Stuck at boot screen after update
kde
boot
#1
Hi all,
I had updated Manjaro a while ago and upon restarting it doesn’t boot into the OS.
See screenshot for what I mean. I tried pressing E at Grub menu and adding number 3 at the end of text, doesn’t help.
Appreciate if someone can help.
Edit: Went into console mode using CTRL+ALT+F2, tried Sudo Pacman -Syyuu and got this
#2
You might want to do this from a live usb. You may have no internet connection coming to your system.
#3
Thank you @SlayerProof32.
I was a little too impatient, so reinstalled the entire distro on top of the existing one. Didn’t have any data to lose.
