
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.3070] device (wlp2s0): supplicant interface state: scanning -> authenticating
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.3071] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
Nov 18 20:19:46 sh3ll wpa_supplicant[724]: wlp2s0: Trying to associate with 90:78:b2:e8:63:f9 (SSID='AmityWifi' freq=2412 MHz)
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.3553] device (wlp2s0): supplicant interface state: authenticating -> associating
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.3554] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Nov 18 20:19:46 sh3ll kernel: wlp2s0: authenticated
Nov 18 20:19:46 sh3ll kernel: wlp2s0: associate with 90:78:b2:e8:63:f9 (try 1/3)
Nov 18 20:19:46 sh3ll kernel: wlp2s0: RX AssocResp from 90:78:b2:e8:63:f9 (capab=0x1431 status=0 aid=1)
Nov 18 20:19:46 sh3ll wpa_supplicant[724]: wlp2s0: Associated with 90:78:b2:e8:63:f9
Nov 18 20:19:46 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 18 20:19:46 sh3ll kernel: wlp2s0: associated
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.3829] device (wlp2s0): supplicant interface state: associating -> associated
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.3830] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> associated
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.4446] device (wlp2s0): supplicant interface state: associated -> 4-way handshake
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.4447] device (p2p-dev-wlp2s0): supplicant management interface state: associated -> 4-way handshake
Nov 18 20:19:46 sh3ll wpa_supplicant[724]: wlp2s0: WPA: Key negotiation completed with 90:78:b2:e8:63:f9 [PTK=CCMP GTK=CCMP]
Nov 18 20:19:46 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 90:78:b2:e8:63:f9 completed [id=0 id_str=]
Nov 18 20:19:46 sh3ll kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5195] device (wlp2s0): supplicant interface state: 4-way handshake -> completed
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5195] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "AmityWifi"
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5196] device (p2p-dev-wlp2s0): supplicant management interface state: 4-way handshake -> completed
Nov 18 20:19:46 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-29 noise=9999 txrate=1000
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5199] device (wlp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5206] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Nov 18 20:19:46 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::7cc9:9e9d:3a80:933e.
Nov 18 20:19:46 sh3ll avahi-daemon[639]: New relevant interface wlp2s0.IPv6 for mDNS.
Nov 18 20:19:46 sh3ll avahi-daemon[639]: Registering new address record for fe80::7cc9:9e9d:3a80:933e on wlp2s0.*.
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5905] dhcp4 (wlp2s0): state changed unknown -> bound
Nov 18 20:19:46 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.43.26.
Nov 18 20:19:46 sh3ll avahi-daemon[639]: New relevant interface wlp2s0.IPv4 for mDNS.
Nov 18 20:19:46 sh3ll avahi-daemon[639]: Registering new address record for 192.168.43.26 on wlp2s0.IPv4.
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5921] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5953] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5956] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5962] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5988] manager: NetworkManager state is now CONNECTED_SITE
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5989] policy: set 'AmityWifi' (wlp2s0) as default for IPv4 routing and DNS
Nov 18 20:19:46 sh3ll NetworkManager[636]: <info>  [1574088586.5994] device (wlp2s0): Activation: successful, device activated.
Nov 18 20:19:47 sh3ll NetworkManager[636]: <info>  [1574088587.3617] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 18 20:19:49 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::7cc9:9e9d:3a80:933e.
Nov 18 20:19:49 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address 2405:204:102c:c0f2:a1ff:e0fd:1f7b:5d53.
Nov 18 20:19:49 sh3ll NetworkManager[636]: <info>  [1574088589.1533] policy: set 'AmityWifi' (wlp2s0) as default for IPv6 routing and DNS
Nov 18 20:19:49 sh3ll avahi-daemon[639]: Registering new address record for 2405:204:102c:c0f2:a1ff:e0fd:1f7b:5d53 on wlp2s0.*.
Nov 18 20:19:49 sh3ll avahi-daemon[639]: Withdrawing address record for fe80::7cc9:9e9d:3a80:933e on wlp2s0.
Nov 18 20:19:53 sh3ll systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Nov 18 20:19:53 sh3ll kernel: audit: type=1131 audit(1574088593.146:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:19:53 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:19:58 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-27 noise=9999 txrate=72200
Nov 18 20:27:28 sh3ll systemd-logind[637]: Lid closed.
Nov 18 20:27:29 sh3ll systemd-logind[637]: Suspending...
Nov 18 20:27:29 sh3ll NetworkManager[636]: <info>  [1574089049.5918] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Nov 18 20:27:29 sh3ll NetworkManager[636]: <info>  [1574089049.5919] device (enp3s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 18 20:27:29 sh3ll NetworkManager[636]: <info>  [1574089049.6146] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 18 20:27:29 sh3ll NetworkManager[636]: <info>  [1574089049.6151] manager: NetworkManager state is now ASLEEP
Nov 18 20:27:29 sh3ll systemd[1]: Starting TLP suspend/resume...
-- The job identifier is 2044.
Nov 18 20:27:29 sh3ll systemd[1]: Started TLP suspend/resume.
Some more lines :frowning:
Nov 18 20:27:29 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:27:29 sh3ll kernel: audit: type=1130 audit(1574089049.763:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:27:29 sh3ll systemd[1]: Reached target Sleep.
-- The job identifier is 2043.
Nov 18 20:27:29 sh3ll systemd[1]: Starting Suspend...
-- The job identifier is 2042.
Nov 18 20:27:29 sh3ll systemd-sleep[3293]: Suspending system...
Nov 18 20:27:29 sh3ll kernel: PM: suspend entry (deep)
Nov 18 20:27:29 sh3ll kernel: broken atomic modeset userspace detected, disabling atomic
Nov 18 20:27:29 sh3ll audit[3178]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=3178 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Nov 18 20:27:29 sh3ll kernel: audit: type=1701 audit(1574089049.796:120): auid=4294967295 uid=0 gid=0 ses=4294967295 subj==unconfined pid=3178 comm="Xorg" exe="/usr/lib/Xorg" sig=6 res=1
Nov 18 20:27:29 sh3ll systemd[1]: Started Process Core Dump (PID 3297/UID 0).
-- Subject: A start job for unit systemd-coredump@3-3297-0.service has finished successfully
-- A start job for unit systemd-coredump@3-3297-0.service has finished successfully.
-- The job identifier is 2097.
Nov 18 20:27:29 sh3ll kernel: audit: type=1130 audit(1574089049.806:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-3297-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 20:27:29 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-3297-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll kernel: Filesystems sync: 0.491 seconds
Nov 18 21:18:09 sh3ll kernel: Freezing user space processes ... (elapsed 0.041 seconds) done.
Nov 18 21:18:09 sh3ll kernel: OOM killer disabled.
Nov 18 21:18:09 sh3ll kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Nov 18 21:18:09 sh3ll kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Nov 18 21:18:09 sh3ll kernel: wlp2s0: deauthenticating from 90:78:b2:e8:63:f9 by local choice (Reason: 3=DEAUTH_LEAVING)
Nov 18 21:18:09 sh3ll kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Nov 18 21:18:09 sh3ll kernel: sd 0:0:0:0: [sda] Stopping disk
Nov 18 21:18:09 sh3ll kernel: ACPI: EC: interrupt blocked
Nov 18 21:18:09 sh3ll kernel: ACPI: Preparing to enter system sleep state S3
Nov 18 21:18:09 sh3ll kernel: ACPI: EC: event blocked
Nov 18 21:18:09 sh3ll kernel: ACPI: EC: EC stopped
Nov 18 21:18:09 sh3ll kernel: PM: Saving platform NVS memory
Nov 18 21:18:09 sh3ll kernel: Disabling non-boot CPUs ...
Nov 18 21:18:09 sh3ll kernel: smpboot: CPU 1 is now offline
Nov 18 21:18:09 sh3ll kernel: smpboot: CPU 2 is now offline
Nov 18 21:18:09 sh3ll kernel: smpboot: CPU 3 is now offline
Nov 18 21:18:09 sh3ll kernel: ACPI: Low-level resume complete
Nov 18 21:18:09 sh3ll kernel: ACPI: EC: EC started
Nov 18 21:18:09 sh3ll kernel: PM: Restoring platform NVS memory
Nov 18 21:18:09 sh3ll kernel: Enabling non-boot CPUs ...
Nov 18 21:18:09 sh3ll kernel: x86: Booting SMP configuration:
Nov 18 21:18:09 sh3ll kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Nov 18 21:18:09 sh3ll kernel: microcode: sig=0x806e9, pf=0x80, revision=0x8e
Nov 18 21:18:09 sh3ll kernel: CPU1 is up
Nov 18 21:18:09 sh3ll kernel: smpboot: Booting Node 0 Processor 2 APIC 0x1
Nov 18 21:18:09 sh3ll kernel: microcode: sig=0x806e9, pf=0x80, revision=0xca
Nov 18 21:18:09 sh3ll kernel: CPU2 is up
Nov 18 21:18:09 sh3ll kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Nov 18 21:18:09 sh3ll kernel: CPU3 is up
Nov 18 21:18:09 sh3ll kernel: ACPI: Waking up from system sleep state S3
Nov 18 21:18:09 sh3ll kernel: ACPI: EC: interrupt unblocked
Nov 18 21:18:09 sh3ll kernel: nvidia 0000:01:00.0: Enabling HDA controller
Nov 18 21:18:09 sh3ll kernel: ACPI: EC: event unblocked
Nov 18 21:18:09 sh3ll kernel: sd 0:0:0:0: [sda] Starting disk
Nov 18 21:18:09 sh3ll kernel: iwlwifi 0000:02:00.0: Applying debug destination EXTERNAL_DRAM
Nov 18 21:18:09 sh3ll kernel: iwlwifi 0000:02:00.0: FW already configured (0) - re-configuring
Nov 18 21:18:09 sh3ll kernel: usb 1-8: reset full-speed USB device number 3 using xhci_hcd
Nov 18 21:18:09 sh3ll kernel: ata3: SATA link down (SStatus 4 SControl 300)
Nov 18 21:18:09 sh3ll kernel: atkbd serio0: Spurious ACK on isa0060/serio0. Some program might be trying to access hardware directly.
Nov 18 21:18:09 sh3ll kernel: usb 1-6: reset high-speed USB device number 2 using xhci_hcd
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:13: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:12: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:11: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:10: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:0f: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:0e: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:0d: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:0c: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:0b: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:0a: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:09: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:08: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:07: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:06: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:04: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:03: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:02: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:01: Turning OFF
Nov 18 21:18:09 sh3ll kernel: acpi LNXPOWER:00: Turning OFF
Nov 18 21:18:09 sh3ll kernel: OOM killer enabled.
Nov 18 21:18:09 sh3ll kernel: Restarting tasks ... done.
Nov 18 21:18:09 sh3ll kernel: mei_hdcp mei::b638ab7e-94e2-4ea2-a552-d1c54b627f04:01: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Nov 18 21:18:09 sh3ll bluetoothd[638]: Endpoint unregistered: sender=:1.70 path=/MediaEndpoint/A2DPSink/sbc
Nov 18 21:18:09 sh3ll systemd-logind[637]: Lid opened.
Nov 18 21:18:09 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=90:78:b2:e8:63:f9 reason=3 locally_generated=1
Nov 18 21:18:09 sh3ll wpa_supplicant[724]: dbus: wpa_dbus_property_changed: no property SessionLength in object /fi/w1/wpa_supplicant1/Interfaces/2
Nov 18 21:18:09 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=WORLD
Nov 18 21:18:09 sh3ll bluetoothd[638]: Endpoint unregistered: sender=:1.70 path=/MediaEndpoint/A2DPSource/sbc
Nov 18 21:18:09 sh3ll systemd[1]: Starting Load/Save RF Kill Switch Status...
-- The job identifier is 2106.
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.7446] bluez5: NAP: removed interface 3C:F8:62:F4:B2:70
Nov 18 21:18:09 sh3ll NetworkManager[636]: <warn>  [1574092089.7538] sup-iface[0x55ced37c5300,wlp2s0]: connection disconnected (reason -3)
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.7539] device (wlp2s0): supplicant interface state: completed -> disconnected
Nov 18 21:18:09 sh3ll systemd[1]: Stopped target Bluetooth.
-- The job identifier is 2114 and the job result is done.
Nov 18 21:18:09 sh3ll kernel: Bluetooth: hci0: read Intel version: 370810011003110e00
Nov 18 21:18:09 sh3ll kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
Nov 18 21:18:09 sh3ll systemd[1]: Started Load/Save RF Kill Switch Status.
Nov 18 21:18:09 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll systemd[1]: Reached target Bluetooth.
-- The job identifier is 2115.
Nov 18 21:18:09 sh3ll kernel: audit: type=1130 audit(1574092089.786:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll systemd-sleep[3293]: System resumed.
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/technical-issues-and-assistance
Nov 18 21:18:09 sh3ll kernel: PM: suspend exit
Nov 18 21:18:09 sh3ll systemd[1]: systemd-suspend.service: Succeeded.
Nov 18 21:18:09 sh3ll systemd[1]: Started Suspend.
Nov 18 21:18:09 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll systemd[1]: Stopped target Sleep.
-- The job identifier is 2170 and the job result is done.
Nov 18 21:18:09 sh3ll systemd[1]: Reached target Suspend.
-- The job identifier is 2041.
Nov 18 21:18:09 sh3ll kernel: audit: type=1130 audit(1574092089.799:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll kernel: audit: type=1131 audit(1574092089.799:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll systemd-logind[637]: Operation 'sleep' finished.
Nov 18 21:18:09 sh3ll systemd[1]: Stopping TLP suspend/resume...
-- The job identifier is 2174.
Nov 18 21:18:09 sh3ll systemd[1]: Stopped target Suspend.
-- The job identifier is 2173 and the job result is done.
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.8131] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.8132] device (wlp2s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 18 21:18:09 sh3ll kernel: broken atomic modeset userspace detected, disabling atomic
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.8300] dhcp4 (wlp2s0): canceled DHCP transaction
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.8300] dhcp4 (wlp2s0): state changed bound -> done
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Withdrawing address record for 192.168.43.26 on wlp2s0.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.43.26.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Withdrawing address record for 2405:204:102c:c0f2:a1ff:e0fd:1f7b:5d53 on wlp2s0.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address 2405:204:102c:c0f2:a1ff:e0fd:1f7b:5d53.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::7cc9:9e9d:3a80:933e.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Registering new address record for fe80::7cc9:9e9d:3a80:933e on wlp2s0.*.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Withdrawing address record for fe80::7cc9:9e9d:3a80:933e on wlp2s0.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::7cc9:9e9d:3a80:933e.
Nov 18 21:18:09 sh3ll avahi-daemon[639]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.8328] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.8396] manager: NetworkManager state is now DISCONNECTED
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.8415] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 18 21:18:09 sh3ll kernel: Generic Realtek PHY r8169-300:00: attached PHY driver [Generic Realtek PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
Nov 18 21:18:09 sh3ll dbus-daemon[635]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.8' (uid=0 pid=636 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Nov 18 21:18:09 sh3ll systemd[1]: Starting Network Manager Script Dispatcher Service...
-- The job identifier is 2175.
Nov 18 21:18:09 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 18 21:18:09 sh3ll systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 18 21:18:09 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll kernel: audit: type=1130 audit(1574092089.853:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:09 sh3ll wpa_supplicant[724]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.9420] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 18 21:18:09 sh3ll kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.9445] device (wlp2s0): set-hw-addr: set MAC address to DA:C8:EC:4F:E8:FE (scanning)
Nov 18 21:18:09 sh3ll NetworkManager[636]: <info>  [1574092089.9467] device (p2p-dev-wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
Nov 18 21:18:10 sh3ll wpa_supplicant[724]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Nov 18 21:18:10 sh3ll kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Nov 18 21:18:10 sh3ll kernel: Bluetooth: hci0: Intel firmware patch completed and activated
Nov 18 21:18:11 sh3ll lightdm[3440]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Nov 18 21:18:12 sh3ll systemd[1]: Created slice User Slice of UID 970.
-- The job identifier is 2230.
Nov 18 21:18:12 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:12 sh3ll systemd[1]: Starting User Manager for UID 970...
-- The job identifier is 2229.
Nov 18 21:18:12 sh3ll kernel: audit: type=1130 audit(1574092092.013:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:12 sh3ll systemd[3444]: Started Update XDG user dir configuration.
-- The job identifier is 17.
Nov 18 21:18:12 sh3ll systemd[3444]: Reached target Main User Target.
-- The job identifier is 1.
Nov 18 21:18:12 sh3ll systemd[3444]: Startup finished in 54ms.
-- Subject: User manager start-up is now complete
-- The user manager instance for user 970 has been started. All services queued
-- for starting have been started. Note that other services might still be starting
-- up or be started at any later time.
-- Startup of the manager took 54251 microseconds.
Nov 18 21:18:12 sh3ll ModemManager[727]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.4/0000:02:00.0': not supported by any plugin
Nov 18 21:18:12 sh3ll ModemManager[727]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.5/0000:03:00.0': not supported by any plugin
Nov 18 21:18:12 sh3ll kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 18 21:18:12 sh3ll kernel: ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
Nov 18 21:18:12 sh3ll kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Nov 18 21:18:12 sh3ll kernel: ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
Nov 18 21:18:12 sh3ll kernel: ata1.00: configured for UDMA/133
Nov 18 21:18:12 sh3ll bluetoothd[638]: Endpoint registered: sender=:1.70 path=/MediaEndpoint/A2DPSink/sbc
Nov 18 21:18:12 sh3ll bluetoothd[638]: Endpoint registered: sender=:1.70 path=/MediaEndpoint/A2DPSource/sbc
Nov 18 21:18:12 sh3ll NetworkManager[636]: <info>  [1574092092.9501] bluez5: NAP: added interface 3C:F8:62:F4:B2:70
Nov 18 21:18:12 sh3ll NetworkManager[636]: <info>  [1574092092.9885] sup-iface[0x55ced37c53f0,wlp2s0]: supports 5 scan SSIDs
Nov 18 21:18:12 sh3ll NetworkManager[636]: <info>  [1574092092.9894] device (wlp2s0): supplicant interface state: starting -> ready
Nov 18 21:18:12 sh3ll NetworkManager[636]: <info>  [1574092092.9895] device (p2p-dev-wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 18 21:18:12 sh3ll NetworkManager[636]: <info>  [1574092092.9898] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 18 21:18:12 sh3ll systemd[3444]: Started D-Bus User Message Bus.
-- The job identifier is 18.
Nov 18 21:18:12 sh3ll dbus-daemon[3490]: [session uid=970 pid=3490] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=970 pid=3456 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Nov 18 21:18:12 sh3ll systemd[3444]: Starting Accessibility services bus...
-- Subject: A start job for unit UNIT has begun execution
-- A start job for unit UNIT has begun execution.
-- The job identifier is 34.
Nov 18 21:18:13 sh3ll dbus-daemon[3490]: [session uid=970 pid=3490] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.2' (uid=970 pid=3499 comm="/usr/lib/at-spi-bus-launcher " label="unconfined")
Nov 18 21:18:13 sh3ll kernel: kauditd_printk_skb: 1 callbacks suppressed
Nov 18 21:18:13 sh3ll kernel: audit: type=1131 audit(1574092093.043:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:13 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:13 sh3ll systemd-coredump[3298]: Process 3178 (Xorg) of user 0 dumped core.
                                              Stack trace of thread 3178:
                                              #0  0x00007f84954faf25 raise (libc.so.6)
                                              #1  0x00007f84954e4897 abort (libc.so.6)
                                              #2  0x000055af4c4ebc8a OsAbort (Xorg)
                                              #3  0x000055af4c4ef4c1 FatalError (Xorg)
                                              #4  0x000055af4c4f2cf2 n/a (Xorg)
                                              #5  0x00007f84954fafb0 __restore_rt (libc.so.6)
                                              #6  0x00007f84954faf25 raise (libc.so.6)
                                              #7  0x00007f84954e4897 abort (libc.so.6)
                                              #8  0x00007f84954e4767 __assert_fail_base.cold (libc.so.6)
                                              #9  0x00007f84954f3526 __assert_fail (libc.so.6)
                                              #10 0x000055af4c59ba79 dixRegisterPrivateKey (Xorg)
                                              #11 0x00007f848feba6e9 glamor_init (libglamoregl.so)
                                              #12 0x00007f84902428cd n/a (modesetting_drv.so)
                                              #13 0x000055af4c5bbfce AddGPUScreen (Xorg)
                                              #14 0x000055af4c4bed22 n/a (Xorg)
                                              #15 0x000055af4c4a05a6 n/a (Xorg)
                                              #16 0x000055af4c49352a n/a (Xorg)
                                              #17 0x000055af4c49428b config_init (Xorg)
                                              #18 0x000055af4c4d9189 InitInput (Xorg)
                                              #19 0x000055af4c4817fa n/a (Xorg)
                                              #20 0x00007f84954e6153 __libc_start_main (libc.so.6)
                                              #21 0x000055af4c4823ae _start (Xorg)
                                              Stack trace of thread 3295:
                                              #0  0x00007f8494f5dc45 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                                              #1  0x00007f848f57b5ac n/a (i965_dri.so)
                                              #2  0x00007f848f57b1a8 n/a (i965_dri.so)
                                              #3  0x00007f8494f574cf start_thread (libpthread.so.0)
                                              #4  0x00007f84955be2d3 __clone (libc.so.6)
-- Subject: Process 3178 (Xorg) dumped core
-- Process 3178 (Xorg) crashed and dumped core.
Nov 18 21:18:13 sh3ll systemd[1]: systemd-coredump@3-3297-0.service: Succeeded.
-- The unit systemd-coredump@3-3297-0.service has successfully entered the 'dead' state.
Nov 18 21:18:16 sh3ll kernel: audit: type=1131 audit(1574092093.133:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-3297-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:16 sh3ll kernel: audit: type=1131 audit(1574092094.786:131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:13 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-3297-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:14 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:13 sh3ll polkitd[632]: /usr/share/polkit-1/rules.d/lightdm.rules:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Nov 18 21:18:16 sh3ll at-spi-bus-launcher[3499]: dbus-daemon[3540]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=970 pid=3456 comm="/usr/bin/lightdm-gtk-greeter " label="unconfined")
Nov 18 21:18:16 sh3ll at-spi-bus-launcher[3499]: dbus-daemon[3540]: Successfully activated service 'org.a11y.atspi.Registry'
Nov 18 21:18:14 sh3ll systemd[1]: systemd-rfkill.service: Succeeded.
-- The unit systemd-rfkill.service has successfully entered the 'dead' state.
Nov 18 21:18:13 sh3ll polkitd[632]: /usr/share/polkit-1/rules.d/lightdm.rules:4: subject=[Subject pid=3456 user='lightdm' groups=lightdm seat='seat0' session='c5' local=true active=true]
Nov 18 21:18:16 sh3ll at-spi-bus-launcher[3499]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Nov 18 21:18:18 sh3ll lightdm[3574]: gkr-pam: unable to locate daemon control file
Nov 18 21:18:18 sh3ll systemd[1]: session-c5.scope: Killing process 3440 (lightdm) with signal SIGTERM.
Nov 18 21:18:18 sh3ll systemd[1]: session-c5.scope: Killing process 3456 (lightdm-gtk-gre) with signal SIGTERM.
Nov 18 21:18:18 sh3ll systemd[1]: Stopping Session c5 of user lightdm.
-- Subject: A stop job for unit session-c5.scope has begun execution
-- A stop job for unit session-c5.scope has begun execution.
-- The job identifier is 2342.
Nov 18 21:18:19 sh3ll lightdm[3440]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Nov 18 21:18:19 sh3ll systemd[1]: session-c5.scope: Succeeded.
-- Subject: Unit succeeded
-- The unit session-c5.scope has successfully entered the 'dead' state.
Nov 18 21:18:19 sh3ll systemd[1]: Stopped Session c5 of user lightdm.
-- Subject: A stop job for unit session-c5.scope has finished
-- A stop job for unit session-c5.scope has finished.
-- The job identifier is 2342 and the job result is done.
Nov 18 21:18:19 sh3ll systemd-logind[637]: Removed session c5.
-- Subject: Session c5 has been terminated
-- A session with the ID c5 has been terminated.
Nov 18 21:18:20 sh3ll systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Nov 18 21:18:20 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:20 sh3ll kernel: audit: type=1131 audit(1574092100.036:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:29 sh3ll systemd[1]: Stopping User Manager for UID 970...
-- Subject: A stop job for unit user@970.service has begun execution
-- A stop job for unit user@970.service has begun execution.
-- The job identifier is 2343.
Nov 18 21:18:29 sh3ll systemd[3444]: Stopping D-Bus User Message Bus...
-- Subject: A stop job for unit UNIT has begun execution
-- A stop job for unit UNIT has begun execution.
-- The job identifier is 81.
Nov 18 21:18:29 sh3ll kernel: audit: type=1131 audit(1574092109.166:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:29 sh3ll kernel: audit: type=1131 audit(1574092109.173:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:29 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:29 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:29 sh3ll systemd[3444]: run-user-970-gvfs.mount: Succeeded.
-- The unit UNIT has successfully entered the 'dead' state.
Nov 18 21:18:29 sh3ll systemd[3445]: pam_unix(systemd-user:session): session closed for user lightdm
Nov 18 21:18:29 sh3ll systemd[3444]: gvfs-daemon.service: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Stopped Virtual filesystem service.
-- Subject: A stop job for unit UNIT has finished
-- A stop job for unit UNIT has finished.
-- The job identifier is 82 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: Stopped target Basic System.
-- The job identifier is 77 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: Stopped target Timers.
-- The job identifier is 69 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: Stopped target Sockets.
-- The job identifier is 85 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: dirmngr.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed GnuPG network certificate management daemon.
-- The job identifier is 87 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: pulseaudio.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed Sound System.
-- The job identifier is 91 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: gpg-agent-ssh.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed GnuPG cryptographic agent (ssh-agent emulation).
-- The job identifier is 88 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: gpg-agent-browser.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
-- The job identifier is 84 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: dbus.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed D-Bus User Message Bus Socket.
-- The job identifier is 83 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: gpg-agent.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed GnuPG cryptographic agent and passphrase cache.
-- The job identifier is 76 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: p11-kit-server.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed p11-kit server.
-- The job identifier is 73 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: gpg-agent-extra.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
-- The job identifier is 90 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: pipewire.socket: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Closed Multimedia System.
-- The job identifier is 89 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: Stopped target Paths.
-- The job identifier is 86 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[3444]: Reached target Shutdown.
-- Subject: A start job for unit UNIT has finished successfully
-- A start job for unit UNIT has finished successfully.
-- The job identifier is 68.
Nov 18 21:18:29 sh3ll systemd[3444]: systemd-exit.service: Succeeded.
Nov 18 21:18:29 sh3ll systemd[3444]: Started Exit the Session.
-- The job identifier is 67.
Nov 18 21:18:29 sh3ll systemd[3444]: Reached target Exit the Session.
-- The job identifier is 66.
Nov 18 21:18:29 sh3ll systemd[1]: user@970.service: Succeeded.
-- The unit user@970.service has successfully entered the 'dead' state.
Nov 18 21:18:29 sh3ll systemd[1]: Stopped User Manager for UID 970.
-- Subject: A stop job for unit user@970.service has finished
-- A stop job for unit user@970.service has finished.
-- The job identifier is 2343 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[1]: Stopping User Runtime Directory /run/user/970...
-- Subject: A stop job for unit user-runtime-dir@970.service has begun execution
-- A stop job for unit user-runtime-dir@970.service has begun execution.
-- The job identifier is 2344.
Nov 18 21:18:29 sh3ll systemd[1]: run-user-970.mount: Succeeded.
-- The unit run-user-970.mount has successfully entered the 'dead' state.
Nov 18 21:18:29 sh3ll systemd[1]: user-runtime-dir@970.service: Succeeded.
-- The unit user-runtime-dir@970.service has successfully entered the 'dead' state.
Nov 18 21:18:29 sh3ll systemd[1]: Stopped User Runtime Directory /run/user/970.
-- Subject: A stop job for unit user-runtime-dir@970.service has finished
-- A stop job for unit user-runtime-dir@970.service has finished.
-- The job identifier is 2344 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[1]: Removed slice User Slice of UID 970.
-- Subject: A stop job for unit user-970.slice has finished
-- A stop job for unit user-970.slice has finished.
-- The job identifier is 2345 and the job result is done.
Nov 18 21:18:29 sh3ll systemd[945]: run-user-970.mount: Succeeded.
Nov 18 21:18:41 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=IN
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1576] policy: auto-activating connection 'Amity-WiFi' (579da533-550b-4513-9e1f-310347e600d0)
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1580] device (wlp2s0): Activation: starting connection 'Amity-WiFi' (579da533-550b-4513-9e1f-310347e600d0)
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1581] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1585] manager: NetworkManager state is now CONNECTING
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1599] device (wlp2s0): set-hw-addr: reset MAC address to 3C:F8:62:F4:B2:6C (preserve)
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1633] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1636] device (wlp2s0): Activation: (wifi) connection 'Amity-WiFi' requires no security.  No secrets needed.
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1636] Config: added 'ssid' value 'Amity-WiFi'
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1636] Config: added 'scan_ssid' value '1'
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1637] Config: added 'bgscan' value 'simple:30:-80:86400'
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1637] Config: added 'key_mgmt' value 'NONE'
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1913] device (wlp2s0): supplicant interface state: ready -> disconnected
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1914] device (p2p-dev-wlp2s0): supplicant management interface state: ready -> disconnected
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1941] device (wlp2s0): supplicant interface state: disconnected -> inactive
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.1942] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.2009] device (wlp2s0): supplicant interface state: inactive -> scanning
Nov 18 21:18:41 sh3ll NetworkManager[636]: <info>  [1574092121.2010] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> scanning
Nov 18 21:18:42 sh3ll wpa_supplicant[724]: wlp2s0: SME: Trying to authenticate with 70:ea:1a:04:cd:d4 (SSID='Amity-WiFi' freq=2437 MHz)
Nov 18 21:18:42 sh3ll kernel: wlp2s0: authenticate with 70:ea:1a:04:cd:d4
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.6181] device (wlp2s0): supplicant interface state: scanning -> authenticating
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.6182] device (p2p-dev-wlp2s0): supplicant management interface state: scanning -> authenticating
Nov 18 21:18:42 sh3ll kernel: wlp2s0: send auth to 70:ea:1a:04:cd:d4 (try 1/3)
Nov 18 21:18:42 sh3ll wpa_supplicant[724]: wlp2s0: Trying to associate with 70:ea:1a:04:cd:d4 (SSID='Amity-WiFi' freq=2437 MHz)
Nov 18 21:18:42 sh3ll kernel: wlp2s0: authenticated
Nov 18 21:18:42 sh3ll kernel: wlp2s0: associate with 70:ea:1a:04:cd:d4 (try 1/3)
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.6236] device (wlp2s0): supplicant interface state: authenticating -> associating
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.6237] device (p2p-dev-wlp2s0): supplicant management interface state: authenticating -> associating
Nov 18 21:18:42 sh3ll kernel: wlp2s0: RX AssocResp from 70:ea:1a:04:cd:d4 (capab=0x1421 status=0 aid=188)
Nov 18 21:18:42 sh3ll wpa_supplicant[724]: wlp2s0: Associated with 70:ea:1a:04:cd:d4
Nov 18 21:18:42 sh3ll kernel: wlp2s0: associated
Nov 18 21:18:42 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 70:ea:1a:04:cd:d4 completed [id=0 id_str=]
Nov 18 21:18:42 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 18 21:18:42 sh3ll kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
Nov 18 21:18:42 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-69 noise=9999 txrate=1000
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.7682] device (wlp2s0): supplicant interface state: associating -> completed
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.7683] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Amity-WiFi"
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.7683] device (p2p-dev-wlp2s0): supplicant management interface state: associating -> completed
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.7696] device (wlp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 18 21:18:42 sh3ll NetworkManager[636]: <info>  [1574092122.7704] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Nov 18 21:18:42 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::b198:3f20:315a:42a8.
Nov 18 21:18:42 sh3ll avahi-daemon[639]: New relevant interface wlp2s0.IPv6 for mDNS.
Nov 18 21:18:42 sh3ll avahi-daemon[639]: Registering new address record for fe80::b198:3f20:315a:42a8 on wlp2s0.*.
Nov 18 21:18:42 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=9999 txrate=43300
Nov 18 21:18:42 sh3ll kernel: wlp2s0: Limiting TX power to 22 dBm as advertised by 70:ea:1a:04:cd:d4
Nov 18 21:18:42 sh3ll dbus-daemon[635]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.8' (uid=0 pid=636 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Nov 18 21:18:43 sh3ll systemd[1]: Starting Network Manager Script Dispatcher Service...
-- Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
-- A start job for unit NetworkManager-dispatcher.service has begun execution.
-- The job identifier is 2346.
Nov 18 21:18:43 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 18 21:18:43 sh3ll systemd[1]: Started Network Manager Script Dispatcher Service.
-- Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
-- A start job for unit NetworkManager-dispatcher.service has finished successfully.
Nov 18 21:18:43 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:43 sh3ll kernel: audit: type=1130 audit(1574092123.013:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7774] dhcp4 (wlp2s0): state changed unknown -> bound
Nov 18 21:18:51 sh3ll avahi-daemon[639]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 10.103.181.184.
Nov 18 21:18:51 sh3ll avahi-daemon[639]: New relevant interface wlp2s0.IPv4 for mDNS.
Nov 18 21:18:51 sh3ll avahi-daemon[639]: Registering new address record for 10.103.181.184 on wlp2s0.IPv4.
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7830] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7866] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7869] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7874] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7900] manager: NetworkManager state is now CONNECTED_SITE
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7902] policy: set 'Amity-WiFi' (wlp2s0) as default for IPv4 routing and DNS
Nov 18 21:18:51 sh3ll NetworkManager[636]: <info>  [1574092131.7908] device (wlp2s0): Activation: successful, device activated.
Nov 18 21:18:52 sh3ll NetworkManager[636]: <info>  [1574092132.3549] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 18 21:18:53 sh3ll systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Nov 18 21:18:53 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:18:53 sh3ll kernel: audit: type=1131 audit(1574092133.026:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:19:34 sh3ll wpa_supplicant[724]: wlp2s0: CTRL-EVENT-BEACON-LOSS
Nov 18 21:20:11 sh3ll systemd[1]: Started Getty on tty2.
-- Subject: A start job for unit getty@tty2.service has finished successfully
-- A start job for unit getty@tty2.service has finished successfully.
-- The job identifier is 2400.
Nov 18 21:20:11 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:11 sh3ll kernel: audit: type=1130 audit(1574092211.686:137): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:11 sh3ll kernel: fbcon: Taking over console
Nov 18 21:20:11 sh3ll kernel: Console: switching to colour frame buffer device 240x67
Nov 18 21:20:20 sh3ll login[3601]: pam_tally2(login:auth): pam_get_uid; no such user
Nov 18 21:20:22 sh3ll login[3601]: pam_unix(login:auth): check pass; user unknown
Nov 18 21:20:22 sh3ll login[3601]: pam_unix(login:auth): authentication failure; logname=LOGIN uid=0 euid=0 tty=tty2 ruser= rhost=
Nov 18 21:20:24 sh3ll login[3601]: FAILED LOGIN 1 FROM tty2 FOR startx, Authentication failure
Nov 18 21:20:28 sh3ll kernel: audit: type=1006 audit(1574092228.296:138): pid=3601 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=8 res=1
Nov 18 21:20:28 sh3ll login[3601]: pam_unix(login:session): session opened for user mehul by LOGIN(uid=0)
Nov 18 21:20:28 sh3ll systemd-logind[637]: New session 8 of user mehul.
-- Subject: A new session 8 has been created for user mehul
-- Documentation: https://www.freedesktop.org/wiki/Software/systemd/multiseat
-- A new session with the ID 8 has been created for the user mehul.
-- The leading process of the session is 3601.
Nov 18 21:20:28 sh3ll systemd[1]: Started Session 8 of user mehul.
-- Subject: A start job for unit session-8.scope has finished successfully
-- A start job for unit session-8.scope has finished successfully.
-- The job identifier is 2456.
Nov 18 21:20:28 sh3ll login[3601]: LOGIN ON tty2 BY mehul
Nov 18 21:20:30 sh3ll kernel: broken atomic modeset userspace detected, disabling atomic
Nov 18 21:20:31 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.gtk.vfs.Daemon' requested by ':1.0' (uid=1000 pid=3649 comm="xfce4-session " label="unconfined")
Nov 18 21:20:31 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.gtk.vfs.Daemon'
Nov 18 21:20:31 sh3ll org.gtk.vfs.Daemon[3656]: fusermount3: failed to access mountpoint /run/user/1000/gvfs: Permission denied
Nov 18 21:20:31 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.xfce.Xfconf' requested by ':1.0' (uid=1000 pid=3649 comm="xfce4-session " label="unconfined")
Nov 18 21:20:31 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.xfce.Xfconf'
Nov 18 21:20:31 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.freedesktop.systemd1' requested by ':1.3' (uid=1000 pid=3677 comm="dbus-update-activation-environment --systemd SSH_A" label="unconfined")
Nov 18 21:20:31 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Nov 18 21:20:33 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.freedesktop.Notifications' requested by ':1.17' (uid=1000 pid=3700 comm="/usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/pa" label="unconfined")
Nov 18 21:20:33 sh3ll xfce4-notifyd[3715]: theme 'Matcha-sea' is not found anywhere is user themes directories
Nov 18 21:20:33 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.freedesktop.Notifications'
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.19' (uid=1000 pid=3701 comm="xfdesktop " label="unconfined")
Nov 18 21:20:34 sh3ll org.freedesktop.thumbnails.Thumbnailer1[3656]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Nov 18 21:20:34 sh3ll org.freedesktop.thumbnails.Thumbnailer1[3656]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Nov 18 21:20:34 sh3ll org.freedesktop.thumbnails.Thumbnailer1[3656]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Nov 18 21:20:34 sh3ll org.freedesktop.thumbnails.Thumbnailer1[3656]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.gtk.vfs.UDisks2VolumeMonitor' requested by ':1.21' (uid=1000 pid=3726 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.gtk.vfs.GPhoto2VolumeMonitor' requested by ':1.21' (uid=1000 pid=3726 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.gtk.vfs.AfcVolumeMonitor' requested by ':1.21' (uid=1000 pid=3726 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 18 21:20:34 sh3ll pulseaudio[1025]: E: [pulseaudio] module-x11-xsmp.c: module-x11-xsmp may not be loaded twice.
Nov 18 21:20:34 sh3ll pulseaudio[1025]: E: [pulseaudio] module.c: Failed to load module "module-x11-xsmp" (argument: "display=:1.0 session_manager=local/sh3ll:@/tmp/.ICE-unix/3649,unix/sh3ll:/tmp/.ICE-unix/3649"): initialization failed.
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='ca.desrt.dconf' requested by ':1.35' (uid=1000 pid=3754 comm="light-locker " label="unconfined")
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'ca.desrt.dconf'
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.gtk.vfs.MTPVolumeMonitor' requested by ':1.21' (uid=1000 pid=3726 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Activating service name='org.gtk.vfs.Metadata' requested by ':1.19' (uid=1000 pid=3701 comm="xfdesktop " label="unconfined")
Nov 18 21:20:34 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.gtk.vfs.Metadata'
Nov 18 21:20:34 sh3ll audit[3754]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=8 subj==unconfined pid=3754 comm="light-locker" exe="/usr/bin/light-locker" sig=5 res=1
Nov 18 21:20:34 sh3ll kernel: traps: light-locker[3754] trap int3 ip:7fd535ceb1b6 sp:7ffc61965370 error:0 in libglib-2.0.so.0.6200.2[7fd535ca3000+81000]
Nov 18 21:20:34 sh3ll kernel: audit: type=1701 audit(1574092234.583:139): auid=1000 uid=1000 gid=1000 ses=8 subj==unconfined pid=3754 comm="light-locker" exe="/usr/bin/light-locker" sig=5 res=1
Nov 18 21:20:34 sh3ll systemd[1]: Started Process Core Dump (PID 3819/UID 0).
-- Subject: A start job for unit systemd-coredump@4-3819-0.service has finished successfully
-- A start job for unit systemd-coredump@4-3819-0.service has finished successfully.
-- The job identifier is 2513.
Nov 18 21:20:34 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-3819-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:34 sh3ll kernel: audit: type=1130 audit(1574092234.603:140): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-3819-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:34 sh3ll polkitd[632]: Registered Authentication Agent for unix-session:8 (system bus name :1.679 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Nov 18 21:20:34 sh3ll pkexec[3823]: pam_unix(polkit-1:session): session opened for user root by (uid=1000)
Nov 18 21:20:34 sh3ll dbus-daemon[635]: [system] Activating via systemd: service name='org.manjaro.pamac.daemon' unit='pamac-daemon.service' requested by ':1.693' (uid=1000 pid=3731 comm="pamac-tray " label="unconfined")
Nov 18 21:20:34 sh3ll systemd[1]: Starting Pamac Daemon...
-- Subject: A start job for unit pamac-daemon.service has begun execution
-- A start job for unit pamac-daemon.service has begun execution.
-- The job identifier is 2522.
Nov 18 21:20:34 sh3ll pkexec[3823]: mehul: Executing command [USER=root] [TTY=unknown] [CWD=/] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness-switch 0]
Nov 18 21:20:34 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.manjaro.pamac.daemon'
Nov 18 21:20:34 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:34 sh3ll systemd[1]: Started Pamac Daemon.
-- Subject: A start job for unit pamac-daemon.service has finished successfully
-- A start job for unit pamac-daemon.service has finished successfully.
Nov 18 21:20:34 sh3ll kernel: audit: type=1130 audit(1574092234.723:141): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:34 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:34 sh3ll systemd[1]: pamac-daemon.service: Succeeded.
-- The unit pamac-daemon.service has successfully entered the 'dead' state.
Nov 18 21:20:34 sh3ll kernel: audit: type=1131 audit(1574092234.733:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 18 21:20:35 sh3ll systemd-coredump[3820]: Process 3754 (light-locker) of user 1000 dumped core.
                                              Stack trace of thread 3754:
                                              #0  0x00007fd535ceb1b6 n/a (libglib-2.0.so.0)
                                              #1  0x00007fd535cdff67 g_log_default_handler (libglib-2.0.so.0)
                                              #2  0x00007fd535ceb3ed g_logv (libglib-2.0.so.0)
                                              #3  0x00007fd535ceb5f0 g_log (libglib-2.0.so.0)
                                              #4  0x000055d64099fcb4 n/a (light-locker)
                                              #5  0x00007fd535dc6340 g_type_create_instance (libgobject-2.0.so.0)
                                              #6  0x00007fd535de2766 n/a (libgobject-2.0.so.0)
                                              #7  0x00007fd535de3bb5 g_object_new_with_properties (libgobject-2.0.so.0)
                                              #8  0x00007fd535de3cb2 g_object_new (libgobject-2.0.so.0)
                                              #9  0x000055d6409a24f3 gs_listener_new (light-locker)
                                              #10 0x000055d64099e484 n/a (light-locker)
                                              #11 0x00007fd535dc6340 g_type_create_instance (libgobject-2.0.so.0)
                                              #12 0x00007fd535de2766 n/a (libgobject-2.0.so.0)
                                              #13 0x00007fd535de3bb5 g_object_new_with_properties (libgobject-2.0.so.0)
                                              #14 0x00007fd535de3cb2 g_object_new (libgobject-2.0.so.0)
                                              #15 0x000055d64099eb03 gs_monitor_new (light-locker)
                                              #16 0x000055d64099d339 main (light-locker)
                                              #17 0x00007fd535820153 __libc_start_main (libc.so.6)
                                              #18 0x000055d64099d48e _start (light-locker)
                                              Stack trace of thread 3780:
                                              #0  0x00007fd5358ed9ef __poll (libc.so.6)
                                              #1  0x00007fd535cf3170 n/a (libglib-2.0.so.0)
                                              #2  0x00007fd535cf3241 g_main_context_iteration (libglib-2.0.so.0)
                                              #3  0x00007fd535cf3292 n/a (libglib-2.0.so.0)
                                              #4  0x00007fd535ccfc11 n/a (libglib-2.0.so.0)
                                              #5  0x00007fd53503a4cf start_thread (libpthread.so.0)
                                              #6  0x00007fd5358f82d3 __clone (libc.so.6)
                                              Stack trace of thread 3782:
                                              #2  0x00007fd535cf4113 g_main_loop_run (libglib-2.0.so.0)
                                              #3  0x00007fd5360dbba8 n/a (libgio-2.0.so.0)
                                              Stack trace of thread 3792:
                                              #3  0x00007fd5342b5e5e n/a (libdconfsettings.so)
-- Subject: Process 3754 (light-locker) dumped core
-- Documentation: man:core(5)
-- Process 3754 (light-locker) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
Nov 18 21:20:35 sh3ll systemd[1]: systemd-coredump@4-3819-0.service: Succeeded.
-- The unit systemd-coredump@4-3819-0.service has successfully entered the 'dead' state.
Nov 18 21:20:57 sh3ll dbus-daemon[3656]: [session uid=1000 pid=3654] Successfully activated service 'org.a11y.Bus'
I am not that advance in debugging and understanding these logs. So sorry for being such a pain.
I cold booted my system and this time lightdm didn't even start. These are the logs (extremely shorter than the previous ones)
$ cat ~/.xsession-errors
/usr/bin/iceauth:  creating new authority file /run/user/1000/ICEauthority
gpg-agent[1010]: WARNING: "--write-env-file" is an obsolete option - it has no effect
gpg-agent: a gpg-agent is already running - not starting a new one
(xfce4-session:960): xfce4-session-WARNING **: 19:31:40.524: gpg-agent returned no PID in the variables
(xfce4-session:960): xfce4-session-WARNING **: 19:31:40.534: xfsm_manager_load_session: Something wrong with /home/mehul/.cache/sessions/xfce4-session-sh3ll:0, Does it exist? Permissions issue?
(wrapper-2.0:1040): Gtk-WARNING **: 19:31:46.649: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner GtkToggleButton)
(wrapper-2.0:1043): Gtk-WARNING **: 19:31:46.682: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner PulseaudioButton)
** (xfce4-clipman:1082): WARNING **: 19:31:47.071: Unable to register GApplication: An object is already exported for the interface org.gtk.Application at /org/xfce/clipman
(xfce4-clipman:1082): GLib-GIO-CRITICAL **: 19:31:47.071: g_application_get_is_remote: assertion 'application->priv->is_registered' failed
(xfce4-clipman:1082): GLib-WARNING **: 19:31:47.071: g_set_application_name() called multiple times
(pamac-tray:1107): Gdk-CRITICAL **: 19:31:50.255: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
xfsettingsd: Another instance took over. Leaving...
(wrapper-2.0:1040): Gdk-CRITICAL **: 19:32:04.150: Window 0x5556c39ec700 has not been made visible in GdkSeatGrabPrepareFunc
(xfce4-panel:1018): Gtk-CRITICAL **: 19:35:20.609: gtk_icon_theme_load_icon: assertion 'icon_name != NULL' failed
(xfce4-panel:1018): Gtk-CRITICAL **: 19:35:20.611: gtk_icon_theme_load_icon: assertion 'icon_name != NULL' failed
(/usr/lib/firefox/firefox:2788): dconf-WARNING **: 20:19:13.259: Unable to open /var/lib/flatpak/exports/share/dconf/profile/user: Permission denied
(xfce4-terminal:3130): Gtk-WARNING **: 20:24:33.130: TerminalWidget 0x55d0dbffbf00 reported min size 22 and natural size 12 in get_preferred_width(); natural size must be >= min size
[Parent 2734, Gecko_IOThread] WARNING: pipe error (121): Connection reset by peer: file /build/firefox/src/firefox-70.0.1/ipc/chromium/src/chrome/common/ipc_channel_posix.cc, line 358
thunar-volman: Unsupported USB device type "usb".
thunar-volman: Unsupported input device type "/dev/input/event22".
thunar-volman: Unsupported input device type "/dev/input/event21".
thunar-volman: Unsupported input device type "/dev/input/event20".
thunar-volman: Unsupported input device type "/dev/input/event19".
thunar-volman: Unsupported input device type "/dev/input/event23".
thunar-volman: Unsupported input device type "(null)".
thunar-volman: Unsupported USB device type "usbhid".
thunar-volman: Unsupported input device type "/dev/input/event18".
Gdk-Message: 06:31:01.522: xfce4-session: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Gdk-Message: 06:31:01.542: xfwm4: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
** (xiccd:1096): WARNING **: 06:31:01.549: Exiting
Gdk-Message: 06:31:01.725: xfdesktop: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
$ journalctl -xb
Nov 20 00:20:36 sh3ll systemd-coredump[1181]: Process 1167 (light-locker) of user 1000 dumped core.
              Stack trace of thread 1167:
              #0  0x00007fe78c39f1b6 n/a (libglib-2.0.so.0)
              #1  0x00007fe78c393f67 g_log_default_handler (libglib-2.0.so.0)
              #2  0x00007fe78c39f3ed g_logv (libglib-2.0.so.0)
              #3  0x00007fe78c39f5f0 g_log (libglib-2.0.so.0)
              #4  0x000055fc7517acb4 n/a (light-locker)
              #5  0x00007fe78c47a340 g_type_create_instance (libgobject-2.0.so.0)
              #6  0x00007fe78c496766 n/a (libgobject-2.0.so.0)
              #7  0x00007fe78c497bb5 g_object_new_with_properties (libgobject-2.0.so.0)
              #8  0x00007fe78c497cb2 g_object_new (libgobject-2.0.so.0)
              #9  0x000055fc7517d4f3 gs_listener_new (light-locker)
              #10 0x000055fc75179484 n/a (light-locker)
              #11 0x00007fe78c47a340 g_type_create_instance (libgobject-2.0.so.0)
              #12 0x00007fe78c496766 n/a (libgobject-2.0.so.0)
              #13 0x00007fe78c497bb5 g_object_new_with_properties (libgobject-2.0.so.0)
              #14 0x00007fe78c497cb2 g_object_new (libgobject-2.0.so.0)
              #15 0x000055fc75179b03 gs_monitor_new (light-locker)
              #16 0x000055fc75178339 main (light-locker)
              #17 0x00007fe78bed4153 __libc_start_main (libc.so.6)
              #18 0x000055fc7517848e _start (light-locker)
              Stack trace of thread 1168:
              #0  0x00007fe78bfa19ef __poll (libc.so.6)
              #1  0x00007fe78c3a7170 n/a (libglib-2.0.so.0)
              #2  0x00007fe78c3a7241 g_main_context_iteration (libglib-2.0.so.0)
              #3  0x00007fe78c3a7292 n/a (libglib-2.0.so.0)
              #4  0x00007fe78c383c11 n/a (libglib-2.0.so.0)
              #5  0x00007fe78b6ee4cf start_thread (libpthread.so.0)
              #6  0x00007fe78bfac2d3 __clone (libc.so.6)
              Stack trace of thread 1170:
              #3  0x00007fe78a969e5e n/a (libdconfsettings.so)
              Stack trace of thread 1169:
              #2  0x00007fe78c3a8113 g_main_loop_run (libglib-2.0.so.0)
              #3  0x00007fe78c78fba8 n/a (libgio-2.0.so.0)
-- Subject: Process 1167 (light-locker) dumped core
-- Process 1167 (light-locker) crashed and dumped core.
Nov 20 00:20:36 sh3ll kernel: audit: type=1131 audit(1574189436.552:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1176-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 20 00:20:36 sh3ll audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-1176-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 20 00:20:36 sh3ll systemd[1]: systemd-coredump@0-1176-0.service: Succeeded.
-- The unit systemd-coredump@0-1176-0.service has successfully entered the 'dead' state.
Nov 20 00:20:38 sh3ll org.freedesktop.thumbnails.Thumbnailer1[1041]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Nov 20 00:20:38 sh3ll org.freedesktop.thumbnails.Thumbnailer1[1041]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Nov 20 00:20:38 sh3ll org.freedesktop.thumbnails.Thumbnailer1[1041]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Nov 20 00:20:38 sh3ll org.freedesktop.thumbnails.Thumbnailer1[1041]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Nov 20 00:20:38 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Activating service name='org.gtk.vfs.UDisks2VolumeMonitor' requested by ':1.22' (uid=1000 pid=1121 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 20 00:20:38 sh3ll dbus-daemon[635]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.124' (uid=1000 pid=1215 comm="/usr/lib/gvfs-udisks2-volume-monitor " label="unconfined")
Nov 20 00:20:38 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.freedesktop.UPower'
Nov 20 00:20:38 sh3ll systemd[1]: Started Daemon for power management.
-- Subject: A start job for unit upower.service has finished successfully
-- A start job for unit upower.service has finished successfully.
-- The job identifier is 1304.
Nov 20 00:20:38 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 20 00:20:38 sh3ll systemd[1]: Starting Disk Manager...
-- Subject: A start job for unit udisks2.service has begun execution
-- A start job for unit udisks2.service has begun execution.
-- The job identifier is 1358.
Nov 20 00:20:38 sh3ll kernel: audit: type=1130 audit(1574189438.626:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 20 00:20:38 sh3ll pkexec[1236]: pam_unix(polkit-1:session): session opened for user root by (uid=1000)
Nov 20 00:20:38 sh3ll pkexec[1236]: mehul: Executing command [USER=root] [TTY=unknown] [CWD=/] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness-switch 0]
Nov 20 00:20:38 sh3ll udisksd[1233]: udisks daemon version 2.8.4 starting
Nov 20 00:20:40 sh3ll dbus-daemon[635]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Nov 20 00:20:40 sh3ll systemd[1]: Started Disk Manager.
-- Subject: A start job for unit udisks2.service has finished successfully
-- A start job for unit udisks2.service has finished successfully.
Nov 20 00:20:40 sh3ll audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 20 00:20:40 sh3ll udisksd[1233]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 20 00:20:40 sh3ll kernel: audit: type=1130 audit(1574189440.419:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Activating service name='org.gtk.vfs.GPhoto2VolumeMonitor' requested by ':1.22' (uid=1000 pid=1121 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Activating service name='org.gtk.vfs.AfcVolumeMonitor' requested by ':1.22' (uid=1000 pid=1121 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Activating service name='org.gtk.vfs.MTPVolumeMonitor' requested by ':1.22' (uid=1000 pid=1121 comm="/usr/lib/tumbler-1/tumblerd " label="unconfined")
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Nov 20 00:20:40 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Nov 20 00:20:41 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Activating service name='org.gtk.vfs.Metadata' requested by ':1.21' (uid=1000 pid=1101 comm="xfdesktop " label="unconfined")
Nov 20 00:20:41 sh3ll dbus-daemon[1041]: [session uid=1000 pid=1039] Successfully activated service 'org.gtk.vfs.Metadata'
And now something more weird happened. After entering password in the lightdm greeter, the screen got blank and started blinking repeatedly every 3-4 seconds and I couldn't even start TTY as it would blink away every 3-4 second. I had to force shutdown.
This was the error I think:
Nov 21 20:49:27 sh3ll systemd-coredump[6781]: Process 6774 (Xorg) of user 0 dumped core.
           Stack trace of thread 6774:
           #0  0x00007f0945de2b8d _Unwind_IteratePhdrCallback (libgcc_s.so.1)
           #1  0x00007f094707fd55 dl_iterate_phdr (libc.so.6)
           #2  0x00007f0945de3c56 _Unwind_Find_FDE (libgcc_s.so.1)
           #3  0x00007f0945de0304 uw_frame_state_for (libgcc_s.so.1)
           #4  0x00007f0945de1510 uw_init_context_1 (libgcc_s.so.1)
           #5  0x00007f0945de225c _Unwind_Backtrace (libgcc_s.so.1)
           #6  0x00007f0947053846 __backtrace (libc.so.6)
           #7  0x000055d1953856fd xorg_backtrace (Xorg)
           #8  0x000055d19537bc88 n/a (Xorg)
           #9  0x00007f0946f82fb0 __restore_rt (libc.so.6)
           #10 0x00007f094714fefd _dl_fixup (ld-linux-x86-64.so.2)
           #11 0x00007f09471568ee _dl_runtime_resolve_xsavec (ld-linux-x86-64.so.2)
           #12 0x00007f09426dbd5c n/a (libglamoregl.so)
           #13 0x000055d1953f80af n/a (Xorg)
           #14 0x000055d1953ce74e n/a (Xorg)
           #15 0x000055d19540e734 RRCrtcSet (Xorg)
           #16 0x000055d19540f197 ProcRRSetCrtcConfig (Xorg)
           #17 0x00007f0942c0216d n/a (nvidia_drv.so)
-- Subject: Process 6774 (Xorg) dumped core
-- Process 6774 (Xorg) crashed and dumped core.
