After the last major update on Manjaro Gnome, Nautilus file manager is a bit stuttery during scrolling and window resize. I’ve noticed it on both work and home pc.
I’ve tried a live usb of Manjaro Gnome(the latest available to download) and everything was silky smooth.
Has anyone else noticed that?
*on both, the installed and live usb, the version of nautilus is the same: 3.36.3-efc97f8a9
I don’t use Gnome or Nautilus, but I would expect that this is a driver or compiz/composite issue.
Did you try to disable the desktop effects?
just tried it, it keeps stuttering
Could you add your system information?
inxi -Fazy
Yes, of course
Here it is
Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=8499008c-d6a4-4425-964e-5e3d6afc86db rw quiet
resume=UUID=a8802d24-51cd-475e-b010-15a84674f368 udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: H87M-PRO v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1308 date: 02/28/2014
Topology: Quad Core model: Intel Core i5-4440 bits: 64 type: MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 6144 KiB
bogomips: 24808
Speed: 1901 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 1901 2: 1900
3: 1900 4: 1900
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.1.8 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0c0c
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-3: Focusrite-Novation Focusrite Scarlett 2i2 type: USB
driver: snd-usb-audio bus ID: 1-10:4 chip ID: 1235:8006
Device-4: KORG Wired Keyboard 600 type: USB driver: snd-usb-audio
bus ID: 1-13.4:7 chip ID: 0944:0111
Sound Server: ALSA v: k5.4.67-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Qualcomm Atheros TP-Link TL-WN821N v3 / TL-WN822N v2 802.11n
[Atheros AR7010+AR9287]
type: USB driver: ath9k_htc bus ID: 1-9:3 chip ID: 0cf3:7015
serial: <filter>
IF: wlp0s20u9 state: up mac: <filter>
Local Storage: total: 1.14 TiB used: 111.81 GiB (9.6%)
ID-1: /dev/sda vendor: Samsung model: SSD 750 EVO 250GB size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1B6Q scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-75WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: MBR
ID-1: / raw size: 223.79 GiB size: 219.28 GiB (97.98%)
used: 111.81 GiB (51.0%) fs: ext4 dev: /dev/sda2
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 226 Uptime: 52m Memory: 7.65 GiB used: 2.24 GiB (29.3%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1368 lib: 413
Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.05
Since you use
Vasilis:
i would have no idea what do there, but if the problem is the intel driver, then i would try these options:
Section "Device"
Driver "intel"
Option "TearFree" "true" #Force the driver to use tearfree instead of auto
Option "DRI" "2" #Use 2 instead of 3
Option "AccelMethod" "uxa" #Use the mature uxa instead of the newer sna
EndSection
More information by man intel
Create a file in /etc/X11/xorg.conf.d/20-intel.conf, put the text into it and reboot. By changing this it could be possible that Gnome doesn’t start. Keep sure you have bootable Manjaro disk, just in case.
Sounds like a bug introduced with the update. Gnome is always a bit rocky when a major release comes out. Can you post your pacman log for the previous update, to pinpoint which package is causing the issue?
Tried it and I had no signal on boot. Thankfully I kept a live usb as you said Thank you anyway though!
Here is my pacman.log.
I also have a manjaro gnome install with nvidia graphics. It behaves just like the other ones with intel graphics.
It’s only visible in list mode. When in icons nothing stutters.
Also tested list view with live usb and it had no problem at all.
[2020-04-18T02:29:03+0300] [ALPM] installed xf86-video-ati (1:19.1.0-1)
[2020-04-18T02:29:03+0300] [ALPM] installed xf86-video-amdgpu (19.1.0-1)
[2020-04-18T02:29:03+0300] [ALPM] installed libxvmc (1.0.12-2)
[2020-04-18T02:29:03+0300] [ALPM] installed xf86-video-intel (1:2.99.917+899+gf66d3954-1)
[2020-04-18T02:29:03+0300] [ALPM] installed xf86-video-nouveau (1.0.16-1)
[2020-04-18T02:29:03+0300] [ALPM] installed vulkan-intel (19.3.4-2)
[2020-04-18T02:29:03+0300] [ALPM] installed vulkan-radeon (19.3.4-2)
[2020-04-18T02:29:03+0300] [ALPM] installed libva-mesa-driver (19.3.4-2)
[2020-04-18T02:29:03+0300] [ALPM] installed libva-vdpau-driver (0.7.4-4)
[2020-04-18T02:29:03+0300] [ALPM] installed mesa-vdpau (19.3.4-2)
[2020-04-18T02:29:03+0300] [ALPM] installed lib32-vulkan-intel (19.3.4-3)
[2020-04-18T02:29:03+0300] [ALPM] installed lib32-vulkan-radeon (19.3.4-3)
[2020-04-18T02:29:03+0300] [ALPM] installed lib32-libva (2.6.0-1)
[2020-04-18T02:29:03+0300] [ALPM] installed lib32-libvdpau (1.3-1)
[2020-04-18T02:29:03+0300] [ALPM] installed lib32-libva-vdpau-driver (0.7.4-6)
[2020-04-18T02:29:03+0300] [ALPM] installed lib32-mesa-vdpau (19.3.4-3)
[2020-04-18T02:34:20+0300] [ALPM] installed htop (2.2.0-3)
[2020-04-18T02:41:54+0300] [ALPM] installed libp11-kit (0.23.20-3)
[2020-04-18T02:41:55+0300] [ALPM] installed gst-plugins-bad-libs (1.16.2-7)
[2020-04-18T02:41:56+0300] [ALPM] warning: /etc/security/limits.d/10-gcr.conf installed as /etc/security/limits.d/10-gcr.conf.pacnew
[2020-04-18T02:41:58+0300] [ALPM] installed amtk (5.0.2-1)
[2020-04-18T02:41:58+0300] [ALPM] installed uchardet (0.0.6-2)
[2020-04-18T02:41:58+0300] [ALPM] installed tepl (4.4.0-1)
[2020-04-18T02:41:58+0300] [ALPM] installed js68 (68.7.0-1)
[2020-04-18T02:42:02+0300] [ALPM] installed gst-plugin-gtk (1.16.2-3)
[2020-04-18T02:42:03+0300] [ALPM] installed lib32-lz4 (1.9.2-1)
[2020-04-18T02:42:03+0300] [ALPM] installed lib32-zstd (1.4.4-2)
[2020-04-18T02:42:05+0300] [ALPM] installed manjaro-gdm-theme (20200331-1)
[2020-04-18T02:42:12+0300] [ALPM] installed python-pyxdg (0.26-6)
[2020-04-18T02:42:43+0300] [ALPM-SCRIPTLET] ==> Printing support not installed, to enable please type this in a terminal:
[2020-04-18T02:52:25+0300] [ALPM] installed boost-libs (1.72.0-1)
[2020-04-18T02:52:25+0300] [ALPM] installed librevenge (0.0.4-2)
[2020-04-18T02:52:25+0300] [ALPM] installed libpagemaker (0.0.4-2)
[2020-04-18T02:52:25+0300] [ALPM] installed python2 (2.7.17-2)
[2020-04-18T02:52:25+0300] [ALPM] installed python2-six (1.14.0-1)
[2020-04-18T02:52:25+0300] [ALPM] installed python2-scour (0.37-4)
[2020-04-18T02:52:25+0300] [ALPM] installed suil (0.10.6-2)
[2020-04-18T02:52:25+0300] [ALPM] installed spirv-tools (2019.5-2)
[2020-04-18T02:52:25+0300] [ALPM] installed glslang (8.13.3559-1)
[2020-04-18T02:52:25+0300] [ALPM] installed shaderc (2019.0-4)
[2020-04-18T02:52:25+0300] [ALPM] installed libplacebo (1.29.1-1)
[2020-04-18T02:52:25+0300] [ALPM] installed libxss (1.2.3-2)
[2020-04-18T02:52:25+0300] [ALPM] installed re2 (1:20200401-1)
[2020-04-18T02:52:25+0300] [ALPM] installed snappy (1.1.8-1)
[2020-04-18T02:52:25+0300] [ALPM] installed minizip (1:1.2.11-4)
[2020-04-18T02:52:25+0300] [ALPM] installed jack2 (1.9.14-1)
[2020-04-18T02:52:26+0300] [ALPM] installed chromium (81.0.4044.92-1)
[2020-04-18T02:52:26+0300] [ALPM] installed metis (5.1.0.p8-1)
[2020-04-18T02:52:26+0300] [ALPM] installed blas (3.9.0-2)
[2020-04-18T02:52:26+0300] [ALPM] installed lapack (3.9.0-2)
[2020-04-18T02:52:26+0300] [ALPM] installed intel-tbb (2020.2-1)
[2020-04-18T02:52:26+0300] [ALPM] installed suitesparse (5.7.2-1)
[2020-04-18T02:52:26+0300] [ALPM] installed portmidi (217-9)
[2020-04-18T02:52:26+0300] [ALPM] installed libebml (1.3.10-1)
[2020-04-18T02:52:26+0300] [ALPM] installed libmatroska (1.5.2-1)
[2020-04-18T02:52:26+0300] [ALPM] installed gc (8.0.4-3)
[2020-04-18T02:52:26+0300] [ALPM] installed liblangtag (0.6.3-1)
[2020-04-18T02:52:26+0300] [ALPM] installed libexttextcat (3.4.5-1)
[2020-04-18T02:52:26+0300] [ALPM] installed libuv (1.35.0-1)
[2020-04-18T02:52:26+0300] [ALPM] installed c-ares (1.16.0-1)
[2020-04-18T02:52:26+0300] [ALPM] installed nodejs (13.12.0-1)
[2020-04-18T02:52:26+0300] [ALPM] installed semver (7.1.3-1)
[2020-04-18T02:52:26+0300] [ALPM] installed python2-lxml (4.5.0-1)
[2020-04-18T02:52:26+0300] [ALPM] installed a2jmidid (9-1)
[2020-04-18T02:52:26+0300] [ALPM] installed jasper (2.0.16-1)
[2020-04-18T02:52:26+0300] [ALPM] installed libraw (0.19.5-2)
[2020-04-18T02:52:26+0300] [ALPM] installed libspiro (1:20190731-1)
[2020-04-18T02:52:26+0300] [ALPM] installed libmicrohttpd (0.9.70-1)
[2020-04-18T02:52:26+0300] [ALPM] installed elfutils (0.178-2)
[2020-04-18T02:52:26+0300] [ALPM] installed babl (0.1.74-1)
[2020-04-18T02:52:26+0300] [ALPM] installed luajit (2.0.5-2)
[2020-04-18T02:52:26+0300] [ALPM] installed lensfun (0.3.95-1)
[2020-04-18T02:52:26+0300] [ALPM] installed gegl (0.4.22-1)
[2020-04-18T02:52:26+0300] [ALPM] installed libheif (1.6.2-2)
[2020-04-18T02:52:26+0300] [ALPM] installed libmng (2.0.3-2)
[2020-04-18T02:52:26+0300] [ALPM] installed libmypaint (1.5.1-1)
[2020-04-18T02:52:26+0300] [ALPM] installed libwmf (0.2.12-1)
[2020-04-18T02:52:26+0300] [ALPM] installed mypaint-brushes1 (1.3.1-1)
[2020-04-18T02:52:27+0300] [ALPM] installed poppler-data (0.4.9-1)
[2020-04-18T02:52:27+0300] [ALPM] installed gimp (2.10.18-5)
[2020-04-18T02:52:27+0300] [ALPM] installed gnu-free-fonts (20120503-7)
[2020-04-18T02:52:27+0300] [ALPM] installed python-isodate (0.6.0-5)
[2020-04-18T02:52:27+0300] [ALPM] installed python-rdflib (4.2.2-3)
[2020-04-18T02:52:27+0300] [ALPM] installed m4 (1.4.18-3)
[2020-04-18T02:52:27+0300] [ALPM] installed flex (2.6.4-3)
[2020-04-18T02:52:28+0300] [ALPM] installed protobuf (3.11.4-1)
[2020-04-18T02:52:28+0300] [ALPM] installed libphonenumber (8.11.5-1)
[2020-04-18T02:52:28+0300] [ALPM] installed evolution-data-server (3.36.1-1)
[2020-04-18T02:52:28+0300] [ALPM] installed cblas (3.9.0-2)
[2020-04-18T02:52:28+0300] [ALPM] installed python2-numpy (1.16.4-2)
[2020-04-18T02:52:28+0300] [ALPM] installed patch (2.7.6-8)
[2020-04-18T02:52:28+0300] [ALPM] installed yarn (1.22.4-1)
[2020-04-18T02:52:28+0300] [ALPM] installed fakeroot (1.24-2)
[2020-04-18T02:52:28+0300] [ALPM] installed mujs (1.0.6-1)
[2020-04-18T02:52:28+0300] [ALPM] installed libdvbpsi (1:1.3.3-1)
[2020-04-18T02:52:28+0300] [ALPM] installed libupnp (1.6.25-1)
[2020-04-18T02:52:28+0300] [ALPM] installed libmad (0.15.1b-8)
[2020-04-18T02:52:28+0300] [ALPM] installed libtar (1.2.20-4)
[2020-04-18T02:52:28+0300] [ALPM] installed aribb24 (1.0.3-2)
[2020-04-18T02:52:28+0300] [ALPM] installed vlc (3.0.8-13)
[2020-04-18T02:52:28+0300] [ALPM] installed aubio (0.4.9-7)
[2020-04-18T02:52:28+0300] [ALPM] installed cadence (0.9.1-2)
[2020-04-18T02:52:28+0300] [ALPM] installed libabw (0.1.3-1)
[2020-04-18T02:52:29+0300] [ALPM] installed libwpd (0.10.3-1)
[2020-04-18T02:52:29+0300] [ALPM] installed libwps (0.4.11-1)
[2020-04-18T02:52:29+0300] [ALPM] installed qt5-translations (5.14.2-1)
[2020-04-18T02:52:29+0300] [ALPM] installed gtkmm (1:2.24.5-3)
[2020-04-18T02:52:29+0300] [ALPM] installed libnumbertext (1.0.5-1)
[2020-04-18T02:52:29+0300] [ALPM] installed fltk (1.3.5-1)
[2020-04-18T02:52:29+0300] [ALPM] installed libcmis (0.5.2-4)
[2020-04-18T02:52:29+0300] [ALPM] installed vamp-plugin-sdk (2.9.0-1)
[2020-04-18T02:52:29+0300] [ALPM] installed rubberband (1.8.2-3)
[2020-04-18T02:52:29+0300] [ALPM] installed mpv (1:0.32.0-3)
[2020-04-18T02:52:29+0300] [ALPM] installed binutils (2.34-2.1)
[2020-04-18T02:52:30+0300] [ALPM] installed gcc (9.3.0-1)
[2020-04-18T02:52:30+0300] [ALPM] installed qt5-webchannel (5.14.2-1)
[2020-04-18T02:52:30+0300] [ALPM] installed qt5-location (5.14.2-1)
[2020-04-18T02:52:30+0300] [ALPM] installed qt5-webengine (5.14.2-1)
[2020-04-18T02:52:30+0300] [ALPM] installed libcurl-gnutls (7.69.1-1)
[2020-04-18T02:52:30+0300] [ALPM] installed ntk (1.3.1000-5)
[2020-04-18T02:52:30+0300] [ALPM] installed libqxp (0.0.2-3)
[2020-04-18T02:52:30+0300] [ALPM] installed liblo (1:0.31-1)
[2020-04-18T02:52:30+0300] [ALPM] installed libfreehand (0.1.2-2)
[2020-04-18T02:52:30+0300] [ALPM] installed libetonyek (0.1.9-2)
[2020-04-18T02:52:30+0300] [ALPM] installed libmagick6 (6.9.11.4-1)
[2020-04-18T02:52:30+0300] [ALPM] installed libcdr (0.1.6-1)
[2020-04-18T02:52:30+0300] [ALPM] installed rtosc (0.2.0-1)
[2020-04-18T02:52:30+0300] [ALPM] installed libltc (1.3.1-2)
[2020-04-18T02:52:31+0300] [ALPM] installed mxml (3.1-2)
[2020-04-18T02:52:31+0300] [ALPM] installed libstaroffice (0.0.7-1)
[2020-04-18T02:52:31+0300] [ALPM] installed libmwaw (0.3.16-1)
[2020-04-18T02:52:31+0300] [ALPM] installed pepper-flash (32.0.0.344-1)
[2020-04-18T02:52:31+0300] [ALPM] installed jack_capture (0.9.73-7)
[2020-04-18T02:52:31+0300] [ALPM] installed libtommath (1.2.0-1)
[2020-04-18T02:52:31+0300] [ALPM] installed xjadeo (0.8.9-1)
[2020-04-18T02:52:31+0300] [ALPM] installed yoshimi (1.7.0.1-1)
[2020-04-18T02:52:31+0300] [ALPM] installed libepubgen (0.1.1-1)
[2020-04-18T02:52:31+0300] [ALPM] installed libzmf (0.0.2-7)
[2020-04-18T02:52:32+0300] [ALPM] installed guile (2.2.6-1)
[2020-04-18T02:52:32+0300] [ALPM] installed make (4.3-3)
[2020-04-18T02:52:32+0300] [ALPM] installed rasqal (1:0.9.33-2)
[2020-04-18T02:52:32+0300] [ALPM] installed potrace (1.16-1)
[2020-04-18T02:52:32+0300] [ALPM] installed gsl (2.6-1)
[2020-04-18T02:52:32+0300] [ALPM] installed gtkspell (2.0.16-7)
[2020-04-18T02:52:32+0300] [ALPM] installed inkscape (0.92.4-15)
[2020-04-18T02:52:33+0300] [ALPM] installed zynaddsubfx (3.0.5-1)
[2020-04-18T02:52:33+0300] [ALPM] installed libixion (0.15.0-1)
[2020-04-18T02:52:33+0300] [ALPM] installed liborcus (0.15.4-1)
[2020-04-18T02:52:33+0300] [ALPM] installed libodfgen (0.1.7-1)
[2020-04-18T02:52:33+0300] [ALPM] installed realtime-privileges (2-1)
[2020-04-18T02:52:33+0300] [ALPM] installed node-gyp (6.1.0-1)
[2020-04-18T02:52:33+0300] [ALPM] installed npm (6.14.4-1)
[2020-04-18T02:52:33+0300] [ALPM] installed libe-book (0.1.3-6)
[2020-04-18T02:52:33+0300] [ALPM] installed bison (3.5.4-1)
[2020-04-18T02:52:33+0300] [ALPM] installed qt5-sensors (5.14.2-1)
[2020-04-18T02:52:33+0300] [ALPM] installed redland (1:1.0.17-7)
[2020-04-18T02:52:33+0300] [ALPM] installed lpsolve (5.5.2.5-3)
[2020-04-18T02:52:33+0300] [ALPM] installed libwpg (0.3.3-1)
[2020-04-18T02:52:33+0300] [ALPM] installed libvisio (0.1.7-2)
[2020-04-18T02:52:34+0300] [ALPM] installed libmspub (0.1.4-6)
[2020-04-18T02:52:34+0300] [ALPM] installed clucene (2.3.3.4-10)
[2020-04-18T02:52:34+0300] [ALPM] installed libatomic_ops (7.6.10-1)
[2020-04-18T02:52:34+0300] [ALPM] installed xmlsec (1.2.29-1)
[2020-04-18T02:52:35+0300] [ALPM] installed libreoffice-still (6.3.5-4)
[2020-04-18T02:52:35+0300] [ALPM] installed automake (1.16.2-1)
[2020-04-18T02:52:35+0300] [ALPM] installed ardour (5.12-14)
[2020-04-18T02:52:35+0300] [ALPM] installed qt5-quickcontrols2 (5.14.2-1)
[2020-04-18T02:52:36+0300] [ALPM] installed calf (0.90.3-1)
[2020-04-18T02:52:36+0300] [ALPM] installed zita-ajbridge (0.8.4-1)
[2020-04-18T02:52:36+0300] [ALPM] installed harvid (0.8.3-1)
[2020-04-18T02:52:36+0300] [ALPM] installed qt5-quickcontrols (5.14.2-1)
[2020-04-18T02:52:36+0300] [ALPM] installed autoconf (2.69-7)
[2020-04-18T02:52:36+0300] [ALPM] installed gnome-notes (3.36.0-1)
[2020-04-18T02:54:01+0300] [ALPM] installed stremio (4.4.77-2)
[2020-04-18T02:54:41+0300] [ALPM] installed google-chrome (81.0.4044.113-1)
[2020-04-18T02:55:26+0300] [ALPM] installed spotify (1:1.1.10.546-4)
[2020-04-18T02:59:15+0300] [ALPM] installed electronplayer (2.0.8-2)
[2020-04-18T02:59:39+0300] [ALPM] installed xnconvert (1.83-4)
[2020-04-18T03:00:20+0300] [ALPM] installed tonelib-gfx-bin (4.3.3-1)
[2020-04-18T03:00:48+0300] [ALPM] installed xdotool (3.20160805.1-2)
[2020-04-18T03:01:49+0300] [ALPM] installed slack-desktop (4.4.2-1)
[2020-04-18T03:09:02+0300] [ALPM] installed xorg-xrandr (1.5.1-1)
[2020-04-18T03:09:02+0300] [ALPM] installed game-devices-udev (0.5-1)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-libxss (1.2.3-1)
[2020-04-18T03:09:02+0300] [ALPM] installed lsof (4.93.2-1)
[2020-04-18T03:09:02+0300] [ALPM] installed libindicator-gtk2 (12.10.1-9)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-atk (2.34.1-1)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-libdatrie (0.2.12-1)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-libthai (0.1.28-1)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-libpng (1.6.37-2)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-harfbuzz (2.6.4-2)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-freetype2 (2.10.1-2)
[2020-04-18T03:09:02+0300] [ALPM] installed lib32-fontconfig (2:2.13.1+12+g5f5ec56-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-pixman (0.38.4-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-cairo (1.17.2+17+g52a7c79fd-2)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libxft (2.3.3-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-fribidi (1.0.9-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-pango (1:1.44.7+11+g73b46b04-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libjpeg-turbo (2.0.4-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libtiff (4.1.0-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-gdk-pixbuf2 (2.40.0-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-e2fsprogs (1.45.6-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-openssl (1:1.1.1.e-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libldap (2.4.49-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-keyutils (1.6.1-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-krb5 (1.18-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-gmp (6.2.0-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-nettle (3.5.1-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libtasn1 (4.16.0-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-p11-kit (0.23.20-3)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libidn (1.35-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-gnutls (3.6.13-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libcups (2.3.1-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libxrandr (1.5.2-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libxinerama (1.1.4-1)
[2020-04-18T03:09:05+0300] [ALPM] installed lib32-libxcomposite (0.4.5-1)
[2020-04-18T03:09:06+0300] [ALPM] installed lib32-gtk2 (2.24.32-1)
[2020-04-18T03:09:06+0300] [ALPM] installed lib32-libindicator-gtk2 (12.10.1-8)
[2020-04-18T03:09:06+0300] [ALPM] installed libdbusmenu-glib (16.04.0-4)
[2020-04-18T03:09:06+0300] [ALPM] installed lib32-libdbusmenu-glib (16.04.0-4)
[2020-04-18T03:09:06+0300] [ALPM] installed libdbusmenu-gtk2 (16.04.0-4)
[2020-04-18T03:09:06+0300] [ALPM] installed lib32-libdbusmenu-gtk2 (16.04.0-4)
[2020-04-18T03:09:06+0300] [ALPM] installed lib32-nspr (4.25-1)
[2020-04-18T03:09:06+0300] [ALPM] installed lib32-sqlite (3.31.1-1)
[2020-04-18T03:09:06+0300] [ALPM] installed lib32-nss (3.51-1)
[2020-04-18T03:09:06+0300] [ALPM] installed steam-manjaro (1.0.0.61-7)
[2020-04-18T03:36:24+0300] [ALPM] installed libsmf (1.3-10)
[2020-04-18T03:36:24+0300] [ALPM] installed drumgizmo (0.9.18.1-1)
[2020-04-18T03:40:46+0300] [ALPM] installed openssl-1.0 (1.0.2.u-1)
[2020-04-18T03:42:15+0300] [ALPM] installed viber (12.0.0.7-1)
[2020-04-18T12:11:21+0300] [ALPM] installed gnome-weather (3.36.1-1)
[2020-04-18T12:42:19+0300] [ALPM] installed libgig (4.2.0-2)
[2020-04-18T12:42:19+0300] [ALPM] installed linuxsampler (2.1.1-2)
[2020-04-18T12:42:19+0300] [ALPM] installed liblscp (0.6.0-2)
[2020-04-18T12:42:19+0300] [ALPM] installed qsampler (0.6.2-1)
[2020-04-18T23:38:01+0300] [ALPM-SCRIPTLET] Total Installed Size: 5.02 MiB
[2020-04-18T23:38:03+0300] [ALPM-SCRIPTLET] Total Installed Size: 2.93 MiB
[2020-04-19T00:03:44+0300] [ALPM] installed mailcap (2.1.48+14+g5811758-1)
[2020-04-19T00:03:44+0300] [ALPM] installed firefox (75.0-1)
[2020-04-19T00:10:36+0300] [ALPM] installed ca-certificates (20181109-3)
[2020-04-19T00:37:10+0300] [ALPM] reinstalled chromium (81.0.4044.92-1)
[2020-04-19T00:38:03+0300] [ALPM] reinstalled google-chrome (81.0.4044.113-1)
[2020-04-19T01:10:02+0300] [ALPM] installed chromium (81.0.4044.113-1)
[2020-04-19T01:53:24+0300] [ALPM] installed ca-certificates-utils (20181109-3)
[2020-04-19T01:53:24+0300] [ALPM] installed ca-certificates-mozilla (3.51.1-1)
[2020-04-19T01:53:24+0300] [ALPM] installed ca-certificates (20181109-3)
[2020-04-19T02:04:10+0300] [ALPM] reinstalled openssl-1.0 (1.0.2.u-1)
[2020-04-19T02:04:11+0300] [ALPM] reinstalled openssl (1.1.1.f-1)
[2020-04-19T02:08:18+0300] [ALPM] installed opera-ffmpeg-codecs (80.0.3987.163-1)
[2020-04-19T02:08:19+0300] [ALPM] installed opera (67.0.3575.137-1)
[2020-04-19T02:13:28+0300] [ALPM] installed chromium (81.0.4044.92-1)
[2020-04-19T11:27:42+0300] [ALPM-SCRIPTLET] Total Installed Size: 5.02 MiB
[2020-04-19T11:27:42+0300] [ALPM-SCRIPTLET] Total Installed Size: 2.93 MiB
[2020-04-20T18:31:35+0300] [ALPM] installed stk (4.6.1-2)
[2020-04-20T18:31:36+0300] [ALPM] installed lmms (1.2.1-3)
[2020-04-21T11:54:40+0300] [ALPM] reinstalled xnconvert (1.85-1)
[2020-04-21T19:54:48+0300] [ALPM] installed rhash (1.3.9-1)
[2020-04-21T19:54:48+0300] [ALPM] installed jsoncpp (1.9.2-1)
[2020-04-21T19:54:49+0300] [ALPM] installed cmake (3.17.1-2)
[2020-04-21T19:56:04+0300] [ALPM] installed rakarrack (0.6.1-3)
[2020-04-21T19:56:20+0300] [ALPM] installed rkr.lv2-git (beta_3.r0.g7edcb4e-1)
[2020-04-22T12:39:55+0300] [ALPM] installed qt5-webkit (5.212.0alpha4-3)
[2020-04-22T12:40:19+0300] [ALPM] installed teamviewer (15.4.4445-1)
[2020-04-22T13:05:02+0300] [ALPM] installed mozilla-common (1.4-5)
[2020-04-22T13:05:02+0300] [ALPM] installed thunderbird (68.7.0-1)
[2020-04-22T15:12:42+0300] [ALPM] installed zita-convolver (4.0.3-2)
[2020-04-22T15:12:42+0300] [ALPM] installed ttf-roboto (2.138-1)
[2020-04-22T15:12:42+0300] [ALPM] installed guitarix (0.39.0-3)
[2020-04-22T15:15:00+0300] [ALPM] installed media-player-info (24-1)
[2020-04-22T15:15:00+0300] [ALPM] installed solid (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kwidgetsaddons (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kjobwidgets (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kdbusaddons (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kconfig (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kcrash (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kglobalaccel (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kcodecs (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kguiaddons (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed ki18n (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kconfigwidgets (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kitemviews (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed karchive (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kiconthemes (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed attica (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kxmlgui (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kbookmarks (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed libdbusmenu-qt5 (0.9.3+16.04.20160218-4)
[2020-04-22T15:15:00+0300] [ALPM] installed qt5-multimedia (5.14.2-1)
[2020-04-22T15:15:00+0300] [ALPM] installed qt5-speech (5.14.2-1)
[2020-04-22T15:15:00+0300] [ALPM] installed knotifications (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kservice (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kwallet (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kcompletion (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed sonnet (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed ktextwidgets (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kio (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed knewstuff (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed knotifyconfig (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed poppler-qt5 (0.87.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed libzip (1.6.1-1)
[2020-04-22T15:15:00+0300] [ALPM] installed convertlit (1.8-8)
[2020-04-22T15:15:00+0300] [ALPM] installed ebook-tools (0.2.2-6)
[2020-04-22T15:15:00+0300] [ALPM] installed kfilemetadata (5.69.0-1)
[2020-04-22T15:15:00+0300] [ALPM] installed kpackage (5.69.0-1)
[2020-04-22T15:15:01+0300] [ALPM] installed kdeclarative (5.69.0-1)
[2020-04-22T15:15:01+0300] [ALPM] installed kcmutils (5.69.0-1)
[2020-04-22T15:15:01+0300] [ALPM] installed signond (8.60-1)
[2020-04-22T15:15:01+0300] [ALPM] installed signon-kwallet-extension (19.12.3-1)
[2020-04-22T15:15:01+0300] [ALPM] installed signon-plugin-oauth2 (0.24-2)
[2020-04-22T15:15:01+0300] [ALPM] installed libaccounts-glib (1.25-1)
[2020-04-22T15:15:01+0300] [ALPM] installed libaccounts-qt (1.16-2)
[2020-04-22T15:15:01+0300] [ALPM] installed signon-ui (0.17+20171022-2)
[2020-04-22T15:15:01+0300] [ALPM] installed kaccounts-integration (19.12.3-1)
[2020-04-22T15:15:01+0300] [ALPM] installed qt5-graphicaleffects (5.14.2-1)
[2020-04-22T15:15:01+0300] [ALPM] installed kirigami2 (5.69.0-1)
[2020-04-22T15:15:01+0300] [ALPM] installed accounts-qml-module (0.7-2)
[2020-04-22T15:15:01+0300] [ALPM] installed purpose (5.69.0-1)
[2020-04-22T15:15:01+0300] [ALPM] installed libebur128 (1.2.4-1)
[2020-04-22T15:15:01+0300] [ALPM] installed mlt (6.20.0-3)
[2020-04-22T15:15:01+0300] [ALPM] installed rttr (0.9.6-2)
[2020-04-22T15:15:02+0300] [ALPM] installed breeze-icons (5.69.0-1)
[2020-04-22T15:15:02+0300] [ALPM] installed kdenlive (19.12.3-1)
[2020-04-22T15:15:02+0300] [ALPM] installed gxplugins.lv2 (0.7-2)
[2020-04-22T20:01:37+0300] [ALPM] installed qt5-tools (5.14.2-1)
[2020-04-22T20:03:24+0300] [ALPM] installed olive (0.1.2-1)
[2020-04-23T10:19:25+0300] [ALPM] installed timeshift (20.03.r0.gcecd294-1)
[2020-04-25T12:29:03+0300] [ALPM] installed transmission-cli (2.94-2)
[2020-04-25T12:29:03+0300] [ALPM] installed transmission-qt (2.94-2)
[2020-04-25T22:30:32+0300] [ALPM] installed gd (2.3.0-1)
[2020-04-25T22:30:32+0300] [ALPM] installed libgphoto2 (2.5.24-1)
[2020-04-25T22:30:33+0300] [ALPM] installed opencv (4.3.0-3)
[2020-04-25T22:43:12+0300] [ALPM] installed vsxu (0.6.3-1)
[2020-04-25T23:50:12+0300] [ALPM] installed portsmf (234-1)
[2020-04-25T23:50:12+0300] [ALPM] installed wxgtk-common (3.0.4-2)
[2020-04-25T23:50:12+0300] [ALPM] installed wxgtk3 (3.0.4-2)
[2020-04-25T23:50:12+0300] [ALPM] installed audacity (1:2.3.3-2)
[2020-04-26T12:35:22+0300] [ALPM] installed manjaro-gnome-settings (20200425-1)
[2020-04-26T12:35:22+0300] [ALPM] installed manjaro-gnome-extension-settings (20200425-1)
[2020-04-26T12:35:22+0300] [ALPM] installed manjaro-gnome-assets (20200425-1)
[2020-04-26T12:35:48+0300] [ALPM-SCRIPTLET] ==> Printing support not installed, to enable please type this in a terminal:
[2020-04-27T11:58:02+0300] [ALPM] installed glm (0.9.9.8-1)
[2020-04-27T11:58:02+0300] [ALPM] installed ftgl (2.4.0-1)
[2020-04-27T11:58:02+0300] [ALPM] installed projectm (3.1.3-1)
[2020-04-27T11:58:03+0300] [ALPM-SCRIPTLET] ==> Printing support not installed, to enable please type this in a terminal:
[2020-04-27T12:03:59+0300] [ALPM] installed ctags (1:r20200106+ga3c87ab5-1)
[2020-04-27T12:04:00+0300] [ALPM] installed apm (2.4.5-1)
[2020-04-27T12:04:00+0300] [ALPM] installed http-parser (2.9.4-1)
[2020-04-27T12:04:00+0300] [ALPM] installed electron4 (4.2.12-4)
[2020-04-27T12:04:00+0300] [ALPM] installed ripgrep (12.0.1-1)
[2020-04-27T12:04:03+0300] [ALPM] installed atom (1.45.0-1)
[2020-04-27T12:41:52+0300] [ALPM] installed firefox (75.0-1)
[2020-04-29T12:29:05+0300] [ALPM] installed colorpicker (1.0.f5d441a-2)
[2020-05-02T17:52:54+0300] [ALPM] installed libsass (3.6.3-1)
[2020-05-02T17:52:54+0300] [ALPM] installed sassc (3.6.1-1)
[2020-05-02T17:52:54+0300] [ALPM] installed optipng (0.7.7-1)
[2020-05-02T17:52:54+0300] [ALPM] installed parallel (20191122-1)
[2020-05-02T17:53:49+0300] [ALPM] installed pop-gtk-theme (4.0.0-1)
[2020-05-03T01:47:25+0300] [ALPM] installed brave (1.7.98-1)
[2020-05-03T02:01:15+0300] [ALPM] installed w3m (0.5.3.git20190105-1)
[2020-05-03T13:02:41+0300] [ALPM] warning: /etc/pam.d/polkit-1 installed as /etc/pam.d/polkit-1.pacnew
[2020-05-04T17:05:36+0300] [ALPM] installed etcher (1.5.83-1)
[2020-05-07T20:13:10+0300] [ALPM] installed quazip (0.9-1)
[2020-05-07T20:13:11+0300] [ALPM] installed krita (4.2.9-2)
[2020-05-07T20:13:11+0300] [ALPM] installed gmic (2.9.0-3)
[2020-05-07T20:13:11+0300] [ALPM] installed krita-plugin-gmic (2.9.0-3)
[2020-05-08T14:55:56+0300] [ALPM] installed gdl (3.34.0-1)
[2020-05-08T14:55:56+0300] [ALPM] installed gtkspell3 (3.0.10-2)
[2020-05-10T22:37:37+0300] [ALPM] reinstalled apache (2.4.43-1)
[2020-05-10T22:40:06+0300] [ALPM] installed mariadb-libs (10.4.12-1)
[2020-05-10T22:40:06+0300] [ALPM] installed jemalloc (1:5.2.1-1)
[2020-05-10T22:40:06+0300] [ALPM] installed mariadb-clients (10.4.12-1)
[2020-05-10T22:40:06+0300] [ALPM] installed mariadb (10.4.12-1)
[2020-05-10T22:42:27+0300] [ALPM] installed oniguruma (6.9.5-1)
[2020-05-10T22:42:27+0300] [ALPM] installed php (7.4.5-2)
[2020-05-10T22:42:27+0300] [ALPM] installed php-apache (7.4.5-2)
[2020-05-10T22:44:29+0300] [ALPM] installed phpmyadmin (5.0.2-1)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-encode-locale (1.05-5)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-http-date (6.05-1)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-file-listing (6.04-6)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-html-tagset (3.20-8)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-html-parser (3.72-8)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-lwp-mediatypes (6.02-6)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-uri (1.76-2)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-io-html (1.001-5)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-http-message (6.22-1)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-http-cookies (6.08-1)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-http-daemon (6.06-1)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-http-negotiate (6.01-6)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-net-http (6.19-2)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-try-tiny (0.30-3)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-www-robotrules (6.02-6)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-libwww (6.44-1)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-xml-parser (2.46-1)
[2020-05-11T11:36:36+0300] [ALPM] installed perl-xml-writer (0.625-5)
[2020-05-11T22:47:38+0300] [ALPM] installed perl-parse-yapp (1.21-2)
[2020-05-11T22:47:38+0300] [ALPM] installed oath-toolkit (2.6.2-8)
[2020-05-11T22:47:38+0300] [ALPM] installed iniparser (4.1-2)
[2020-05-11T22:47:38+0300] [ALPM] installed ceph-libs (14.2.8-1)
[2020-05-11T22:47:39+0300] [ALPM] installed samba (4.12.2-3)
[2020-05-11T22:47:39+0300] [ALPM] installed nautilus-share (0.7.3-8)
[2020-05-11T22:47:39+0300] [ALPM] installed manjaro-settings-samba (20191208-1)
[2020-05-12T12:07:40+0300] [ALPM] installed java-runtime-common (3-2)
[2020-05-12T12:07:40+0300] [ALPM] installed libnet (1.1.6-3)
[2020-05-12T12:07:40+0300] [ALPM] installed jre-openjdk-headless (13.0.2.u8-1)
[2020-05-12T12:07:40+0300] [ALPM] installed jre-openjdk (13.0.2.u8-1)
[2020-05-12T12:07:40+0300] [ALPM] installed java-environment-common (3-2)
[2020-05-12T12:07:40+0300] [ALPM] installed jdk-openjdk (13.0.2.u8-1)
[2020-05-12T12:08:19+0300] [ALPM] installed jwildfire (5.50-1)
[2020-05-13T12:15:55+0300] [ALPM] installed qqwing (1.3.4-4)
[2020-05-13T12:15:55+0300] [ALPM] installed gnome-sudoku (3.36.0-1)
[2020-05-14T13:51:50+0300] [ALPM] installed skypeforlinux-stable-bin (8.59.0.77-4)
[2020-05-16T14:22:35+0300] [ALPM] installed aspell-el (0.08-3)
[2020-05-21T03:19:40+0300] [ALPM] installed qgnomeplatform (0.6.0+8+gd4277c9-1)
[2020-05-21T03:20:07+0300] [ALPM-SCRIPTLET] ==> Printing support not installed, to enable please type this in a terminal:
[2020-05-22T12:45:54+0300] [ALPM] installed python-ply (3.11-4)
[2020-05-22T12:45:54+0300] [ALPM] installed libmaxminddb (1.4.2-1)
[2020-05-22T12:45:54+0300] [ALPM] installed bind-tools (9.16.2-2)
[2020-05-22T23:16:48+0300] [ALPM] installed gnome-sound-recorder (3.34.0+10+gc4bdfa0-1)
[2020-05-26T23:08:15+0300] [ALPM] installed kded (5.70.0-1)
[2020-05-29T19:03:31+0300] [ALPM] installed pavucontrol (1:4.0-1)
[2020-06-01T19:34:39+0300] [ALPM] installed lib32-mpg123 (1.25.13-1)
[2020-06-01T19:34:39+0300] [ALPM] installed ucl (1.03-8)
[2020-06-01T19:34:39+0300] [ALPM] installed upx (3.96-2)
[2020-06-01T19:34:48+0300] [ALPM] installed kega-fusion (3.63-17)
[2020-06-01T19:58:47+0300] [ALPM] warning: /etc/shadow installed as /etc/shadow.pacnew
[2020-06-01T19:58:52+0300] [ALPM] installed libev (4.33-1)
[2020-06-01T19:58:52+0300] [ALPM] installed libwebsockets (4.0.13-1)
[2020-06-01T19:58:53+0300] [ALPM] installed vmaf (1.5.1-1)
[2020-06-01T19:58:55+0300] [ALPM] installed electron5 (5.0.13-5)
[2020-06-01T19:59:05+0300] [ALPM] installed graphicsmagick (1.3.35-1)
[2020-06-01T19:59:32+0300] [ALPM] installed perl-clone (0.45-1)
[2020-06-01T19:59:34+0300] [ALPM] installed lib32-vulkan-icd-loader (1.2.140-1)
[2020-06-01T19:59:37+0300] [ALPM] installed libdbusmenu-gtk3 (16.04.0-4)
[2020-06-01T19:59:37+0300] [ALPM] installed xapps (1.8.6-0.1)
[2020-06-04T11:20:08+0300] [ALPM] installed avldrums.lv2 (0.4.1-1)
[2020-06-09T19:43:03+0300] [ALPM] installed gcolor3 (2.3.1-2)
[2020-06-13T12:58:49+0300] [ALPM] installed lib32-libunistring (0.9.10-1)
[2020-06-13T12:58:49+0300] [ALPM] installed lib32-libidn2 (2.3.0-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-vkd3d (1.1-2)
[2020-06-13T12:58:58+0300] [ALPM] installed libimagequant (2.12.6-1)
[2020-06-13T12:58:58+0300] [ALPM] installed python-pillow (6.2.1-1)
[2020-06-13T12:58:58+0300] [ALPM] installed python-evdev (1.3.0-1)
[2020-06-13T12:58:58+0300] [ALPM] installed vkd3d (1.1-1)
[2020-06-13T12:58:58+0300] [ALPM] installed python-yaml (5.3.1-1)
[2020-06-13T12:58:58+0300] [ALPM] installed p7zip (16.02-6)
[2020-06-13T12:58:58+0300] [ALPM] installed cabextract (1.9.1-1)
[2020-06-13T12:58:58+0300] [ALPM] installed python-distro (1.5.0-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lutris (0.5.6-2)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-libnl (3.5.0-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-libusb (1.0.23-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-libpcap (1.9.1-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-acl (2.2.53-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-gettext (0.20.2-1)
[2020-06-13T12:58:58+0300] [ALPM] installed faudio (20.06-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-faudio (20.06-1)
[2020-06-13T12:58:58+0300] [ALPM] installed lib32-lcms2 (2.9-2)
[2020-06-13T12:59:00+0300] [ALPM] installed wine (5.9-1)
[2020-06-18T23:10:14+0300] [ALPM] installed dkms (2.8.1-3)
[2020-06-18T23:10:14+0300] [ALPM] installed bluez-utils (5.54-2)
[2020-06-18T23:10:35+0300] [ALPM] installed xpadneo-dkms-git (0.7.r452.g7d69de4-1)
[2020-06-18T23:17:22+0300] [ALPM] installed xpad-dkms-git (0.4-2)
[2020-06-22T23:27:34+0300] [ALPM] installed xmlto (0.0.28-4)
[2020-06-22T23:27:34+0300] [ALPM] installed lynx (2.8.9-3)
[2020-06-22T23:27:34+0300] [ALPM] installed docbook-xml (4.5-9)
[2020-06-22T23:27:34+0300] [ALPM] installed docbook-xsl (1.79.2-6)
[2020-06-24T17:33:13+0300] [ALPM] installed wine-installer (5.0.2-1)
[2020-07-20T19:59:44+0300] [ALPM] warning: /etc/fonts/fonts.conf installed as /etc/fonts/fonts.conf.pacnew
[2020-07-20T19:59:47+0300] [ALPM] installed hidapi (0.9.0-2)
[2020-07-20T20:00:01+0300] [ALPM] installed tbb (2020.2-1)
[2020-07-20T20:00:41+0300] [ALPM] installed xxhash (0.7.4-1)
[2020-08-29T17:30:37+0300] [ALPM] warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
[2020-08-29T17:30:41+0300] [ALPM] installed libxcrypt (4.4.16-3)
[2020-08-29T17:30:42+0300] [ALPM] installed rav1e (0.3.3-1)
[2020-08-29T17:30:51+0300] [ALPM] installed bind (9.16.6-1)
[2020-08-29T17:31:39+0300] [ALPM] installed mhwd-nvidia-450xx (450.66-1)
[2020-08-29T17:32:38+0300] [ALPM-SCRIPTLET] ==> Printing support not installed, to enable please type this in a terminal:
[2020-08-29T19:41:24+0300] [ALPM] installed xorg-xwininfo (1.1.5-2)
[2020-08-29T19:41:48+0300] [ALPM] installed libxres (1.2.0-2)
[2020-08-29T19:41:48+0300] [ALPM] installed libwnck3 (3.36.0-1)
[2020-08-29T19:43:19+0300] [ALPM] installed spotify-tray-git (1.2.0.r2.gc7d80d0-1)
[2020-09-06T12:47:32+0300] [ALPM] installed sdl2_net (1:2.0.1-3)
[2020-09-06T12:47:32+0300] [ALPM] installed scummvm (2.1.2-1)
[2020-09-09T18:39:51+0300] [ALPM] installed lib32-libxcrypt (4.4.17-1)
[2020-09-09T18:40:08+0300] [ALPM] installed xapp (1.8.9-4)
[2020-09-10T19:02:22+0300] [ALPM-SCRIPTLET] ==> Printing support not installed, to enable please type this in a terminal:
[2020-09-12T13:09:17+0300] [ALPM] installed qjackctl (0.6.3-1)
[2020-09-13T13:34:54+0300] [ALPM] installed libreoffice-still-en-gb (6.4.6-1)
[2020-09-13T13:35:08+0300] [ALPM] installed libreoffice-extension-orthos-greek-cypriot-dictionary (0.4.0-1)
[2020-09-16T20:09:23+0300] [ALPM] installed xorg-xmessage (1.0.5-2)
[2020-09-16T20:09:23+0300] [ALPM] installed winetricks (20200412-1)
[2020-09-18T21:43:45+0300] [ALPM] installed soundconverter (3.0.2-2)
[2020-09-19T23:31:54+0300] [ALPM] installed intltool (0.51.0-6)
[2020-09-19T23:31:54+0300] [ALPM] installed swh-plugins (0.4.17-4)
[2020-09-19T23:32:18+0300] [ALPM] installed jamin (0.98.9-1)
[2020-09-19T23:33:50+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-19T23:33:50+0300] [ALPM] installed new-session-manager (1.4.0-2)
[2020-09-19T23:57:15+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-20T12:32:38+0300] [ALPM] installed drumkv1 (0.9.17-1)
[2020-09-20T12:35:21+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-20T12:43:17+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-20T12:48:25+0300] [ALPM] reinstalled samplv1 (0.9.17-1)
[2020-09-20T13:12:22+0300] [ALPM] installed synthv1 (0.9.17-1)
[2020-09-20T13:12:55+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-20T13:20:22+0300] [ALPM] installed recbox-ardour-theme-git (r14.51d4f3a-1)
[2020-09-20T13:21:48+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-20T13:24:38+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-20T15:59:24+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-20T16:44:56+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-09-23T08:23:08+0300] [ALPM] installed sublime-text-3 (3.3211-1)
[2020-09-23T09:13:42+0300] [ALPM] installed birdtray (1.8.1-1)
[2020-09-23T09:52:55+0300] [ALPM] installed nodejs-postcss-cli (7.1.2-1)
[2020-09-24T10:55:17+0300] [ALPM] installed libfilezilla (0.19.3-2)
[2020-09-24T10:55:17+0300] [ALPM] installed filezilla (3.46.3-1)
[2020-09-30T08:54:03+0300] [ALPM] installed gtksourceview3 (3.24.11+28+g73e57b57-1)
[2020-09-30T08:54:03+0300] [ALPM] installed libgit2 (1:1.0.1-1)
[2020-09-30T08:54:03+0300] [ALPM] installed libgit2-glib (0.99.0.1-2)
[2020-09-30T08:54:03+0300] [ALPM] installed gitg (1:3.32.1+17+gb4c8155f-1)
[2020-10-01T08:49:28+0300] [ALPM] installed samplv1 (0.9.17-1)
[2020-10-02T21:00:24+0300] [ALPM] installed util-linux-libs (2.36-4)
[2020-10-02T21:00:34+0300] [ALPM] installed libinih (51-1)
[2020-10-02T21:00:35+0300] [ALPM] installed libavtp (0.1.0-2)
[2020-10-02T21:00:35+0300] [ALPM] installed svt-hevc (1.5.0-1)
[2020-10-02T21:00:35+0300] [ALPM] installed libmicrodns (0.2.0-1)
[2020-10-02T21:00:35+0300] [ALPM] installed zxing-cpp (1.1.1-1)
[2020-10-02T21:00:42+0300] [ALPM] installed adwaita-qt (1.1.90-1)
[2020-10-02T21:00:42+0300] [ALPM] installed liburing (0.7-2)
[2020-10-02T21:01:26+0300] [ALPM-SCRIPTLET] ==> Printing support not installed, to enable please type this in a terminal:
[2020-10-02T21:07:34+0300] [ALPM] installed samplv1 (0.9.17-1)
Ok to clarify: i mean not “use all options at once”, but use them one by one. I just put all options into the config.
Oh dear god…what a noob am I. Will try and post the results. Thanks for the clarification.
Tried every option separately and nothing changed. Thanks for your help though!
