Hello !
I am new to the manjaro forum. Quick history on me ; I got manjaro about a year ago as I was searching for a fast OS and my friend recommended it. I have dual booted it alongside Windows 10 on a Dell Vostro 15 3568 laptop. I haven’t faced many issues using manjaro but I have a limited RAM of 4gb which causes my laptop to hang often while multitasking.
Problem : Recently my laptop has been detecting low signal strength of my wifi network. My phone and other devices are working fine at the same distance from the router. Network Manager in my system tray keeps showing “Log in required” message which usually only happens when I restart my router and it goes away after a few minutes. But now I have had this issue for 5 days and am unable to connect to the wifi sometimes. Could someone please help me with this issue?
I am new to the forum so please forgive me if I have broken any rules.
Thank you !
inxi info :
Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=777834ab-cba5-45c2-b3c6-ffb07e29d837 rw quiet apparmor=1
security=apparmor resume=UUID=6a36373e-7951-4db9-9499-f4eefeb3178e
udev.log_priority=3
Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 info: plank wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Dell product: Vostro 15-3568 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 06XGVW v: A00 serial: <filter> UEFI: Dell v: 2.3.0
date: 02/06/2018
ID-1: BAT0 charge: 28.3 Wh condition: 32.2/41.4 Wh (78%) volts: 17.2/14.8
model: SMP DELL VN3N047 type: Li-ion serial: <filter> status: Charging
RAM: total: 3.71 GiB used: 1.50 GiB (40.4%)
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: D6
L2 cache: 3072 KiB bogomips: 21607
Speed: 1461 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 1434 2: 1377
3: 1331 4: 1709
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Dell driver: radeon
v: kernel alternate: amdgpu bus ID: 01:00.0 chip ID: 1002:666f
Device-3: Sunplus Innovation Integrated Webcam type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 1bcf:2c00
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel,radeon
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.10.26-1-MANJARO
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel port: e000 bus ID: 02:00.0
chip ID: 168c:0042
vendor: Dell driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-8:5
chip ID: 0cf3:e009
Local Storage: total: 931.51 GiB used: 120.09 GiB (12.9%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 3D scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5LH rev: 6D11
dev-links: cdrom
ID-1: / raw size: 31.25 GiB size: 30.63 GiB (98.03%) used: 19.94 GiB (65.1%)
fs: ext4 dev: /dev/sda11 label: N/A
uuid: 777834ab-cba5-45c2-b3c6-ffb07e29d837
ID-2: /boot/efi raw size: 512.0 MiB size: 511.0 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/sda9 label: N/A uuid: A250-2DEC
ID-3: /home raw size: 28.75 GiB size: 28.17 GiB (98.00%)
used: 9.90 GiB (35.2%) fs: ext4 dev: /dev/sda12 label: N/A
uuid: d6b70ad8-8c85-45b2-9c6b-35cfb2fd082c
ID-4: /run/media/pranavpiedy/OS raw size: 458.54 GiB
size: 458.54 GiB (100.00%) used: 90.24 GiB (19.7%) fs: ntfs dev: /dev/sda3
label: OS uuid: A0EE574BEE5718BC
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda10 label: N/A uuid: 6a36373e-7951-4db9-9499-f4eefeb3178e
ID-1: /dev/sda1 size: 500.0 MiB fs: vfat label: ESP uuid: 6A0C-0A41
ID-2: /dev/sda2 size: 128.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-3: /dev/sda4 size: 166.22 GiB fs: ntfs label: New Volume
uuid: 06A2BF2FA2BF21DB
ID-4: /dev/sda5 size: 228.72 GiB fs: ntfs label: p_piedy
uuid: A856666B56663A68
ID-5: /dev/sda6 size: 450.0 MiB fs: ntfs label: WINRETOOLS
uuid: 143441FA3441DEFC
ID-6: /dev/sda7 size: 13.47 GiB fs: ntfs label: Image uuid: 527A42D77A42B80D
ID-7: /dev/sda8 size: 1.00 GiB fs: ntfs label: DELLSUPPORT
uuid: 24C613BAC6138AE6
Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-4:2 info: Validity Sensors VFS Fingerprint sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
chip ID: 138a:0010 serial: <filter>
Device-2: 1-5:3 info: Sunplus Innovation Integrated Webcam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1bcf:2c00
Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 serial: <filter>
Device-4: 1-8:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 0cf3:e009
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 43.0 C mobo: 42.0 C gpu: radeon temp: 42.0 C
Fan Speeds (RPM): cpu: 0
Processes: 194 Uptime: 30m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1355 lib: 381 flatpak: 0 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.08 ```
