I did not use my system for about a month, and I started using it again today. I did a full system update and restarted. Since this change, there is now a vertical padding on the task bar.
You can see the space above and below everything in the task bar, which wasn’t there before.
I tried finding a place to configure this, but was unable.
It looks like this: imgur dot com/a/1ZKpK67
Where can I disable this?
My system info:
KDE Plasma Version: 5.20.4
KDE Frameworks Version: 5.77.0
Qt Version: 5.15.2
Kernel Version: 5.10.4-2-MANJARO
OS Type: 64-bit
Processors: 8 × Intel® Core™ i7-6700K CPU @ 4.00GHz
Memory: 15,6 GiB of RAM
Graphics Processor: GeForce GTX 970/PCIe/SSE2
Welcome to the forum!
I don’t think you can, or at least, not in any user–friendly way ─ maybe if you start hacking into the Plasma theme, but I don’t know how to do that.
It was obviously introduced as a change to the Breeze theme for Plasmoids.
It’s a shame that such a change is forced on me, I don’t really like it, tho I guess I can live with it. I was hoping there was an easy way to change it somewhere. Thanks for the help!
Edit: I tested it, and changing away from Breeze does indeed fix this problem.
Well, there is an alternative approach: you can try looking for another Plasma theme at store.kde.org.
Do however make sure that you’re only installing a Plasma theme, not a global theme. Global themes change too much and make it difficult to alter individual components, not to mention that there’s also a greater chance at breakage if you use an old and unmaintained theme.
That’s a great idea, I’ll take a look at this tomorrow
