I recently changed my psu after my old one died
Afterwards my manjaro install started booting super slow, taking about 2 mins to boot, where before it would take 20sec
My ssd and all other components seem to be working fine and my windows dual boot has the usual boot time
Anyone know how to fix this?
systemd-analyze:
Startup finished in 996ms (kernel) + 1min 56.003s (userspace) = 1min 57.000s
graphical.target reached after 1min 34.600s in userspace
systemd-analyze blame:
24.530s linux-module-cleanup.service
3.131s snapd.service
2.754s udisks2.service
2.495s user@1000.service
1.472s cups.service
982ms ModemManager.service
869ms upower.service
867ms lvm2-monitor.service
715ms dev-sdb2.device
543ms colord.service
377ms polkit.service
331ms systemd-random-seed.service
309ms apparmor.service
307ms ldconfig.service
283ms tlp.service
203ms dev-disk-by\x2duuid-cef1c8d6\x2ddad7\x2d4d08\x2d9ec7\x2dbcb9b5dc1c03.swap
151ms systemd-journal-flush.service
124ms avahi-daemon.service
121ms NetworkManager.service
116ms systemd-logind.service
101ms var-lib-snapd-snap-core-11316.mount
97ms systemd-sysusers.service
93ms var-lib-snapd-snap-core-11187.mount
75ms systemd-udevd.service
72ms systemd-modules-load.service
66ms snapd.apparmor.service
58ms systemd-udev-trigger.service
Zesko
August 5, 2021, 6:18pm
#2
This may be the problem with the GPU driver.
What is output of inxi -Fx
inxi -Fx
System: Host:--- Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.4 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: Gigabyte model: B85M-D2V v: x.x serial: <superuser required>
UEFI: American Megatrends v: FC date: 06/19/2014
CPU: Info: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell rev: 3 cache:
L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25549
Speed: 1078 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 1078 2: 1095 3: 1033 4: 975
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Gigabyte
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Sapphire Limited
driver: amdgpu v: kernel bus-ID: 01:00.0
Display: x11 server: XOrg 1.20.11 driver: loaded: amdgpu resolution: 1: 1920x1080
2: 1920x1080~60Hz
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0 5.10.53-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.5 direct render: Yes
Audio: Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Sapphire Limited
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.32 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 74:d4:35:de:63:f9
Drives: Local Storage: total: 1.36 TiB used: 709.28 GiB (50.8%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3500G size: 465.76 GiB
ID-2: /dev/sdb vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
Partition: ID-1: / size: 906.94 GiB used: 709.27 GiB (78.2%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 284 KiB (0.1%) fs: vfat dev: /dev/sdb1
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 4.2 MiB (0.0%) dev: /dev/sdb3
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 801
Info: Processes: 222 Uptime: 3h 6m Memory: 7.66 GiB used: 4.06 GiB (53.0%) Init: systemd Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1870 Shell: Bash v: 5.1.8 inxi: 3.3.06
What is this/did it come from the AUR?
Your PSU has nothing to do with this.
@Zesko gave you your solution as well.
Tip: When pasting terminal output on Discourse forums, one can either…
Highlight it and use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
text
Use HTML:
<pre><code>
text
</pre></code>
I’ve done it for you this time.
Update:
The problem was that I unplugged two of my unneeded hard drives
Seems like the OS waited for them at boot
Replugging them fixed it
system
Closed
August 24, 2021, 11:41am
#8
