After some issues with my dmesg logs and the audit mecanism …
I have those strange “failed” boot up entries :
[ 3.830366] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 3.840542] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 3.877863] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 3.880815] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 3.884178] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
Where and how do I start to analyse those ?
Sorry for the delayed info …
here is my inxi report :
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=f4bc51ae-9d55-400c-b716-e17bcf600731 rw
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
Type: Desktop Mobo: ASUSTeK model: P8P67 v: Rev 1.xx serial: <filter>
BIOS: American Megatrends v: 3602 date: 11/01/2012
RAM: total: 31.32 GiB used: 3.21 GiB (10.2%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 1333 MT/s type: DDR3
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Corsair
part-no: CMY16GX3M2A1866C9 serial: N/A
Device-2: ChannelA-DIMM1 size: 8 GiB speed: 1333 MT/s type: DDR3
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Kingston
part-no: 99U5471-040.A00LF serial: <filter>
Device-3: ChannelB-DIMM0 size: 8 GiB speed: 1333 MT/s type: DDR3
Device-4: ChannelB-DIMM1 size: 8 GiB speed: 1333 MT/s type: DDR3
part-no: 99U5471-038.A00LF serial: <filter>
Info: model: Intel Core i7-3770 socket: LGA1155 bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1873 high: 2198 min/max: 1600/3400 base/boost: 3430/3800
scaling: driver: intel_cpufreq governor: schedutil volts: 1.0 V
ext-clock: 100 MHz cores: 1: 1934 2: 1956 3: 1699 4: 1873 5: 2198 6: 1835
7: 1656 8: 1838 bogomips: 54593
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms
est f16c flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tsc tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: AMD Barts PRO [Radeon HD 6850] vendor: ASUSTeK EAH6850
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6739 class-ID: 0300
Display: server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: radeon display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: AMD Barts HDMI Audio [Radeon HD 6790/6850/6870 / 7720 OEM]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aa88 class-ID: 0403
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.42 running: no
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: c000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 2-1.7:4 chip-ID: 0b05:179c class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Device-1: VG: almalinux type: LVM2 size: 27 GiB free: 4 MiB
LV-1: home maj-min: 254:3 type: linear dm: dm-3 size: 10 GiB
Components:
p-1: sdb3 maj-min: 8:19 size: 27.01 GiB
LV-2: root maj-min: 254:4 type: linear dm: dm-4 size: 15 GiB
Components:
LV-3: swap maj-min: 254:0 type: linear dm: dm-0 size: 2 GiB
Components:
Device-2: VG: rl type: LVM2 size: 17 GiB free: 4 MiB
LV-1: home maj-min: 254:2 type: linear dm: dm-2 size: 5 GiB
Components:
p-1: sdb10 maj-min: 8:26 size: 17.01 GiB
LV-2: root maj-min: 254:5 type: linear dm: dm-5 size: 10 GiB
Components:
LV-3: swap maj-min: 254:1 type: linear dm: dm-1 size: 2 GiB
Components:
Local Storage: total: 1.62 TiB lvm-free: 8 MiB used: 119.53 GiB (7.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
family: Micron Client SSDs size: 223.57 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: MU05 temp: 26 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 3y 136d 10h cycles: 2199
written: 11.19 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD3200AAJS-65RYA0 family: Caviar Blue Serial ATA size: 298.09 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: N/A
serial: <filter> rev: 1B01 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 130d 23h cycles: 2452
ID-3: /dev/sdc maj-min: 8:32 vendor: OCZ model: VERTEX2
family: Driven SSDs size: 55.9 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: SSD serial: <filter>
rev: 1.35 temp: 30 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 251d 4h cycles: 5179
read: 12992 GiB written: 4416 GiB
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST31000528AS
family: Barracuda 7200.12 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: CC49 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 304d 0h cycles: 1344
read: 668.28 GiB written: 1.72 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-5: /dev/sde maj-min: 8:64 vendor: Samsung model: HD161GJ
family: SpinPoint F1 DT size: 149.05 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1118
temp: 21 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 6y 122d 6h cycles: 277
Pre-Fail: reallocated sector: 100 threshold: 10
ID-1: / raw-size: 65.2 GiB size: 64.05 GiB (98.24%) used: 56.3 GiB (87.9%)
fs: ext4 block-size: 4096 B dev: /dev/sda3 maj-min: 8:3 label: ManjaroSSD
uuid: f4bc51ae-9d55-400c-b716-e17bcf600731
ID-2: /run/media/markmarques/ssd4 raw-size: 107.42 GiB
size: 105.61 GiB (98.31%) used: 63.22 GiB (59.9%) fs: ext4
block-size: 4096 B dev: /dev/sda4 maj-min: 8:4 label: ssd4
uuid: 721a05da-d5dc-4109-ac8e-d005406ea9a9
ID-1: /dev/dm-0 maj-min: 254:0 mapped: almalinux-swap size: 2 GiB fs: swap
label: N/A uuid: 9291ae2e-45fd-4ba8-9465-2aff0654d274
ID-2: /dev/dm-1 maj-min: 254:1 mapped: rl-swap size: 2 GiB fs: swap
label: N/A uuid: ed93185a-2460-4881-a0a1-7d84b9b3685d
ID-3: /dev/dm-2 maj-min: 254:2 mapped: rl-home size: 5 GiB fs: xfs
label: N/A uuid: 3a3c3180-94f3-44db-829c-049bef8f77fd
ID-4: /dev/dm-3 maj-min: 254:3 mapped: almalinux-home size: 10 GiB fs: xfs
label: N/A uuid: 62b55f8b-cec8-4dee-9547-978bab9be3bb
ID-5: /dev/dm-4 maj-min: 254:4 mapped: almalinux-root size: 15 GiB fs: xfs
label: alma84 uuid: 0b17b5df-ff4f-4e02-b403-0303186e6bf2
ID-6: /dev/dm-5 maj-min: 254:5 mapped: rl-root size: 10 GiB fs: xfs
label: N/A uuid: 99d2a8d5-0bcf-4010-9050-c1e4db11b3a6
ID-7: /dev/sda1 maj-min: 8:1 size: 19.53 GiB fs: ntfs label: N/A
uuid: AE3818E43818ACF9
ID-8: /dev/sda2 maj-min: 8:2 size: 31.42 GiB fs: ntfs label: N/A
uuid: 74D604323809405D
ID-9: /dev/sdb1 maj-min: 8:17 size: 2 MiB fs: N/A label: N/A uuid: N/A
ID-10: /dev/sdb2 maj-min: 8:18 size: 1024 MiB fs: xfs label: almaboot
uuid: fe88cd2e-3286-4335-b891-6fe7c521b971
ID-11: /dev/sdb4 maj-min: 8:20 size: 19.53 GiB fs: btrfs label: Endearvous
uuid: 7ef1234c-2836-4155-8145-64212a276f26
ID-12: /dev/sdb5 maj-min: 8:21 size: 1024 MiB fs: xfs label: N/A
uuid: 3e95ed6e-3dc2-4148-b8a1-cf866c7cd042
ID-13: /dev/sdb6 maj-min: 8:22 size: 10.78 GiB fs: ext4 label: rootantiX21
uuid: 8c9c5f48-8b51-4d8d-a023-2dad73dd5cf1
ID-14: /dev/sdb7 maj-min: 8:23 size: 19.53 GiB fs: ext4 label: rootMX21
uuid: 3d49019c-030e-44e6-955f-26df4211df61
ID-15: /dev/sdb8 maj-min: 8:24 size: 9.77 GiB fs: ext4 label: Archbang
uuid: f50fc3ae-8d48-42da-905d-1786bf90d848
ID-16: /dev/sdb9 maj-min: 8:25 size: 19.53 GiB fs: ext4 label: Artix
uuid: be87401a-d8d8-4a16-89e7-9a4702ce440e
ID-17: /dev/sdc1 maj-min: 8:33 size: 500 MiB fs: ntfs
label: System Reserved uuid: 5C1A1A261A19FDA8
ID-18: /dev/sdc2 maj-min: 8:34 size: 54.94 GiB fs: ntfs label: N/A
uuid: DC5E38D75E38ABE0
ID-19: /dev/sdc3 maj-min: 8:35 size: 481 MiB fs: ntfs label: N/A
uuid: D2A40622A40609A5
ID-20: /dev/sdd1 maj-min: 8:49 size: 1007 KiB fs: N/A label: N/A uuid: N/A
ID-21: /dev/sdd2 maj-min: 8:50 size: 512 MiB fs: vfat label: N/A
uuid: FD0E-77FC
ID-22: /dev/sde1 maj-min: 8:65 size: 14.65 GiB fs: ext4 label: N/A
uuid: 3f998520-e606-4699-9269-48b640f641c3
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.4:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-6: 2-1.4.1:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 2-1.4.4:6 info: SOAI USB Gaming Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 12c9:2003 class-ID: 0300
Device-2: 2-1.7:4 info: ASUSTek Bluetooth Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-9: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 6-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 29.0 C gpu: radeon temp: 55.0 C
Fan Speeds (RPM): cpu: 1028 fan-1: 1104 fan-3: 0 fan-4: 0 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.31
Processes: 250 Uptime: 21h 41m wakeups: 0 Init: systemd v: 250
target: multi-user.target tool: systemctl Compilers: gcc: 11.1.0
clang: 13.0.0 Packages: apt: 0 pacman: 2317 lib: 571 Shell: Bash (sudo)
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
The root filesystem could not be checked because it was mounted rw
instead of ro
Uncomment/set GRUB_ROOT_FS_RO=true
in /etc/default/grub
to adjust that one. Also see
https://wiki.archlinux.org/title/Fsck#Boot_time_checking
The rest look normal to me:
Seems to be a good thing - or did you want to repartition your root disk?
Seems to be alright - or was this boot the first boot ever?
Apparently there was no need…
$ systemctl cat systemd-hwdb-update.service
$ systemctl cat systemd-sysusers.service
Solved the first one with the proposed GRUB_ROOT_FS_RO = true variable.
As the others are “normal” systemd warnings I will ignore them for now …
Although I will check later the indicated systemd services …
(By default I start my machine in terminal mode only then manually ( if needed ) I will proceed to graphical target mode … )
thanks again for the fast reply …
