Sudden reboots
Hi there,
Been having a weird intermittent issue and I'm not sure where to start diagnosing this.
Once in a while my screen will go black while I'm in the middle of doing something (browsing the web, playing a game, doesn't seem to be task dependent) and a few seconds later I get my BIOS splash and my computer reboots.
Appreciate any help on this, and bear with me, bit of a noob on a lot of basic Linux diagnostics.
inxi -SxG
System: Host: ED11 Kernel: 5.2.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: Gnome 3.32.2
Distro: Manjaro Linux
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: Tul driver: amdgpu
v: kernel bus ID: 0b:00.0
Display: x11 server: X.org 1.20.5 driver: none resolution:
OpenGL: renderer: Radeon RX Vega (VEGA10 DRM 3.32.0 5.2.11-1-MANJARO LLVM 8.0.1) v: 4.5 Mesa 19.1.5
direct render: Yes
In my experience a complete sudden reboot is usually hardware rather than software related. You could test this for sure by booting a Live Linux CD distro (even Manjaro) - from a CD or USB stick. If you get the same intermittent reboot than you can be sure you have a hardware, not software, fault.
(Perhaps your CPU is overheating??)
Post the full inxi.
inxi -Fxxxza --no-host
Please use the </> button with the pasted text so it'll be formatted properly.
with a thermal limit safety shut down enforced by EFI or legacy BIOS the computer would not reboot itself immediately, it would stay off. A hardware fault is entirely possible but that restarting behaviour rules out CPU overheating.
@cactus check for EFI/BIOS updates and if your motherboard is not running the current release update it.
System:    Kernel: 5.2.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.2-x86_64 root=UUID=7ac8885e-f0a0-497b-96f4-7f2faf1ca394 rw quiet
           Desktop: Gnome 3.32.2 wm: gnome-shell dm: GDM 3.32.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Gigabyte model: AX370-Gaming 5 serial: <filter> UEFI [Legacy]: American Megatrends v: F5
           date: 04/07/2017
CPU:       Topology: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
           microcode: 800111C L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 108624
           Speed: 2120 MHz min/max: 2200/3400 MHz boost: enabled Core speeds (MHz): 1: 2672 2: 2634 3: 2338 4: 2334 5: 1747
           6: 1748 7: 1744 8: 1738 9: 2057 10: 1977 11: 2083 12: 2276 13: 1930 14: 1920 15: 2933 16: 2847
           Vulnerabilities: Type: l1tf status: Not affected
           Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
           v: kernel bus ID: 0b:00.0 chip ID: 1002:687f
           Display: x11 server: X.org 1.20.5 driver: none compositor: gnome-shell resolution: <xdpyinfo missing>
           direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel v: kernel
           bus ID: 0b:00.1 chip ID: 1002:aaf8
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 12:00.3 chip ID: 1022:1457
           Device-3: C-Media Blue Snowball type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-1:2 chip ID: 0d8c:0005
           serial: <filter>
           Device-4: C-Media type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-2:3 chip ID: 0d8c:0004
           Sound Server: ALSA v: k5.2.11-1-MANJARO
Network:   Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.6.0-k port: e000 bus ID: 06:00.0
           chip ID: 8086:1539
           IF: ens1 state: down mac: <filter>
           Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte driver: alx v: kernel port: d000
           bus ID: 07:00.0 chip ID: 1969:e0b1
           IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 4.09 TiB used: 839.19 GiB (20.0%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 500GB size: 465.76 GiB block size: physical: 512 B
           logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B7QCXE7 scheme: GPT
           ID-2: /dev/sda vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 1B6Q scheme: MBR
           ID-3: /dev/sdb vendor: Seagate model: ST1000DM003-1CH162 size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC49 scheme: MBR
           ID-4: /dev/sdc vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 020 scheme: GPT
           ID-5: /dev/sdd vendor: Seagate model: ST1000DM003-9YN162 size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: CC4B scheme: MBR
Partition: ID-1: / raw size: 232.60 GiB size: 227.95 GiB (98.00%) used: 21.31 GiB (9.3%) fs: ext4 dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: 41.4 C mobo: N/A gpu: amdgpu temp: 28 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 914
Info:      Processes: 517 Uptime: 3h 10m Memory: 15.67 GiB used: 3.67 GiB (23.4%) Init: systemd v: 242 Compilers: gcc: 9.1.0
           Shell: bash v: 5.0.9 running in: guake inxi: 3.0.36
Update your BIOS. It's very old.
Just finished doing that, fingers crossed!
Also test alternate kernels both newer and older.
To me with 30 yrs of experience this smells physical damaged RAM. It might be something else but I'd say 85% chance that's what wrong.
This is still happening unfortunately. I might try the RAM sticks next but this Hardware Error seems to be a fundamental issue with Ryzen 7.
journalctl -p err -b
-- Logs begin at Fri 2019-08-23 01:26:23 CDT, end at Wed 2019-09-18 19:51:43 CDT. --
Sep 18 19:45:18 ED11 kernel: mce: [Hardware Error]: CPU 15: Machine Check: 0 Bank 5: bea0000000000108
Sep 18 19:45:18 ED11 kernel: mce: [Hardware Error]: TSC 0 ADDR 1ffff86a6c12c MISC d012000100000000 SYND 4d000000 IPID 500b000000000
Sep 18 19:45:18 ED11 kernel: mce: [Hardware Error]: PROCESSOR 2:800f11 TIME 1568853912 SOCKET 0 APIC f microcode 8001138
Sep 18 19:45:18 ED11 kernel: hid-generic 0003:0D8C:0005.0001: No inputs registered, leaving
Sep 18 19:45:18 ED11 kernel: usb 1-7.4.4: device descriptor read/64, error -32
Sep 18 19:45:18 ED11 kernel: usb 1-7.4.4: device not accepting address 7, error -71
Sep 18 19:45:18 ED11 kernel: usb 1-7.4.4: device not accepting address 8, error -71
Sep 18 19:45:18 ED11 kernel: usb 1-7.4-port4: unable to enumerate USB device
Sep 18 19:45:19 ED11 kernel: kvm: disabled by bios
Sep 18 19:45:20 ED11 kernel: kvm: disabled by bios
Sep 18 19:45:21 ED11 kernel: kvm: disabled by bios
Sep 18 19:45:26 ED11 gdm-password][1193]: gkr-pam: unable to locate daemon control file
An update: I disabled C-State 6 and greater in my UEFI and I haven't had a sudden reboot in the last week. :crossed_fingers:
I found a thread on the forum related to the issue if you can't disable via UEFI:
I was also getting this same issue and initially thought memory issue but notice a processor hardware fault during boot. After running this fix I have not had the random reboots.
Something to add to your fix is to add the msr module to /etc/modules-load.d
so it loads at boot before the service we created is ran.
# List of modules to load at boot
msr
