Sudo pip install data_pipeline error printout
I tried to install the package.
He gave an error. How can I do. Thanks.
Rolling back uninstall of PyYAML
  Moving to /usr/lib/python3.9/site-packages/PyYAML-5.4.1-py3.9.egg-info
   from /usr/lib/python3.9/site-packages/~yYAML-5.4.1-py3.9.egg-info
  Moving to /usr/lib/python3.9/site-packages/_yaml
   from /usr/lib/python3.9/site-packages/~yaml
  Moving to /usr/lib/python3.9/site-packages/yaml
   from /usr/lib/python3.9/site-packages/~aml
ERROR: Command errored out with exit status 1: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-fzc5fh67/pyyaml_287e8cf0691c408ba3ddb44b5f358105/setup.py'"'"'; __file__='"'"'/tmp/pip-install-fzc5fh67/pyyaml_287e8cf0691c408ba3ddb44b5f358105/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-001chnq0/install-record.txt --single-version-externally-managed --compile --install-headers /usr/include/python3.9/pyyaml Check the logs for full command output.
System log:
=== START CALAMARES 3.2.37-1
2021-04-10 - 13:52:46 [0]: "/proc/2453/root"
2021-04-10 - 13:52:48 [8]: Loaded backend plugin:  "pmsfdiskbackendplugin"
2021-04-10 - 13:53:05 [0]: unknown file system type  "dos"  on  "/dev/sda4"
2021-04-10 - 13:53:05 [8]: smartctl initialization failed for  "/dev/sdb" :  No such file or directory
2021-04-10 - 13:53:05 [8]: error during smart output parsing for  "/dev/sdb" :  Success
2021-04-10 - 13:54:06 [1]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
    ERROR: os-prober timed out.
2021-04-10 - 13:54:06 [0]: QProcess: Destroyed while process ("os-prober") is still running.
2021-04-10 - 17:03:16 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
2021-04-10 - 17:03:16 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
  build/temp.linux-x86_64-3.9/_openssl.c:70083:21: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70083:21: bilgi: ('_cffi_fields[99].field_size' için near ilklendirme)
  In file included from /usr/include/sched.h:29,
                   from /usr/include/pthread.h:22,
                   from /usr/include/openssl/crypto.h:415,
                   from /usr/include/openssl/bio.h:20,
                   from /usr/include/openssl/asn1.h:16,
                   from build/temp.linux-x86_64-3.9/_openssl.c:586:
  build/temp.linux-x86_64-3.9/_openssl.c:70085:12: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70085 |   { "num", offsetof(BIO, num),
  build/temp.linux-x86_64-3.9/_openssl.c:70085:12: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70085:12: bilgi: ('_cffi_fields[100].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70085:12: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70086:29: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70086 |            sizeof(((BIO *)0)->num),
  build/temp.linux-x86_64-3.9/_openssl.c:70086:12: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70086:12: bilgi: ('_cffi_fields[100].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70086:12: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70088:12: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70088 |   { "ptr", offsetof(BIO, ptr),
  build/temp.linux-x86_64-3.9/_openssl.c:70088:12: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70088:12: bilgi: ('_cffi_fields[101].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70088:12: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70089:29: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70089 |            sizeof(((BIO *)0)->ptr),
  build/temp.linux-x86_64-3.9/_openssl.c:70089:12: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70089:12: bilgi: ('_cffi_fields[101].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70089:12: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70091:17: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70091 |   { "next_bio", offsetof(BIO, next_bio),
  build/temp.linux-x86_64-3.9/_openssl.c:70091:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70091:17: bilgi: ('_cffi_fields[102].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70091:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70092:34: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70092 |                 sizeof(((BIO *)0)->next_bio),
  build/temp.linux-x86_64-3.9/_openssl.c:70092:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70092:17: bilgi: ('_cffi_fields[102].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70092:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70094:17: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70094 |   { "prev_bio", offsetof(BIO, prev_bio),
  build/temp.linux-x86_64-3.9/_openssl.c:70094:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70094:17: bilgi: ('_cffi_fields[103].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70094:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70095:34: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70095 |                 sizeof(((BIO *)0)->prev_bio),
  build/temp.linux-x86_64-3.9/_openssl.c:70095:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70095:17: bilgi: ('_cffi_fields[103].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70095:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70097:19: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70097 |   { "references", offsetof(BIO, references),
  build/temp.linux-x86_64-3.9/_openssl.c:70097:19: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70097:19: bilgi: ('_cffi_fields[104].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70097:19: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70098:36: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70098 |                   sizeof(((BIO *)0)->references),
  build/temp.linux-x86_64-3.9/_openssl.c:70098:19: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70098:19: bilgi: ('_cffi_fields[104].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70098:19: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70100:17: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70100 |   { "num_read", offsetof(BIO, num_read),
  build/temp.linux-x86_64-3.9/_openssl.c:70100:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70100:17: bilgi: ('_cffi_fields[105].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70100:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70101:34: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70101 |                 sizeof(((BIO *)0)->num_read),
  build/temp.linux-x86_64-3.9/_openssl.c:70101:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70101:17: bilgi: ('_cffi_fields[105].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70101:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70103:18: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70103 |   { "num_write", offsetof(BIO, num_write),
  build/temp.linux-x86_64-3.9/_openssl.c:70103:18: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70103:18: bilgi: ('_cffi_fields[106].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70103:18: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70104:35: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70104 |                  sizeof(((BIO *)0)->num_write),
  build/temp.linux-x86_64-3.9/_openssl.c:70104:18: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70104:18: bilgi: ('_cffi_fields[106].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70104:18: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70106:10: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70106 |   { "p", offsetof(DH, p),
  build/temp.linux-x86_64-3.9/_openssl.c:70106:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70106:10: bilgi: ('_cffi_fields[107].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70106:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70107:26: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70107 |          sizeof(((DH *)0)->p),
  build/temp.linux-x86_64-3.9/_openssl.c:70107:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70107:10: bilgi: ('_cffi_fields[107].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70107:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70109:10: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70109 |   { "g", offsetof(DH, g),
  build/temp.linux-x86_64-3.9/_openssl.c:70109:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70109:10: bilgi: ('_cffi_fields[108].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70109:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70110:26: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70110 |          sizeof(((DH *)0)->g),
  build/temp.linux-x86_64-3.9/_openssl.c:70110:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70110:10: bilgi: ('_cffi_fields[108].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70110:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70112:17: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70112 |   { "priv_key", offsetof(DH, priv_key),
  build/temp.linux-x86_64-3.9/_openssl.c:70112:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70112:17: bilgi: ('_cffi_fields[109].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70112:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70113:33: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70113 |                 sizeof(((DH *)0)->priv_key),
  build/temp.linux-x86_64-3.9/_openssl.c:70113:17: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70113:17: bilgi: ('_cffi_fields[109].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70113:17: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70115:16: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70115 |   { "pub_key", offsetof(DH, pub_key),
  build/temp.linux-x86_64-3.9/_openssl.c:70115:16: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70115:16: bilgi: ('_cffi_fields[110].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70115:16: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70116:32: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70116 |                sizeof(((DH *)0)->pub_key),
  build/temp.linux-x86_64-3.9/_openssl.c:70116:16: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70116:16: bilgi: ('_cffi_fields[110].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70116:16: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70118:10: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70118 |   { "q", offsetof(DH, q),
  build/temp.linux-x86_64-3.9/_openssl.c:70118:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70118:10: bilgi: ('_cffi_fields[111].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70118:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70119:26: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70119 |          sizeof(((DH *)0)->q),
  build/temp.linux-x86_64-3.9/_openssl.c:70119:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70119:10: bilgi: ('_cffi_fields[111].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70119:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70121:10: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70121 |   { "j", offsetof(DH, j),
  build/temp.linux-x86_64-3.9/_openssl.c:70121:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70121:10: bilgi: ('_cffi_fields[112].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70121:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70122:26: hata: invalid use of incomplete typedef 'DH' {aka 'struct dh_st'}
  70122 |          sizeof(((DH *)0)->j),
  build/temp.linux-x86_64-3.9/_openssl.c:70122:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70122:10: bilgi: ('_cffi_fields[112].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70122:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70124:10: hata: invalid use of incomplete typedef 'DSA' {aka 'struct dsa_st'}
  70124 |   { "p", offsetof(DSA, p),
  build/temp.linux-x86_64-3.9/_openssl.c:70124:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70124:10: bilgi: ('_cffi_fields[113].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70124:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70125:27: hata: invalid use of incomplete typedef 'DSA' {aka 'struct dsa_st'}
  70125 |          sizeof(((DSA *)0)->p),
  build/temp.linux-x86_64-3.9/_openssl.c:70125:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70125:10: bilgi: ('_cffi_fields[113].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70125:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70127:10: hata: invalid use of incomplete typedef 'DSA' {aka 'struct dsa_st'}
  70127 |   { "q", offsetof(DSA, q),
  build/temp.linux-x86_64-3.9/_openssl.c:70127:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70127:10: bilgi: ('_cffi_fields[114].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70127:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70128:27: hata: invalid use of incomplete typedef 'DSA' {aka 'struct dsa_st'}
  70128 |          sizeof(((DSA *)0)->q),
  build/temp.linux-x86_64-3.9/_openssl.c:70128:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70128:10: bilgi: ('_cffi_fields[114].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70128:10: hata: ilklendirici öğe bir sabit değil
  build/temp.linux-x86_64-3.9/_openssl.c:70130:10: hata: invalid use of incomplete typedef 'DSA' {aka 'struct dsa_st'}
  70130 |   { "g", offsetof(DSA, g),
  build/temp.linux-x86_64-3.9/_openssl.c:70130:10: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70130:10: bilgi: ('_cffi_fields[115].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70061:22: bilgi: ('_cffi_fields[92].field_offset' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70061:22: hata: ilklendirici öğe bir sabit değil
  70061 |   { "callback_ctrl", offsetof(BIO_METHOD, callback_ctrl),
  build/temp.linux-x86_64-3.9/_openssl.c:70062:46: hata: invalid use of incomplete typedef 'BIO_METHOD' {aka 'struct bio_method_st'}
  70062 |                      sizeof(((BIO_METHOD *)0)->callback_ctrl),
  build/temp.linux-x86_64-3.9/_openssl.c:70062:22: UYARI: initialization of 'long unsigned int' from 'void **' makes integer from pointer without a cast [-Wint-conversion]
  build/temp.linux-x86_64-3.9/_openssl.c:70062:22: bilgi: ('_cffi_fields[92].field_size' için near ilklendirme)
  build/temp.linux-x86_64-3.9/_openssl.c:70062:22: hata: ilklendirici öğe bir sabit değil
                   from /usr/inclu`Önceden biçimlendirilmiş yazı`de/openssl/crypto.h:415,
  build/temp.linux-x86_64-3.9/_openssl.c:70064:15: hata: invalid use of incomplete typedef 'BIO' {aka 'struct bio_st'}
  70064 |   { "method", offsetof(BIO, method)
I don’t think you should be using sudo pip install <package>
Why not install python-pyaml with pacman ? Not use sudo with pip :wink:
Yes I tried to install the package this way:
sudo pip install data_pipeline
error
I have uploaded python-pyaml.
problem not solved.
   ~/D/Stock-Selection-a-Framework-master  python3 run.py              ✔
  File "/home/levent/Downloads/Stock-Selection-a-Framework-master/run.py", line 23, in <module>
import  data_pipeline
ModuleNotFoundError: No module named 'data_pipeline'
Hi
Am I the only one having this problem?
for testing
Can you try installing the package on your own computer?
module data_pipeline is local to user and not system
best is to install all in user conf (pipenv)
ps: this project is very old for python (3.5) and rolling …
thank.
