Stuck at login screen after enabling mongodb service
I am using Manjaro KDE and I am stuck at the ssdm login screen after i did the following steps
  1. Enable and Start MongoDB Service:
    Enable and start the MongoDB service to ensure it starts automatically when your laptop boots up:
    sudo systemctl enable mongodb.service
    sudo systemctl start mongodb.service
  2. Configure Shell Startup:
    a. Create a script file as mentioned earlier:
    touch ~/mongo-startup.fish
    b. Open the file in a text editor (e.g., Kate):
    kate ~/mongo-startup.fish
    c. Add the following content to the file:
    #!/usr/bin/fish
    Start MongoDB if not already running
    if not pgrep -x “mongod” > /dev/null
    sudo mongod
    end
    Start mongosh
    mongosh
    d. Save and close the file.
    e. Make the script executable:
    chmod +x ~/mongo-startup.fish
  3. Configure Fish Shell Startup:
    a. Open your Fish shell configuration file:
    kate ~/.config/fish/config.fish
    b. Add the following line to the end of the file to run the script when you start a terminal session:
    c. Save and close the file.
  4. Reboot and Test:
and then after I rebooted the laptop, it boots fine but then at the ssdm login screen i entered the password the time and the buttons freezes only the mouse cursor moves
Kindly please help
