I’m trying to set up my desktop with an Ethernet connection, but I think I may have accidentally deleted it.
Below is my system information output
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c4e37665-29b2-4c99-89c1-1a3a50ba7b6c rw quiet apparmor=1
security=apparmor resume=UUID=d92dca27-9c78-443b-95d0-73271f580b35
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Dell product: Precision T1650 v: 01
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Dell model: 0C3YXR v: A01 serial: <superuser required> UEFI: Dell
v: A28 date: 06/28/2018
RAM: total: 15.58 GiB used: 2.84 GiB (18.2%)
RAM Report:
Info: model: Intel Core i7-3770 bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1712 high: 2090 min/max: 1600/3900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1597 2: 1738 3: 1892
4: 1596 5: 1597 6: 1597 7: 1596 8: 2090 bogomips: 54296
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA TU106 [GeForce GTX 1650] vendor: ASUSTeK driver: nvidia
v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f0a class-ID: 0300
Device-2: Logitech Webcam C260 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.2:3 chip-ID: 046d:081a class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3728x1152 s-dpi: 75 s-size: 1263x390mm (49.72x15.35")
s-diag: 1322mm (52.04")
Monitor-1: DP-0 pos: bottom-r res: 1680x1050 hz: 60 dpi: 98
size: 434x270mm (17.09x10.63") diag: 511mm (20.12") modes: N/A
Monitor-2: DVI-D-0 pos: primary,top-left res: 2048x1152 hz: 60 size: N/A
modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Logitech Webcam C260 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.49 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8192EU 802.11b/g/n WLAN Adapter type: USB
driver: rtl8192eu bus-ID: 3-4.2:5 chip-ID: 0bda:818b class-ID: 0000
serial: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-4.1:4 chip-ID: 0a12:0001 class-ID: e001
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 3.86 TiB used: 1.35 TiB (35.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0102 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000NM0035-1V4107
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: TN04 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRWBD CH30N rev: A101
dev-links: cdrom
Features: speed: 1 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 206.13 GiB size: 201.84 GiB (97.92%)
used: 99.06 GiB (49.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c4e37665-29b2-4c99-89c1-1a3a50ba7b6c
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: AB99-CF97
ID-3: /home/<filter>/data raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 1.26 TiB (35.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Data
uuid: 9d04f3d4-1d6e-4719-ae30-54066208fd6d
ID-1: swap-1 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: d92dca27-9c78-443b-95d0-73271f580b35
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3 info: Logitech Webcam C260 type: Video,Audio
power: 500mA chip-ID: 046d:081a class-ID: 0102 serial: <filter>
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: Logitech G413 Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 046d:c33a class-ID: 0300 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-6: 3-4:3 info: Microchip (formerly SMSC) Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2504 class-ID: 0900
Device-1: 3-4.1:4
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
Device-2: 3-4.2:5 info: Realtek RTL8192EU 802.11b/g/n WLAN Adapter
type: Network driver: rtl8192eu interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 0bda:818b class-ID: 0000 serial: <filter>
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 38.0 C mobo: 25.0 C gpu: nvidia temp: 38 C
Fan Speeds (RPM): cpu: 1024 mobo: 1169 gpu: nvidia fan: 27%
Processes: 252 Uptime: 11m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: apt: 0 pacman: 1652 lib: 419
flatpak: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
I tried the solution proposed in this post however it didn’t help.
Where should I go from here?
