frdbr
18 January 2022 15:28
1
Right after decrypting the disk, it gets stuck at the screen with the Dell logo and Manjaro logo under it. Tried pressing ctrl + alt + f3 to access the terminal but it doesn’t seem to take the keyboard input. Any hints on what to do?
Use the Live Media installer and try to follow this
Difficulty: ★☆☆☆☆
Original author in old forum was @jonathon
While there are many potential reasons why your Manjaro installation doesn’t boot to a desktop, the primary reason is that the graphics drivers haven’t loaded correctly so your login/display manager (DM) doesn’t start. This is why you get a “black screen” or stuck at an
[ OK ] Started some service
message.
The normal reason for this is that you have the incorrect driver version for the kernel. This happens when the mirror you …
Also, from Live Media try to gather the information about your setup and share it as described here
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
