Black screen on laptop after waking up from a suspended session
Hello fellow Manjarians, I am facing this issue for almost a year now and over various kernels, approximately since 5.11 without any kernel or Manjaro stable update since then ever fixing it for me (currently on 5.16.7-1). The laptop acts as if it suspended successfully, but after waking up I get black screen without any cursor or the possibility of switching to another tty, and all I can do is force-shutdown using the power button. Happens with like a 50% probability, plugging into power doesn’t help.
My laptop is Lenovo Ideapad Gaming 3 15IMH05 with Intel and Nvidia GPU. I use the hybrid proprietary driver but without any packages for switching between them, due to stability issues, as I game on Windows 10 anyways. Windows is sitting at a physically separate drive on this machine, with fast boot and hibernation disabled, and its suspend/wakeup is working flawlessly.
Really ANY help is appreciated. as the similar threads regarding this issue haven’t really been helpful so far and I’m tired by not being able to use such a basic function of my laptop due to using Manjaro.
inxi -Fazy
Journalctl of startup after restart since last blackscreen after suspend
The title reminded me AC/DC - Back in Black :wink:
Not this one. After the next round of pressing per button to force shutdown and booting, do journalctl -b-1 -p3 --no-hostname --no-pager and post the output.
And is you device supported by power-profiles-daemon ? Because it might show:
* balanced :
Driver: placeholder
power saver:
Driver: placeholder
And in that case, there is no actual support for power management, hence is not knowing what to do on resume from suspend.
Some interesting observations
After I suspend/wake by not closing/opening the lid, but simply executing the suspend command and waking up by pressing a key on the keyboard, the screen lights up with the last screen but I cannot see the mouse moving or any of my inputs doing any actions, even for changing tty or restarting Plasma.
The Caps and Num Lock key LEDs however turn off and on as I press them.
@openminded this is the output after suspending and trying to wake up:
úno 24 21:18:31 kernel: x86/cpu: SGX disabled by BIOS.
úno 24 21:18:31 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20210930/dswload2-162)
úno 24 21:18:31 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210930/psobject-220)
úno 24 21:18:31 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20210930/dswload2-162)
úno 24 21:18:32 kernel:
úno 24 21:18:39 nmbd[809]: [2022/02/24 21:18:39.462296,  0] ../../source3/nmbd/nmbd.c:901(main)
úno 24 21:18:39 nmbd[809]:   nmbd version 4.15.5 started.
úno 24 21:18:39 nmbd[809]:   Copyright Andrew Tridgell and the Samba Team 1992-2021
úno 24 21:18:39 nmbd[809]: [2022/02/24 21:18:39.464393,  0] ../../lib/util/become_daemon.c:150(daemon_status)
úno 24 21:18:39 nmbd[809]:   daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
úno 24 21:18:39 nmbd[809]: [2022/02/24 21:18:39.464576,  0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
úno 24 21:18:39 nmbd[809]:   NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
úno 24 21:18:43 smbd[1210]: [2022/02/24 21:18:43.784040,  0] ../../source3/smbd/server.c:1734(main)
úno 24 21:18:43 smbd[1210]:   smbd version 4.15.5 started.
úno 24 21:18:43 smbd[1210]:   Copyright Andrew Tridgell and the Samba Team 1992-2021
úno 24 21:19:06 nmbd[809]: [2022/02/24 21:19:06.743700,  0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
úno 24 21:19:06 nmbd[809]:   *****
úno 24 21:19:06 nmbd[809]:   Samba name server HYPERION-NB is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.128
And this is another (not sure why it’s longer this time, but I suspended by closing the lid now):
úno 24 21:25:38 kernel: x86/cpu: SGX disabled by BIOS.
úno 24 21:25:38 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20210930/dswload2-162)
úno 24 21:25:38 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210930/psobject-220)
úno 24 21:25:38 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20210930/dswload2-162)
úno 24 21:25:39 kernel:
úno 24 21:25:46 nmbd[811]: [2022/02/24 21:25:46.518954,  0] ../../source3/nmbd/nmbd.c:901(main)
úno 24 21:25:46 nmbd[811]:   nmbd version 4.15.5 started.
úno 24 21:25:46 nmbd[811]:   Copyright Andrew Tridgell and the Samba Team 1992-2021
úno 24 21:25:46 nmbd[811]: [2022/02/24 21:25:46.520246,  0] ../../lib/util/become_daemon.c:150(daemon_status)
úno 24 21:25:46 nmbd[811]:   daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
úno 24 21:25:46 nmbd[811]: [2022/02/24 21:25:46.520453,  0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
úno 24 21:25:46 nmbd[811]:   NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
úno 24 21:25:50 smbd[1206]: [2022/02/24 21:25:50.131096,  0] ../../source3/smbd/server.c:1734(main)
úno 24 21:25:50 smbd[1206]:   smbd version 4.15.5 started.
úno 24 21:25:50 smbd[1206]:   Copyright Andrew Tridgell and the Samba Team 1992-2021
úno 24 21:26:14 nmbd[811]: [2022/02/24 21:26:14.526966,  0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
úno 24 21:26:14 nmbd[811]:   *****
úno 24 21:26:14 nmbd[811]:   Samba name server HYPERION-NB is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.128
úno 24 21:26:17 systemd-coredump[1564]: Process 822 (appimagelaunche) of user 1000 dumped core.
                                         Module linux-vdso.so.1 with build-id 2392bc566695c3d07e55c26c295895c93e5a5039
                                         Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
                                         Module libblkid.so.1 with build-id 16cc0887733296cbf17ddbac780435e8a9071246
                                         Module libgpg-error.so.0 with build-id 82524ee3d1c4c2244d7cfdcc1e6eea5f9855f6c6
                                         Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
                                         Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
                                         Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
                                         Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
                                         Module libpangoft2-1.0.so.0 with build-id ef74c3ce7ee52a746fb5f2840d80a84e314edb92
                                         Module libmount.so.1 with build-id 03ade3c7be7f082dc9275212a30771131625fee7
                                         Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
                                         Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
                                         Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
                                         Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
                                         Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b681dc0
                                         Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
                                         Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
                                         Module libcom_err.so.2 with build-id 1481d614a1c3e3692b1673e8ad35ba41fbea3658
                                         Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
                                         Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
                                         Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
                                         Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
                                         Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
                                         Module libcap.so.2 with build-id eb6dae97527fc89dbb0d5bb581a15acd02ae9f56
                                         Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
                                         Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
                                         Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
                                         Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
                                         Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
                                         Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
                                         Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
                                         Module libfontconfig.so.1 with build-id 9fdeb38479c4090d673efc2e8cb60176efe65da1
                                         Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
                                         Module libpango-1.0.so.0 with build-id 730a8183a36afae82dd6a5564c0e490fed239a40
                                         Module libpangocairo-1.0.so.0 with build-id 10d2af38056eee9a6b3458d8aac24095c4dfab72
                                         Module libxml2.so.2 with build-id b710b880b0d4e9c93554fa632129db44c20632cd
                                         Module libgio-2.0.so.0 with build-id e04146bb599deb6eb15744fc2e95e5f538952d56
                                         Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b36
                                         Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
                                         Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
                                         Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
                                         Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
                                         Module libexpat.so.1 with build-id c3b8b6921f5b323540b84acd301ccc7bc5bc0428
                                         Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
                                         Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
                                         Module libboost_atomic.so.1.78.0 with build-id 8f26af08821860115fcd3b2525cc3476fdbaa6fe
                                         Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
                                         Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
                                         Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
                                         Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b18107473aeda4c
                                         Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
                                         Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
                                         Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0786de4
                                         Module libssl.so.1.1 with build-id 1024424ab33a3767da03f4fdb1fc1b02479f160f
                                         Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
                                         Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
                                         Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
                                         Module libnghttp2.so.14 with build-id eca975f5266a67fc4895065727647e98ff99a128
                                         Module libzstd.so.1 with build-id 72f3511cba7db578f6a2647925f35664da6c838b
                                         Module libpcre2-16.so.0 with build-id 195fbccafbcff538ce13805ba687514fb614c5ed
                                         Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
                                         Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
                                         Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
                                         Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
                                         Module libsystemd.so.0 with build-id eca1e10a62234b73a4e32d1b52598ce39cb186d4
                                         Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
                                         Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
                                         Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
                                         Module libgobject-2.0.so.0 with build-id e67b3a29cecdd98c3d8bd6eb7524a812331b20a2
                                         Module librsvg-2.so.2 with build-id 6b6b837ebec63485c2e1b826260885f065d22683
                                         Module libsquashfuse.so.0 with build-id 450212c2ecbebc35d1bd40b0c3d26c540c482218
                                         Module libarchive.so.13 with build-id ae505295325ae814b94b23d8f79c0eb25d4efa02
                                         Module libboost_filesystem.so.1.78.0 with build-id fc551e378bf62b82453ccc49e0ef1c88f9bc80e6
                                         Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
                                         Module libharfbuzz.so.0 with build-id 8006a225ec61b8231d0b003aebab9920ac0b9179
                                         Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
                                         Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
                                         Module libGL.so.1 with build-id 912ac4f37a9fa2d5abcf7a9088c9983cfe46f12a
                                         Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
                                         Module libcurl.so.4 with build-id d4dec3d9f8c789ec28d441f2a3f73d532809e6ef
                                         Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
                                         Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
                                         Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d835
                                         Module libstdc++.so.6 with build-id 9b5eeeb149bf3c4efe787fb398b44f00507aec87
                                         Module libQt5Core.so.5 with build-id 9f61dcde37e5e8e3227aed850bd5d5776b64911a
                                         Module libglib-2.0.so.0 with build-id bd949a4794ad959019499c6afcb8f416dcff9810
                                         Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f31066229996
                                         Module libappimage.so.1.0 with build-id a63e854d9d7bb2ad01eda1f63863e1089bde2071
                                         Module libQt5Gui.so.5 with build-id 73b7663290a34c406bbc1467cc483dccd00cec32
                                         Module libQt5Widgets.so.5 with build-id 4767af8c8c21020ef7d60235894aefb9504e2f4e
                                         Module libappimageupdate.so with build-id e102343adacf6676d8481a521db2482e6c6b8b3e
                                         Module libQt5DBus.so.5 with build-id 91faf7a9b6b7cbcfd37c1e6abb0dad44f7cba2b8
                                         Module appimagelauncherd with build-id 2fafbe9e86541032ce92120998276a7dda1b22c3
                                         Stack trace of thread 822:
                                         #0  0x00007fd8c1b22054 _ZNK4QDireqERKS_ (libQt5Core.so.5 + 0x1cf054)
                                         #1  0x000055e6e1e455ce n/a (appimagelauncherd + 0x215ce)
                                         #2  0x000055e6e1e32a4f n/a (appimagelauncherd + 0xea4f)
                                         #3  0x00007fd8c1c0fd93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #4  0x00007fd8c1c120ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf0ff)
                                         #5  0x00007fd8c1c02e06 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2afe06)
                                         #6  0x00007fd8c1bdf14e _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28c14e)
                                         #7  0x00007fd8c1c29ca5 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6ca5)
                                         #8  0x00007fd8c1c2a2d2 n/a (libQt5Core.so.5 + 0x2d72d2)
                                         #9  0x00007fd8c1ec5f13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
                                         #10 0x00007fd8c1f1c0d9 n/a (libglib-2.0.so.0 + 0xab0d9)
                                         #11 0x00007fd8c1ec3485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
                                         #12 0x00007fd8c1c2a44a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d744a)
                                         #13 0x00007fd8c1bd744b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28444b)
                                         #14 0x00007fd8c1be2b97 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fb97)
                                         #15 0x000055e6e1e31189 n/a (appimagelauncherd + 0xd189)
                                         #16 0x00007fd8c157db25 __libc_start_main (libc.so.6 + 0x27b25)
                                         #17 0x000055e6e1e3169e n/a (appimagelauncherd + 0xd69e)
@bogdancovaciu upon installing power-profiles-daemon and running powerprofilesctl I get this output:
performance:
    Driver:     intel_pstate
    Degraded:   no
* balanced:
  power-saver:
That should be fine now. The black screen issue also happens with the 5.15 kernel now ?
Maybe you want to switch to testing , update mirrors then the system, for newer and a bit better 5.16 kernel …
As I understand it, power-profiles-daemon only allows switching of power profiles and not much else. So how does installing it and just checking that it runs fix anything for me? I’m already on 5.16.7-1 and nothing is fixed, neither was on 5.15.
Was more about the power governors use the proper drivers, so power saving is not an issue, so you can then check this
https://wiki.archlinux.org/title/Power_management
and this
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate
Reading through power management issues on Arch wiki I came across the /etc/mkinitcpio.conf file which defines hooks, so I went to check it out and discovered that since july it hasn’t been updated but a .pacnew version exists, which has the following changes:
$ diff mkinitcpio.conf mkinitcpio.conf.pacnew
52c52
< HOOKS=(base udev autodetect modconf block filesystems resume keyboard)
> HOOKS=(base udev autodetect modconf block filesystems keyboard fsck)
62a63
> #COMPRESSION="zstd"
I’m considering adding the resume hook, after keyboard and before the fsck, regenerate it using mkinitcpio -P and see if it helps.
EDIT: Seems that adding the fsck hook helped, I just successfuly suspended a few times, and even woke up after a hibernation! So my hooks now read:
HOOKS=(base udev autodetect modconf block filesystems resume fsck keyboard)
I’ll give it a few days and if not a single suspend / hibernation fails, I’ll close this topic as solved :blush: thanks for the help so far!
Suspending with power save mode causes my computer not to wake up again. Here is the log (note that I suspended some time around 22:30, not sure why the log goes that much into history instead):
úno 27 21:04:14 kernel: x86/cpu: SGX disabled by BIOS.
úno 27 21:04:14 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20210930/dswload2-162)
úno 27 21:04:14 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210930/psobject-220)
úno 27 21:04:14 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20210930/dswload2-162)
úno 27 21:04:15 kernel:
úno 27 21:04:22 nmbd[803]: [2022/02/27 21:04:22.423036,  0] ../../source3/nmbd/nmbd.c:901(main)
úno 27 21:04:22 nmbd[803]:   nmbd version 4.15.5 started.
úno 27 21:04:22 nmbd[803]:   Copyright Andrew Tridgell and the Samba Team 1992-2021
úno 27 21:04:22 nmbd[803]: [2022/02/27 21:04:22.424883,  0] ../../lib/util/become_daemon.c:150(daemon_status)
úno 27 21:04:22 nmbd[803]:   daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
úno 27 21:04:22 nmbd[803]: [2022/02/27 21:04:22.425012,  0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
úno 27 21:04:22 nmbd[803]:   NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
úno 27 21:04:30 smbd[1316]: [2022/02/27 21:04:30.248932,  0] ../../source3/smbd/server.c:1734(main)
úno 27 21:04:30 smbd[1316]:   smbd version 4.15.5 started.
úno 27 21:04:30 smbd[1316]:   Copyright Andrew Tridgell and the Samba Team 1992-2021
úno 27 21:04:52 systemd-coredump[1387]: Process 814 (appimagelaunche) of user 1000 dumped core.
                                         Stack trace of thread 814:
                                         #0  0x00007f022e9c7054 _ZNK4QDireqERKS_ (libQt5Core.so.5 + 0x1cf054)
                                         #1  0x0000560a657a25ce n/a (appimagelauncherd + 0x215ce)
                                         #2  0x0000560a6578fa4f n/a (appimagelauncherd + 0xea4f)
                                         #3  0x00007f022eab4d93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #4  0x00007f022eab70ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf0ff)
                                         #5  0x00007f022eaa7e06 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2afe06)
                                         #6  0x00007f022ea8414e _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28c14e)
                                         #7  0x00007f022eaceca5 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6ca5)
                                         #8  0x00007f022eacf2d2 n/a (libQt5Core.so.5 + 0x2d72d2)
                                         #9  0x00007f022ed6af13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
                                         #10 0x00007f022edc10d9 n/a (libglib-2.0.so.0 + 0xab0d9)
                                         #11 0x00007f022ed68485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
                                         #12 0x00007f022eacf44a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d744a)
                                         #13 0x00007f022ea7c44b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28444b)
                                         #14 0x00007f022ea87b97 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fb97)
                                         #15 0x0000560a6578e189 n/a (appimagelauncherd + 0xd189)
                                         #16 0x00007f022e422b25 __libc_start_main (libc.so.6 + 0x27b25)
                                         #17 0x0000560a6578e69e n/a (appimagelauncherd + 0xd69e)
úno 27 21:04:54 nmbd[803]: [2022/02/27 21:04:54.468924,  0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
úno 27 21:04:54 nmbd[803]:   *****
úno 27 21:04:54 nmbd[803]:   Samba name server HYPERION-NB is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.128
úno 27 21:05:15 systemd-udevd[1477]: controlC1: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/controlC1/../uevent}, ignoring: No such file or directory
úno 27 21:05:32 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
úno 27 21:05:46 systemd-udevd[2358]: controlC1: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/controlC1/../uevent}, ignoring: No such file or directory
úno 27 21:05:51 systemd-coredump[2582]: Process 1479 (appimagelaunche) of user 1000 dumped core.
                                         Stack trace of thread 1479:
                                         #0  0x00007fa30a21d054 _ZNK4QDireqERKS_ (libQt5Core.so.5 + 0x1cf054)
                                         #1  0x0000561c6235f5ce n/a (appimagelauncherd + 0x215ce)
                                         #2  0x0000561c6234ca4f n/a (appimagelauncherd + 0xea4f)
                                         #3  0x00007fa30a30ad93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #4  0x00007fa30a30d0ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf0ff)
                                         #5  0x00007fa30a2fde06 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2afe06)
                                         #6  0x00007fa30a2da14e _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28c14e)
                                         #7  0x00007fa30a324ca5 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6ca5)
                                         #8  0x00007fa30a3252d2 n/a (libQt5Core.so.5 + 0x2d72d2)
                                         #9  0x00007fa30a5c0f13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
                                         #10 0x00007fa30a6170d9 n/a (libglib-2.0.so.0 + 0xab0d9)
                                         #11 0x00007fa30a5be485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
                                         #12 0x00007fa30a32544a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d744a)
                                         #13 0x00007fa30a2d244b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28444b)
                                         #14 0x00007fa30a2ddb97 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fb97)
                                         #15 0x0000561c6234b189 n/a (appimagelauncherd + 0xd189)
                                         #16 0x00007fa309c78b25 __libc_start_main (libc.so.6 + 0x27b25)
                                         #17 0x0000561c6234b69e n/a (appimagelauncherd + 0xd69e)
úno 27 21:05:54 kernel: iwlwifi 0000:00:14.3: Unhandled alg: 0x707
úno 27 21:06:06 systemd-udevd[2658]: controlC1: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/controlC1/../uevent}, ignoring: No such file or directory
úno 27 21:06:25 systemd-udevd[3004]: controlC1: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/controlC1/../uevent}, ignoring: No such file or directory
úno 27 21:07:02 systemd-udevd[3340]: controlC1: /usr/lib/udev/rules.d/78-sound-card.rules:5 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/controlC1/../uevent}, ignoring: No such file or directory
úno 27 21:07:04 pulseaudio[988]: Device /org/bluez/hci0/dev_38_69_85_E8_67_7B points to a nonexistent adapter /org/bluez/hci0.
úno 27 21:07:04 pulseaudio[988]: Device /org/bluez/hci0/dev_FC_58_FA_C5_67_58 points to a nonexistent adapter /org/bluez/hci0.
úno 27 21:07:04 pulseaudio[988]: Device /org/bluez/hci0/dev_FC_58_FA_D3_F6_45 points to a nonexistent adapter /org/bluez/hci0.
úno 27 21:07:04 pulseaudio[988]: Device /org/bluez/hci0/dev_18_01_F1_93_C6_15 points to a nonexistent adapter /org/bluez/hci0.
úno 27 21:07:13 systemd-coredump[3595]: Process 2858 (appimagelaunche) of user 1000 dumped core.
                                         Stack trace of thread 2858:
                                         #0  0x00007fdca1a20054 _ZNK4QDireqERKS_ (libQt5Core.so.5 + 0x1cf054)
                                         #1  0x00005616f05d65ce n/a (appimagelauncherd + 0x215ce)
                                         #2  0x00005616f05c3a4f n/a (appimagelauncherd + 0xea4f)
                                         #3  0x00007fdca1b0dd93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #4  0x00007fdca1b100ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf0ff)
                                         #5  0x00007fdca1b00e06 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2afe06)
                                         #6  0x00007fdca1add14e _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28c14e)
                                         #7  0x00007fdca1b27ca5 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6ca5)
                                         #8  0x00007fdca1b282d2 n/a (libQt5Core.so.5 + 0x2d72d2)
                                         #9  0x00007fdca1dc3f13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
                                         #10 0x00007fdca1e1a0d9 n/a (libglib-2.0.so.0 + 0xab0d9)
                                         #11 0x00007fdca1dc1485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
                                         #12 0x00007fdca1b2844a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d744a)
                                         #13 0x00007fdca1ad544b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28444b)
                                         #14 0x00007fdca1ae0b97 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fb97)
                                         #15 0x00005616f05c2189 n/a (appimagelauncherd + 0xd189)
                                         #16 0x00007fdca147bb25 __libc_start_main (libc.so.6 + 0x27b25)
                                         #17 0x00005616f05c269e n/a (appimagelauncherd + 0xd69e)
úno 27 21:07:53 systemd-coredump[3719]: Process 3714 (appimagelaunche) of user 1000 dumped core.
                                         Stack trace of thread 3714:
                                         #0  0x00007fbf92d9d054 _ZNK4QDireqERKS_ (libQt5Core.so.5 + 0x1cf054)
                                         #1  0x000055f7f69d95ce n/a (appimagelauncherd + 0x215ce)
                                         #2  0x000055f7f69c6a4f n/a (appimagelauncherd + 0xea4f)
                                         #3  0x00007fbf92e8ad93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #4  0x00007fbf92e8d0ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf0ff)
                                         #5  0x00007fbf92e7de06 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2afe06)
                                         #6  0x00007fbf92e5a14e _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28c14e)
                                         #7  0x00007fbf92ea4ca5 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6ca5)
                                         #8  0x00007fbf92ea52d2 n/a (libQt5Core.so.5 + 0x2d72d2)
                                         #9  0x00007fbf93140f13 g_main_context_dispatch (libglib-2.0.so.0 + 0x54f13)
                                         #10 0x00007fbf931970d9 n/a (libglib-2.0.so.0 + 0xab0d9)
                                         #11 0x00007fbf9313e485 g_main_context_iteration (libglib-2.0.so.0 + 0x52485)
                                         #12 0x00007fbf92ea544a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d744a)
                                         #13 0x00007fbf92e5244b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28444b)
                                         #14 0x00007fbf92e5db97 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fb97)
                                         #15 0x000055f7f69c5189 n/a (appimagelauncherd + 0xd189)
                                         #16 0x00007fbf927f8b25 __libc_start_main (libc.so.6 + 0x27b25)
                                         #17 0x000055f7f69c569e n/a (appimagelauncherd + 0xd69e)
úno 27 21:10:15 kernel: Uhhuh. NMI received for unknown reason 20 on CPU 0.
úno 27 21:10:15 kernel: Do you have a strange power saving mode enabled?
úno 27 21:10:15 kernel: Dazed and confused, but trying to continue
úno 27 21:49:52 systemd-coredump[7808]: Process 883 (kwin_x11) of user 1000 dumped core.
                                         Module libqtquickcontrolsplugin.so with build-id 4b92fe99856123798af47a2d02f9f474fb38a817
                                         Module libqtquicktemplates2plugin.so with build-id c3b8b3c611e2738466f63103b112a117b0d23565
                                         Module libwindowplugin.so with build-id ff5d38c7207c5f908aa6c6af9d281ed0a67bdba4
                                         Module libqmlplugin.so with build-id 5641500dbafbcc0b39202fd752bb4e39ff7184db
                                         Module libplasmaextracomponentsplugin.so with build-id ced20c36e785ef6cf45c5a444d24e6cf66717e45
                                         Module libplasmacomponentsplugin.so with build-id 726ed98fbad154afd7322d9c393dcd0a6883abe9
                                         Module libqquicklayoutsplugin.so with build-id 3e04597f4ec3a43712562d531e8de7572447e697
                                         Module libkquickcontrolsaddonsplugin.so with build-id ec7da4335bdc5856cd69dae1714fc47e997a6cf3
                                         Module libOpenGL.so.0 with build-id f09885433fcfb48c54d308f1c8fbe2898b5e9ceb
                                         Module libKF5PlasmaQuick.so.5 with build-id e2abde03dd32c7004808046d0237eed544989787
                                         Module libcorebindingsplugin.so with build-id fe5c21b6364ea04020b1e26580a779457e8f3edb
                                         Module libQt5QmlWorkerScript.so.5 with build-id 82d0ade5fade144bcd98d9ab07288743fac0d551
                                         Module libqtquick2plugin.so with build-id 6029f04ad70290332095bf815280fcbdadc1c6e7
                                         Module libdecorationplugin.so with build-id 6e8d936d5c96f9655ecae19355a01727fd52f3e5
                                         Module KWinSceneOpenGL.so with build-id 567483ba7bf28f2e43e5d0b50975cff9eeebcafe
                                         Module libKWinNightColorPlugin.so with build-id bd459f840b97698c56ce7116fcfb0499e844c6e8
                                         Module krunnerintegration.so with build-id 689e473b17a3139e283d80f07d100b339cc331fb
                                         Module colordintegration.so with build-id 22da7563ae926546e64bb5f6cd615104f21e3fba
                                         Module libxcb-res.so.0 with build-id b825f66a75478fd00eeb4c57ecb0ac7792e00f5e
                                         Module KF5WindowSystemX11Plugin.so with build-id 0f9ff286b7df3b3704f482f775b9845994acee35
                                         Module kwin5_aurorae.so with build-id 1dc6ca262841caf7dc9dae1ae5dca7ae08bb8d52
                                         Module libkwinxrenderutils.so.13 with build-id 7408c79b6f2402af85ce5aebb9c1267f1a22a803
                                         Module KWinX11Platform.so with build-id e2346b0b556a7cd8ff413c0bb6bdc3ee1b127d58
                                         Module libwebp.so.7 with build-id 0add7a572705244ed810b7e722cce7da0dcfb62c
                                         Module libwebpdemux.so.2 with build-id 7bc15ac239db643015e169a2c6cc822156eb999a
                                         Module libwebpmux.so.3 with build-id 4232d5263a45719ba12f58ed7d8cae3a0fc887de
                                         Module libqwebp.so with build-id 4c9c68e5ad684209eebcc41c23d7c9a700fa84fd
                                         Module libqwbmp.so with build-id 266f01cf84c000fff5463ee44c422737dd5a6a55
                                         Module libqtiff.so with build-id 0ecb9be29e5c5f5b86263a2fa318540a91245d4d
                                         Module libqsvg.so with build-id 528eb97e6f2c08b91aac53de95cb672fbb997155
                                         Module libQt5Pdf.so.5 with build-id ba6bf675e8a83e05b2736a3b2d6989059c6a6cf7
                                         Module libqpdf.so with build-id d1c9dd818ead94b07e4e75c654e8457d45417448
                                         Module libmng.so.2 with build-id 2de13b8bba73f358ab2e323aa2209c2e2fc886e7
                                         Module libqmng.so with build-id f82452e874e7fb0bfcca0a9b87ede1725e221bf0
                                         Module libqjpeg.so with build-id 2c125f4f44bc9c91d6b4da710c933caa0d9226ea
                                         Module libjasper.so.4 with build-id 062fa02a47172a8bf53b976a67eea42a61f37f0f
                                         Module libqjp2.so with build-id 53eef9e3520a681f5c424f67125bd2cb733932e9
                                         Module libqico.so with build-id 130fa1779836b9d23fe04bcc4203163b5edb246c
                                         Module libqicns.so with build-id 27a319033c0468ae142a4bf74e6ca92783b27bf1
                                         Module libqgif.so with build-id c93caa72d1745c3f503a3a9ef26c5bff6e181889
                                         Module kimg_xcf.so with build-id 0cbe2e882a3436129559e2c328774ecdfd5e4901
                                         Module kimg_tga.so with build-id 65c111094d339d56a3d55109b73370eb624d9c0d
                                         Module kimg_rgb.so with build-id 48fb36ce3e5d182c39885a899a738cac1b8ddf6b
                                         Module kimg_ras.so with build-id 4eebe999cbaead7a9c005907bcb52f10ff7e9157
                                         Module kimg_psd.so with build-id c731345a05015a7db442c987e134baf188e33a57
                                         Module kimg_pic.so with build-id 45b62e011e4d566ed511476125efcb88836c4873
                                         Module kimg_pcx.so with build-id b2af032c5351f3336b1544ca28872bb08db592ba
                                         Module kimg_ora.so with build-id 1010721c697f0bb2873f88d1f226c1f6bbd59680
                                         Module kimg_kra.so with build-id ddc12f851793c34d603ee394fc810f0c98f64a3f
                                         Module libmvec.so.1 with build-id 9aa05e22565568b778a97933527b3c64bdb8418b
                                         Module libx265.so.199 with build-id 22130b9b0d2aa957b148b0fdeb27e3fd04f0fb58
                                         Module libde265.so.0 with build-id d1ea0fbd83f7dd3dd2b0ce3d356006d305093d7a
                                         Module libheif.so.1 with build-id 5edeb8cfd3e472f2ead12893189f124bfe2c10a9
                                         Module kimg_heif.so with build-id c5e59ef98eb3ca9c2e004d2e12c429605ca28631
                                         Module kimg_hdr.so with build-id f420b8aad0260d6d49f85c389a67a0589385df18
                                         Module libIlmThread-3_1.so.30 with build-id 1d5714e7fdf53519be7a5cedbf91bcd1cbc2fb2e
                                         Module libIex-3_1.so.30 with build-id 90c74db82d22b8d1ac7a77361fd579bd1c08af94
                                         Module libImath-3_1.so.29 with build-id a6382ff94f639bb105265ceb819bdac92a7a9ae3
                                         Module libOpenEXR-3_1.so.30 with build-id d1572feb4f222f541eec5e11a2ca5276da9317c5
                                         Module kimg_exr.so with build-id e3e25598bf407ca5a7bdde9bdd745b171dc33907
                                         Module kimg_eps.so with build-id a66a3b7849b1c199be4b6ed1b509d8b75489c579
                                         Module libyuv.so with build-id c7a5e1943921367b12460b618d38ce4afd1e6caf
                                         Module libaom.so.3 with build-id 17c2d78932dffd790b290358a144c2b0ef5ddd17
                                         Module libSvtAv1Enc.so.0 with build-id 16a86797b9743608665ae8dffaebba7d492f7d05
                                         Module librav1e.so.0 with build-id 2e9e70e2433e4d2955a870f2de730172729fbe4f
                                         Module libdav1d.so.5 with build-id 82862181dbe48302fde94240f68e17fb6f9a03c7
                                         Module libavif.so.13 with build-id cdc4233bc1ff2e9b419e9bf8aaf8b5a94cf0bd87
                                         Module kimg_avif.so with build-id 912c6efab859000065709113048d182f3cdc2067
                                         Module kimg_ani.so with build-id 933e82daed1632b2f11ab3ece9a755c2b83d898f
                                         Module libkvantum.so with build-id 2fde2a248b672a35870832092a84005879cf8785
                                         Module libnss_files.so.2 with build-id 1a36dfc01d3a1010b2ee79766a24a8090a3266d5
                                         Module libncursesw.so.6 with build-id 1f873ddb2c32ab39d0b7d8646d03680ffe99de7c
                                         Module libedit.so.0 with build-id 4b0babfcad161c2ad0af6e59e2493258db23a331
                                         Module libvulkan.so.1 with build-id 40c7a455d37803dbd362377df831a77142acb66b
                                         Module libdrm_nouveau.so.2 with build-id ee16fa6a4d0bd08f5448cfc046ccb76b49aaa8a3
                                         Module libdrm_amdgpu.so.1 with build-id 30d019987d514b23115b47d6b47c1e45c18fdbaf
                                         Module libelf.so.1 with build-id 0eee16e5e39ae4c5016f31b2abb6c92f0804ae47
                                         Module libdrm_radeon.so.1 with build-id 5d1615e0467d0a34a5a82cbd4ebc84851e116307
                                         Module libsensors.so.5 with build-id dc8b2c1c0d8525411aca188ea3cc3fb86d381d30
                                         Module libLLVM-13.so with build-id 62bb83aeee3a955305312248a401be2cf62a0ea8
                                         Module iris_dri.so with build-id 10a9eafed46383cccd7c3dc76676aa5fdd37f3e5
                                         Module libxshmfence.so.1 with build-id 8876d9ccf620858795724ca24b9e567585a77cec
                                         Module libxcb-present.so.0 with build-id 68f5465258750e2397b1333b3ffc01ee33caa4e1
                                         Module libxcb-dri3.so.0 with build-id 9407a2480e09dc5a1dd9d9a0652fa8d32b328c91
                                         Module libXxf86vm.so.1 with build-id 01e8243d0c6c971fa9e743e6e53d606b1cb76f6e
                                         Module libxcb-dri2.so.0 with build-id 2dd6e65129a809dab828a1d26215a3f7a363fcc8
                                         Module libdrm.so.2 with build-id 457a1a1bd25f1d5541a10d3f16c5dc1440d77c7d
                                         Module libglapi.so.0 with build-id 9331aed5060062bcfafd463d36506312fab59549
                                         Module libGLX_mesa.so.0 with build-id f91aa66837ddb99687bb6d5e2a6414f11b04b6af
                                         Module libqxcb-glx-integration.so with build-id 7f34805ddbdfd608a12d44bcecfbc3208668564b
                                         Module libcomposeplatforminputcontextplugin.so with build-id bf776824fdfc77e5c873a9cf2171f784b81006b5
                                         Module libQt5QuickTemplates2.so.5 with build-id 14040d43cfee8889eb0ca0aba20cadf55df07d4c
                                         Module libKF5Bookmarks.so.5 with build-id df102985b23ad32db0b0dd1eb13541377ac4ebeb
                                         Module libQt5QuickControls2.so.5 with build-id f4d53b2750c80cfc6961b34d166b2cfb2aaa4a0b
                                         Module libKF5KIOFileWidgets.so.5 with build-id f4885b022b1e5569aa1ff09c47eb2c9480e54154
                                         Module KDEPlasmaPlatformTheme.so with build-id cb6f0e1d98c13616ab294b7a6eceeeabf5adafc0
                                         Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
                                         Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
                                         Module libuuid.so.1 with build-id 0c161b5e50e446f00bd0f95e98307db9d23a2024
                                         Module libxkbcommon-x11.so.0 with build-id c942fd85702bc7165a42bcb102660f9413376572
                                         Module libICE.so.6 with build-id af53458a64fe1e62a4d95606f7b03c210b2b098c
                                         Module libSM.so.6 with build-id ac7b055fd3f16b4f29373285ab04ed52eebb632d
                                         Module libxcb-xinput.so.0 with build-id 6403174c48f05f40cf7c168beb86f2886b9f09c1
                                         Module libxcb-xkb.so.1 with build-id fce20d2101f3e5439923e9283c489c2cad4420c3
                                         Module libxcb-xinerama.so.0 with build-id b328103ce7502d94fd3a4e2e8773978a9aa84adc
                                         Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
                                         Module libQt5XcbQpa.so.5 with build-id d5678ee6722e9502dd35cd145ae32643a37bf064
                                         Module libqxcb.so with build-id 4ed3a574ecda7b7f9d019aed428e518d7079ad8f
                                         Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e58290
                                         Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
                                         Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
                                         Module libp11-kit.so.0 with build-id cc372ea3c28c4d3dfc633b4d2e933c8584d2af16
                                         Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
                                         Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
                                         Module libgnutls.so.30 with build-id 50f3a52ba3db67b822fd5888790238eb548b64aa
                                         Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
                                         Module libvorbis.so.0 with build-id ad0a6c1af8f219b4e314090b6e8847223d424cbe
                                         Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
                                         Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
                                         Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
                                         Module libltdl.so.7 with build-id 64bc54a40a0b6e4209a2c712364b4ae653c3f5b2
                                         Module libtdb.so.1 with build-id 6c9ccf6d9a22d117d984d1666842a49fd7669f09
                                         Module libvorbisfile.so.3 with build-id 0010b21da05e318b42e718d90738febf58028141
                                         Module libgudev-1.0.so.0 with build-id a9f734ea9206d637d5aacfbd86298c91cdc1a33a
                                         Module libxcb-util.so.1 with build-id 4188ebc629b472b560849c5792a69c1803c3d1a4
                                         Module libQt5WaylandClient.so.5 with build-id 1261291888bdc004bf8ec269b7b479b6344e548a
                                         Module libKF5Completion.so.5 with build-id 1a0549c505fa36da417ea35e97883267ef76177e
                                         Module libKF5Solid.so.5 with build-id 662e79a4f3becf542fa4cda8ada6723bb78295e1
                                         Module libKF5JobWidgets.so.5 with build-id 0690aa6a286cc9e7f6122343c79faab444957bc4
                                         Module libKF5KIOCore.so.5 with build-id 97b93006b6a35dead8be176937e30c1b75640ac9
                                         Module libKF5ItemViews.so.5 with build-id e4757fd171ae6c4275382d433ed3bb697638686e
                                         Module libQt5PrintSupport.so.5 with build-id 94851169c75c67062006f84a7c40fa44177ca497
                                         Module libKF5AuthCore.so.5 with build-id d6c222c5566f4c7fc50695fdc36143a1b210bac0
                                         Module libKF5Codecs.so.5 with build-id 72a2a63e7416a55d354a4aff199a3b6a0bf03e3c
                                         Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
                                         Module libXtst.so.6 with build-id 96411faea62997274e362f263e65082e601a787b
                                         Module libQt5TextToSpeech.so.5 with build-id 970b9c21bf2f45dea1cf276263dd08f9cdd5a08e
                                         Module libcanberra.so.0 with build-id 379ed64f9d1408a83806cd5d94dc5bb903765615
                                         Module libQt5Network.so.5 with build-id 894f63c0d0ae61f0e8568eb7469f9cd5a61aca05
                                         Module libQt5QmlModels.so.5 with build-id 7f0c3351dabc8bac16f0737a30e45291d9dfdd77
                                         Module libKF5DBusAddons.so.5 with build-id 2d3ca02cc76d878e00280b05ec8728c677dbd6b1
                                         Module libQt5Xml.so.5 with build-id 1d21541719c1474efe2a5df203b6505ab33e4002
                                         Module libwacom.so.9 with build-id bb1b4e6bbfa3929968f1acc5311154920dd9fc0b
                                         Module libevdev.so.2 with build-id b62ae69f839f1b6b06ef2c1df19f25ff09b0d824
                                         Module libmtdev.so.1 with build-id 0cea2a842ae9a0ef02a08477076caab0e5ac5e42
                                         Module libxcb-image.so.0 with build-id ee7f8577926fe7c1d6972036c2f8e6f727e43b1b
                                         Module libxcb-render-util.so.0 with build-id c64fb28ea20a320a9754273d9ea3af85f6f74b17
                                         Module libEGL.so.1 with build-id 686c2e4036c01a3a72349ed0dd04f7c434af14ce
                                         Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
                                         Module libKF5WaylandServer.so.5 with build-id d344f68a928b077dedbdfca8d6093e0b0ca6c548
                                         Module libKF5IdleTime.so.5 with build-id 54b299ba2e4803832eae5160b2e973021e950dbf
                                         Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
                                         Module libKF5GuiAddons.so.5 with build-id 3f8ebbfcec6b33d97aeb5234522e8d0a0b4c6b22
                                         Module libKF5Archive.so.5 with build-id 1edf6dc1ca4d38f0ebf6113fb089778b93085676
                                         Module libQt5Svg.so.5 with build-id 2aa0ac65f04852ede5fb055994ebdcc8c354f419
                                         Module libKF5IconThemes.so.5 with build-id a96c9d2a2b3585355c7efbb93eb6b74ffc9813fd
                                         Module libKF5KIOGui.so.5 with build-id 14950f98ef994c6b071d1444459d0ce69c79b008
                                         Module libKF5KIOWidgets.so.5 with build-id 5ada62a44b5f4d375c9911d0cf27d836f966ee3c
                                         Module libKF5XmlGui.so.5 with build-id 3d58ac806211e72b35b32ed884b9b610fad1da41
                                         Module libQt5Sql.so.5 with build-id 06e80fe540027d969388c23c8cf96b12d0dc5202
                                         Module libqaccessibilityclient-qt5.so.0 with build-id 3133e868d77f4c2c6ebd657793baeb6a4e824544
                                         Module libKF5Declarative.so.5 with build-id 83c0cde7ff07b1c9ec3f5142dd50076069949605
                                         Module libKF5WidgetsAddons.so.5 with build-id 1ecb6c8da7ea562d7aff1acbdd19c74a1f9d393f
                                         Module libKF5ConfigGui.so.5 with build-id 82585efd4a6c6078d45ba753f17a9a7e3f3e45ff
                                         Module libKF5ConfigWidgets.so.5 with build-id 2152b99ad82c9be1096abfc4be7f9cc431114dd4
                                         Module libKF5GlobalAccel.so.5 with build-id 76523e2497f0431f013016b5230a674a9bb7aece
                                         Module libKF5Package.so.5 with build-id 9492efb4542d5c57531a07c62991a149232b0a21
                                         Module libKF5Notifications.so.5 with build-id cf776e57e2e8be19d6ccaec217f91db22751d115
                                         Module libQt5Qml.so.5 with build-id 0e85c0e0169b9d00bbded28c74432ffdafa1389b
                                         Module libQt5Quick.so.5 with build-id 4bfe07ddf0311d872a7a579775559b42dc479ebd
                                         Module libKF5Service.so.5 with build-id d1b849804483cf5e5d045fb60432203206c2ed38
                                         Module libwayland-server.so.0 with build-id 645526447334b85a6f4bf5a8b37737b27696365f
                                         Module libKF5Activities.so.5 with build-id b500ac9d9db8af60bf0d5223c830887b1503612c
                                         Module liblcms2.so.2 with build-id c01e5649a38dbf37768d02dc751b52de0dcbd141
                                         Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
                                         Module libxkbcommon.so.0 with build-id 3a9338b2085f0af41217bc0a90ffcc941938a16e
                                         Module libudev.so.1 with build-id cf0e9710c7cebd21a13840b2bc2329213cfd0192
                                         Module libinput.so.10 with build-id 956df35c2a15681d4aa87253ed15a5c18a339183
                                         Module libxcb-xfixes.so.0 with build-id a6b197ace5b9b59f913f5969eb419a88d1194f47
                                         Module libxcb-sync.so.1 with build-id dda14591103b01b1311906053bf1ca9e82ade35c
                                         Module libxcb-shape.so.0 with build-id f1b3376c4534fab0469feb1cd19f022ff98df533
                                         Module libxcb-randr.so.0 with build-id b6c1c7d4b28863b55ade251813db7f246b7ffe8b
                                         Module libxcb-keysyms.so.1 with build-id 333e5eb4075795f947c924a2085f17e2e2ae7147
                                         Module libxcb-icccm.so.4 with build-id 73f1e12d76af383aa969a60279ed5ed922045f47
                                         Module libxcb-glx.so.0 with build-id 8ad115382ad874165523dc5b4488c99d73bbc3c4
                                         Module libxcb-damage.so.0 with build-id 14ba8de82d16adadd150a1d0ae3e8ac2119ccc8a
                                         Module libxcb-cursor.so.0 with build-id 69d87b342ff51e520334e5fda3dd33bcf09c1483
                                         Module libxcb-composite.so.0 with build-id 94fff40466ef37eb5973997211aa68f9beb81d15
                                         Module libKWaylandServer.so.5 with build-id 8f56d56f8fce558576756f0606fb98889a1e5c4c
                                         Module libKScreenLocker.so.5 with build-id e41887d51747be992fe9dc2498b9794785889994
                                         Module libkdecorations2private.so.9 with build-id 822f79e2c74a010056323c4e2eb160ba8c72c696
                                         Module libkdecorations2.so.5 with build-id 684b26b757edf543097bfa3d97fececaf9bf16c2
                                         Module libKF5WaylandClient.so.5 with build-id 62d9d21d32df6ff25802eeef87b59e7b0895af39
                                         Module libKF5Plasma.so.5 with build-id 7ac5e2f353ba47c4dff42030a193726be02d88da
                                         Module libKF5GlobalAccelPrivate.so.5 with build-id 0494e001b0fcf80c92d46eb125bca973b22afe7b
                                         Module libkwinglutils.so.13 with build-id f72c5ba411dd42a69550f4680f7d773d24c2124f
                                         Module libkwineffects.so.13 with build-id 84d829e31edc209ef11ee45774861142a9b8f7e1
                                         Module libkwin4_effect_builtins.so.1 with build-id d384ea377d851f05b3da475a55ce0d1a0fba29b8
                                         Module libQt5X11Extras.so.5 with build-id 15391ece1569cf0dc6458ec05be60a05dbc398e3
                                         Module libKF5WindowSystem.so.5 with build-id 10d0f0de888eb46a1fddcb91ef4ea4dcb3f117f2
                                         Module libKF5CoreAddons.so.5 with build-id 42164ce0f5987f623e5285b1ecd65ceeb0bfce2e
                                         Module libKF5I18n.so.5 with build-id 141662ef754d2d992a1a32082b2f2ddb830676b8
                                         Module libKF5ConfigCore.so.5 with build-id c58e94e4adb85b1097f065447c2af4cc585906ff
                                         Module libKF5QuickAddons.so.5 with build-id fd00c054198847ab6d9e6c1142e512d53ec4cdbc
                                         Module libKF5Crash.so.5 with build-id bb5c5cd905cfdd34bd246bed989f3989ec8bde08
                                         Module libkwin.so.5 with build-id fa21e5537a1debaf20908cd58b27ad55c6f38fd1
                                         Module kwin_x11 with build-id 6d5af51113adb5f4631fb02c7a103be19fc50da7
                                         Stack trace of thread 883:
                                         #0  0x00007f7cd674ad22 raise (libc.so.6 + 0x3cd22)
                                         #1  0x00007f7cd7fa5384 _ZN6KCrash19defaultCrashHandlerEi (libKF5Crash.so.5 + 0x7384)
                                         #2  0x00007f7cd674ada0 __restore_rt (libc.so.6 + 0x3cda0)
                                         #3  0x00007f7cd674ad22 raise (libc.so.6 + 0x3cd22)
                                         #4  0x00007f7cd6734862 abort (libc.so.6 + 0x26862)
                                         #5  0x00007f7ccdb55ae5 n/a (iris_dri.so + 0x1b5ae5)
                                         #6  0x00007f7cce7d4ad5 n/a (iris_dri.so + 0xe34ad5)
                                         #7  0x00007f7ccdd5c699 n/a (iris_dri.so + 0x3bc699)
                                         #8  0x00007f7cd819a688 n/a (libkwin.so.5 + 0x1f0688)
                                         #9  0x00007f7cd75dfd93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #10 0x00007f7cd8172a50 _ZN4KWin5Scene11paintScreenERK7QRegionS3_PS1_S4_PNS_10RenderLoopERK10QMatrix4x4 (libkwin.so.5 + 0x1c8a50)
                                         #11 0x00007f7ca8f34354 _ZN4KWin11SceneOpenGL5paintEPNS_14AbstractOutputERK7QRegionRK5QListIPNS_8ToplevelEEPNS_10RenderLoopE (KWinSceneOpenGL.so + 0x17354)
                                         #12 0x00007f7cd80cf8fc _ZN4KWin10Compositor9compositeEPNS_10RenderLoopE (libkwin.so.5 + 0x1258fc)
                                         #13 0x00007f7cd80cfde8 _ZN4KWin13X11Compositor9compositeEPNS_10RenderLoopE (libkwin.so.5 + 0x125de8)
                                         #14 0x00007f7cd75dfd93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #15 0x00007f7cd808a437 _ZN4KWin10RenderLoop14frameRequestedEPS0_ (libkwin.so.5 + 0xe0437)
                                         #16 0x00007f7cd8161248 _ZN4KWin17RenderLoopPrivate8dispatchEv (libkwin.so.5 + 0x1b7248)
                                         #17 0x00007f7cd75dfd93 n/a (libQt5Core.so.5 + 0x2bcd93)
                                         #18 0x00007f7cd75e20ff _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2bf0ff)
                                         #19 0x00007f7cd75d2e06 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2afe06)
                                         #20 0x00007f7cd6c721a6 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x1791a6)
                                         #21 0x00007f7cd75af16a _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28c16a)
                                         #22 0x00007f7cd75f9ca5 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d6ca5)
                                         #23 0x00007f7cd75fa142 _ZN20QEventDispatcherUNIX13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d7142)
                                         #24 0x00007f7cd03cddb3 n/a (libQt5XcbQpa.so.5 + 0x63db3)
                                         #25 0x00007f7cd75a744b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28444b)
                                         #26 0x00007f7cd75b2b97 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x28fb97)
                                         #27 0x000055b10f42548c n/a (kwin_x11 + 0x748c)
                                         #28 0x00007f7cd6735b25 __libc_start_main (libc.so.6 + 0x27b25)
                                         #29 0x000055b10f4259ce n/a (kwin_x11 + 0x79ce)
                                         Stack trace of thread 893:
                                         #0  0x00007f7cd6795ba1 _int_free (libc.so.6 + 0x87ba1)
                                         #1  0x00007f7cd67999e8 __libc_free (libc.so.6 + 0x8b9e8)
                                         #2  0x00007f7cd6799af2 __malloc_arena_thread_freeres (libc.so.6 + 0x8baf2)
                                         #3  0x00007f7cd52a527f start_thread (libpthread.so.0 + 0x927f)
                                         #4  0x00007f7cd680c5e3 __clone (libc.so.6 + 0xfe5e3)
                                         Stack trace of thread 905:
                                         #0  0x00007f7cd52b18ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
                                         #1  0x00007f7cd52ab270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
                                         #2  0x00007f7ccdb7bdfc n/a (iris_dri.so + 0x1dbdfc)
                                         #3  0x00007f7ccdb74aac n/a (iris_dri.so + 0x1d4aac)
                                         #4  0x00007f7cd52a5259 start_thread (libpthread.so.0 + 0x9259)
                                         #5  0x00007f7cd680c5e3 __clone (libc.so.6 + 0xfe5e3)
                                         Stack trace of thread 935:
                                         Stack trace of thread 938:
                                         Stack trace of thread 903:
                                         Stack trace of thread 7230:
                                         #1  0x00007f7cd52ab574 pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf574)
                                         #2  0x00007f7cd740ec84 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xebc84)
                                         #3  0x00007f7cd740bb47 n/a (libQt5Core.so.5 + 0xe8b47)
                                         #4  0x00007f7cd740788c n/a (libQt5Core.so.5 + 0xe488c)
                                         #5  0x00007f7cd52a5259 start_thread (libpthread.so.0 + 0x9259)
                                         #6  0x00007f7cd680c5e3 __clone (libc.so.6 + 0xfe5e3)
                                         Stack trace of thread 907:
                                         Stack trace of thread 902:
                                         Stack trace of thread 7233:
                                         Stack trace of thread 904:
                                         Stack trace of thread 7544:
                                         Stack trace of thread 906:
                                         Stack trace of thread 7545:
                                         #2  0x00007f7cd740ecfc _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xebcfc)
                                         #3  0x00007f7cd5b3529f n/a (libQt5Quick.so.5 + 0x1fe29f)
                                         Stack trace of thread 908:
                                         Stack trace of thread 917:
                                         Stack trace of thread 924:
                                         #0  0x00007f7cd6801c2e ppoll (libc.so.6 + 0xf3c2e)
                                         #1  0x00007f7cd75f338b _Z12qt_safe_pollP6pollfdmPK8timespec (libQt5Core.so.5 + 0x2d038b)
                                         #2  0x00007f7cd75f9f8e _ZN20QEventDispatcherUNIX13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d6f8e)
                                         #3  0x00007f7cd75a744b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28444b)
                                         #4  0x00007f7cd740aac6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xe7ac6)
                                         #5  0x00007f7cd72c63c9 n/a (libQt5DBus.so.5 + 0x233c9)
                                         #6  0x00007f7cd740788c n/a (libQt5Core.so.5 + 0xe488c)
                                         #7  0x00007f7cd52a5259 start_thread (libpthread.so.0 + 0x9259)
                                         #8  0x00007f7cd680c5e3 __clone (libc.so.6 + 0xfe5e3)
                                         Stack trace of thread 930:
                                         #5  0x00007f7cd57f5570 n/a (libQt5Qml.so.5 + 0x2c6570)
                                         Stack trace of thread 936:
                                         Stack trace of thread 937:
                                         Stack trace of thread 939:
                                         Stack trace of thread 940:
                                         Stack trace of thread 941:
                                         Stack trace of thread 942:
                                         Stack trace of thread 944:
                                         Stack trace of thread 1788:
                                         Stack trace of thread 1793:
                                         Stack trace of thread 7235:
                                         Stack trace of thread 7677:
                                         Stack trace of thread 945:
                                         #5  0x00007f7cd740788c n/a (libQt5Core.so.5 + 0xe488c)
                                         #6  0x00007f7cd52a5259 start_thread (libpthread.so.0 + 0x9259)
                                         #7  0x00007f7cd680c5e3 __clone (libc.so.6 + 0xfe5e3)
