(This is a total dejavu, I was going to make the title identical to a thread that already exists from back in March, and I started it…).
I turned on my laptop today and my screen kept flickering. Since I have started using Timeshift a short wile ago, this is the first time I was able to check if the problem could be fixed be rolling back a recent update, and - voila: It could!
I restored my previous system state with Timeshift and the problem is gone.
Specs:
[ben@paul-mnj ~]$ inxi -Fxxxza
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0
root=UUID=02d09efd-0036-4efc-ace1-08d57809dd36 rw quiet
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
Type: Laptop System: TUXEDO product: TUXEDO v: N/A
serial: <filter> Chassis: Notebook type: 10 serial: <filter>
Mobo: TUXEDO model: N141CU serial: <filter> UEFI: INSYDE
v: 1.07.04 date: 08/30/2019
ID-1: BAT0 charge: 34.0 Wh (98.6%)
condition: 34.5/35.3 Wh (97.6%) volts: 13.1 min: 11.4
model: Notebook BAT type: Li-ion serial: <filter>
status: Charging
Device-1: hidpp_battery_0
model: Logitech Wireless Mouse M315/M235 serial: <filter>
charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: Quad Core model: Intel Core i7-10510U bits: 64
type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: DE cache:
L2: 8 MiB
bogomips: 36812
Speed: 700 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 700
2: 700 3: 700 4: 700 5: 701 6: 700 7: 700 8: 699
Type: spec_store_bypass mitigation: Speculative Store Bypass
disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
pointer sanitization
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: CLEVO/KAPOK driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony Chicony USB2.0 Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 04f2:b649 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 5000
bus-ID: 3b:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp59s0f1 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel
port: 5000 bus-ID: 40:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp64s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0025
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no
software: yes address: see --recommends
Local Storage: total: 1.41 TiB used: 395.58 GiB (27.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel
model: SSDPEKNW010T8 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: 002C temp: 31.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial
model: CT525MX300SSD1 size: 489.05 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: R060 scheme: GPT
ID-1: / raw-size: 300 GiB size: 294.23 GiB (98.08%)
used: 17.61 GiB (6.0%) fs: ext4 dev: /dev/nvme0n1p1
maj-min: 259:1
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 553.57 GiB size: 543.81 GiB (98.24%)
used: 128.05 GiB (23.5%) fs: ext4 dev: /dev/nvme0n1p4
maj-min: 259:4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 254 Uptime: 1h 20m wakeups: 5 Memory: 31.06 GiB
used: 4.24 GiB (13.6%) Init: systemd v: 247 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1387 pacman: 1381 lib: 380
flatpak: 6 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
It’s just that I don’t know how to proceed from here - I can hardly refrain from ever updating my system again. What to do now?
