Hi guys, I asked this question in the Nvidia support section but didn’t get a reply and since it’s dealing with Gnome it probably is better to ask here.
My display is a LG CX OLED driven by a 3090. I have the Nvidia driver installed and have 0 issues with playing any games or the like.
What I am dealing with is my display is 120hz. When I set it to 120hz it applies and on the desktop I can tell it’s at 120hz(been running 120+hz displays for 5 years now).
The problem is in Gnome on the desktop, When moving windows around on the desktop they are not very smooth and appear to be “hitching,” stuttering," or “dropping Frames.”
For a test I did a fresh install of Manjaro this time using KDE Plasma and it does not have this issue and everything is smooth as it should be at 120hz.
My specs are
intel 10940x
32gb ram
RTX 3090.
I’d love to be able to figure this out as I much prefer gnome over KDE Plasma.
Gnome version is 3.38.
So I installed MangoHUD and GOverlay and had it running on the desktop.
Without any windows moving around on the desktop MangoHUD displayed the Desktop FPS at 120fps.
I opened up the terminal and started moving it around and saw FPS drop to 88 FPS in MangoHUD.
Please post your system info as outlined here:
Welcome to Manjaro!
To allow all of us helpful gurus on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone probably linked you to this tutorial, so if you’re reading this in response to a question, please click the green link above this text to bring you to the full and unabridged text of the tutorial…
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b87bd145-97e0-4bd3-aecd-1cd1675587cb rw quiet splash apparmor=1
security=apparmor resume=UUID=ed39a145-b614-4873-a477-85de40d529d8
udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Desktop System: EVGA product: X299 DARK v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: EVGA model: X299 DARK v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.26 date: 01/20/2021
ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 4.1 min: N/A
model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
status: Discharging
RAM: total: 31.06 GiB used: 2.38 GiB (7.7%)
Info: 14-Core model: Intel Core i9-10940X bits: 64 type: MT MCP
arch: Cascade Lake family: 6 model-id: 55 (85) stepping: 7
microcode: 5003006 cache: L2: 19.2 MiB bogomips: 184883
Speed: 1804 MHz min/max: 1200/4700 MHz Core speeds (MHz): 1: 1804 2: 1200
3: 1200 4: 1200 5: 1200 6: 1200 7: 1564 8: 1200 9: 1200 10: 1200 11: 1200
12: 1201 13: 1201 14: 1200 15: 1201 16: 4714 17: 1200 18: 1200 19: 1200
20: 1200 21: 1200 22: 1200 23: 1200 24: 1201 25: 1202 26: 1200 27: 1212
28: 1200
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_vnni avx512bw avx512cd avx512dq avx512f
avx512vl bmi1 bmi2 bts cat_l3 cdp_l3 clflush clflushopt clwb cmov
constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb erms est f16c
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mba mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pts rdrand rdseed rdt_a rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: eVga.com. driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 65:00.0 chip-ID: 10de:2204
class-ID: 0300
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA vendor: eVga.com. driver: snd_hda_intel v: kernel
bus-ID: 65:00.1 chip-ID: 10de:1aef class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Mellanox MT27500 Family [ConnectX-3] driver: mlx4_core v: 4.0-0
port: 0580 bus-ID: 02:00.0 chip-ID: 15b3:1003 class-ID: 0200
IF: enp2s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.66 TiB used: 8.93 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T8
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 002C temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Intel model: SSDPEKNW020T8
lanes: 4 rotation: SSD serial: <filter> rev: 002C temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH31024G
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 4000 scheme: GPT
ID-1: / raw-size: 919.41 GiB size: 903.9 GiB (98.31%) used: 8.93 GiB (1.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b87bd145-97e0-4bd3-aecd-1cd1675587cb
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 564A-2D62
ID-1: swap-1 type: partition size: 34.16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: ed39a145-b614-4873-a477-85de40d529d8
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: BAC8-F110
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.86 TiB fs: ntfs label: N/A
uuid: 04A2CF4AA2CF3EC4
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 499 MiB fs: ntfs label: N/A
uuid: 58E0D342E0D32552
ID-5: /dev/nvme1n1p1 maj-min: 259:6 size: 16 MiB fs: <superuser required>
ID-6: /dev/nvme1n1p2 maj-min: 259:7 size: 1.86 TiB fs: ntfs label: Games
uuid: 88EE3246EE322CB6
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: MCT Elektronikladen MPS type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 10mA chip-ID: 0c70:f003 class-ID: 0300
Device-2: 1-5:3 info: MCT Elektronikladen aquaero type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0c70:f001 class-ID: 0300 serial: <filter>
Device-3: 1-7:4 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300
serial: <filter>
Device-4: 1-9:5 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-5: 1-12:6 info: MCT Elektronikladen aquaero type: Keyboard,HID
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-2:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 304mA chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 28 C
Processes: 450 Uptime: 7m wakeups: 2 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1135 lib: 285 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.04```
