Supertuxkart startet nicht
Ich habe supertuxkart installiert, leider startet das Game nicht.
stdout.log zeigt folgendes
[error  ] User Config: Unknown value for multitouch_auto_acceleration; expected true or false
[error  ] User Config: Couldn't find parameter group server-bookmarks
[error  ] User Config: Couldn't find parameter group address-history
[error  ] User Config: Couldn't find parameter group ipv4-stun-servers
[error  ] User Config: Couldn't find parameter group ipv6-stun-servers
[error  ] User Config: Unknown value for lan-server-gp; expected true or false
[error  ] User Config: Unknown value for wan-server-gp; expected true or false
[info   ] [FileManager]: Data files will be fetched from: '/usr/share/supertuxkart/data/'
[info   ] [FileManager]: User directory is '/home/swh/.config/supertuxkart/config-0.10/'.
[info   ] [FileManager]: Addons files will be stored in '/home/swh/.local/share/supertuxkart/addons/'.
[info   ] [FileManager]: Screenshots will be stored in '/home/swh/.local/share/supertuxkart/screenshots/'.
[info   ] [FileManager]: User-defined grand prix will be stored in '/home/swh/.local/share/supertuxkart/grandprix/'.
[info   ] [FileManager]: Asset 0 will be loaded from '/usr/share/supertuxkart/data/challenges/'.
[info   ] [FileManager]: Asset 1 will be loaded from '/usr/share/supertuxkart/data/gfx/'.
[info   ] [FileManager]: Asset 2 will be loaded from '/usr/share/supertuxkart/data/grandprix/'.
[info   ] [FileManager]: Asset 3 will be loaded from '/usr/share/supertuxkart/data/gui/icons/'.
[info   ] [FileManager]: Asset 4 will be loaded from '/usr/share/supertuxkart/data/gui/screens/'.
[info   ] [FileManager]: Asset 5 will be loaded from '/usr/share/supertuxkart/data/gui/dialogs/'.
[info   ] [FileManager]: Asset 6 will be loaded from '/usr/share/supertuxkart/data/replay/'.
[info   ] [FileManager]: Asset 7 will be loaded from '/usr/share/supertuxkart/data/shaders/'.
[info   ] [FileManager]: Asset 8 will be loaded from '/usr/share/supertuxkart/data/skins/'.
[info   ] [FileManager]: Asset 9 will be loaded from '/usr/share/supertuxkart/data/ttf/'.
[info   ] [FileManager]: Asset 10 will be loaded from '/usr/share/supertuxkart/data/po/'.
[info   ] [FileManager]: Asset 11 will be loaded from '/usr/share/supertuxkart/data/library/'.
[info   ] [FileManager]: Asset 12 will be loaded from '/usr/share/supertuxkart/data/models/'.
[info   ] [FileManager]: Asset 13 will be loaded from '/usr/share/supertuxkart/data/music/'.
[info   ] [FileManager]: Asset 14 will be loaded from '/usr/share/supertuxkart/data/sfx/'.
[info   ] [FileManager]: Asset 15 will be loaded from '/usr/share/supertuxkart/data/textures/'.
[info   ] [FileManager]: Asset 16 will be loaded from '/usr/share/supertuxkart/data/tracks/'.
[verbose  ] translation: Env var LANGUAGE = 'de:en_US'.
[verbose  ] translation: Language 'German'.
..:: Antarctica Rendering Engine 2.0 ::..
[info   ] [IrrDriver Logger]: ..:: Antarctica Rendering Engine 2.0 ::..
X connection to :0 broken (explicit kill or server shutdown).
Könnte sich das mal jemand ansehen? Gibt es eine Möglichkeit das zum laufen zu bringen?
Aus dem Startmenu startert gar nix, im Terminal hab ich dieselbe Fehlermeldung.
Das müsste eine Kleinigkeit für ecuh Experten hier sein :wink:
Schonmal vielen Dank für eure Hilfe!
Hallo @swh :wink:
Müsste es mal testen, aber scheint ein Problem mit dem X-Server zu geben. Kann es sein, dass du stattdessen xWayland verwendest?
inxi -Gazy
Im Grunde braucht supertuxcart nicht viel zum laufen.
Hallo @megavolt
schau mal, das ist die Ausgabe:
╭─swh@kde ~
╰─$ inxi -Gazy
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:0102 class-ID: 0300
  Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: VGA-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
  diag: 547mm (21.5")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
  v: 3.3 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
Das ist doch X-Server der läuft, oder sehe ich das falsch?
Irgendwas stimmt nicht…
@swh Habe es mal auf meinem älteren Laptop mit einer Intel GPU versucht. Selbes Problem wie bei dir… ich habes es aber mit:
IRR_DEVICE_TYPE=x11 supertuxkart
getestet und es lief. Woran das genau liegt, da habe ich keine Ahnung. :man_shrugging:
Von der SuperTuxKart GitHub Seite:
To run SuperTuxKart, make sure that your computer's specifications are equal or higher than the following specifications:
A graphics card capable of 3D rendering - NVIDIA GeForce 470 GTX, AMD Radeon 6870 HD series card or **Intel HD Graphics 4000 and newer.** OpenGL >= 3.3
Eine Intel HD Graphics 4000 ist zwar wirklich keine hohe Anforderung, aber eine Intel HD Graphics 2000 liegt halt leistungsmäßig bei nur ca. 40% davon.
Ok, danke für Eure Antworten.
@megavolt läuft bei mir nicht. auf meinem älteren DELL Laptop läuft es auch mit manjaro KDE
@denonom als ich MINT auf meinem Rechner hatte lief es halt mit eben dieser Hardware. Deswegen macht mcih das ja auch stutzig
