Stuck at log in screen
I can’t type the correct password, because I’m stuck on a different keyboard layout. The key binding I use to change keyboard layout doesn’t work. I’ve just installed xfce and wanted to try it… reboot does not help.
Hi, Welcome to Manjaro.
Did you try using a terminal and rectify the issue with your keyboard layout?
Ctrl+Alt+F2 / F3 etc.
Thanks for your response, I’ve already found the solution. Had to edit a config file.
