I installed my nvidia graphic driver and then rebooted the system and now it is stuck at cleaning and it isn’t starting.
it says “/dev/sda1: clean, 2185217/3276800 files, 9789411/13107200 blocks”
Can someone please help me with this?
The issue can be detected at your Xorg log:
cat /var/log/Xorg.0.log | less
At least provide some information please:
inxi -Fazy
result of Xorg.0.log
[ 29.151] (--) Log file renamed from "/var/log/Xorg.pid-865.log" to "/var/log/Xorg.0.log"
[ 29.221]
X.Org X Server 1.20.11
[ 29.221] Build Operating System: Linux Manjaro Linux
[ 29.221] Current Operating System: Linux kushank-pc 5.10.42-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:37:11 UTC 2021 x86_64
[ 29.221] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=0cd3ed40-73f6-4a9b-88f5-6da5ee564da2 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 29.221] Build Date: 13 April 2021 04:11:08PM
[ 29.221]
[ 29.221] Current version of pixman: 0.40.0
[ 29.221] Before reporting problems, check http://wiki.x.org
[ 29.221] Markers: (--) probed, (**) from config file, (==) default setting,
[ 29.221] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun 29 16:01:13 2021
[ 29.292] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 29.293] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 29.390] (==) ServerLayout "Layout0"
[ 29.390] (**) |-->Screen "Screen0" (0)
[ 29.390] (**) | |-->Monitor "Monitor0"
[ 29.390] (**) | |-->Device "Device0"
[ 29.390] (**) |-->Input Device "Keyboard0"
[ 29.390] (**) |-->Input Device "Mouse0"
[ 29.390] (==) Automatically adding devices
[ 29.390] (==) Automatically enabling devices
[ 29.390] (==) Automatically adding GPU devices
[ 29.390] (==) Automatically binding GPU devices
[ 29.390] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 29.418] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 29.418] Entry deleted from font path.
[ 29.418] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 29.418] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 29.418] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 29.418] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 29.418] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 29.418] (**) Extension "COMPOSITE" is enabled
[ 29.419] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 29.419] (WW) Disabling Keyboard0
[ 29.419] (WW) Disabling Mouse0
[ 29.419] (II) Module ABI versions:
[ 29.419] X.Org ANSI C Emulation: 0.4
[ 29.419] X.Org Video Driver: 24.1
[ 29.419] X.Org XInput driver : 24.1
[ 29.419] X.Org Server Extension : 10.0
[ 29.419] (++) using VT number 1
[ 29.419] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 29.420] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 29.426] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 29.427] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 29.427] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[ 29.428] (--) PCI: (0@0:2:0) 8086:1616:1028:0655 rev 9, Mem @ 0xa9000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 29.428] (--) PCI:*(8@0:0:0) 10de:1140:1028:0655 rev 161, Mem @ 0xaa000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 29.428] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 29.428] (II) LoadModule: "glx"
[ 29.443] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[ 29.858] (II) Module glx: vendor="NVIDIA Corporation"
[ 29.858] compiled for 4.0.2, module version = 1.0.0
[ 29.858] Module class: X.Org Server Extension
[ 29.866] (II) NVIDIA GLX Module 390.143 Fri Mar 12 07:23:57 UTC 2021
[ 29.879] (II) LoadModule: "nvidia"
[ 29.906] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 29.984] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 29.984] compiled for 4.0.2, module version = 1.0.0
[ 29.984] Module class: X.Org Video Driver
[ 29.999] (II) NVIDIA dlloader X Driver 390.143 Fri Mar 12 07:27:02 UTC 2021
[ 29.999] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 30.031] (II) Loading sub module "fb"
[ 30.031] (II) LoadModule: "fb"
[ 30.031] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 30.040] (II) Module fb: vendor="X.Org Foundation"
[ 30.040] compiled for 1.20.11, module version = 1.0.0
[ 30.040] ABI class: X.Org ANSI C Emulation, version 0.4
[ 30.040] (II) Loading sub module "wfb"
[ 30.040] (II) LoadModule: "wfb"
[ 30.040] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 30.045] (II) Module wfb: vendor="X.Org Foundation"
[ 30.045] compiled for 1.20.11, module version = 1.0.0
[ 30.045] ABI class: X.Org ANSI C Emulation, version 0.4
[ 30.045] (II) Loading sub module "ramdac"
[ 30.045] (II) LoadModule: "ramdac"
[ 30.045] (II) Module "ramdac" already built-in
[ 30.063] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 30.063] (==) NVIDIA(0): RGB weight 888
[ 30.063] (==) NVIDIA(0): Default visual is TrueColor
[ 30.063] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 30.063] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 30.063] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 30.063] (**) NVIDIA(0): Enabling 2D acceleration
[ 30.344] (II) NVIDIA(0): NVIDIA GPU GeForce 820M (GF117) at PCI:8:0:0 (GPU-0)
[ 30.344] (--) NVIDIA(0): Memory: 2097152 kBytes
[ 30.344] (--) NVIDIA(0): VideoBIOS: 75.17.84.00.0d
[ 30.344] (II) NVIDIA(0): Detected PCI Express Link width: 8X
[ 30.344] (II) NVIDIA(0): Validated MetaModes:
[ 30.344] (II) NVIDIA(0): "NULL"
[ 30.344] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 30.344] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 30.344] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 30.345] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 30.345] (II) NVIDIA: access.
[ 30.348] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 30.348] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 30.348] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 30.348] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 30.348] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 30.348] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 30.348] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 30.348] (II) NVIDIA(0): Config Options in the README.
[ 30.384] (II) NVIDIA(0): Setting mode "NULL"
[ 30.414] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 30.414] (==) NVIDIA(0): Backing store enabled
[ 30.414] (==) NVIDIA(0): Silken mouse disabled
[ 30.414] (**) NVIDIA(0): DPMS enabled
[ 30.414] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[ 30.414] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 30.414] (II) Loading sub module "dri2"
[ 30.414] (II) LoadModule: "dri2"
[ 30.414] (II) Module "dri2" already built-in
[ 30.414] (II) NVIDIA(0): [DRI2] Setup complete
[ 30.414] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 30.415] (II) Initializing extension Generic Event Extension
[ 30.415] (II) Initializing extension SHAPE
[ 30.415] (II) Initializing extension MIT-SHM
[ 30.415] (II) Initializing extension XInputExtension
[ 30.415] (II) Initializing extension XTEST
[ 30.415] (II) Initializing extension BIG-REQUESTS
[ 30.416] (II) Initializing extension SYNC
[ 30.416] (II) Initializing extension XKEYBOARD
[ 30.416] (II) Initializing extension XC-MISC
[ 30.416] (II) Initializing extension SECURITY
[ 30.416] (II) Initializing extension XFIXES
[ 30.416] (II) Initializing extension RENDER
[ 30.416] (II) Initializing extension RANDR
[ 30.416] (II) Initializing extension COMPOSITE
[ 30.416] (II) Initializing extension DAMAGE
[ 30.417] (II) Initializing extension MIT-SCREEN-SAVER
[ 30.417] (II) Initializing extension DOUBLE-BUFFER
[ 30.417] (II) Initializing extension RECORD
[ 30.417] (II) Initializing extension DPMS
[ 30.417] (II) Initializing extension Present
[ 30.417] (II) Initializing extension DRI3
[ 30.417] (II) Initializing extension X-Resource
[ 30.417] (II) Initializing extension XVideo
[ 30.417] (II) Initializing extension XVideo-MotionCompensation
[ 30.417] (II) Initializing extension XFree86-VidModeExtension
[ 30.417] (II) Initializing extension XFree86-DGA
[ 30.417] (II) Initializing extension XFree86-DRI
[ 30.417] (II) Initializing extension DRI2
[ 30.417] (II) Initializing extension GLX
[ 30.417] (II) Indirect GLX disabled.
[ 30.418] (II) Initializing extension NV-GLX
[ 30.418] (II) Initializing extension NV-CONTROL
[ 30.851] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 30.851] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 30.851] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 30.851] (**) Power Button: Applying InputClass "system-keyboard"
[ 30.851] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 30.851] (II) LoadModule: "libinput"
[ 30.851] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 30.884] (II) Module libinput: vendor="X.Org Foundation"
[ 30.884] compiled for 1.20.11, module version = 1.0.1
[ 30.884] Module class: X.Org XInput Driver
[ 30.884] ABI class: X.Org XInput driver, version 24.1
[ 30.884] (II) Using input driver 'libinput' for 'Power Button'
[ 30.884] (**) Power Button: always reports core events
[ 30.884] (**) Option "Device" "/dev/input/event3"
[ 30.884] (**) Option "_source" "server/udev"
[ 30.927] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 30.927] (II) event3 - Power Button: device is a keyboard
[ 30.927] (II) event3 - Power Button: device removed
[ 30.953] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 30.953] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 30.953] (**) Option "xkb_layout" "us"
[ 30.953] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 30.976] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 30.976] (II) event3 - Power Button: device is a keyboard
[ 30.977] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 30.977] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 30.977] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 30.977] (**) Video Bus: Applying InputClass "system-keyboard"
[ 30.977] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[ 30.977] (II) Using input driver 'libinput' for 'Video Bus'
[ 30.977] (**) Video Bus: always reports core events
[ 30.977] (**) Option "Device" "/dev/input/event9"
[ 30.977] (**) Option "_source" "server/udev"
[ 30.978] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 30.978] (II) event9 - Video Bus: device is a keyboard
[ 30.978] (II) event9 - Video Bus: device removed
[ 31.016] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12/event9"
[ 31.016] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 31.016] (**) Option "xkb_layout" "us"
[ 31.016] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.017] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 31.017] (II) event9 - Video Bus: device is a keyboard
[ 31.018] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[ 31.018] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 31.018] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 31.018] (**) Video Bus: Applying InputClass "system-keyboard"
[ 31.018] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[ 31.018] (II) Using input driver 'libinput' for 'Video Bus'
[ 31.018] (**) Video Bus: always reports core events
[ 31.018] (**) Option "Device" "/dev/input/event10"
[ 31.018] (**) Option "_source" "server/udev"
[ 31.019] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 31.019] (II) event10 - Video Bus: device is a keyboard
[ 31.019] (II) event10 - Video Bus: device removed
[ 31.063] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:23/LNXVIDEO:01/input/input13/event10"
[ 31.063] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 31.063] (**) Option "xkb_layout" "us"
[ 31.063] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.064] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 31.064] (II) event10 - Video Bus: device is a keyboard
[ 31.065] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 31.065] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 31.065] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 31.065] (**) Power Button: Applying InputClass "system-keyboard"
[ 31.065] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 31.065] (II) Using input driver 'libinput' for 'Power Button'
[ 31.065] (**) Power Button: always reports core events
[ 31.065] (**) Option "Device" "/dev/input/event2"
[ 31.065] (**) Option "_source" "server/udev"
[ 31.065] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 31.065] (II) event2 - Power Button: device is a keyboard
[ 31.066] (II) event2 - Power Button: device removed
[ 31.076] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[ 31.076] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 31.076] (**) Option "xkb_layout" "us"
[ 31.076] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.077] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 31.077] (II) event2 - Power Button: device is a keyboard
[ 31.078] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 31.078] (II) No input driver specified, ignoring this device.
[ 31.078] (II) This device may have been added with another device file.
[ 31.078] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 31.078] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 31.078] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 31.078] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 31.078] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[ 31.078] (II) Using input driver 'libinput' for 'Sleep Button'
[ 31.078] (**) Sleep Button: always reports core events
[ 31.078] (**) Option "Device" "/dev/input/event0"
[ 31.078] (**) Option "_source" "server/udev"
[ 31.079] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 31.079] (II) event0 - Sleep Button: device is a keyboard
[ 31.079] (II) event0 - Sleep Button: device removed
[ 31.090] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 31.090] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 31.090] (**) Option "xkb_layout" "us"
[ 31.090] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.091] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 31.091] (II) event0 - Sleep Button: device is a keyboard
[ 31.091] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event12)
[ 31.091] (II) No input driver specified, ignoring this device.
[ 31.091] (II) This device may have been added with another device file.
[ 31.092] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event13)
[ 31.092] (II) No input driver specified, ignoring this device.
[ 31.092] (II) This device may have been added with another device file.
[ 31.092] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event14)
[ 31.092] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event15)
[ 31.093] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event16)
[ 31.093] (II) No input driver specified, ignoring this device.
[ 31.093] (II) This device may have been added with another device file.
[ 31.093] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event11)
[ 31.094] (II) config/udev: Adding input device Synaptics s3203 (/dev/input/event6)
[ 31.094] (**) Synaptics s3203: Applying InputClass "evdev touchpad catchall"
[ 31.094] (**) Synaptics s3203: Applying InputClass "libinput touchpad catchall"
[ 31.094] (**) Synaptics s3203: Applying InputClass "touchpad"
[ 31.094] (II) Using input driver 'libinput' for 'Synaptics s3203'
[ 31.094] (**) Synaptics s3203: always reports core events
[ 31.094] (**) Option "Device" "/dev/input/event6"
[ 31.094] (**) Option "_source" "server/udev"
[ 31.095] (II) event6 - Synaptics s3203: is tagged by udev as: Touchpad
[ 31.096] (II) event6 - Synaptics s3203: device is a touchpad
[ 31.096] (II) event6 - Synaptics s3203: device removed
[ 31.140] (**) Option "Tapping" "on"
[ 31.140] (**) Option "config_info" "udev:/sys/devices/pci0000:00/INT3433:00/i2c-1/i2c-DLL0655:00/0018:06CB:2985.0001/input/input14/event6"
[ 31.140] (II) XINPUT: Adding extended input device "Synaptics s3203" (type: TOUCHPAD, id 11)
[ 31.141] (**) Option "AccelerationScheme" "none"
[ 31.141] (**) Synaptics s3203: (accel) selected scheme none/0
[ 31.141] (**) Synaptics s3203: (accel) acceleration factor: 2.000
[ 31.141] (**) Synaptics s3203: (accel) acceleration threshold: 4
[ 31.142] (II) event6 - Synaptics s3203: is tagged by udev as: Touchpad
[ 31.144] (II) event6 - Synaptics s3203: device is a touchpad
[ 31.144] (II) config/udev: Adding input device Synaptics s3203 (/dev/input/mouse0)
[ 31.144] (**) Synaptics s3203: Applying InputClass "touchpad"
[ 31.144] (II) Using input driver 'libinput' for 'Synaptics s3203'
[ 31.144] (**) Synaptics s3203: always reports core events
[ 31.144] (**) Option "Device" "/dev/input/mouse0"
[ 31.144] (**) Option "_source" "server/udev"
[ 31.193] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 31.193] (EE) libinput: Synaptics s3203: Failed to create a device for /dev/input/mouse0
[ 31.193] (EE) PreInit returned 2 for "Synaptics s3203"
[ 31.193] (II) UnloadModule: "libinput"
[ 31.194] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event8)
[ 31.194] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 31.194] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 31.194] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 31.194] (**) Dell WMI hotkeys: Applying InputClass "Keyboard Defaults"
[ 31.194] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 31.194] (**) Dell WMI hotkeys: always reports core events
[ 31.194] (**) Option "Device" "/dev/input/event8"
[ 31.194] (**) Option "_source" "server/udev"
[ 31.195] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 31.195] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 31.195] (II) event8 - Dell WMI hotkeys: device removed
[ 31.233] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:01/wmi_bus/wmi_bus-PNP0C14:01/PNP0C14:01-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input11/event8"
[ 31.233] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 12)
[ 31.233] (**) Option "xkb_layout" "us"
[ 31.233] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.234] (II) event8 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 31.234] (II) event8 - Dell WMI hotkeys: device is a keyboard
[ 31.235] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 31.235] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 31.235] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 31.235] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 31.235] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[ 31.235] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 31.235] (**) AT Translated Set 2 keyboard: always reports core events
[ 31.235] (**) Option "Device" "/dev/input/event4"
[ 31.235] (**) Option "_source" "server/udev"
[ 31.236] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 31.236] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 31.236] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 31.256] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 31.256] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 31.256] (**) Option "xkb_layout" "us"
[ 31.256] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.257] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 31.258] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 31.258] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 31.259] (II) No input driver specified, ignoring this device.
[ 31.259] (II) This device may have been added with another device file.
[ 31.261] (II) config/udev: Adding input device DELL Wireless hotkeys (/dev/input/event5)
[ 31.261] (**) DELL Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[ 31.261] (**) DELL Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[ 31.261] (**) DELL Wireless hotkeys: Applying InputClass "system-keyboard"
[ 31.261] (**) DELL Wireless hotkeys: Applying InputClass "Keyboard Defaults"
[ 31.261] (II) Using input driver 'libinput' for 'DELL Wireless hotkeys'
[ 31.261] (**) DELL Wireless hotkeys: always reports core events
[ 31.261] (**) Option "Device" "/dev/input/event5"
[ 31.261] (**) Option "_source" "server/udev"
[ 31.261] (II) event5 - DELL Wireless hotkeys: is tagged by udev as: Keyboard
[ 31.261] (II) event5 - DELL Wireless hotkeys: device is a keyboard
[ 31.261] (II) event5 - DELL Wireless hotkeys: device removed
[ 31.313] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/event5"
[ 31.313] (II) XINPUT: Adding extended input device "DELL Wireless hotkeys" (type: KEYBOARD, id 14)
[ 31.313] (**) Option "xkb_layout" "us"
[ 31.313] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 31.314] (II) event5 - DELL Wireless hotkeys: is tagged by udev as: Keyboard
[ 31.314] (II) event5 - DELL Wireless hotkeys: device is a keyboard
[ 36.969] (II) event3 - Power Button: device removed
[ 36.983] (II) event9 - Video Bus: device removed
[ 37.049] (II) event10 - Video Bus: device removed
[ 37.103] (II) event2 - Power Button: device removed
[ 37.143] (II) event0 - Sleep Button: device removed
[ 37.183] (II) event6 - Synaptics s3203: device removed
[ 37.250] (II) event8 - Dell WMI hotkeys: device removed
[ 37.303] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 37.330] (II) event5 - DELL Wireless hotkeys: device removed
[ 1091.821] (II) UnloadModule: "libinput"
[ 1091.822] (II) UnloadModule: "libinput"
[ 1091.838] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 1091.839] (II) Server terminated successfully (0). Closing log file.
hope this helps.
It seems the nvidia legacy driver cannot detect the correct screen size:
Beside that, officially from nvidia, the legacy driver supports only kernel 5.4 and below, but it can work with older gpus on new kernels:
Runnung an older kernel could help:
sudo mhwd-kernel --install linux54
What is in your config?
cat /etc/X11/xorg.conf.d/90-mhwd.conf
update of
on executing the above command i got
[manjaro@manjaro xorg.conf.d]$ cat /run/media/manjaro/0cd3ed40-73f6-4a9b-88f5-6da5ee564da2/etc/X11/xorg.conf.d/90-mhwd.conf
cat: /run/media/manjaro/0cd3ed40-73f6-4a9b-88f5-6da5ee564da2/etc/X11/xorg.conf.d/90-mhwd.conf: No such file or directory
so on listing for the file i got
[manjaro@manjaro xorg.conf.d]$ ls -la
total 16
drwxr-xrwx 2 root root 4096 Jun 28 05:13 .
drwxr-xr-x 5 root root 4096 Jun 14 15:03 ..
-rw-r--r-- 1 root root 232 Jun 24 09:55 00-keyboard.conf
-rw-r--r-- 1 root root 131 Jun 14 15:04 30-touchpad.conf
lrwxrwxrwx 1 root root 27 Jun 28 05:13 90-mhwd.conf -> /etc/X11/mhwd.d/nvidia.conf
so im sending the pointed file content as follows
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.143 (dvs-builder@U64-P10-14) Fri Mar 12 07:18:28 UTC 2021
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
im not sure if the content of /etc/X11/mhwd.d/nvidia.conf is the one you are asking
UPDATE [SOLVED]
as per the reference NVIDIA GPU running 390xx drivers not being used in any software - #10 by omano
removing the preinstalled “broken” nvidia390xx driver and reinstalling with command
sudo mhwd -a pci nonfree 0300 had it solved
