Suspend no longer working
Some help requested.
Since updating last Sunday to this stable update, on my main system, Suspend has stopped working. Using Kernel 7.1.3. Suspend ends in a system hang. Rebooting with REISUB works.
Anyone else having issues?
Journalctl boot log from one of the hangs log
Around line 2723 suspend is initiated.
Another boot log: jul 14 00:08:13 Infinity systemd[1172]: Started Sleep System.jul 14 00:08:13 I - Pastebin.com
Will test if 6.18 is also effected on my system.
Tested Kernel 6.18, system does not go into suspend or hangs, log: On kernel 6.18 - Pastebin.com
There are more issues, networking seems to not start up well, firefox gives Server Not Found page on startup and Steam continuously updates after each reboot. Odd this is that this sarted happening only today, yesterday and this morning the system suspend and wake up funtioned normally.
System info inxi -v7azy
Seems like there’s a problem with the GPU module.
But the formatting is really hard to read.
The pastebin links worked for your logs, but you forgot to use --no-pager with journalctl.
The inxi didn’t work at all (the link is not there).
Which would tell us your GPU and other useful stuff.
Or you can just paste that to a code block here.
Pre-formatted text in the rich text editor mode.
And triple backticks ``` in markdown editor mode.
The inxi link seemed to been borked while posting, fixed it.
Late last evening I might have found the culprit, but I need to test. I’ll come back to this.
Here is the code block log from testing on 6.18
log with 6.18
jul 14 00:13:32 Infinity systemd[1130]: Started Sleep System.
jul 14 00:13:32 Infinity systemd-logind[900]: /etc/systemd/sleep.conf:27: Support for option SuspendMode= has been removed and it is ignored
jul 14 00:13:32 Infinity systemd-logind[900]: suspend requested from client PID 10435 ('systemctl') (unit user@1000.service)...
jul 14 00:13:32 Infinity systemd-logind[900]: The system will suspend now!
jul 14 00:13:32 Infinity org_kde_powerdevil[1458]: [  1514][245.021475] (ldbus_handle_message)Received dbus signal PrepareForSleep(true=prepare)
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Demoting known real-time threads.
jul 14 00:13:32 Infinity coolercontrold[985]: Received message that system is going to sleep.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 6500 of process 2672.
jul 14 00:13:32 Infinity org_kde_powerdevil[1458]: Watching for display connection changes, resolved watch mode = Watch_Mode_Udev, poll loop interval = 500 millisec
jul 14 00:13:32 Infinity org_kde_powerdevil[1458]:                                          initial_stabilization_millisec: 0,  stabilization_poll_millisec: 100
jul 14 00:13:32 Infinity NetworkManager[893]: <info>  [1783980812.4308] manager: sleep: sleep requested (sleeping: no  enabled: yes)
jul 14 00:13:32 Infinity ModemManager[965]: <msg> [sleep-monitor-systemd] system is about to suspend
jul 14 00:13:32 Infinity NetworkManager[893]: <info>  [1783980812.4309] manager: NetworkManager state is now DISABLED (ASLEEP)
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 4240 of process 2971.
jul 14 00:13:32 Infinity systemd[1]: Reached target Sleep.
jul 14 00:13:32 Infinity ModemManager[965]: <msg> [sleep-monitor-systemd] ready to sleep; dropping inhibitor
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 3724 of process 2624.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 2599 of process 1773.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 1435 of process 1431.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 1431 of process 1431.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 1311 of process 1306.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 1306 of process 1306.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Successfully demoted thread 1315 of process 1307.
jul 14 00:13:32 Infinity rtkit-daemon[1312]: Demoted 9 threads.
jul 14 00:13:32 Infinity systemd[1]: Starting System Suspend...
jul 14 00:13:32 Infinity kwin_wayland[1255]: Failed to delay sleep: The operation inhibition has been requested for is already running
jul 14 00:13:32 Infinity systemd-sleep[10438]: /etc/systemd/sleep.conf:27: Support for option SuspendMode= has been removed and it is ignored
jul 14 00:13:32 Infinity systemd[1]: user@1000.service: Unit now frozen-by-parent.
jul 14 00:13:32 Infinity systemd[1]: session-2.scope: Unit now frozen-by-parent.
jul 14 00:13:32 Infinity systemd[1]: user-1000.slice: Unit now frozen-by-parent.
jul 14 00:13:32 Infinity systemd[1]: user.slice: Unit now frozen.
jul 14 00:13:32 Infinity systemd-sleep[10438]: Successfully froze unit 'user.slice'.
jul 14 00:13:32 Infinity systemd-sleep[10444]: SG_IO: bad/missing sense data, sb[]:  f0 00 0b 04 51 40 7f 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
jul 14 00:13:32 Infinity systemd-sleep[10444]: /dev/sda:
jul 14 00:13:32 Infinity systemd-sleep[10444]:  setting Advanced Power Management level to 0x7f (127)
jul 14 00:13:32 Infinity systemd-sleep[10444]:  APM_level        = not supported
jul 14 00:13:32 Infinity systemd-sleep[10438]: Performing sleep operation 'suspend'...
jul 14 00:13:32 Infinity kernel: PM: suspend entry (deep)
jul 14 00:13:32 Infinity kernel: Filesystems sync: 0.014 seconds
jul 14 00:13:38 Infinity kernel: Freezing user space processes
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/ldac
jul 14 00:13:38 Infinity kernel: Freezing user space processes completed (elapsed 0.002 seconds)
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/aptx_hd
jul 14 00:13:38 Infinity kernel: OOM killer disabled.
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_hd
jul 14 00:13:38 Infinity kernel: Freezing remaining freezable tasks
jul 14 00:13:38 Infinity kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
jul 14 00:13:38 Infinity kernel: printk: Suspending console(s) (use no_console_suspend to debug)
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/aac
jul 14 00:13:38 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aac
jul 14 00:13:38 Infinity kernel: sd 6:0:0:0: [sdc] Synchronizing SCSI cache
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/opus_g
jul 14 00:13:38 Infinity systemd[1]: Starting Load/Save RF Kill Switch Status...
jul 14 00:13:38 Infinity kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/opus_g
jul 14 00:13:38 Infinity kernel: sd 2:0:0:0: [sdb] Synchronizing SCSI cache
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
jul 14 00:13:38 Infinity kernel: ata3.00: Entering standby power mode
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
jul 14 00:13:38 Infinity kernel: ata1.00: Entering standby power mode
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jul 14 00:13:38 Infinity kernel: ACPI: PM: Preparing to enter system sleep state S3
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/faststream
jul 14 00:13:38 Infinity kernel: ACPI: PM: Saving platform NVS memory
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/faststream_duplex
jul 14 00:13:38 Infinity kernel: Disabling non-boot CPUs ...
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/opus_05
jul 14 00:13:38 Infinity kernel: Wakeup pending. Abort CPU freeze
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/opus_05
jul 14 00:13:38 Infinity kernel: Non-boot CPUs are not disabled
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSink/opus_05_duplex
jul 14 00:13:38 Infinity kernel: ACPI: PM: Waking up from system sleep state S3
jul 14 00:13:38 Infinity bluetoothd[896]: Endpoint unregistered: sender=:1.46 path=/MediaEndpoint/A2DPSource/opus_05_duplex
jul 14 00:13:38 Infinity kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F41FC00000).
jul 14 00:13:38 Infinity bluetoothd[896]: Battery Provider Manager destroyed
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: PSP is resuming...
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
jul 14 00:13:38 Infinity kernel: nvme nvme0: D3 entry latency set to 8 seconds
jul 14 00:13:38 Infinity kernel: xhci_hcd 0000:0e:00.0: xHC error in resume, USBSTS 0x401, Reinit
jul 14 00:13:38 Infinity kernel: usb usb1: root hub lost power or was reset
jul 14 00:13:38 Infinity kernel: usb usb2: root hub lost power or was reset
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: reserve 0xa00000 from 0xf41e000000 for PSP TMR
jul 14 00:13:38 Infinity kernel: nvme nvme1: D3 entry latency set to 10 seconds
jul 14 00:13:38 Infinity kernel: nvme nvme1: 8/0/0 default/read/poll queues
jul 14 00:13:38 Infinity kernel: nvme nvme1: Ignoring bogus Namespace Identifiers
jul 14 00:13:38 Infinity kernel: nvme nvme0: 8/0/0 default/read/poll queues
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: RAS: optional ras ta ucode is not available
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: RAP: optional rap ta ucode is not available
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: SMU is resuming...
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: SMU is resumed successfully!
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: kiq ring mec 2 pipe 1 q 0
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
jul 14 00:13:38 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000033, smu fw program = 0, smu fw version = 0x00684c00 (104.76.0)
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x05003000
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
jul 14 00:13:38 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
jul 14 00:13:39 Infinity bluetoothd[896]: Battery Provider Manager created
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
jul 14 00:13:39 Infinity bluetoothd[896]: Failed to set default system config for hci0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0x4000000
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0xc000000
jul 14 00:13:39 Infinity kernel: ata4: SATA link down (SStatus 0 SControl 300)
jul 14 00:13:39 Infinity kernel: ata2: SATA link down (SStatus 0 SControl 300)
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x0A000C00
jul 14 00:13:39 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:13:39 Infinity kernel: usb 1-12: reset high-speed USB device number 7 using xhci_hcd
jul 14 00:13:39 Infinity kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
jul 14 00:13:39 Infinity kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
jul 14 00:13:39 Infinity kernel: ata3.00: supports DRM functions and may not be fully accessible
jul 14 00:13:39 Infinity kernel: ata1.00: supports DRM functions and may not be fully accessible
jul 14 00:13:39 Infinity kernel: sd 2:0:0:0: [sdb] Starting disk
jul 14 00:13:39 Infinity kernel: sd 0:0:0:0: [sda] Starting disk
jul 14 00:13:39 Infinity kernel: ata1.00: configured for UDMA/133
jul 14 00:13:39 Infinity kernel: ata3.00: configured for UDMA/133
jul 14 00:13:39 Infinity kernel: ahci 0000:0f:00.0: port does not support device sleep
jul 14 00:13:39 Infinity kernel: ata1.00: Enabling discard_zeroes_data
jul 14 00:13:39 Infinity kernel: ata3.00: Enabling discard_zeroes_data
jul 14 00:13:39 Infinity kernel: usb 1-11: WARN: invalid context state for evaluate context command.
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 9 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 10 on hub 0
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
jul 14 00:13:39 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
jul 14 00:13:39 Infinity kernel: usb 1-11: reset full-speed USB device number 5 using xhci_hcd
jul 14 00:13:39 Infinity kernel: usb 1-10: WARN: invalid context state for evaluate context command.
jul 14 00:13:39 Infinity kernel: usb 1-10: reset full-speed USB device number 3 using xhci_hcd
jul 14 00:13:39 Infinity kernel: usb 1-5: reset high-speed USB device number 2 using xhci_hcd
jul 14 00:13:39 Infinity kernel: usb 2-5: reset SuperSpeed USB device number 2 using xhci_hcd
jul 14 00:13:39 Infinity kernel: usb 1-5.3: WARN: invalid context state for evaluate context command.
jul 14 00:13:39 Infinity kernel: usb 1-5.3: reset full-speed USB device number 6 using xhci_hcd
jul 14 00:13:39 Infinity kernel: usb 1-5.1: WARN: invalid context state for evaluate context command.
jul 14 00:13:39 Infinity kernel: usb 1-5.1: reset full-speed USB device number 4 using xhci_hcd
jul 14 00:13:39 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Up - 1Gbps/Full - flow control off
jul 14 00:13:39 Infinity kernel: usb 1-5.4: reset low-speed USB device number 8 using xhci_hcd
jul 14 00:13:39 Infinity kernel: OOM killer enabled.
jul 14 00:13:39 Infinity kernel: Restarting tasks: Starting
jul 14 00:13:39 Infinity kernel: Restarting tasks: Done
jul 14 00:13:39 Infinity kernel: efivarfs: resyncing variable state
jul 14 00:13:39 Infinity kernel: efivarfs: finished resyncing variable state
jul 14 00:13:39 Infinity kernel: random: crng reseeded on system resumption
jul 14 00:13:39 Infinity kernel: PM: suspend exit
jul 14 00:13:39 Infinity kernel: PM: suspend entry (s2idle)
jul 14 00:13:39 Infinity kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
jul 14 00:13:39 Infinity kernel: Filesystems sync: 0.010 seconds
jul 14 00:13:39 Infinity kernel: Freezing user space processes
jul 14 00:13:39 Infinity kernel: Freezing user space processes completed (elapsed 0.002 seconds)
jul 14 00:13:39 Infinity kernel: OOM killer disabled.
jul 14 00:13:39 Infinity kernel: Freezing remaining freezable tasks
jul 14 00:13:39 Infinity kernel: Freezing remaining freezable tasks completed (elapsed 0.016 seconds)
jul 14 00:13:39 Infinity kernel: pci_bus 0000:05: Allocating resources
jul 14 00:13:39 Infinity kernel: printk: Suspending console(s) (use no_console_suspend to debug)
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: Power consumption will be higher as BIOS has not been configured for suspend-to-idle.
                                 To use suspend-to-idle change the sleep mode in BIOS setup.
jul 14 00:13:39 Infinity kernel: sd 2:0:0:0: [sdb] Synchronizing SCSI cache
jul 14 00:13:39 Infinity kernel: ata3.00: Entering standby power mode
jul 14 00:13:39 Infinity kernel: sd 6:0:0:0: [sdc] Synchronizing SCSI cache
jul 14 00:13:39 Infinity kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: [drm] *ERROR* Unsupported suspend state 1
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: PM: pci_pm_suspend(): amdgpu_pmops_suspend [amdgpu] returns -22
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -22
jul 14 00:13:39 Infinity kernel: amdgpu 0000:11:00.0: PM: failed to suspend async: error -22
jul 14 00:13:39 Infinity kernel: PM: Some devices failed to suspend, or early wake event detected
jul 14 00:13:39 Infinity kernel: nvme nvme0: D3 entry latency set to 8 seconds
jul 14 00:13:39 Infinity kernel: nvme nvme1: D3 entry latency set to 10 seconds
jul 14 00:13:39 Infinity kernel: nvme nvme1: 8/0/0 default/read/poll queues
jul 14 00:13:39 Infinity kernel: nvme nvme1: Ignoring bogus Namespace Identifiers
jul 14 00:13:39 Infinity kernel: nvme nvme0: 8/0/0 default/read/poll queues
jul 14 00:13:39 Infinity kernel: Bluetooth: MGMT ver 1.23
jul 14 00:13:39 Infinity systemd[1]: Stopped target Bluetooth Support.
jul 14 00:13:39 Infinity systemd[1]: Reached target Bluetooth Support.
jul 14 00:13:39 Infinity systemd-sleep[10438]: Failed to put system to sleep. System resumed again: Device or resource busy
jul 14 00:13:39 Infinity bluetoothd[896]: Controller resume with wake event 0x0
jul 14 00:13:39 Infinity bluetoothd[896]: Wrong size of local name changed parameters
jul 14 00:13:39 Infinity systemd-sleep[10587]: SG_IO: bad/missing sense data, sb[]:  f0 00 0b 04 51 40 7f 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
jul 14 00:13:39 Infinity systemd-sleep[10587]: /dev/sda:
jul 14 00:13:39 Infinity systemd-sleep[10587]:  setting Advanced Power Management level to 0x7f (127)
jul 14 00:13:39 Infinity systemd-sleep[10587]:  APM_level        = not supported
jul 14 00:13:39 Infinity systemd[1]: Started Load/Save RF Kill Switch Status.
jul 14 00:13:39 Infinity systemd-sleep[10586]: SG_IO: bad/missing sense data, sb[]:  f0 00 0b 04 51 40 7f 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
jul 14 00:13:39 Infinity systemd-sleep[10586]: /dev/sdb:
jul 14 00:13:39 Infinity systemd-sleep[10586]:  setting Advanced Power Management level to 0x7f (127)
jul 14 00:13:39 Infinity systemd-sleep[10586]:  setting standby to 0 (off)
jul 14 00:13:39 Infinity systemd-sleep[10586]:  APM_level        = not supported
jul 14 00:13:39 Infinity systemd[1]: user.slice: Unit now thawed.
jul 14 00:13:39 Infinity systemd-sleep[10438]: Successfully thawed unit 'user.slice'.
jul 14 00:13:39 Infinity systemd[1]: user-1000.slice: Unit now thawed.
jul 14 00:13:39 Infinity systemd[1]: session-2.scope: Unit now thawed.
jul 14 00:13:39 Infinity systemd[1]: user@1000.service: Unit now thawed.
jul 14 00:13:39 Infinity systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.223322] Udev event detected
jul 14 00:13:39 Infinity systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
jul 14 00:13:39 Infinity systemd[1]: Failed to start System Suspend.
jul 14 00:13:39 Infinity systemd[1]: Dependency failed for Suspend.
jul 14 00:13:39 Infinity systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
jul 14 00:13:39 Infinity systemd-logind[900]: Operation 'suspend' finished.
jul 14 00:13:39 Infinity coolercontrold[985]: Received message that system is waking from sleep
jul 14 00:13:39 Infinity ModemManager[965]: <msg> [sleep-monitor-systemd] system is resuming
jul 14 00:13:39 Infinity NetworkManager[893]: <info>  [1783980819.6339] manager: sleep: wake requested (sleeping: yes  enabled: yes)
jul 14 00:13:39 Infinity avahi-daemon[895]: Withdrawing address record for 192.168.1.11 on enp12s0.
jul 14 00:13:39 Infinity NetworkManager[893]: <info>  [1783980819.6340] device (enp12s0): state change: activated -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
jul 14 00:13:39 Infinity avahi-daemon[895]: Leaving mDNS multicast group on interface enp12s0.IPv4 with address 192.168.1.11.
jul 14 00:13:39 Infinity systemd[1]: Stopped target Sleep.
jul 14 00:13:39 Infinity avahi-daemon[895]: Interface enp12s0.IPv4 no longer relevant for mDNS.
jul 14 00:13:39 Infinity avahi-daemon[895]: Withdrawing address record for fe80::c825:f148:6891:ace1 on enp12s0.
jul 14 00:13:39 Infinity avahi-daemon[895]: Leaving mDNS multicast group on interface enp12s0.IPv6 with address fe80::c825:f148:6891:ace1.
jul 14 00:13:39 Infinity avahi-daemon[895]: Interface enp12s0.IPv6 no longer relevant for mDNS.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Resuming known real-time threads.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 6500 of process 2672 owned by '1000' RT at priority 10.
jul 14 00:13:39 Infinity systemd[1130]: Reached target Bluetooth.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 4240 of process 2971 owned by '1000' RT at priority 10.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 3724 of process 2624 owned by '1000' RT at priority 10.
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1514][252.224507] (ldbus_handle_message)Received dbus signal PrepareForSleep(false=resume)
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 2599 of process 1773 owned by '1000' RT at priority 10.
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677] Udev_Event_Detail
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_subsystem:  drm
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_action:     change
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_connector:  (null)
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_devname:    /dev/dri/card0
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_devmode:    (null)
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_hotplug:    1
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_major:      226
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    prop_minor:      0
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    sysname:         card0
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    syspath:         /sys/devices/pci0000:00/0000:00:08.1/0000:11:00.0/drm/card0
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227677]    attr_name:       (null)
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227729] (dw_watch_display_connections) Time since last return from sleep = 3221870 ns = 3 ms
jul 14 00:13:39 Infinity org_kde_powerdevil[1458]: [  1721][252.227734] (dw_watch_display_connections) Pausing for 997
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 1435 of process 1431 owned by '1000' RT at priority 20.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 1431 of process 1431 owned by '1000' high priority at nice level -11.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 1311 of process 1306 owned by '1000' RT at priority 20.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 1306 of process 1306 owned by '1000' high priority at nice level -11.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Successfully made thread 1315 of process 1307 owned by '1000' RT at priority 20.
jul 14 00:13:39 Infinity rtkit-daemon[1312]: Resumed scheduling 9 threads.
jul 14 00:13:39 Infinity kdeconnectd[1604]: Bluetooth device is powered off
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/ldac
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/aptx_hd
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_hd
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/aac
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aac
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/opus_g
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/opus_g
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_1
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_0
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/faststream
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/faststream_duplex
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/opus_05
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/opus_05
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/opus_05_duplex
jul 14 00:13:39 Infinity bluetoothd[896]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/opus_05_duplex
jul 14 00:13:39 Infinity NetworkManager[893]: <info>  [1783980819.6796] manager: NetworkManager state is now CONNECTED_GLOBAL
jul 14 00:13:39 Infinity NetworkManager[893]: <info>  [1783980819.6854] manager: NetworkManager state is now DISCONNECTED
jul 14 00:13:39 Infinity NetworkManager[893]: <info>  [1783980819.6858] device (enp12s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
jul 14 00:13:39 Infinity systemd[1]: Starting Network Manager Script Dispatcher Service...
jul 14 00:13:39 Infinity systemd[1]: Started Network Manager Script Dispatcher Service.
jul 14 00:13:39 Infinity kernel: Realtek Internal NBASE-T PHY r8169-0-c00:00: attached PHY driver (mii_bus:phy_addr=r8169-0-c00:00, irq=MAC)
jul 14 00:13:40 Infinity coolercontrold[985]: Waiting 5s before resuming after waking from sleep.
jul 14 00:13:40 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:13:40 Infinity bluetoothd[896]: Failed to set mode: Failed (0x03)
jul 14 00:13:40 Infinity kded6[1380]: PendingCall Error: "Failed"
jul 14 00:13:40 Infinity org_kde_powerdevil[1458]: [  1721] Adding connected display with bus 10
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.956426] Emitting DDCA_Display_Status_Event[253.956:  DDCA_EVENT_DISPLAY_CONNECTED, card0-HDMI-A-3, dref: DDCA_Display_Ref[2], io_path:/dev/i2c-10, ddc working: true]
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.956482] Starting 1 callback threads
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.956686] libddcutil callback thread 0x7fbe6801bd20 started
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.956706] Started 1 event callback thread(s)
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [ 10680][253.956962] Invoking callback function 0x7fbe95a738b0 for event DDCA_Display_Status_Event[253.956:  DDCA_EVENT_DISPLAY_CONNECTED, card0-HDMI-A-3, dref: DDCA_Display_Ref[2], io_path:/dev/i2c-10, ddc working: true] in this thread [ 10680]
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [ 10680][253.957058] Callback function 0x7fbe95a738b0 for event DDCA_Display_Status_Event[253.956:  DDCA_EVENT_DISPLAY_CONNECTED, card0-HDMI-A-3, dref: DDCA_Display_Ref[2], io_path:/dev/i2c-10, ddc working: true] complete
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1458] Quiescing libddcutil API...
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1458] Quiesce libddcutil API complete
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1458] Display redetection starting.
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957376] Udev event detected
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658] Udev_Event_Detail
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_subsystem:  drm
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_action:     change
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_connector:  (null)
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_devname:    /dev/dri/card0
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_devmode:    (null)
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_hotplug:    1
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_major:      226
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    prop_minor:      0
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    sysname:         card0
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    syspath:         /sys/devices/pci0000:00/0000:00:08.1/0000:11:00.0/drm/card0
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1721][253.957658]    attr_name:       (null)
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1720] recheck thread terminating because watch thread terminated
jul 14 00:13:41 Infinity org_kde_powerdevil[1458]: [  1458] Watch thread terminated.
jul 14 00:13:42 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Up - 1Gbps/Full - flow control rx/tx
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6275] device (enp12s0): carrier: link connected
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6282] device (enp12s0): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6301] policy: auto-activating connection 'Wired connection 1' (90d101e1-3cd7-3dd6-97a5-c3c6ac1b86a9)
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6311] device (enp12s0): Activation: starting connection 'Wired connection 1' (90d101e1-3cd7-3dd6-97a5-c3c6ac1b86a9)
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6313] device (enp12s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6318] manager: NetworkManager state is now CONNECTING
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6324] device (enp12s0): state change: prepare -> config (reason 'none', managed-type: 'full')
jul 14 00:13:42 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6347] device (enp12s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
jul 14 00:13:42 Infinity NetworkManager[893]: <info>  [1783980822.6365] policy: set 'Wired connection 1' (enp12s0) as default for IPv4 routing and DNS
jul 14 00:13:42 Infinity avahi-daemon[895]: Joining mDNS multicast group on interface enp12s0.IPv4 with address 192.168.1.11.
jul 14 00:13:42 Infinity avahi-daemon[895]: New relevant interface enp12s0.IPv4 for mDNS.
jul 14 00:13:42 Infinity avahi-daemon[895]: Registering new address record for 192.168.1.11 on enp12s0.IPv4.
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458][255.403594] Time since library initialized: 255.403590 seconds
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458][255.403637] Extra delay starting dw_start_watch_displays: 0 millisec
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458] Watching for display connection changes, resolved watch mode = Watch_Mode_Udev, poll loop interval = 500 millisec
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458]                                          initial_stabilization_millisec: 0,  stabilization_poll_millisec: 100
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458] libddcutil recheck thread 0x55b932609ba0 started
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458] libddcutil watch thread 0x55b9326f3300 started
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [ 10688][255.445421] Recheck interval: Sleeping for 200 milliseconds
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458] Display redetection finished.
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458] Unquiescing libddcutil API...
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458][255.445514] (ddca_get_display_refs) Returned DDCA_Display_Ref list:
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458][255.445527]    DDCA_Display_Ref Display_Ref[3:bus /dev/i2c-8 @0x55b932624060]
jul 14 00:13:42 Infinity org_kde_powerdevil[1458]: [  1458][255.445537]    DDCA_Display_Ref Display_Ref[4:bus /dev/i2c-10 @0x55b9326187f0]
jul 14 00:13:43 Infinity ModemManager[965]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0a.0/0000:0c:00.0': not supported by any plugin
jul 14 00:13:44 Infinity systemd[1]: systemd-rfkill.service: Deactivated successfully.
jul 14 00:13:44 Infinity NetworkManager[893]: <info>  [1783980824.6420] device (enp12s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
jul 14 00:13:44 Infinity NetworkManager[893]: <info>  [1783980824.6461] device (enp12s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
jul 14 00:13:44 Infinity NetworkManager[893]: <info>  [1783980824.6467] device (enp12s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
jul 14 00:13:44 Infinity NetworkManager[893]: <info>  [1783980824.6476] manager: NetworkManager state is now CONNECTED_SITE
jul 14 00:13:44 Infinity NetworkManager[893]: <info>  [1783980824.6486] device (enp12s0): Activation: successful, device activated.
jul 14 00:13:44 Infinity NetworkManager[893]: <info>  [1783980824.6497] manager: NetworkManager state is now CONNECTED_GLOBAL
jul 14 00:13:44 Infinity steam[3543]: [2026-07-14 00:13:44] Background update loop checking for update. . .
jul 14 00:13:44 Infinity steam[3543]: [2026-07-14 00:13:44] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
jul 14 00:13:44 Infinity steam[3543]: [2026-07-14 00:13:44] Manifest download: send request
jul 14 00:13:44 Infinity steam[3543]: [2026-07-14 00:13:44] Manifest download: waiting for download to finish
jul 14 00:13:45 Infinity coolercontrold[985]: Re-initializing and re-applying settings after waking from sleep
jul 14 00:13:45 Infinity coolercontrold[985]: Applying all saved device settings
jul 14 00:13:45 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Up - 1Gbps/Full - flow control off
jul 14 00:13:45 Infinity NetworkManager[893]: <info>  [1783980825.9456] device (enp12s0): carrier: link connected
jul 14 00:13:47 Infinity avahi-daemon[895]: Joining mDNS multicast group on interface enp12s0.IPv6 with address fe80::c825:f148:6891:ace1.
jul 14 00:13:47 Infinity avahi-daemon[895]: New relevant interface enp12s0.IPv6 for mDNS.
jul 14 00:13:47 Infinity avahi-daemon[895]: Registering new address record for fe80::c825:f148:6891:ace1 on enp12s0.*.
jul 14 00:13:49 Infinity systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
jul 14 00:13:50 Infinity steam[3543]: [2026-07-14 00:13:50] Manifest download: finished
jul 14 00:13:50 Infinity steam[3543]: [2026-07-14 00:13:50] Download skipped by HTTP 304 Not Modified
jul 14 00:13:50 Infinity steam[3543]: [2026-07-14 00:13:50] Nothing to do
jul 14 00:13:59 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: VM memory stats for proc (0) task (0) is non-zero when fini
jul 14 00:14:21 Infinity plasmashell[1430]: Final member StackingOrder is overridden in class QQmlDMAbstractItemModelData. The override won't be used.
jul 14 00:15:22 Infinity plasmashell[1430]: Final member StackingOrder is overridden in class QQmlDMAbstractItemModelData. The override won't be used.
jul 14 00:16:10 Infinity plasmashell[1430]: Final member StackingOrder is overridden in class QQmlDMAbstractItemModelData. The override won't be used.
jul 14 00:16:12 Infinity systemd[1130]: Started Konsole - Terminal.
jul 14 00:16:12 Infinity konsole[11221]: Icon theme "elementary" not found.
jul 14 00:16:12 Infinity systemd[1130]: Started app-org.kde.konsole-11221.scope.
jul 14 00:16:32 Infinity plasmashell[1430]: Final member StackingOrder is overridden in class QQmlDMAbstractItemModelData. The override won't be used.
jul 14 00:17:01 Infinity systemd-logind[900]: /etc/systemd/sleep.conf:27: Support for option SuspendMode= has been removed and it is ignored
jul 14 00:17:01 Infinity systemd-logind[900]: suspend requested from client PID 1430 ('plasmashell') (unit user@1000.service)...
jul 14 00:17:01 Infinity systemd-logind[900]: The system will suspend now!
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: [  1514][454.430354] (ldbus_handle_message)Received dbus signal PrepareForSleep(true=prepare)
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    Number of buses:       7
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    All I2C buses:         3 4 5 6 8 9 10
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    Buses with edid:       8
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    Buses with x37 active: 8
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    Display_Ref[1:bus /dev/i2c-8 @0x55b9325ebc70]
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     ) After buses added or removed:
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    Buses with edid:       8 10
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    Buses with x37 active: 8 10
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     ) After display refs added or marked disconnected:
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: (dw_hotplug_change_handler     )    Display_Ref[2:bus /dev/i2c-10 @0x7fbe68003520]
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]: Watching for display connection changes, resolved watch mode = Watch_Mode_Udev, poll loop interval = 500 millisec
jul 14 00:17:01 Infinity org_kde_powerdevil[1458]:                                          initial_stabilization_millisec: 0,  stabilization_poll_millisec: 100
jul 14 00:17:01 Infinity coolercontrold[985]: Received message that system is going to sleep.
jul 14 00:17:01 Infinity ModemManager[965]: <msg> [sleep-monitor-systemd] system is about to suspend
jul 14 00:17:01 Infinity NetworkManager[893]: <info>  [1783981021.8401] manager: sleep: sleep requested (sleeping: no  enabled: yes)
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Demoting known real-time threads.
jul 14 00:17:01 Infinity NetworkManager[893]: <info>  [1783981021.8404] manager: NetworkManager state is now DISABLED (ASLEEP)
jul 14 00:17:01 Infinity ModemManager[965]: <msg> [sleep-monitor-systemd] ready to sleep; dropping inhibitor
jul 14 00:17:01 Infinity systemd[1]: Reached target Sleep.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 6500 of process 2672.
jul 14 00:17:01 Infinity systemd[1]: Starting System Suspend...
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 4240 of process 2971.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 3724 of process 2624.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 2599 of process 1773.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 1435 of process 1431.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 1431 of process 1431.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 1311 of process 1306.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 1306 of process 1306.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Successfully demoted thread 1315 of process 1307.
jul 14 00:17:01 Infinity rtkit-daemon[1312]: Demoted 9 threads.
jul 14 00:17:01 Infinity kwin_wayland[1255]: Failed to delay sleep: The operation inhibition has been requested for is already running
jul 14 00:17:01 Infinity systemd-sleep[11395]: /etc/systemd/sleep.conf:27: Support for option SuspendMode= has been removed and it is ignored
jul 14 00:17:01 Infinity systemd[1]: user@1000.service: Unit now frozen-by-parent.
jul 14 00:17:01 Infinity systemd[1]: session-2.scope: Unit now frozen-by-parent.
jul 14 00:17:01 Infinity systemd[1]: user-1000.slice: Unit now frozen-by-parent.
jul 14 00:17:01 Infinity systemd[1]: user.slice: Unit now frozen.
jul 14 00:17:01 Infinity systemd-sleep[11395]: Successfully froze unit 'user.slice'.
jul 14 00:17:01 Infinity systemd-sleep[11401]: SG_IO: bad/missing sense data, sb[]:  f0 00 0b 04 51 40 7f 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
jul 14 00:17:01 Infinity systemd-sleep[11401]: /dev/sda:
jul 14 00:17:01 Infinity systemd-sleep[11401]:  setting Advanced Power Management level to 0x7f (127)
jul 14 00:17:01 Infinity systemd-sleep[11401]:  APM_level        = not supported
jul 14 00:17:01 Infinity systemd-sleep[11395]: Performing sleep operation 'suspend'...
jul 14 00:17:01 Infinity kernel: PM: suspend entry (deep)
jul 14 00:17:01 Infinity kernel: Filesystems sync: 0.014 seconds
jul 14 00:17:04 Infinity kernel: Freezing user space processes
jul 14 00:17:04 Infinity kernel: Freezing user space processes completed (elapsed 0.002 seconds)
jul 14 00:17:04 Infinity kernel: OOM killer disabled.
jul 14 00:17:04 Infinity kernel: Freezing remaining freezable tasks
jul 14 00:17:04 Infinity kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
jul 14 00:17:04 Infinity kernel: printk: Suspending console(s) (use no_console_suspend to debug)
jul 14 00:17:04 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:17:04 Infinity kernel: sd 2:0:0:0: [sdb] Synchronizing SCSI cache
jul 14 00:17:04 Infinity kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
jul 14 00:17:04 Infinity kernel: sd 6:0:0:0: [sdc] Synchronizing SCSI cache
jul 14 00:17:04 Infinity kernel: ata3.00: Entering standby power mode
jul 14 00:17:04 Infinity kernel: ata1.00: Entering standby power mode
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: MODE1 reset
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: GPU mode1 reset
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: GPU smu mode1 reset
jul 14 00:17:04 Infinity kernel: ACPI: PM: Preparing to enter system sleep state S3
jul 14 00:17:04 Infinity kernel: ACPI: PM: Saving platform NVS memory
jul 14 00:17:04 Infinity kernel: Disabling non-boot CPUs ...
jul 14 00:17:04 Infinity kernel: Wakeup pending. Abort CPU freeze
jul 14 00:17:04 Infinity kernel: Non-boot CPUs are not disabled
jul 14 00:17:04 Infinity kernel: ACPI: PM: Waking up from system sleep state S3
jul 14 00:17:04 Infinity kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F41FC00000).
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: PSP is resuming...
jul 14 00:17:04 Infinity kernel: nvme nvme0: D3 entry latency set to 8 seconds
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: reserve 0xa00000 from 0xf41e000000 for PSP TMR
jul 14 00:17:04 Infinity kernel: nvme nvme1: D3 entry latency set to 10 seconds
jul 14 00:17:04 Infinity kernel: nvme nvme1: 8/0/0 default/read/poll queues
jul 14 00:17:04 Infinity kernel: nvme nvme1: Ignoring bogus Namespace Identifiers
jul 14 00:17:04 Infinity kernel: nvme nvme0: 8/0/0 default/read/poll queues
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: RAS: optional ras ta ucode is not available
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: RAP: optional rap ta ucode is not available
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: SMU is resuming...
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: SMU is resumed successfully!
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: kiq ring mec 2 pipe 1 q 0
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x05003000
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
jul 14 00:17:04 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000033, smu fw program = 0, smu fw version = 0x00684c00 (104.76.0)
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
jul 14 00:17:04 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
jul 14 00:17:08 Infinity kernel: ata4: SATA link down (SStatus 0 SControl 300)
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0x4000000
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: program CP_MES_CNTL : 0xc000000
jul 14 00:17:08 Infinity kernel: ata2: SATA link down (SStatus 0 SControl 300)
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: [drm] DMUB hardware initialized: version=0x0A000C00
jul 14 00:17:08 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:17:08 Infinity kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
jul 14 00:17:08 Infinity kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
jul 14 00:17:08 Infinity kernel: ata1.00: supports DRM functions and may not be fully accessible
jul 14 00:17:08 Infinity kernel: ata3.00: supports DRM functions and may not be fully accessible
jul 14 00:17:08 Infinity kernel: sd 0:0:0:0: [sda] Starting disk
jul 14 00:17:08 Infinity kernel: sd 2:0:0:0: [sdb] Starting disk
jul 14 00:17:08 Infinity kernel: ata1.00: configured for UDMA/133
jul 14 00:17:08 Infinity kernel: ata3.00: configured for UDMA/133
jul 14 00:17:08 Infinity kernel: ahci 0000:0f:00.0: port does not support device sleep
jul 14 00:17:08 Infinity kernel: ata3.00: Enabling discard_zeroes_data
jul 14 00:17:08 Infinity kernel: ata1.00: Enabling discard_zeroes_data
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 9 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 10 on hub 0
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
jul 14 00:17:08 Infinity kernel: OOM killer enabled.
jul 14 00:17:08 Infinity systemd-sleep[11395]: Failed to put system to sleep. System resumed again: Device or resource busy
jul 14 00:17:08 Infinity kernel: Restarting tasks: Starting
jul 14 00:17:08 Infinity kernel: Restarting tasks: Done
jul 14 00:17:08 Infinity kernel: efivarfs: resyncing variable state
jul 14 00:17:08 Infinity kernel: efivarfs: finished resyncing variable state
jul 14 00:17:08 Infinity kernel: random: crng reseeded on system resumption
jul 14 00:17:08 Infinity kernel: PM: suspend exit
jul 14 00:17:08 Infinity kernel: PM: suspend entry (s2idle)
jul 14 00:17:08 Infinity kernel: Filesystems sync: 0.008 seconds
jul 14 00:17:08 Infinity kernel: Freezing user space processes
jul 14 00:17:08 Infinity kernel: Freezing user space processes completed (elapsed 0.002 seconds)
jul 14 00:17:08 Infinity kernel: OOM killer disabled.
jul 14 00:17:08 Infinity kernel: Freezing remaining freezable tasks
jul 14 00:17:08 Infinity kernel: Freezing remaining freezable tasks completed (elapsed 0.023 seconds)
jul 14 00:17:08 Infinity kernel: pci_bus 0000:05: Allocating resources
jul 14 00:17:08 Infinity kernel: printk: Suspending console(s) (use no_console_suspend to debug)
jul 14 00:17:08 Infinity kernel: sd 6:0:0:0: [sdc] Synchronizing SCSI cache
jul 14 00:17:08 Infinity kernel: sd 2:0:0:0: [sdb] Synchronizing SCSI cache
jul 14 00:17:08 Infinity kernel: ata3.00: Entering standby power mode
jul 14 00:17:08 Infinity kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: PM: pci_pm_suspend(): amdgpu_pmops_suspend [amdgpu] returns -22
jul 14 00:17:08 Infinity kernel: ata1.00: Entering standby power mode
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -22
jul 14 00:17:08 Infinity kernel: amdgpu 0000:11:00.0: PM: failed to suspend async: error -22
jul 14 00:17:08 Infinity kernel: PM: Some devices failed to suspend, or early wake event detected
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: PCIE GART of 512M enabled (table at 0x00000083DAB00000).
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: PSP is resuming...
jul 14 00:17:08 Infinity kernel: nvme nvme0: D3 entry latency set to 8 seconds
jul 14 00:17:08 Infinity kernel: nvme nvme1: D3 entry latency set to 10 seconds
jul 14 00:17:08 Infinity kernel: nvme nvme1: 8/0/0 default/read/poll queues
jul 14 00:17:08 Infinity kernel: nvme nvme1: Ignoring bogus Namespace Identifiers
jul 14 00:17:08 Infinity kernel: nvme nvme0: 8/0/0 default/read/poll queues
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: optional securedisplay ta ucode is not available
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x0000002e, smu fw if version = 0x00000033, smu fw program = 0, smu fw version = 0x00684c00 (104.76.0)
jul 14 00:17:08 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Up - 1Gbps/Full - flow control off
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000006 SMN_C2PMSG_82:0x00000000
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: Failed to enable requested dpm features!
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: Failed to setup smc hw!
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: resume of IP block <smu> failed -62
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: amdgpu: amdgpu_device_ip_resume failed (-62).
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: PM: dpm_run_callback(): pci_pm_resume returns -62
jul 14 00:17:08 Infinity kernel: amdgpu 0000:03:00.0: PM: failed to resume async: error -62
jul 14 00:17:08 Infinity kernel: snd_hda_intel 0000:03:00.1: Refused to change power state from D0 to D3hot
jul 14 00:17:08 Infinity systemd-sleep[11437]: SG_IO: bad/missing sense data, sb[]:
jul 14 00:17:08 Infinity systemd-sleep[11436]: SG_IO: bad/missing sense data, sb[]:
jul 14 00:17:08 Infinity systemd-sleep[11437]:  f0
jul 14 00:17:08 Infinity systemd-sleep[11436]:  f0
jul 14 00:17:08 Infinity systemd-sleep[11437]:  00
jul 14 00:17:08 Infinity systemd-sleep[11436]:  00
jul 14 00:17:08 Infinity systemd-sleep[11437]:  0b
jul 14 00:17:08 Infinity systemd-sleep[11436]:  0b
jul 14 00:17:08 Infinity systemd-sleep[11437]:  04
jul 14 00:17:08 Infinity systemd-sleep[11436]:  04
jul 14 00:17:08 Infinity systemd-sleep[11437]:  51
jul 14 00:17:08 Infinity systemd-sleep[11436]:  51
jul 14 00:17:08 Infinity systemd-sleep[11437]:  40
jul 14 00:17:08 Infinity systemd-sleep[11436]:  40
jul 14 00:17:08 Infinity systemd-sleep[11437]:  7f
jul 14 00:17:08 Infinity systemd-sleep[11436]:  7f
jul 14 00:17:08 Infinity systemd-sleep[11437]:  0a
jul 14 00:17:08 Infinity systemd-sleep[11436]:  0a
jul 14 00:17:08 Infinity systemd-sleep[11436]:  00 00
jul 14 00:17:08 Infinity systemd-sleep[11437]:  00 00 00
jul 14 00:17:08 Infinity systemd-sleep[11437]: /dev/sda:
jul 14 00:17:08 Infinity systemd-sleep[11437]:  setting Advanced Power Management level to 0x7f (127)
jul 14 00:17:08 Infinity systemd-sleep[11437]:  APM_level        = not supported
jul 14 00:17:08 Infinity systemd-sleep[11436]: /dev/sdb:
jul 14 00:17:08 Infinity systemd-sleep[11436]:  setting Advanced Power Management level to 0x7f (127)
jul 14 00:17:08 Infinity systemd-sleep[11436]:  setting standby to 0 (off)
jul 14 00:17:08 Infinity systemd-sleep[11436]:  APM_level        = not supported
jul 14 00:17:08 Infinity systemd[1]: user@1000.service: Unit now thawed.
jul 14 00:17:08 Infinity systemd[1]: user.slice: Unit now thawed.
jul 14 00:17:08 Infinity systemd[1]: user-1000.slice: Unit now thawed.
jul 14 00:17:08 Infinity systemd[1]: session-2.scope: Unit now thawed.
jul 14 00:17:08 Infinity systemd-sleep[11395]: Successfully thawed unit 'user.slice'.
jul 14 00:17:08 Infinity systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
jul 14 00:17:08 Infinity systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
jul 14 00:17:08 Infinity systemd[1]: Failed to start System Suspend.
jul 14 00:17:08 Infinity systemd[1]: Dependency failed for Suspend.
jul 14 00:17:08 Infinity systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
jul 14 00:17:08 Infinity systemd-logind[900]: Operation 'suspend' finished.
jul 14 00:17:08 Infinity coolercontrold[985]: Received message that system is waking from sleep
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [  1514][461.290171] (ldbus_handle_message)Received dbus signal PrepareForSleep(false=resume)
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290376] Udev event detected
jul 14 00:17:08 Infinity ModemManager[965]: <msg> [sleep-monitor-systemd] system is resuming
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490] Udev_Event_Detail
jul 14 00:17:08 Infinity NetworkManager[893]: <info>  [1783981028.7012] manager: sleep: wake requested (sleeping: yes  enabled: yes)
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_subsystem:  drm
jul 14 00:17:08 Infinity NetworkManager[893]: <info>  [1783981028.7017] device (enp12s0): state change: activated -> unmanaged (reason 'unmanaged-nm-disabled', managed-type: 'full')
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_action:     change
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_connector:  (null)
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_devname:    /dev/dri/card0
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_devmode:    (null)
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_hotplug:    1
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_major:      226
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    prop_minor:      0
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    sysname:         card0
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    syspath:         /sys/devices/pci0000:00/0000:00:08.1/0000:11:00.0/drm/card0
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290490]    attr_name:       (null)
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290562] (dw_watch_display_connections) Time since last return from sleep = 391349 ns = 0 ms
jul 14 00:17:08 Infinity org_kde_powerdevil[1458]: [ 10689][461.290569] (dw_watch_display_connections) Pausing for 1000
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Resuming known real-time threads.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 6500 of process 2672 owned by '1000' RT at priority 10.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 4240 of process 2971 owned by '1000' RT at priority 10.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 3724 of process 2624 owned by '1000' RT at priority 10.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 2599 of process 1773 owned by '1000' RT at priority 10.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 1435 of process 1431 owned by '1000' RT at priority 20.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 1431 of process 1431 owned by '1000' high priority at nice level -11.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 1311 of process 1306 owned by '1000' RT at priority 20.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 1306 of process 1306 owned by '1000' high priority at nice level -11.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Successfully made thread 1315 of process 1307 owned by '1000' RT at priority 20.
jul 14 00:17:08 Infinity rtkit-daemon[1312]: Resumed scheduling 9 threads.
jul 14 00:17:08 Infinity avahi-daemon[895]: Withdrawing address record for 192.168.1.11 on enp12s0.
jul 14 00:17:08 Infinity avahi-daemon[895]: Leaving mDNS multicast group on interface enp12s0.IPv4 with address 192.168.1.11.
jul 14 00:17:08 Infinity avahi-daemon[895]: Interface enp12s0.IPv4 no longer relevant for mDNS.
jul 14 00:17:08 Infinity avahi-daemon[895]: Withdrawing address record for fe80::c825:f148:6891:ace1 on enp12s0.
jul 14 00:17:08 Infinity avahi-daemon[895]: Leaving mDNS multicast group on interface enp12s0.IPv6 with address fe80::c825:f148:6891:ace1.
jul 14 00:17:08 Infinity avahi-daemon[895]: Interface enp12s0.IPv6 no longer relevant for mDNS.
jul 14 00:17:08 Infinity systemd[1]: Stopped target Sleep.
jul 14 00:17:08 Infinity kdeconnectd[1604]: Bluetooth device is powered off
jul 14 00:17:08 Infinity NetworkManager[893]: <info>  [1783981028.7280] manager: NetworkManager state is now CONNECTED_GLOBAL
jul 14 00:17:08 Infinity NetworkManager[893]: <info>  [1783981028.7345] manager: NetworkManager state is now DISCONNECTED
jul 14 00:17:08 Infinity NetworkManager[893]: <info>  [1783981028.7353] device (enp12s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
jul 14 00:17:08 Infinity systemd[1]: Starting Network Manager Script Dispatcher Service...
jul 14 00:17:08 Infinity kernel: Realtek Internal NBASE-T PHY r8169-0-c00:00: attached PHY driver (mii_bus:phy_addr=r8169-0-c00:00, irq=MAC)
jul 14 00:17:08 Infinity systemd[1]: Started Network Manager Script Dispatcher Service.
jul 14 00:17:09 Infinity coolercontrold[985]: Waiting 5s before resuming after waking from sleep.
jul 14 00:17:09 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:17:09 Infinity kdeconnectd[1604]: LanLinkProvider/newTcpConnection: Host timed out without sending any identity. QHostAddress("::ffff:192.168.1.13")
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424818] Udev event detected
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863] Udev_Event_Detail
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_subsystem:  drm
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_action:     change
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_connector:  (null)
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_devname:    /dev/dri/card1
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_devmode:    (null)
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_hotplug:    1
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_major:      226
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    prop_minor:      1
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    sysname:         card1
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    syspath:         /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.0/drm/card1
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424863]    attr_name:       (null)
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.424884] (dw_watch_display_connections) Time since last return from sleep = 1134713742 ns = 1135 ms
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527478] Udev event detected
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530] Udev_Event_Detail
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_subsystem:  drm
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_action:     change
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_connector:  (null)
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_devname:    /dev/dri/card0
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_devmode:    (null)
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_hotplug:    1
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_major:      226
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    prop_minor:      0
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    sysname:         card0
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    syspath:         /sys/devices/pci0000:00/0000:00:08.1/0000:11:00.0/drm/card0
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527530]    attr_name:       (null)
jul 14 00:17:09 Infinity org_kde_powerdevil[1458]: [ 10689][462.527562] (dw_watch_display_connections) Time since last return from sleep = 1237392536 ns = 1237 ms
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635736] Udev event detected
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821] Udev_Event_Detail
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_subsystem:  drm
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_action:     change
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_connector:  (null)
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_devname:    /dev/dri/card1
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_devmode:    (null)
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_hotplug:    1
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_major:      226
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    prop_minor:      1
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    sysname:         card1
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    syspath:         /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/0000:02:00.0/0000:03:00.0/drm/card1
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635821]    attr_name:       (null)
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635865] (dw_watch_display_connections) Time since last return from sleep = 1345695059 ns = 1346 ms
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635870] (recently_resumed_from_sleep_by_clocktime) Resume from sleep detected by BOOTTIME/MONOTONIC
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635874] (dw_watch_display_connections) Recently resumed from sleep detected
jul 14 00:17:10 Infinity org_kde_powerdevil[1458]: [ 10689][462.635878] (dw_watch_display_connections) Pausing for 1000 millisec
jul 14 00:17:11 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Up - 1Gbps/Full - flow control rx/tx
jul 14 00:17:11 Infinity NetworkManager[893]: <info>  [1783981031.9994] device (enp12s0): carrier: link connected
jul 14 00:17:11 Infinity NetworkManager[893]: <info>  [1783981031.9998] device (enp12s0): state change: unavailable -> disconnected (reason 'carrier-changed', managed-type: 'full')
jul 14 00:17:12 Infinity NetworkManager[893]: <info>  [1783981032.0013] policy: auto-activating connection 'Wired connection 1' (90d101e1-3cd7-3dd6-97a5-c3c6ac1b86a9)
jul 14 00:17:12 Infinity NetworkManager[893]: <info>  [1783981032.0025] device (enp12s0): Activation: starting connection 'Wired connection 1' (90d101e1-3cd7-3dd6-97a5-c3c6ac1b86a9)
jul 14 00:17:12 Infinity NetworkManager[893]: <info>  [1783981032.0028] device (enp12s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
jul 14 00:17:12 Infinity NetworkManager[893]: <info>  [1783981032.0035] manager: NetworkManager state is now CONNECTING
jul 14 00:17:12 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Down
jul 14 00:17:12 Infinity NetworkManager[893]: <info>  [1783981032.0043] device (enp12s0): state change: prepare -> config (reason 'none', managed-type: 'full')
jul 14 00:17:12 Infinity NetworkManager[893]: <info>  [1783981032.0071] device (enp12s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
jul 14 00:17:12 Infinity NetworkManager[893]: <info>  [1783981032.0096] policy: set 'Wired connection 1' (enp12s0) as default for IPv4 routing and DNS
jul 14 00:17:12 Infinity avahi-daemon[895]: Joining mDNS multicast group on interface enp12s0.IPv4 with address 192.168.1.11.
jul 14 00:17:12 Infinity avahi-daemon[895]: New relevant interface enp12s0.IPv4 for mDNS.
jul 14 00:17:12 Infinity avahi-daemon[895]: Registering new address record for 192.168.1.11 on enp12s0.IPv4.
jul 14 00:17:12 Infinity ModemManager[965]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.1/0000:04:00.0/0000:05:0a.0/0000:0c:00.0': not supported by any plugin
jul 14 00:17:14 Infinity coolercontrold[985]: Re-initializing and re-applying settings after waking from sleep
jul 14 00:17:14 Infinity coolercontrold[985]: Applying all saved device settings
jul 14 00:17:14 Infinity NetworkManager[893]: <info>  [1783981034.0145] device (enp12s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
jul 14 00:17:14 Infinity NetworkManager[893]: <info>  [1783981034.0168] device (enp12s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
jul 14 00:17:14 Infinity NetworkManager[893]: <info>  [1783981034.0170] device (enp12s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
jul 14 00:17:14 Infinity NetworkManager[893]: <info>  [1783981034.0176] manager: NetworkManager state is now CONNECTED_SITE
jul 14 00:17:14 Infinity NetworkManager[893]: <info>  [1783981034.0180] device (enp12s0): Activation: successful, device activated.
jul 14 00:17:14 Infinity NetworkManager[893]: <info>  [1783981034.0189] manager: NetworkManager state is now CONNECTED_GLOBAL
jul 14 00:17:14 Infinity steam[3543]: [2026-07-14 00:17:14] Background update loop checking for update. . .
jul 14 00:17:14 Infinity steam[3543]: [2026-07-14 00:17:14] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
jul 14 00:17:14 Infinity steam[3543]: [2026-07-14 00:17:14] Manifest download: send request
jul 14 00:17:14 Infinity steam[3543]: [2026-07-14 00:17:14] Manifest download: waiting for download to finish
jul 14 00:17:15 Infinity kernel: r8169 0000:0c:00.0 enp12s0: Link is Up - 1Gbps/Full - flow control off
jul 14 00:17:15 Infinity NetworkManager[893]: <info>  [1783981035.3448] device (enp12s0): carrier: link connected
jul 14 00:17:16 Infinity avahi-daemon[895]: Joining mDNS multicast group on interface enp12s0.IPv6 with address fe80::c825:f148:6891:ace1.
jul 14 00:17:16 Infinity avahi-daemon[895]: New relevant interface enp12s0.IPv6 for mDNS.
jul 14 00:17:16 Infinity avahi-daemon[895]: Registering new address record for fe80::c825:f148:6891:ace1 on enp12s0.*.
jul 14 00:17:16 Infinity steam[3543]: [2026-07-14 00:17:16] Manifest download: finished
jul 14 00:17:16 Infinity steam[3543]: [2026-07-14 00:17:16] Download skipped by HTTP 304 Not Modified
jul 14 00:17:16 Infinity steam[3543]: [2026-07-14 00:17:16] Nothing to do
jul 14 00:17:17 Infinity kernel: sysrq: This sysrq operation is disabled.
jul 14 00:17:18 Infinity kernel: sysrq: Emergency Sync
Update.
Culprit found. My old backup keyboard Logitech G105. Switched it out after the F-key switch on my mechanical failed on Sunday. No issues till needing a reboot yesterday afternoon.
A fresh (re)boot, only the Logitech connected to one of the mobo I/O USB ports, this seems to cause this Suspend issue. Which instantly wakes up the system after sleep state has been reached and it messing things at waking up amdgpu.
When (on fresh (re)boot) the Logitech is connected through my USB hub, in my monitor, no issues.
The logs do not indicate the Logitech keyboard being the cause.
So I think it might be related to my MSI AM5 mainboard. A replacement mechenical keyboard is on order, will see what it does.
This has nothing to do with the problem, but why do you have your second 1080p monitor connected to the Raphael iGPU?
In general, it’s better to connect all monitors to the primary discrete GPU unless there’s a specific reason not to.
That dGPU runs circles around your other one, so just let the iGPU sleep.
When using two this way, some things you have to almost do double of with the compositor, which is also some added bloat.
You can make everything faster, and at the same time, your iGPU can basically sleep (good riddance)! :grin:
One exception I have done many times, on laptops anyway, is to only use the iGPU. But this is more for power savings than anything.
Off topic
That secondary, is an repurposed laptop 15.6" in portrait besides a 34" 3440x1440 and is only used to monitor and display sensors readings and system logs.
It is connected to the iGPU as a workaround, because of known dGPU multi monitor power management issues. Both on my former 6700XT and current 9070XT.
When both monitors were/are connected to the dGPU, it’s MCLK (VRAM) did not go to lowest (idle) c-state. Causing high idle power consumption which is a known issue.
As workaround, connecting it to the iGPU, lets the dGPU’s MCLK idle properly lowest c-state. The combined idle consumption was lower then when both monitors were connected to the dGPU.
But I have not tested if this was fixed, for my case, on recent kernels.
/Off topic
It seems the issue is related to my MSI main board and the USB keyboard being connected on the IO to the USB ports that are routed to the chipset instead of the CPU. On the CPU, where my monitor’s USB switch is connected to the keyboard and it’s current new replacement give no issues.
Issues solved
