There’s a problem when i let my laptop open for few minuts without using it, in this time it doesn’t go to the sleep mode and just show a black screen even after click Space or Enter. the weird thing is that it still work.
my version is Manjaro-XFCE 20.1
my laptop informations are in my profile
Fabby
8 October 2020 19:24
2
Welcome to Manjaro!
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
After a reboot , please do the following:
journalctl --system --boot=-1 | grep "suspend entry"
journalctl --system --boot=-1 | grep "suspend exit"
then have a look at the begin and end time and post the output of:
journalctl --system --boot=-1 --since "YYYY-MM-DD HH:MM:SS" --until "YYYY-MM-DD HH:MM:SS"
where obviously --since
is the datetime of suspend entry and --until
is the datetime of suspension exit.
Hi, the output of ```
journalctl --system --boot-1 | grep “suspend entry”
ournalctl: unrecognized option '--boot-1'
There isn't any output for ```
My system informatins
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=0348ae0b-0071-4170-aa30-603bf81f314f rw quiet apparmor=1
security=apparmor resume=UUID=bf0529af-6810-4c69-972b-959470f3562c
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire E5-576G v: V1.32 serial: <filter>
Mobo: KBL model: Ironman_SK v: V1.32 serial: <filter> UEFI: Insyde v: 1.32
date: 10/24/2017
ID-1: BAT1 charge: 13.1 Wh condition: 33.3/41.4 Wh (80%) volts: 14.4/14.8
model: PANASONIC AS16A5K type: Li-ion serial: <filter> status: Discharging
RAM: total: 3.72 GiB used: 2.60 GiB (69.8%)
Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 3072 KiB bogomips: 21607
Speed: 500 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 500 2: 500 3: 500
4: 500
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Acer Incorporated ALI
driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:174d
Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus ID: 1-7:4
chip ID: 04f2:b573
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia
display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: GeForce MX130/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 4000 bus ID: 03:00.0 chip ID: 8086:24fb
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 04:00.1 chip ID: 10ec:8168
IF: enp4s0f1 state: down mac: <filter>
Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter type: USB
driver: hid-generic,usbhid bus ID: 1-1:7 chip ID: 0458:6001
Local Storage: total: 223.57 GiB used: 11.79 GiB (5.3%)
ID-1: /dev/sda vendor: SanDisk model: SSD PLUS 240GB size: 223.57 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 04RL scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XA1M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw size: 215.08 GiB size: 210.71 GiB (97.97%)
used: 11.79 GiB (5.6%) fs: ext4 dev: /dev/sda2 label: N/A
uuid: 0348ae0b-0071-4170-aa30-603bf81f314f
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 56C0-0620
ID-1: swap-1 type: partition size: 8.19 GiB used: 4.0 MiB (0.0%)
priority: -2 dev: /dev/sda3 label: N/A
uuid: bf0529af-6810-4c69-972b-959470f3562c
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-1:7 info: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s chip ID: 0458:6001
Device-2: 1-7:4 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b573
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 43 C
Processes: 196 Uptime: 30m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1136 lib: 317 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.05```
Fabby
9 October 2020 12:00
4
My mistake:
that should have had a =
before the -1
but from your journalctl --system --boot=-1 | grep "suspend exit"
having no output I can infer:
Please try this then:
journalctl --system --boot=0 | grep "suspend entry"
If that gives no output neither, is your system set up to suspend and hibernate ?
P.S. Multiple lines of text: 3 backticks as the first and last line of the output. Just one word
in a sentence: one backtick before and after the word…
