Super key does not show Activities menu in Gnome 3.36
Hello everyone,
After upgrading to Gnome 3.36 (I followed the instructions to upgrade from a tty) my Super key does not show the activities menu anymore.
If I drag the mouse to the upper left corner the menu opens, as expected.
I know that the Super key is not locked and working because if I use the Super + A shortcut, it takes me to the Applications menu.
I tried setting the Super key to the activities using the settings but it's not possible because Super is a mod key.
Using Gnome Tweaks I've set the left super to open the activities, but it's not working.
Does anyone have a similar problem?
Any toughts on the solution?
Thanks.
Yes, here
see my comment on that one
and something related here, with some more detail but not sure how it ended of the OP
On my install i can't reproduce the issue.
Well, it seems like the second post you linked has the same problem I have.
If I set the input to #1 then the Super key works as it should.
The problem is with the #2.
I think I should wait for the bugfix.
Thanks!
Correct upstream issue is https://gitlab.gnome.org/GNOME/mutter/-/issues/1144
Please upvote it. Hopefully they'll look into it soon.
I confirm the problem. Russian language.
This issue is not hard to reproduce at all. Some keyboards that have the problem:
  • Portuguese (Brazil, Dvorak)
  • English (Dvorak, international, with dead keys)
  • Russian
Some keyboards that DO NOT have the issue:
  • English (US, international, with dead keys)
  • Polish
I am a Gnome Shell user and this issue makes my desktop unusable!
EDIT: Workaround: This behaviour doesn't depend on the language itself, but on its position in the Input Sources list. #1 works, #2 and 3 don't, #4 works again.
It works with such settings for me. Suitable as a temporary solution.
dconf-editor > /org/gnome/desktop/wm/keybindings/panel-main-menu > ['Super_L']
Unfortunately proposed workaround doesn't work for me: it conflicts with default keyboard layouts switching shortcut (super + space). When trying to change input language from layout 2 to layout 1 it brings up overview in the middle of the process.
I change the layout of Alt-Shift. :man_shrugging:
