did a test run of the command that you gave me
export txt=("/etc/X11/xorg.conf.d/*" "/etc/modprobe.d/*" "/etc/modules-load.d/*" "/var/log/Xorg*")
[jonas@jonas-ms7b86 ~]$ for x in ${txt[@]}; do echo -e "\n---$x---\n$(cat $x)"; done | curl -F'file=@hallooma' https://0x0.st
curl: (26) Failed to open/read local data from file/application
oh okay i thought you can set the filename yourself
rebooting now
And this?
( for x in ${txt[@]}; do echo -e "\n---$x---\n$(cat $x)"; done ) | curl -F'file=@-' https://0x0.st`
Fabby
9 September 2021 09:58
91
I’ve upgraded you to Basic user but you will be bumped down again in 24h, but at the moment you should be able to continue posting.
DM me if that’s not the case.
the first one worked just fine, i thought i had to customize it myself (look at what ive wrote in the file
parameter)
want to be a little careful with my messages now, how many i create.
IM ON 5.10!!!1
[jonas@jonas-ms7b86 ~]$ sudo dmesg | grep -i vfio
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a27f0baf-14fa-41db-844a-9ff44f8c8f6f rw quiet apparmor=1 security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2,10de:0fbb
[ 0.063344] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a27f0baf-14fa-41db-844a-9ff44f8c8f6f rw quiet apparmor=1 security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2,10de:0fbb
[ 3.071299] VFIO - User Level meta-driver version: 0.3
[ 3.074375] vfio-pci 0000:26:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.089366] vfio_pci: add [10de:13c2[ffffffff:ffffffff]] class 0x000000/00000000
[ 3.105916] vfio_pci: add [10de:0fbb[ffffffff:ffffffff]] class 0x000000/00000000
[ 177.189425] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x1e@0x258
[ 177.189443] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x19@0x900
[ 177.190939] vfio-pci 0000:26:00.0: BAR 3: can't reserve [mem 0xc0000000-0xc1ffffff 64bit pref]
[ 177.192508] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 181.673718] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 181.673774] vfio-pci 0000:26:00.0: No more image in the PCI ROM
got the bar issue tho it seems :^) (could be any other issue tho, just looks like it from what i can see in those error messages)
so the guest stays black now, cant start
but at least i can boot now my passthrough kernel now
i know that im moving a little fast again rn but ive changed kernel parameters as described in the guide on the archwiki:
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2,10de:0fbb video=efifb:off"
GRUB_CMDLINE_LINUX=""
which did not help
i screenshot the cpu usage to give a better idea what was happening when my 2 logs were recorded:
https://i.imgur.com/VK8Bs9j.png
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a27f0baf-14fa-41db-844a-9ff44f8c8f6f rw quiet apparmor=1 security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2,10de:0fbb video=efifb:off
[ 0.062908] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a27f0baf-14fa-41db-844a-9ff44f8c8f6f rw quiet apparmor=1 security=apparmor resume=UUID=d0dac5d0-5548-41e7-8572-14de99a109cc udev.log_priority=3 iommu=pt vfio-pci.ids=10de:13c2,10de:0fbb video=efifb:off
[ 3.067899] VFIO - User Level meta-driver version: 0.3
[ 3.071093] vfio-pci 0000:26:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.085387] vfio_pci: add [10de:13c2[ffffffff:ffffffff]] class 0x000000/00000000
[ 3.102142] vfio_pci: add [10de:0fbb[ffffffff:ffffffff]] class 0x000000/00000000
[ 125.565465] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x1e@0x258
[ 125.565484] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x19@0x900
[ 125.566861] vfio-pci 0000:26:00.0: BAR 3: can't reserve [mem 0xc0000000-0xc1ffffff 64bit pref]
[ 125.568525] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 129.756149] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 129.756184] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 172.168081] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x1e@0x258
[ 172.168095] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x19@0x900
[ 172.169166] vfio-pci 0000:26:00.0: BAR 3: can't reserve [mem 0xc0000000-0xc1ffffff 64bit pref]
[ 172.171229] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 176.454946] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 176.455020] vfio-pci 0000:26:00.0: No more image in the PCI ROM
ill wait now
Well you need to grab the device GTX970 and pass it through to the VM. But this is a configuration on the VM Manager… What configuration have you done so far there?
<domain type="kvm">
<name>wintest</name>
<uuid>b9b55015-1588-4a90-b64b-a5ef193c9e4b</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">8323072</memory>
<currentMemory unit="KiB">8323072</currentMemory>
<vcpu placement="static">14</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-6.1">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/edk2-ovmf/x64/OVMF_CODE.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/wintest_VARS.fd</nvram>
<boot dev="hd"/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vendor_id state="on" value="nfiogdhodgri"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
</features>
<cpu mode="host-model" check="partial">
<topology sockets="1" dies="1" cores="7" threads="2"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<source file="/var/lib/libvirt/images/wintest.qcow2"/>
<target dev="vda" bus="virtio"/>
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</disk>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="/home/jonas/VirtualBox VMs/Win10_20H2_v2_English_x64.iso"/>
<target dev="sdb" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="1"/>
</disk>
<source file="/home/jonas/VirtualBox VMs/virtio-win-0.1.196.iso"/>
<target dev="sdc" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="2"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0xa"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0xb"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0xc"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0xd"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0xe"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x6"/>
</controller>
<interface type="network">
<mac address="52:54:00:38:f9:ed"/>
<source network="default"/>
<model type="e1000e"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<input type="tablet" bus="usb">
<address type="usb" bus="0" port="3"/>
</input>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<audio id="1" type="none"/>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x26" slot="0x00" function="0x0"/>
</source>
<rom bar="off"/>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x26" slot="0x00" function="0x1"/>
</source>
<rom bar="off"/>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<hostdev mode="subsystem" type="usb" managed="yes">
<source>
<vendor id="0x046d"/>
<product id="0xc248"/>
</source>
<address type="usb" bus="0" port="1"/>
</hostdev>
<source>
<vendor id="0x1ea7"/>
<product id="0x090e"/>
</source>
<address type="usb" bus="0" port="2"/>
</hostdev>
<redirdev bus="usb" type="spicevmc">
<address type="usb" bus="0" port="4"/>
</redirdev>
<address type="usb" bus="0" port="5"/>
</redirdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</memballoon>
</devices>
</domain>
what i connected:
https://i.imgur.com/l7g3QiU.png
Fabby
9 September 2021 11:23
98
Please be more specific: Guest or host? Ah, Windows guest.
Always remove quiet
when debugging…
Looks like you’re all set now from the Manjaro perspective and anything else is Windows now.
(Or am I missing something?)
well idk whats gonna come
there is still a troubleshooting guide in the arch wiki…
i found this guide on yt
https://www.youtube.com/watch?v=h7SG7ccjn-g&t=916s
that one worked on my older pc which i replaced motherboard and cpu on and added a gpu to
also the guide you linked me is 3 years old
just removed the windows disc and i still got the
[ 4339.247030] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x1e@0x258
[ 4339.247044] vfio-pci 0000:26:00.0: vfio_ecap_init: hiding ecap 0x19@0x900
[ 4339.248139] vfio-pci 0000:26:00.0: BAR 3: can't reserve [mem 0xc0000000-0xc1ffffff 64bit pref]
[ 4339.250134] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 4343.575139] vfio-pci 0000:26:00.0: No more image in the PCI ROM
[ 4343.575188] vfio-pci 0000:26:00.0: No more image in the PCI ROM
error
just to show you how old it is:
if you search for nvram in the file youre supposed to put it in you get this:
# This configuration option is obsolete. Libvirt will follow the
# QEMU firmware metadata specification to automatically locate
# firmware images. See docs/interop/firmware.json in the QEMU
# source tree. These metadata files are distributed alongside any
# firmware images intended for use with QEMU.
# NOTE: if ANY firmware metadata files are detected, this setting
# will be COMPLETELY IGNORED.
I didnt use SCSI in my earlier setup and that worked fine (most of the time )
also you dont need to enable amd_iommu anymore
EDIT: WRONG:
there is now an autostart option for those and i dont think you have to enable anymore:
$ sudo systemctl start libvirtd.service
$ sudo systemctl start virtlogd.socket
$ sudo systemctl enable libvirtd.service
$ sudo systemctl enable virtlogd.socket
the autostart is for sudo virsh net-autostart default
Fabby
9 September 2021 13:56
104
Shoxx98:
Forget about YouTube for troubleshooting!!!
Although its easy to create a video, it’s hard to keep it updated so unless it’s 1 month old, it’s probably garbage.
This is not a Windows issue, so I’d advise you to please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Especially the What’s this Upstream/Downstream business section and then take up the rest of the troubleshooting Upstream to qemu.
I dont remember there being any troubleshooting in that video
system
Closed
12 September 2021 03:58
106
