Sudo causing segmentation fault
Could you please explain how these two specific packages alone can be downgraded ? Thanks.
To be frank, if you don’t know how to downgrade packages, you probably shouldn’t be using the unstable branch. :wink:
$ su
# downgrade fprintd libfprint
Choose the versions I mentioned above and answer y to add them to IgnorePkg.
If you don’t have a fingerprint sensor, you could probably just remove them instead.
fprintd released 7 h ago 1.90.7 with the following release notes:
Version 1.90.7:
While 1.90.6 fixed a number of issues, we did have a bad regression due
causing pam_fprintd to crash when there are no fingerprint devices
installed.
Highlights:
 - pam: Guard strdup calls against NULL pointers
Edit: Removing them solved the problem immediately.
I won’t know/learn until I do it the first time right. Now I know how. For me, that’s the point behind tinkering with Linux. Someday I’ll know enough to be able to teach others :slight_smile:
Thanks for explaining and teaching me something new.
Okay the update worked for me, too.
But when you don’t have installed downgrade you can boot from an usb stick and mount your filesystem.
Edit the file: /etc/pam.d/sudo and comment out the pam.fprint.d
#auth sufficient pam_fprintd.so.
Further i added in /etc/pam.d/su**
auth sufficient pam_wheel.so trust use_uid
auth required pam_wheel.so use_uid
After that reboot and you have sudo without a problem and you can update fprintd.
