I would like to launch Krunner with a custom shortcut.
It is actually one key (with a magnifying glass → Microsoft ergonomic keyboard) and it is recognized as “meta + shift + touchpad toggle” shortcut.
The shortcut does not work for any applications actually.
Citation
Have you set it in System Settings → Workspace → Sortcuts → KRunner:
Absolutely, but it doesn’t work.
It seems actually that it is not Krunner the problem but the key. Not a single app opens with it assigned as a shortcut.
I used Ulauncher (because of this problem) but now with the last update it is broken. Ulauncher worked with the shortcut but if I remember correctly, I assigned the shortcut within Ulauncher and not in System settings.
Somehow, KDE Manjaro seems to not recognize the key
It doesn’t work unfortunately (I did everything and rebooted too)
Thank you for trying to help me
I really don’t understand why it doesn’t work… the key works, it is detected, but when it is assigned as a shortcut, nothing happens. And why did it work when I assigned it within Ulauncher ??
Okay soooo… don’t be sorry, with your help, I eventually found the solution !!
I uninstalled Ulauncher, and build it again (by the way, Ulauncher works again). Then I added within Ulauncher the custom shortcut and I realized that Ulauncher detects the key as Meta + Shift R and not Meta + Shift + Touchpad toggle .
So, back to system settings → shortcuts and by pressing Shift R and Meta I get a very weird shortcut (see image below)
