Hi
Fresh installation, apps were lagging, so I searched and did this:
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
…and now I’m stuck at the 3 dots and the system does not load. When I press ctrl+alt and any of the F keys, the dots just freeze. Pressing esc does nothing. I’ve accessed the system via installation disk to provide this:
[manjaro /]# inxi --full --admin --filter --width
12System:
12Kernel 6.1.30-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.1
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2213 quiet
systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Desktop Xfce 12v 4.18.1 12tk Gtk 12v 3.24.36 12info xfce4-panel 12wm xfwm 12v 4.18.0
12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
12Type Portable 12System Dell 12product Inspiron 3521 12v A12 12serial <filter> 12Chassis
12type 8 12v A12 12serial <filter>
12Mobo Dell 12model 06RYX8 12v A02 12serial <filter> 12UEFI-[Legacy] Dell 12v A12
12date 10/25/2013
12Battery:
12ID-1 BAT1 12charge 8.4 Wh (57.5%) 12condition 14.6/41.4 Wh (35.1%) 12volts 15.3
12min 14.8 12model SANYO DELL 4WY7C42E 12type Unknown 12serial <filter>
12status not charging
12CPU:
12Info 12model Intel Core i3-3217U 12socket rPGA988B (U3E1) 12note check 12bits 64
12type MT MCP 12arch Ivy Bridge 12gen core 3 12level v2 12built 2012-15
12process Intel 22nm 12family 6 12model-id 0x3A (58) 12stepping 9 12microcode 0x21
12Topology 12cpus 1x 12cores 2 12tpc 2 12threads 4 12smt enabled 12cache 12L1 128 KiB
12desc d-2x32 KiB; i-2x32 KiB 12L2 512 KiB 12desc 2x256 KiB 12L3 3 MiB 12desc 1x3 MiB
12Speed (MHz) 12avg 799 12high 800 12min/max 800/1800 12base/boost 1800/4000 12scaling
12driver intel_cpufreq 12governor schedutil 12volts 0.8 V 12ext-clock 100 MHz 12cores
121 800 122 800 123 798 124 800 12bogomips 14375
12Flags avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
12Vulnerabilities
12Type itlb_multihit 12status KVM: VMX disabled
12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT
vulnerable
12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
12Type meltdown 12mitigation PTI
12Type mmio_stale_data 12status Unknown: No mitigations
12Type retbleed 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling, PBRSB-eIBRS: Not affected
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel 3rd Gen Core processor Graphics 12vendor Dell 12driver i915
12v kernel 12arch Gen-7 12process Intel 22nm 12built 2012-13 12ports 12active LVDS-1
12empty DP-1,HDMI-A-1,VGA-1 12bus-ID 00:02.0 12chip-ID 8086:0166 12class-ID 0300
12Device-2 Realtek Integrated Webcam HD 12driver uvcvideo 12type USB 12rev 2.0
12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-1.4:5 12chip-ID 0bda:58c2
12class-ID 0e02 12serial <filter>
12Display 12server X.Org 12v 21.1.8 12compositor xfwm 12v 4.18.0 12driver 12X
12loaded modesetting 12alternate fbdev,vesa 12dri crocus 12gpu i915 12display-ID :0.0
12screens 1
12Screen-1 0 12s-res 1366x768 12s-dpi 96 12s-size 361x203mm (14.21x7.99")
12s-diag 414mm (16.31") 12monitors <missing: xrandr>
12Monitor-1 LVDS-1 12model AU Optronics 0x45ec 12built 2011 12res 1366x768 12dpi 101
12gamma 1.2 12size 344x193mm (13.54x7.6") 12diag 394mm (15.5") 12ratio 16:9
12modes 1366x768
12API OpenGL 12Message Unable to show GL data. Required tool glxinfo missing.
12Audio:
12Device-1 Intel 7 Series/C216 Family High Definition Audio 12vendor Dell 7
12driver snd_hda_intel 12v kernel 12bus-ID 00:1b.0 12chip-ID 8086:1e20 12class-ID 0403
12API ALSA 12v k6.1.30-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
12Server-2 PipeWire 12v 0.3.75 12status n/a (root, process) 12tools pw-cli
12Server-3 PulseAudio 12v 16.1 12status active (root, process)
12with pulseaudio-alsa 12type plugin 12tools pacat,pactl,pavucontrol
12Network:
12Device-1 Realtek RTL810xE PCI Express Fast Ethernet 12vendor Dell 12driver r8169
12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port 2000 12bus-ID 01:00.0
12chip-ID 10ec:8136 12class-ID 0200
12IF enp1s0 12state up 12speed 100 Mbps 12duplex full 12mac <filter>
12Device-2 Broadcom BCM43142 802.11b/g/n 12vendor Dell Wireless 1704 802.11n +
BT 4.0 12driver bcma-pci-bridge 12v N/A 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1
12bus-ID 02:00.0 12chip-ID 14e4:4365 12class-ID 0280
12Bluetooth:
12Device-1 Broadcom BCM43142 Bluetooth 4.0 12driver btusb 12v 0.8 12type USB 12rev 2.0
12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 1-1.1:3 12chip-ID 0a5c:21d7 12class-ID fe01
12serial <filter>
12Report rfkill 12ID hci0 12rfk-id 0 12state down 12bt-service N/A 12rfk-block
12hardware no 12software yes 12address see --recommends
12Drives:
12Local Storage 12total 252.63 GiB 12used 10.54 GiB (4.2%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/sda 12maj-min 8:0 12vendor Crucial 12model CT240BX500SSD1
12size 223.57 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 6.0 Gb/s
12tech SSD 12serial <filter> 12fw-rev 041
12ID-2 /dev/sdb 12maj-min 8:16 12vendor SanDisk 12model Cruzer Glide 3.0
12size 29.06 GiB 12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 2.1
12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech N/A 12serial <filter> 12fw-rev 1.00
12Partition:
12ID-1 / 12raw-size 223.57 GiB 12size 219 GiB (97.96%) 12used 10.54 GiB (4.8%)
12fs ext4 12block-size 4096 B 12dev /dev/sda1 12maj-min 8:1
12Swap:
12Alert No swap data was found.
12Sensors:
12System Temperatures 12cpu 47.0 C 12mobo N/A
12Fan Speeds (RPM) 12cpu 0
12Info:
12Processes 208 12Uptime 17m 12wakeups 1 12Memory 12total 8 GiB 12available 7.65 GiB
12used 2.11 GiB (27.6%) 12igpu 64 MiB 12Init systemd 12v 253 12default graphical
12tool systemctl 12Compilers 12gcc 13.1.1 12clang 15.0.7 12Packages 12pm pacman 12pkgs 1106
12libs 365 12tools pamac 12pm flatpak 12pkgs 0 12Client Unknown Client:
rcu_tasks_kthread 12inxi 3.3.28
How should I proceed?
Thanks
Why do you need either of those on an xfce system? The problem you describe sounds related to a Plymouth issue.
What is going on with the kernel parameters? Noveau (Nvidia), Radeon? I see Intel graphics in your inxi output.
whazzatt:
That cannot have affected the boot sequence of your system. The xdg-desktop-portal
is simply the backend to the “file open/save” dialog in your desktop environment.
Whatever caused your system to hang must have been something else, and probably something that you did but that you’re not telling us.
Think back. Did you install or remove anything else? Did you change anything with regard to partitions or the system-wide configuration?
Hi, yes, I had to install something to make my broadcom wifi work. I followed instructions here:
Hello, I’m stuck on installing wireless network driver offline on my computer. The computer has a win10os, I install manjaro-xfce-21.3.6-minimal-220729-linux515.
wireless network controller is Broadcom BCM43142 .
I have follow the broadcom-bcm43142-wifi-driver-problem/54709 to install the driver. after reboot the computer, it still not found wifi.
but when I use lspci -k to inspect, it still not found the kernel driver in use.
how to resolve it?
I have no idea what’s going on here…
I shut down and restarted several times. On attempt 6, the system loaded.
Shut down, and back to the never ending 3 dots. Shut down, restart, shut down, repeat, and after 4 or 5 attempts it loads again.
Can anyone help?
Kernel: 6.4.0-2-rt6-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-rt-x86_64
root=UUID=395cc26a-6ae0-48dd-a41a-e6f780ed027a rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron 3521 v: A12
serial: <superuser required> Chassis: type: 8 v: A12
Mobo: Dell model: 06RYX8 v: A02 serial: <superuser required>
UEFI-[Legacy]: Dell v: A12 date: 10/25/2013
ID-1: BAT1 charge: 8.4 Wh (57.5%) condition: 14.6/41.4 Wh (35.1%) volts: 15.3
min: 14.8 model: SANYO DELL 4WY7C42E type: Unknown serial: <filter>
status: not charging
Info: model: Intel Core i3-3217U bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1048 high: 1800 min/max: 800/1800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 798 4: 1800
bogomips: 14367
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Realtek Integrated Webcam HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:5 chip-ID: 0bda:58c2
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
Monitor-1: LVDS-1 model: AU Optronics 0x45ec built: 2011 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k6.4.0-2-rt6-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.75 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Dell Wireless 1704 802.11n
+ BT 4.0 driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4365 class-ID: 0280
Device-1: Broadcom BCM43142 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1:3 chip-ID: 0a5c:21d7
Local Storage: total: 223.57 GiB used: 11.7 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 041 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 11.7 GiB (5.3%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 211 Uptime: 8m wakeups: 1 Memory: total: 8 GiB available: 7.65 GiB
used: 1.55 GiB (20.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1111 libs: 365 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.28
try with different kernel, for example switch to the 6.1 and / or 5.15 and test with them…
IF you don’t need 6.4, stay with LTS-kernel (6.1)!
whazzatt:
That sounds like a race condition, creating a chicken-and-egg problem. Your system needs something during the boot process — possibly the Broadcom driver — but it’s not available yet when the system tries to appeal unto it, while the rest of the system tries to continue booting, and then grinds to a halt because of the dependency that wasn’t met.
It shouldn’t happen, but unfortunately, it does. under certain circumstances.
As the others have said, try a different kernel — preferably one of the LTS kernels, i.e. 6.1, 5.15, 5.10, or 4.19.
I pressed shift at boot and tried an older kernel. After doing so, the system would not load - I tried dozens of times and sat staring at the 3 dots each time. Pressing an F button simply froze whatever was happening.
So I did a fresh installation of the image I downloaded from the site in April (because that image worked fine until a recent update). All I did was install and update. The one difference is that I chose propriety drivers, which automatically installed my broadcom wifi, so I did not have to tamper like I did last time.
After the update, the system loaded the first time. I tried again, and it did not load 7 times in a row. It loaded on the eighth time.
There are no other kernels installed to try.
I cannot gamble in this manner each time I want to use my laptop. Please help .
Kernel: 6.1.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=05cf2b6b-a2d9-411d-b9cd-122a505ecb07 rw quiet splash apparmor=1
ID-1: BAT1 charge: 0.8 Wh (5.5%) condition: 14.6/41.4 Wh (35.1%) volts: 15.2
Speed (MHz): avg: 1049 high: 1800 min/max: 800/1800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 1800 3: 800 4: 800
bogomips: 14374
vulnerable
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
class-ID: 0403
API: ALSA v: k6.1.41-1-MANJARO status: kernel-api with: aoss
Local Storage: total: 223.57 GiB used: 10.94 GiB (4.9%)
ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 10.94 GiB (5.0%)
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 185 Uptime: 6m wakeups: 1 Memory: total: 8 GiB available: 7.65 GiB
used: 1.86 GiB (24.3%) Init: systemd v: 253 default: graphical
pkgs: 1076 libs: 340 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
What did you think we were trying to do, then?
I did not imply that anyone’s past replies were not attempts to help.
Having not solved the problem, I need help going forward.
brahma
11 August 2023 05:57
12
are you on RAID? check with:
inxi -R
and does this happens everytime you start the pc?
are you dual booting with windows? if yes, check if fast startup is disabled…
also check if fast boot is disabled in your bios/uefi - you may not have this option…
when it happens again, provide logs from the failed boot:
journalctl -b-1 -p4 --no-pager
