Surface Pro 4 Win10 + Manjaro on uSD
Dear reader,
After trying out the Live boot USB of Manjaro Gnome for a bit, I decided I'd like to try it out on my Surface Pro 4:
Processor: Intel 6700U
RAM: 8GB
Storage: NVMe 256GB
Storage: microSD 128GB
The installation went smoothly, however, booting is messed up.
I found this helpful post, which helped me boot Manjaro (from which I am currently typing this post!).
While it did help me boot to Manjaro, following the steps did not help me boot without any live boot usb; hence this post.
I also found this post which seemed related, but I did not quite know how to follow these instructions:
That did not stop me from trying, though... Without luck. This resulted in now being launched straight into grub rescue > when booting without my Live Boot USB. :sweat_smile:
Any help is greatly appreciated!
The post urges one to include the following output when seeking help:
efibootmgr -v
BootCurrent: 0003
Timeout: 0 seconds
BootOrder: 0005,0001,0002,0000
Boot0000* Internal Storage	FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(50670071-478f-4be7-ad13-8754f379c62f)SDD.
Boot0001* USB Storage	FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(50670071-478f-4be7-ad13-8754f379c62f)USB.
Boot0002* PXE Network	FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(50670071-478f-4be7-ad13-8754f379c62f)PXE.
Boot0003* MsTemp	PciRoot(0x0)/Pci(0x14,0x0)/USB(0,0)/HD(2,MBR,0x0,0x3c1228,0x2000)
Boot0005* Windows Boot Manager	HD(1,GPT,7626a74d-7e69-4adf-815b-b06a09f2d6a3,0x800,0x82000)/File(\EFI\manjaro\grubx64.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
sudo parted -l
Model: Ut165 USB2FlashStorage (scsi)
Disk /dev/sda: 7902MB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 2      2016MB  2020MB  4194kB  primary               esp
Model: Generic- USB3.0 CRW -SD (scsi)
Disk /dev/sdb: 128GB
Disk Flags:
 1      1049kB  538MB   537MB   primary  fat32
 2      538MB   13,4GB  12,9GB  primary
 3      13,4GB  128GB   115GB   primary  ext4
Model: Unknown (unknown)
Disk /dev/nvme0n1: 256GB
Partition Table: gpt
Disk Flags:
Number  Start   End    Size    File system  Name                          Flags
 1      1049kB  274MB  273MB   fat32        EFI system partition          boot, esp
 2      274MB   408MB  134MB                Microsoft reserved partition  msftres
 3      408MB   253GB  253GB                Basic data partition          msftdata
 4      253GB   256GB  2716MB  ntfs         Basic data partition          hidden, diag
sudo blkid
/dev/nvme0n1p1: LABEL="SYSTEM" UUID="5634-9BBE" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="7626a74d-7e69-4adf-815b-b06a09f2d6a3"
/dev/nvme0n1p3: TYPE="BitLocker" PARTLABEL="Basic data partition" PARTUUID="6e617b82-d5cc-4917-b4a2-606bc524c7d7"
/dev/nvme0n1p4: LABEL="Windows RE tools" UUID="74FE98D8FE989448" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="028ad5f4-c354-45e7-9a4b-989e87efb94d"
/dev/nvme0n1: PTUUID="3f5ee74a-05e8-4a8d-a2ab-1b907b6ac19e" PTTYPE="gpt"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="a1e3226c-6fc1-4b66-b627-d36a3a9298c7"
/dev/sda1: UUID="2019-03-12-10-29-49-00" LABEL="M1804" TYPE="iso9660"
/dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="88F5-8C2D" TYPE="vfat"
/dev/sdb1: UUID="EB48-5464" TYPE="vfat" PARTUUID="f6449fff-01"
/dev/sdb2: UUID="572bd232-d442-4424-9e6b-bc01e2ded3b2" TYPE="crypto_LUKS" PARTUUID="f6449fff-02"
/dev/sdb3: UUID="3e70ca09-7d43-4028-938e-57d63a5e048e" TYPE="ext4" PARTUUID="f6449fff-03"
/dev/mapper/luks-572bd232-d442-4424-9e6b-bc01e2ded3b2: UUID="66b7d4ba-4064-40c6-9a03-601974b5ef62" TYPE="swap"
findmnt -s
TARGET    SOURCE                                                FSTYPE OPTIONS
/boot/efi UUID=5634-9BBE                                        vfat   defaults,noatime
swap      /dev/mapper/luks-572bd232-d442-4424-9e6b-bc01e2ded3b2 swap   defaults,noatime
/         UUID=3e70ca09-7d43-4028-938e-57d63a5e048e             ext4   defaults,noatime
/boot/efi /dev/nvme0n1p1 vfat   rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro
You probably just need to https://wiki.manjaro.org/index.php/Restore_the_GRUB_Bootloader
Thanks for your immediate reply. I took some time to check that page; seems helpful. Some questions before I execute any of it, if you don't mind.
1.) I am already in my 'real' Manjaro installation, using the grub from the live boot usb. The entire chroot-instructions can therefore be skipped, correct? I simply start from here.
2.) It seems the guide instructs me to mount the ESP from my Windows-drive (nvme) and re-install grub there, directly. Now, I followed these instructions with the manual partitioning because I'd prefer to not mess up anything on my Windows drive. Don't these instructions contradict each other in that sense?
One set of instructions can't cover every eventuality and/or user customisation. You'll have to use some common sense to adapt them to your specific setup.
If you can boot into the installed Manjaro from a "live boot USB" then you need to fix the bootloader on the internal disk.
I can't see that anywhere on the wiki page - it says to mount your EFI partition as /boot/efi. So, mount whichever partition you used for the EFI partition during installation.
At the first link ( the helpful post), you must do the [2 Additional Commands ]
efibootmgr did not show the manjaro entry, implying you did not do them.
Do them, if you think you've done them, do again. If still having problems, look at the section [Difficult problems ] and check out the links there for your computer type.
PS: do not do the chroot method.
It may complicate matters. If the first link don't help, the chroot method won't, either.
Thanks, you're the writer of some of those posts I linked earlier!
The reason you don't see the manjaro entries in efibootmgr -v-output is because I deleted them. I had multiple non-functional entries. The grub recovery instruction added a new one, too, however.
I just dug my hole a bit deeper. I think I have overwritten my Windows bootrecord (that's what they're called, right?). When booting from the Live Boot USB it is no longer listed. Probably because I followed the steps from the Grub Restore instructions while I still had that my /dev/nvme0n1p1 mounted to /boot/efi/ as well (through /etc/fstab, when I tried to follow the instructions of the other Surface Pro 4 post I linked in my original post; I suppose that's the extent of my 'common sense'. I should be able to recover it at some point using a Windows 10 installation USB.
I'll continue with the Manjaro boot first... :slight_smile:
Yes, looks like you destroyed windows efi file with the chroot method (restore bootloader).
But, to be fair, if done properly, you shouldn't destroy it. Just more easily to get things wrong.
Anyway, check if windows efi file is still somewhere, at the esp partition,and if it is not there, get back the windows boot first. If it is there, getting manjaro bootloader will get your windows to boot.
I won't be online for the next 8 hours. In fact , I'm typing from phone and saw that you're about to hit a dangerous corner.
Catch you later.
Thanks for the help so far!
After changing my /etc/fstab, and unmounting my /dev/nvme0n1p1 partition, my windows partition is listed in my Live Boot USB's grub again. Also, mounting the nvme partition again, I can see a Microsoft EFI record. So all seems well!
I appreciate the help. It's really great from both of you. Are you in China/asia, per chance? Not being online for 8 hours... I believe office hours are starting in that timezone about now, right? :slight_smile:
Good to hear. Hopefully you gat your manjaro back too.
Yes, I'm at utc +8.
Cheers.
EDIT; seem to have triggered a post of my reply by mistake, still need to finish it...
EDIT2; writing out my question word-by-word helped me understand what I did better.. I managed to boot to Manjaro without Live Boot USB and my Windows partition shows up in grub as well!
I'll simply post what I did, in case it might help someone else.
I ended up having two EFI System Partitions, by following this guide. They were /dev/nvme0n1p1 and /dev/sdb1 from my original sudo blkid-output.
The hint by @gohlip in the post I quoted in the original post helped me get on the right track.
  1. I edited my /etc/fstab to include the following line:
    UUID=5634-9BBE /boot/efi vfat defaults,noatime 0 2
    Where that UUID corresponds to the nvme0n1p1-partition.
  2. Unmounted the current /sdb1 from /boot/efi
    sudo umount /boot/efi
  3. Mounted nvme0n1p1 to /boot/efi
    sudo mount /dev/nvme0n1p1 /boot/efi
  4. Refered to step 10 from the useful post, but replaced /dev/sda by /dev/nvme0n1
sudo rm /boot/grub/grubenv
sudo grub-editenv /boot/grub/grubenv create
sudo grub-editenv - set boot_success=0
sudo grub-install /dev/nvme0n1
sudo update-grub
  1. Referred to the UEFI-specific instructions from the useful post, again substituting my relevant partition in the commands
sudo cp /boot/grub/x86_64-efi/core.efi /boot/efi/EFI/boot/bootx64.efi
sudo efibootmgr -c -d /dev/nvme0n1 -p 1 -L "manjaro" -l "\EFI\Manjaro\grubx64.efi"
One thing that I still need to resolve is that I am launched into grub rescue when I simply boot the system... I need to manually select the manjaro boot entry from UEFI in order to boot my system. Any ideas on what this means and how to resolve it?
I'm another step closer to a properly booting system, though. Thanks for all help! :slight_smile:
Aha! Your sdb drive is msdos.
o And your root partition (manjaro) is located there (sdb3) - never good for uefi to be in msdos partition.
o Your Manjaro $esp is at nvme (/dev/nvme0n1p1) and most likely shared with Windows (which is okay).
o The so-called efi partition at sdb3 is not working and will never work. And neither windows nor manjaro uses it.
o Not surprisingly, you do not have a efiboot entry for manjaro.
Your setup is not good.
You will need to make your Manjaro partitions in gpt.
A reinstall is necessary, sorry.
A few pointers.
o It is okay to set your manjaro $esp (/boot/efi) in /dev/nvme0n1p1
For having a nvme disk, suggest you do use a nvme partition as $esp.
reminder - do not format this at reinstallation.
o /dev/nvme0n1p4 is windows reserved partition - do not touch this.
o You can use other manjaro partitions outside nvme - root, swap, home
but must be in gpt partitions, not msdos partitions.
o noticed your swap fstab parameters contain luks. Any idea?
When reinstalling, since swap in sdb will be wiped out, just do a 'simple' swap.
Oh, after reinstalled, it good to do this at manjaro terminal (not livecd)
and print out
efibootmgr -v
cat /etc/fstab
sudo parted -l
sudo blkid
just to make sure you have a manjaro efiboot entry
Good luck.
Luckily, reinstalling Manjaro is no problem, it's an empty OS for now. But I think I should fix the boot into grub rescue issue first, or do you recon this will be fixed when I reinstall Manjaro?
It got this way when I tried to follow the restore guide (and probably made a mistake). The working Manjaro boot entry is the first in the boot-order when I enter UEFI, so I'd expect to boot straight into this when not using any modifiers.
EDIT: the grub rescue doesn't seem to have any modules available, I cannot issue a reboot command, nor search.file or configfile.
Yes. That should fix it.
But the important thing is that the disk has to be gpt.
You must do this -->
Use gparted, device tab --> create partition table --> gpt.
grub rescue does not have these modules. only grub. There is a way to get to grub prompt from grub rescue prompt (maybe, sometimes not) and a hassle. But... since you're reinstalling.... ?
Ok. So then I'll just nuke the current install... Curious what causes the boot into grub rescue, though.
Boot0005 seems weird to me...
efibootmgr -v
BootCurrent: 0006
Timeout: 0 seconds
BootOrder: 0006,0004,0005,0001,0002,0000
Boot0003* SurfaceFrontPage	FvVol(a881d567-6cb0-4eee-8435-2e72d33e45b5)/FvFile(4042708a-0f2d-4823-ac60-0d77b3111889)VOL+.
Boot0004* manjaro	HD(1,GPT,7626a74d-7e69-4adf-815b-b06a09f2d6a3,0x800,0x82000)/File(\EFI\manjaro\grubx64.efi)
Boot0006* manjaro	HD(1,GPT,7626a74d-7e69-4adf-815b-b06a09f2d6a3,0x800,0x82000)/File(\EFI\Manjaro\grubx64.efi)
Thanks for all the help!
Yes, I noticed this earlier. I guess you had used easyBCD or something like this to get the windows boot use grub. Is that true? I have never tried to use windows boot for anything else except for windows. But just doing the restore grub (chroot) shouldn't change windows boot into using grubx64.efi. Unless you chroot into windows {scrap that} or select windows $esp in your chroot selection {more likely}. Again, I rarely use chroot, so that is also just a guess. Another reason I avoid chroot and if unavoidable, I do it manually.
But when we have a working grub, that shouldn't matter, I guess.
You do have the windows efi file, right? I remember you said that, somewhere.
Oh, you're welcome.
@AgentS re: grub rescue
I have not got into grub rescue for a very very long time.
I have no problems in grub for such a long time I cannot recall getting into grub rescue.
However hard I try, I just cannot get into grub rescue (to test, of course).
Do you know how to get into it (from a good grub)?
Thanks.
I noticed I didn't reply to this point. The luks got in there because I specified it to be, again, following instructions from this wiki. It advised to format is as 'linuxswap' which ended up as luks.
As I am using a laptop (surface pro 4) I'd like to be able to hibernate the device, so I thought I'd require a swap partition (not sure if Manjaro has file-based swap on root?)
Thanks for the reply on swap. I'm not the swap guy and I don't pay too much attention to it. So I really don't know if your swap fstab parameter is correct. I have a swap partition (not swap file) but my parameters are much simpler. Hope you're right (I'm skeptical, but you're reinstalling) so after you reinstall, let's take a look at your swap parameters again. Just let the system take care of it. If there is some thing weird, let's have some swap guy take a look at it.
Let's not worry about it now.
I don't recall using any tool like that, I've never heard of it.
I actually haven't used chroot either. Already being able to boot into the installed Manjaro through the Live Boot USB, I simply executed the command from this point on directly.
I'm not sure exactly what the Windows efi should look like, but I am able to get into Windows through the Manjaro boot entry (UEFI -> Manjaro -> GRUB -> Windows).
My /boot/efi looks like this:
/boot/efi/
β”œβ”€β”€ EFI
β”‚   β”œβ”€β”€ Boot
β”‚   β”‚   └── bootx64.efi
β”‚   β”œβ”€β”€ manjaro
β”‚   β”‚   └── grubx64.efi
β”‚   └── Microsoft
β”‚       β”œβ”€β”€ Boot
β”‚       β”‚   β”œβ”€β”€ ar-SA
β”‚       β”‚   β”‚   β”œβ”€β”€ bootmgfw.efi.mui
β”‚       β”‚   β”‚   └── bootmgr.efi.mui
β”‚       β”‚   β”œβ”€β”€ BCD
β”‚       β”‚   β”œβ”€β”€ BCD.LOG
β”‚       β”‚   β”œβ”€β”€ BCD.LOG1
β”‚       β”‚   β”œβ”€β”€ BCD.LOG2
β”‚       β”‚   β”œβ”€β”€ bg-BG
β”‚       β”‚   β”œβ”€β”€ bootmgr.efi
β”‚       β”‚   β”œβ”€β”€ bootspaces.dll
β”‚       β”‚   β”œβ”€β”€ BOOTSTAT.DAT
β”‚       β”‚   β”œβ”€β”€ boot.stl
β”‚       β”‚   β”œβ”€β”€ cs-CZ
β”‚       β”‚   β”‚   β”œβ”€β”€ bootmgr.efi.mui
β”‚       β”‚   β”‚   └── memtest.efi.mui
β”‚       β”‚   β”œβ”€β”€ da-DK
β”‚       β”‚   β”œβ”€β”€ de-DE
β”‚       β”‚   β”œβ”€β”€ el-GR
β”‚       β”‚   β”œβ”€β”€ en-GB
β”‚       β”‚   β”œβ”€β”€ en-US
β”‚       β”‚   β”œβ”€β”€ es-ES
β”‚       β”‚   β”œβ”€β”€ es-MX
β”‚       β”‚   β”œβ”€β”€ et-EE
β”‚       β”‚   β”œβ”€β”€ fi-FI
β”‚       β”‚   β”œβ”€β”€ Fonts
β”‚       β”‚   β”‚   β”œβ”€β”€ chs_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ cht_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ jpn_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ kor_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ malgun_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ malgunn_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ meiryo_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ meiryon_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ msjh_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ msjhn_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ msyh_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ msyhn_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ segmono_boot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ segoen_slboot.ttf
β”‚       β”‚   β”‚   β”œβ”€β”€ segoe_slboot.ttf
β”‚       β”‚   β”‚   └── wgl4_boot.ttf
β”‚       β”‚   β”œβ”€β”€ fr-CA
β”‚       β”‚   β”œβ”€β”€ fr-FR
β”‚       β”‚   β”œβ”€β”€ FveTcg_0.log
β”‚       β”‚   β”œβ”€β”€ FveTcg_1.log
β”‚       β”‚   β”œβ”€β”€ FveTcg_2.log
β”‚       β”‚   β”œβ”€β”€ hr-HR
β”‚       β”‚   β”œβ”€β”€ hu-HU
β”‚       β”‚   β”œβ”€β”€ it-IT
β”‚       β”‚   β”œβ”€β”€ ja-JP
β”‚       β”‚   β”œβ”€β”€ kd_02_10df.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_10ec.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_1137.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_14e4.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_15b3.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_1969.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_19a2.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_1af4.dll
β”‚       β”‚   β”œβ”€β”€ kd_02_8086.dll
β”‚       β”‚   β”œβ”€β”€ kd_07_1415.dll
β”‚       β”‚   β”œβ”€β”€ kd_0C_8086.dll
β”‚       β”‚   β”œβ”€β”€ kdstub.dll
β”‚       β”‚   β”œβ”€β”€ ko-KR
β”‚       β”‚   β”œβ”€β”€ lt-LT
β”‚       β”‚   β”œβ”€β”€ lv-LV
β”‚       β”‚   β”œβ”€β”€ memtest.efi
β”‚       β”‚   β”œβ”€β”€ nb-NO
β”‚       β”‚   β”œβ”€β”€ nl-NL
β”‚       β”‚   β”œβ”€β”€ pl-PL
β”‚       β”‚   β”œβ”€β”€ pt-BR
β”‚       β”‚   β”œβ”€β”€ pt-PT
β”‚       β”‚   β”œβ”€β”€ qps-ploc
β”‚       β”‚   β”œβ”€β”€ Resources
β”‚       β”‚   β”‚   β”œβ”€β”€ bootres.dll
β”‚       β”‚   β”‚   β”œβ”€β”€ da-DK
β”‚       β”‚   β”‚   β”‚   └── bootres.dll.mui
β”‚       β”‚   β”‚   β”œβ”€β”€ de-DE
β”‚       β”‚   β”‚   β”œβ”€β”€ en-US
β”‚       β”‚   β”‚   β”œβ”€β”€ es-ES
β”‚       β”‚   β”‚   β”œβ”€β”€ fi-FI
β”‚       β”‚   β”‚   β”œβ”€β”€ fr-FR
β”‚       β”‚   β”‚   β”œβ”€β”€ it-IT
β”‚       β”‚   β”‚   β”œβ”€β”€ nb-NO
β”‚       β”‚   β”‚   β”œβ”€β”€ nl-NL
β”‚       β”‚   β”‚   β”œβ”€β”€ pl-PL
β”‚       β”‚   β”‚   β”œβ”€β”€ pt-PT
β”‚       β”‚   β”‚   β”œβ”€β”€ sv-SE
β”‚       β”‚   β”‚   β”œβ”€β”€ zh-CN
β”‚       β”‚   β”‚   β”œβ”€β”€ zh-HK
β”‚       β”‚   β”‚   └── zh-TW
β”‚       β”‚   β”œβ”€β”€ ro-RO
β”‚       β”‚   β”œβ”€β”€ ru-RU
β”‚       β”‚   β”œβ”€β”€ sk-SK
β”‚       β”‚   β”œβ”€β”€ sl-SI
β”‚       β”‚   β”œβ”€β”€ sr-Latn-CS
β”‚       β”‚   β”œβ”€β”€ sr-Latn-RS
β”‚       β”‚   β”œβ”€β”€ th-TH
β”‚       β”‚   β”œβ”€β”€ tr-TR
β”‚       β”‚   β”œβ”€β”€ uk-UA
β”‚       β”‚   β”œβ”€β”€ updaterevokesipolicy.p7b
β”‚       β”‚   β”œβ”€β”€ winsipolicy.p7b
β”‚       β”‚   └── zh-TW
β”‚       └── Recovery
β”‚           β”œβ”€β”€ BCD
β”‚           └── BCD.LOG2
└── System Volume Information
    └── IndexerVolumeGuid
64 directories, 171 files
Okay, strange.
(without chrooting) There is no way a linux can change a windows efi entry.
But stranger things have happened when we install uefi into a msdos partition.
Still wondering how/why we still let this happen (install uefi into msdos).
Never mind. Just reinstall.
Make sure you have a gpt disk and installed uefi.
Are you suggesting the Manjaro installer will create a swap partition by itself? I recall when trying to install to my microSD I only had the option for 'manual install'.
