Hello World.
I usually manage and transfer my music from PC to SD card with Strawberry, since Clementine is discontinued. It worked fine till the last version but now… not.
It show and mount the SD card as a device but, when I double click to open the device and show the files it does nothing.
Installing Strawberry from source works fine.
Explain exactly what you mean here. Version 1.0.20-1 is in available in all branches and seem to be fairly up-to-date. Did you fully update your system? What versions are you comparing?
I’m comparing version 1.0.20-1 from repository (which, in my sistem fully updated, has problem with external device) with version 1.0.20 compiled from source (which has no problem, at least with external device, I didn’t test all features)
GitHub - strawberrymusicplayer/strawberry: 🍓 Strawberry Music Player
If I launch strawberry (repository version) in terminal show this:
strawberry
18:11:44.570 INFO main:178 Strawberry 1.0.20 Qt "6.5.3"
18:11:44.570 INFO main:179 "Manjaro Linux unknown - (linux 5.15.133-1-MANJARO) [x86_64]"
18:11:44.650 INFO main:47 TagReader worker connecting to "/tmp/strawberry_1558420931"
18:11:44.651 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Next"))
18:11:44.652 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Play"))
18:11:44.654 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Previous"))
18:11:44.655 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Stop"))
18:11:44.775 INFO Player:951 Registered URL handler for "subsonic"
18:11:44.780 INFO Player:951 Registered URL handler for "tidal"
18:11:44.803 INFO Player:951 Registered URL handler for "qobuz"
18:11:45.255 INFO DeviceManager:266 Device added from database: "Fiio 500"
18:11:45.255 INFO DeviceManager:450 Device added: "Gio//exfat/500849180672" QList("Gio//exfat/500849180672")
18:11:45.255 INFO DeviceManager:450 Device added: "Udisks2/0123456789ABCDE/NORELSYS/1081/500867006464/6EB3-B3E4" QList("Udisks2/0123456789ABCDE/NORELSYS/1081/500867006464/6EB3-B3E4")
18:11:53.961 INFO DeviceManager:597 Connecting QUrl("file:///run/media/sgilfra/Fiio 500")
18:11:53.961 WARN DeviceManager:649 Could not create device for "file:///run/media/sgilfra/Fiio 500"
and launching the github version
strawberry
18:05:34.480 INFO main:178 Strawberry 1.0.20-59-gcd534bbd Qt "6.5.3"
18:05:34.480 INFO main:179 "Manjaro Linux unknown - (linux 5.15.133-1-MANJARO) [x86_64]"
18:05:34.517 DEBUG main:226 Style: "fusion"
18:05:34.517 DEBUG Lazy<T>:67 DeviceFinders(0x55ce6c9f74c0) created
18:05:34.522 DEBUG Application:276 Database(0x55ce6c9f1000) moved to thread QThread(0x55ce6ca45650)
18:05:34.523 DEBUG Lazy<T>:67 Database(0x55ce6c9f1000) created
18:05:34.523 DEBUG SCollection:71 CollectionBackend(0x55ce6c9dcff0) moved to thread QThread(0x55ce6ca45650)
18:05:34.523 DEBUG Lazy<T>:67 TaskManager(0x55ce6caa3d60) created
18:05:34.526 DEBUG Application:276 AlbumCoverLoader(0x55ce6cacc1b0) moved to thread QThread(0x55ce6cac51e0)
18:05:34.526 DEBUG Lazy<T>:67 AlbumCoverLoader(0x55ce6cacc1b0) created
18:05:34.529 DEBUG Lazy<T>:67 SCollection(0x55ce6c9f7820) created
18:05:34.529 DEBUG SCollection:103 CollectionWatcher(0x55ce6cae0910) moved to thread Thread(0x55ce6cae9120)
18:05:34.530 DEBUG Lazy<T>:67 NetworkAccessManager(0x55ce6cae8da0) created
18:05:34.530 DEBUG Lazy<T>:67 LastFMImport(0x55ce6cadd800) created
18:05:34.530 DEBUG Application:276 TagReaderClient(0x55ce6ca466b0) moved to thread QThread(0x55ce6cae8d80)
18:05:34.530 DEBUG Lazy<T>:67 TagReaderClient(0x55ce6ca466b0) created
18:05:34.530 DEBUG NetworkProxyFactory:52 Detected system proxy URLs: QList("", "", "", "")
18:05:34.530 DEBUG WorkerPool<HandlerType>:257 Using worker "strawberry-tagreader" from "/usr/local/bin"
18:05:34.531 DEBUG WorkerPool<HandlerType>:304 Starting worker 0x7f2262ffc230 "/usr/local/bin/strawberry-tagreader" "/tmp/strawberry_714793969"
18:05:34.539 DEBUG EngineBase:204 SOUP_FORCE_HTTP1: ON
18:05:34.539 DEBUG Lazy<T>:67 Player(0x55ce6cacd170) created
18:05:34.539 DEBUG Lazy<T>:67 PlaylistManager(0x55ce6cb56540) created
18:05:34.539 DEBUG Lazy<T>:67 CurrentAlbumCoverLoader(0x55ce6cb52a10) created
18:05:34.558 DEBUG GlobalShortcutsBackendKDE:73 Registering
18:05:34.561 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Next"))
18:05:34.562 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Play"))
18:05:34.563 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Previous"))
18:05:34.564 ERROR GlobalShortcutsBackendKDE:161 KGlobalAccel returned QList() when setting shortcut QList(QKeySequence("Media Stop"))
18:05:34.588 INFO main:47 TagReader worker connecting to "/tmp/strawberry_714793969"
18:05:34.588 DEBUG WorkerPool<HandlerType>:326 Worker 0x7f2258001a80 connected to "/tmp/strawberry_714793969"
18:05:34.689 INFO Player:951 Registered URL handler for "subsonic"
18:05:34.694 DEBUG InternetServices:49 Added internet service "Subsonic"
18:05:34.694 INFO Player:951 Registered URL handler for "tidal"
18:05:34.711 DEBUG InternetServices:49 Added internet service "Tidal"
18:05:34.711 INFO Player:951 Registered URL handler for "qobuz"
18:05:34.729 DEBUG InternetServices:49 Added internet service "Qobuz"
18:05:34.729 DEBUG Lazy<T>:67 InternetServices(0x55ce6cd8b410) created
18:05:34.874 DEBUG MainWindow:349 Starting
18:05:34.903 DEBUG CoverProviders:105 Registered cover provider "Last.fm"
18:05:34.904 DEBUG CoverProviders:105 Registered cover provider "MusicBrainz"
18:05:34.904 DEBUG CoverProviders:105 Registered cover provider "Discogs"
18:05:34.904 DEBUG CoverProviders:105 Registered cover provider "Deezer"
18:05:34.904 DEBUG CoverProviders:105 Registered cover provider "Musixmatch"
18:05:34.904 DEBUG CoverProviders:105 Registered cover provider "Spotify"
18:05:34.904 DEBUG CoverProviders:105 Registered cover provider "Tidal"
18:05:34.904 DEBUG CoverProviders:105 Registered cover provider "Qobuz"
18:05:34.904 DEBUG Lazy<T>:67 CoverProviders(0x55ce6da355a0) created
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "Genius"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "Lyrics.ovh"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "LoloLyrics"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "Musixmatch"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "ChartLyrics"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "songlyrics.com"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "azlyrics.com"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "elyrics.net"
18:05:34.910 DEBUG LyricsProviders:104 Registered lyrics provider "lyricsmode.com"
18:05:34.910 DEBUG Lazy<T>:67 LyricsProviders(0x55ce6dca7ca0) created
18:05:34.930 DEBUG MainWindow:400 Initializing player
18:05:34.931 DEBUG MainWindow:410 Creating models
18:05:34.931 DEBUG MainWindow:417 Creating models finished
18:05:34.933 DEBUG DeviceLister:67 CddaLister(0x55ce6cd79300) moved to thread QThread(0x55ce6df0c970)
18:05:34.933 DEBUG DeviceLister:67 Udisks2Lister(0x55ce6df14ec0) moved to thread QThread(0x55ce6df0c620)
18:05:34.933 DEBUG DeviceLister:67 GioLister(0x55ce6df15930) moved to thread QThread(0x55ce6df0c550)
18:05:34.933 DEBUG Lazy<T>:67 DeviceManager(0x55ce6df0bd30) created
18:05:34.934 DEBUG CddaLister:115 No CD devices found
18:05:34.940 DEBUG logging:95(GLib-GIO) Using cross-namespace EXTERNAL authentication (this will deadlock if server is GDBus < 2.73.3)
18:05:34.943 DEBUG Application:276 PlaylistBackend(0x55ce6cbfd780) moved to thread QThread(0x55ce6ca45650)
18:05:34.943 DEBUG Lazy<T>:67 PlaylistBackend(0x55ce6cbfd780) created
18:05:34.943 DEBUG logging:95(GLib-GIO) Using cross-namespace EXTERNAL authentication (this will deadlock if server is GDBus < 2.73.3)
18:05:34.947 DEBUG logging:95(GLib-GIO) Using cross-namespace EXTERNAL authentication (this will deadlock if server is GDBus < 2.73.3)
18:05:34.950 DEBUG Lazy<T>:67 OrganizeDialog(0x55ce6df4cb40, name="OrganizeDialog") created
18:05:34.950 DEBUG Application:276 RadioBackend(0x55ce6dfe7af0) moved to thread QThread(0x55ce6ca45650)
18:05:34.952 DEBUG RadioServices:66 Adding radio service: "SomaFM"
18:05:34.953 DEBUG RadioServices:66 Adding radio service: "Radio Paradise"
18:05:34.953 DEBUG Lazy<T>:67 RadioServices(0x55ce6df5c1d0) created
18:05:34.954 DEBUG MainWindow:437 Creating UI
18:05:34.954 DEBUG logging:95(GLib-GIO) _g_io_module_get_default: Found default implementation gvfs (GDaemonVfs) for ‘gio-vfs’
18:05:35.001 DEBUG AudioScrobbler:63 Registered scrobbler service "Last.fm"
18:05:35.001 DEBUG AudioScrobbler:63 Registered scrobbler service "Libre.fm"
18:05:35.001 DEBUG AudioScrobbler:63 Registered scrobbler service "ListenBrainz"
18:05:35.001 DEBUG AudioScrobbler:63 Registered scrobbler service "Subsonic"
18:05:35.001 DEBUG Lazy<T>:67 AudioScrobbler(0x55ce6e34b970) created
18:05:35.026 DEBUG Lazy<T>:67 MoodbarController(0x55ce6e524370) created
18:05:35.026 DEBUG MainWindow:860 Creating playing widget
18:05:35.072 DEBUG MainWindow:907 Loading settings
18:05:35.174 DEBUG MainWindow:1072 Started QThread(0x55ce6c961fb0)
18:05:35.182 INFO DeviceManager:266 Device added from database: "Fiio 500"
18:05:35.182 INFO DeviceManager:450 Device added: "Gio//exfat/500849180672" QList("Gio//exfat/500849180672")
18:05:35.182 INFO DeviceManager:450 Device added: "Udisks2/0123456789ABCDE/NORELSYS/1081/500867006464/6EB3-B3E4" QList("Udisks2/0123456789ABCDE/NORELSYS/1081/500867006464/6EB3-B3E4")
18:05:35.210 DEBUG GlobalShortcutsBackendKDE:120 Registered.
18:05:50.210 INFO DeviceManager:597 Connecting QUrl("file:///run/media/sgilfra/Fiio 500")
18:05:50.210 INFO ConnectedDevice:56 Connected QUrl("file:///run/media/sgilfra/Fiio 500") "Udisks2/0123456789ABCDE/NORELSYS/1081/500867006464/6EB3-B3E4" false
18:05:50.210 DEBUG ConnectedDevice:61 CollectionBackend(0x55ce6ebc1670) for device "Udisks2/0123456789ABCDE/NORELSYS/1081/500867006464/6EB3-B3E4" moved to thread QThread(0x55ce6ca45650)
18:05:50.236 DEBUG FilesystemDevice:50 CollectionWatcher(0x55ce6f0101c0) for device "Udisks2/0123456789ABCDE/NORELSYS/1081/500867006464/6EB3-B3E4" moved to thread QThread(0x55ce6d89de00)
18:06:04.626 DEBUG Database:485 Starting database integrity check
18:06:04.711 DEBUG Database:555 Starting database backup
this post is longer than I expected.
Thanks for your attention.
Hi guys!
I think this problem is solved in version 1.0.21
Fixed connecting devices (#1288).
I don’t have with me my Manjaro, so i don´t now if is already updated, but I tested in v. 1.0.21 in other distro and the bug is solved.
