so install the drivers first, then edit the mkinitcpio
Output of sudo mhwd -a pci nonfree 0300
https://0x0.st/oCWz.txt
So I got the same conflict between libxnvctrl-470xx and libxnvctrl as I had before on Live ISO (check main post)
ok, so remove it:
sudo pacman -R libxnvctrl
then continue with the steps - installing the drivers and editing the mkinitcpio
uhh, mhwd installation says the following:
and then
https://0x0.st/oCWt.txt
do i need to force it?
remove the conky too with the libxnvctrl:
sudo pacman -R libxnvctrl conky
then continue with the steps, and when you are done install conky back:
sudo pacman -S conky
reboot
:: removing conky breaks dependency 'conky>=1.10' required by conky-i3
so, I am removing conky-i3 too?
this is a mess haha … yes remove it too, and after you installed the nvidia drivers, install it back
had to remove manjaro-i3-settings too, bruh
ok I followed the steps, rebooted and everything still works
output of mhwd -li
says there is video-linux and video-nvidia-470xx.
output of inxi -v7azy
https://0x0.st/oCWF.txt
that’s all?
since you have only nvidia, i would uninstall video linux:
sudo mhwd -r pci video-linux
and install also the conky and manjaro settings back, and thats it
Seems everything to work. Thanks for helping with that issue, big thanks.
